Staro 25.05.2008., 13:04   #1
lordVerdranius
Postovi: 310
HDTV out? TV out i S-VIDEO?
Imam grafu 8600gt, te ona ima izlaz na telku, ali ko fol samo HDTV i sada mi nije jasno, uz nju sam dobio onu novu verziju (manje pinova) S-video kabla, ali kada spojim stari kabl odnosno staru verziju S-video kabla u taj ulaz primjenjen valjda za HDtv onda se nikaj ne događa...
I još jedna bitna stvar, nigdje al ama baš nigdje i nikako nemogu prebaciti na CLONE, te tako nemogu poslati sliku na drugi monitor odnosno TV...
Gledao sam u Display propertisima, nema, gledao u Nvidijinim postavkam, ima ALI ne mogu prebaciti na to jer mi NEDA! I kaj sad...
govorim o grafulji 8600gt sa čipsetom od Calibre (prije nikad ćuo :P)...
Jeli bi HDtv trebao biti isto ko i TV out ili ne... pošto sam dobio žice i za HDTV i TV out odnosno S-video?
lordVerdranius je offline   Reply With Quote
Staro 25.05.2008., 15:48   #2
taip@n
Master of the VCR
taip@n's Avatar
Postovi: 340
http://www.tweak.dk/tests2.php?id=1413
ako je to ova, onda ne podržava, kao što piše... kaže da bi u uputama trebalo pisati što kartica hoće a što neće raditi...
PACKAGING
By using the multi cable, it is possible to connect video-in and component-in as well as video-out and component-out, but since the card does not support any other signal it is a little strange, though, the cable has a fine length. The reason as to why the included cable offers some functions that the card doesn’t support most likely is that the card also comes in a “MH” edition, which exactly has these capabilities.
A real manual that tells about the specifications and explains what the different connectors are for is lacking. It’s a quite poor bundle that only contains what is just needed and nothing more, nothing less. A additional game or some extra piece of software wouldn’t be asking too much.
♦ As i was going up the stair ♦ I met a man who wasn't there ♦ He wasn't there again today! ♦ I wish, I wish he'd stay away.♦
taip@n je offline   Reply With Quote
Staro 25.05.2008., 16:28   #3
lordVerdranius
Postovi: 310
OMG! Hvala ti!
Nego:
A čemu to? Mislim ono, znači ja sada mogu jedino svoju karticu spajati na HDtv? WTF?
