Staro 03.05.2008., 23:26   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
EVGA Precision
NGOHQ Posted (and hosted) information regarding EVGA's new Exclusive Precision Overclocking Utility.
"****, once again, sets itself apart from the rest with the **** Exclusive Precision Overclocking Utility. This program allows you to fine tune your **** graphics card for the maximum performance possible, with Core/Shader/Memory clock tuning, real time monitoring support including in-game, Logitech Keyboard LCD Display support, and compatibility with almost all **** graphics cards.
* Core/Shader Clock Link/Unlink capability
* Fan Speed manual or auto adjustment
* Real-Time on-screen display support for ingame temp, framerate, and clock monitoring
* Logitech Keyboard LCD Display support
* In-app temp/clockspeed monitoring of GPU's (up to 4 supported)
* Information button shows device, driver, memory size, BIOS Revision and SLI mode
* Ability to choose different skins, with more coming soon"
Koliko vidim-fino su se počerupali sa škvadrom iz EVGA...potonjim nije bilo baš drago kaj je soft raspoloživ za download
http://www.2manydownloads.com/index....d=73&Itemid=54
Staro 05.05.2008., 17:57   #2
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Staro 05.05.2008., 18:34   #3
Z-man
Z-man's Avatar
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
napokon nešto novo
već ide u pogon
Z-man je offline   Reply With Quote
Staro 05.05.2008., 18:50   #4
AskThePro
Running With Scizzors
AskThePro's Avatar
Datum registracije: Apr 2008
Lokacija: Mraclin/VG
Postovi: 84
meni je glupo
ostajem na riva tuneru
ono driver checking je khm
AskThePro je offline   Reply With Quote
Staro 05.05.2008., 20:38   #5
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,154
malen i jednostavan-me like it
Staro 05.05.2008., 22:29   #6
Z-man
Z-man's Avatar
Postovi: 1,079
1.01 release notes:
EVGA Precision Version 1.01 Released
It was yesterday when the EVGA Precision utility first became available, and now just a day later here's a brand new version released. The EVGA Precision 1.01 features the following changes:
  • Added desktop shortcut creation feature to the installer
  • Fixed problem with instance checking in the installer
  • Added display driver version detection for Vista x64
Staro 27.03.2009., 15:12   #7
dejanbinladen
konjpjukter
Postovi: 934
1.6.0
EVGA Precision v1.6.0 (2009-03-26)
  • Now Precision monitoring window can be detached from the main form allowing the user to define custom monitoring window position and size. Double click attached monitoring window to detach it from the main form, double click it one more time or simply close it to attach it back.
  • Now Precision provides multi-GPU control for the systems with up to 8 NVIDIA GPUs to ensure compatibility with future SLI systems and provide support for modern 5-GPU Quad-SLI + PhysX systems.
  • Optimized multi-GPU profiles loader drastically reduces profiles load time when GPU synchronization mode is enabled.
  • Now Precision always sorts GPUs by PCI location to ensure that GPU indices stay the same in the system regardless of operating system, display driver version and GPU display outputs connection.
  • EVGA On-Screen Display Server has been updated to version 3.2.0. Similar to the previous version of Precision, new server also features new skin format v1.1 adding bitmap effects support to the skin compiler.
  • Added new black skin edition.
DOWNLOAD
Zadnje izmijenjeno od: Razer. 28.03.2009. u 20:36.
dejanbinladen je offline   Reply With Quote
Staro 28.03.2009., 20:37   #8
Razer
Razer's Avatar
Postovi: 11,642
Ovo je odlična novost - dodavanje kontrole, odnosno overclockinga svake kartice zasebno u SLI-ju
Staro 28.03.2009., 22:19   #9
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Radi samo sa EVGA-om ili i sa drugim karticama?
blaa
Staro 28.03.2009., 22:20   #10
Razer
Razer's Avatar
Postovi: 11,642
Radi sa svim nVidijinim karticama.
Staro 28.03.2009., 22:28   #11
hammer_of_thor
Postovi: 5,430
Da, evo upravo vidjeh.
Radi OK, možda da je interface malo "jednostavniji"...
Ovak mi se čini sve nabacano na malom području. Ali OK
Dobar je program, puno profila može spremati, i lagano, one click prebacivanje između prve i druge grafičke
blaa
Staro 28.03.2009., 22:29   #12
Razer
Razer's Avatar
Postovi: 11,642
Jesi pratio preko Monitoringa jel svaka kartica može "primati" različite taktove?
Staro 28.03.2009., 22:29   #13
maX
maX's Avatar
Postovi: 7,326
ne kuzim koliko moze jednostavniji biti? program je user friendly i jednostavan je cak i previse...
Staro 28.03.2009., 22:45   #14
hammer_of_thor
Postovi: 5,430
Autor Razer Pregled postova
Može kad je Sync isključen.
Autor maX Pregled postova
Nisi skužio
Naravno, slažem se da je i prejednostavan nego mi se jednostavno čini "puno" toga nabacano na premalom screenu
EDIT:
Inače veliki bigup za program, RivaTuner mi se čini kao prošlost, već je maknut iz autostarta sa Windowsima i stavljen EVGA Precision
Eh da, Razer:
Različiti clockovi kad je Sync isključen
Kako padne FPS u Furmarku kad se nešto drugo sa Alt+Tab stavi u prvi plan, sa EVGAom prikazanom 35 FPSa, a kad je Furmark u prvom planu FPS je 90-100
blaa
Staro 29.03.2009., 10:15   #15
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 413
Dobar programcic, posebno mi se svidja sto se za razliku od Riva Tunera mogu clockovi direktno upisati (kod Rive iskljucivo koristenje slidera).
Ono sto mu nedostaje i zbog cega ostajem na Rivi je podesavanje ponasanja automatske regulacije brzine ventilatora:
S njom se ventilator moze ubrzati (ranije dize brzinu i ranije dostize 100%) sto je mrak za overclock, a jos uvijek radi tiho kada je bez opterecenja.
Ili je netko ipak otkrio nacin kako to u Precisionu napraviti (ne sa 10 profila i sl. nego cista automatika)?
Tumor je offline   Reply With Quote
Staro 29.03.2009., 14:44   #16
Verbum
Postovi: 682
Autor Tumor Pregled postova
Vidim da imamo istu grafu pa bih te molio ako mozes navesti sve svoje vrijednosti u riva tuneru.
Mislim na duty cycle min, max, Tmin, Tmax ..itd... (ne vide se sve vrjednosti na slici :P)
Htjeo bih to podesiti i na svojoj grafi jer ventilator prakticki ne ubrzava dok ne dodje do 85C sto je po meni previse s obzirom da ima stvarno dobar hladnjak koji nije i previse bucan.
Zadnje izmijenjeno od: Verbum. 29.03.2009. u 14:59.
Verbum je offline   Reply With Quote
Staro 29.03.2009., 16:12   #17
Tumor
Tumor's Avatar
Postovi: 413
Autor creativo91 Pregled postova
Najprije moras omoguciti mijenjanje kontrole brzine ventilatora.
To napravis da podesis kao u ovoj slici:
Dakle, pod Power User tabom nadjes parametar Riva Tuner / Fan -> AutoFanSpeedControl i postavis vrijednost 3
Nakon toga odes u podesavanje ventilatora, cekiras kao u onom mom prethodnom postu i stavis ove vrijednosti:
Duty Cycle Min - 40
Duty Cycle Max - 100
T min - 40
T range - 32
T operating - 110
T low limit - 0
T high limit - 110
Ono sto ovakve vrijednosti donose:
- ventilator radi po defaultu na 40%. Tako je na najnizoj vrijednosti kod normalnog koristenja (surfanje, 2D). Idllanje, surfanje i sl. daju temeperature 40-45'C ovisno o sobnoj temperaturi
- brzina ventilatora se pocinje dizati na 48'C
- ventilator postize brzinu vrtnje od 100% negdje oko 78'C
Ja sam ovako podesio jer je kartica lagano overclockana (648/1404/1134), a volim da je hladna.
Takodjer, kada se brzine pocinju dizati to je obicno za vrijeme igranja, a tada imam slusalice, pa nista ne cujem
Najvise sto sam vidio pod gornjim vrijednostima je 75'C i tada se ventilator vrtio pod 94% brzine. To je bilo kada sam "silovao" karticu Furmarkom da bi vidio stabilnost overclocka. Za vrijeme igranja ne moze doci ni blizu tim vrijednostima (Crysis na 1680*1050, high setting ju dize do nekih 65-66'C).
Doduse, moja kartica radi u lijepo hladjenom kucistu (Stacker), ali joj drustvo radi Q6600 B3 clockan na 3,2GHz, pa vjerovatno i on salje u okolinu finih celzijaca.
Ako hoces malo vise vidjeti o podesavanjima vrtnje ventilatora pogledaj ovaj post:
http://www.vaguetech.com/index.php?p...207#advcontrol
Scrolaj malo nize da dodjes do dijela gdje se ovakav nacin objasnjava.
Ono sto bi mene zanimalo je kako ono gore sto sam napravio u Riva Tuneru za ventilator "kopirati" u NiBiTor kod eventualnog editiranja i nakon toga flashanja BIOS-a
Staro 29.03.2009., 16:44   #18
Verbum
Postovi: 682
Hvala puno .
Sad kad sam podesio ne prelazi 70C, predobro.
Staro 01.04.2009., 19:34   #19
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,844
ja koristim ali za w7 jer riva ne radi na w7,program je super jednostavan,samo zatš onaj test ne radi kad dignem taktove??,možda driveri za w7 nisu podržani.
Staro 08.04.2009., 08:22   #20
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
izasla nova verzija...
EVGA Precision v1.6.1 (2009-04-1)
  • Added PCB temperature monitoring (also known as board, ambient or environment temperature in other hardware monitoring tools) for display adapters equipped with additional thermal sensors (e.g. 8800GTX or GTX 200 series).
  • Added workaround for NVIDIA driver's internal fan control timing issues causing wrong fan speed to be displayed on the slider during switching from automatic to manual fan control mode on display adapters equipped with discrete ADT7473 fan controllers under certain conditions.
  • Added new OSD tab to advanced Precision settings window. New tab allows users to define global hotkeys for toggling On-Screen Display visibility and allows disabling On-Screen Display header.
  • Now Precision can display system time in On-Screen Display header.
  • EVGA On-Screen Display Server has been updated to version 3.2.1. New version includes improved exception handling and no longer crashes on startup after closing the previous running instance of the server improperly (e.g. due to crash or due to forcible server process killing via the task manager).
  • Various code and skin engine cleanups and optimizations.
Staro 08.04.2009., 10:49   #21
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Autor bluefluid Pregled postova
To to to!!!
Staro 19.08.2009., 11:20   #22
maX
maX's Avatar
Postovi: 7,326
EVGA Precision v1.8.0 (2009-08-18)
* All vendor specific hardware access code has been moved from the executable file to separate hardware abstraction layer library (RTHAL.dll) to simplify the process of supporting new hardware products in the future
* Fixed GDI resource leak during monitoring window detachment / attachment.
* EVGA On-Screen Display Server has been updated to version 3.4.0. New version adds pre-created On-Screen Display rendering profile for "The Chronicles of Riddick: Assault on Dark Athena" and introduces floating injection address hooking technology aimed to reduce the risk of On-Screen Display detection by third party applications (e.g. anti-cheat systems).
* New skin format v1.2 gives new possibilities to skin developers and reduces skin file size and runtime skin engine memory footprint.
* Reduced CPU usage for simultaneous GPU and PCB temperature readings, both sensors are being read in single pass now.
* Added workaround for SLI mode switching related issues on ForceWare 190.xx series drivers. Now Precision is waiting for the end of SLI mode switching process before retrieving any data via NVIDIA driver API.
* Includes new "Sleek Skins" by Jonttu.
Staro 21.08.2009., 12:59   #23
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Jučer sam prvi put koristio ovaj tool i neusporedivo je pregledniji i lakši za korištenje od Riva Tunera, a tek mogućnost manualnog utipkavanja frekvencija a ne zajebavanja sa sliderima, milina... Uglavnom, sve što mi može trebati smješteno je unutar jednog prozora i stvarno je prelagano za koristiti. Sve u svemu što se OC-anja GPU-a tiče mislim da sam našao svog favorita. Good stuff
C L O W N I N G A R O U N D
Staro 21.08.2009., 13:50   #24
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Ipak cu ja ostat na staroj verziji... Neda mi se skidat ova, nepotrebno...
Staro 06.10.2009., 22:51   #25
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
EVGA Precision 1.8.1 released
- Added Nvidia GeForce G 210, GT 220 and GT 240 series graphics cards support
- EVGA On-Screen Display Server has been updated to version 3.5.0. Floating injection address hooking technology, which has been introduced in the previous version, is now disabled by default and can be enabled via the "Stealth mode" option in the server's properties
- Added hotkeys cross-links checking, Precision no longer allows defining the same hotkey for two different actions at the same time
- "Browse" button to "Screen capture" tab to allow users to change target folder for screenshots
- Added integration with external overclocking stability testing applications
Download link:
http://www.toomanydownloads.com/inde...=425&Itemid=54
Matth€w je offline   Reply With Quote
Staro 18.01.2010., 11:21   #26
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
EVGA Precision 1.9.0
Nove zanimljive mogućnosti:
-Added videomemory usage monitoring for NVIDIA graphics cards under Forceware 185.xx and newer drivers
-Added GPU usage monitoring for NVIDIA GT2xx and newer graphics cards under Forceware 185.xx and newer drivers
-Now you can save screenshots from your favorite games!
Download link:
http://majorgeeks.com/EVGA_Precision_d6209.html
Staro 10.04.2012., 19:51   #27
Doink the Clown
Postovi: 6,214
EVGA Precision X Updated to Version 3.0.2
EVGA has today rolled out a new version (3.0.2) of its Precision X GPU overclocking software. This latest release includes a new skin (EVGA Classified), support for hardware monitoring history logging, and is bundled with the new EVGA VoltageTuner utility.
Download Precision X
Full 3.0.2 changelog
- Added "Always on top" setting to the context menu of detached hardware monitor window. When this option is disabled, hardware monitoring window can be minimized to the taskbar when it is detached from the main window
- Added hardware monitoring history logging support. Now EVGA Precision is able to save history in native RivaTuner Hardware Monitoring Log file format. The log files captured with EVGA Precision can be viewed in any text editor like Notepad or in graphics form in RivaTuner's HML file viewer (RivaTuner must be installed for viewing log files in graphics form)
- Maximum framerate target increased to 120 FPS
- Maximum length of GPU name for GPU selection buttons has been increased to 10 symbols
- Added new "Force fan speed update on each period" option to the "Fan" tab. New option may improve compatibility of software automatic fan speed control mode with some bugged display drivers, overriding manually programmed fan speed under certain conditions
- Bundled EVGA EVTune utility has been replaced with brand new EVGA VoltageTuner utility
- Added bundled EVGA Bridge utility, allowing controlling EVGA Precision via Bluetooth from Android smartphones. The bridge utility is automatically started by EVGA Precision when "Enable external access to application via Bluetooth" is ticked in advanced settings
- Fixed issue in skin engine causing boost clock marker legend to be rendered improperly under certain conditions
- Added new "EVGA Classified" skin
http://www.techpowerup.com/163927/EV...ion-3.0.2.html
