Lokacija: Varazdin
Postovi: 288
Pioneer vs. Nec
Koju se przilicu isplati bolje uzet nec 2500a ili pioneer 107, koja je bolja? I koja je razlika između Nec-a 2500 i 2500a?
Msi neo2/wini 3200+/OCZ TCCD/6600gt |
Postovi: 64
Pioneer je bolji čitač i manje izbirljiv kod medija Imam 106D i dobar je prijatelj ima 107D i čita kaj mu pržilica i dvd rom nije htio čitati. Meni je snimao i na kvarkove, NEC 1300A nije htio pogledaj komentare na www.cdrlabs.com BTW svi hvale Pioneer, pitam se zašto (više od 5g proizvodnje dvd pržilica) |
#3 | |
#erase startup-config
Postovi: 3,732
Re: Pioneer vs. Nec
Junior Member
Datum registracije: May 2003
Postovi: 3,205
http://www.cdrinfo.com/Sections/Arti...2500A&Series=0 POSTOJI SAMO NEC2500A, samo neki u cjenicima zovu to 2500, i naravno sad ima novi 2510. ili ak oces cekat: NEC Introduces Chipset For 16x Rewritable DVD Drives NEC has announced a new DVD writer chipset offering 16x DVD-R and DVD+R writing speeds. Here's part of their press release: NEC Electronics Corporation (TSE: 6723) and its subsidiary in Europe, NEC Electronics (Europe) GmbH, today introduced a chipset for rewritable DVD drives that supports 16x recording speed in DVD-R and DVD+R formats. The improved efficiency enables users to record high data volumes on DVD recorders and personal computers in approximately half the time required by previous 8x speed devices. Compliant with recording and playback formats such as DVD-R/RW, DVD+R/RW, and DVD-RAM, the new chipset enables OEMs to easily configure rewritable DVD drives capable of handling all major standards. The chipset consists of the µPD63635 digital signal processor (DSP) with ATAPI interface, and the µPC3335 analog signal processor (ASP), which controls the laser and servo systems of the optical pickup unit. The µPD63635's new LVDS (Low Voltage Differential Signaling) driver, 50% reduction of clock jitter, write strategy for high-precision control of the recording laser power, and high logic speed enabled by optimizing the design flow in C, together with the µPC3335's high-bandwidth amplifier optimized for higher operating speeds, help ensure stable recording at 16x speed for DVD-R and DVD+R. According to NEC, this new chipset is expected to be used by Pioneer and NEC for their new dual format DVD writers. More information can be found here. [discuss this in the forum]
__________________ |
#6 | |
Junior Member
Postovi: 3,205
Partner je BENQ. I 16 x je samo na + medije. Sljedece generacija ce bit i + i - 16x, i naravno kao sto je vec i nec2510 i benx DOUBLE LAYER po defaultu. http://www.cdrinfo.com/Sections/Arti...2500A&Series=0 Citiraj:
#7 | |
8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,159
http://www.eetuk.com/bus/news/OEG20030212S0005 To je samo ekonomska klasa brand, ogranak od Acera. Philips mu je samo licencirao drive i koristi se sa istim, paralelno za druga trzista na kojima je bolje "umrezen" Sav razvoj je Philipsov (transporti CD1,3,4, CDM, 11,12,14...) od cijih patenata ce zivjeti do kraja 2010. Philips se malo uplasio zbog Grundiga koji je propao kao jedan od naj'jaceg partnera u Thomson grupe (+propali clanovi sada u akviziciji istog: Telfunken,Saba,Nordmende) pa je odlucio malo ucvrstiti svoju poziciju. |
