Super Moderators
Datum registracije: May 2002
Postovi: 17,485
EVGA Precision
NGOHQ Posted (and hosted) information regarding EVGA's new Exclusive Precision Overclocking Utility. "****, once again, sets itself apart from the rest with the **** Exclusive Precision Overclocking Utility. This program allows you to fine tune your **** graphics card for the maximum performance possible, with Core/Shader/Memory clock tuning, real time monitoring support including in-game, Logitech Keyboard LCD Display support, and compatibility with almost all **** graphics cards. * Core/Shader Clock Link/Unlink capability * Fan Speed manual or auto adjustment * Real-Time on-screen display support for ingame temp, framerate, and clock monitoring * Logitech Keyboard LCD Display support * In-app temp/clockspeed monitoring of GPU's (up to 4 supported) * Information button shows device, driver, memory size, BIOS Revision and SLI mode * Ability to choose different skins, with more coming soon" ![]() Koliko vidim-fino su se počerupali sa škvadrom iz EVGA...potonjim nije bilo baš drago kaj je soft raspoloživ za download ![]() http://www.2manydownloads.com/index....d=73&Itemid=54
Ekspert iz sjene ...
Lokacija: New Eden
Postovi: 3,801
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
1.01 release notes: EVGA Precision Version 1.01 Released It was yesterday when the EVGA Precision utility first became available, and now just a day later here's a brand new version released. The EVGA Precision 1.01 features the following changes:
konjpjukter
Postovi: 934
1.6.0 EVGA Precision v1.6.0 (2009-03-26)
DOWNLOAD Zadnje izmijenjeno od: Razer. 28.03.2009. u 20:36. |
Postovi: 11,642
Ovo je odlična novost - dodavanje kontrole, odnosno overclockinga svake kartice zasebno u SLI-ju ![]() |
Postovi: 11,642
Radi sa svim nVidijinim karticama. |
its slightly turbocharged
Postovi: 5,430
Da, evo upravo vidjeh. ![]() Radi OK, možda da je interface malo "jednostavniji"... Ovak mi se čini sve nabacano na malom području. Ali OK Dobar je program, puno profila može spremati, i lagano, one click prebacivanje između prve i druge grafičke
blaa |
Postovi: 11,642
Jesi pratio preko Monitoringa jel svaka kartica može "primati" različite taktove? |
#14 | ||
Postovi: 5,430
![]() Naravno, slažem se da je i prejednostavan nego mi se jednostavno čini "puno" toga nabacano na premalom screenu ![]() EDIT: Inače veliki bigup za program, RivaTuner mi se čini kao prošlost, već je maknut iz autostarta sa Windowsima i stavljen EVGA Precision ![]() Eh da, Razer: ![]() Različiti clockovi kad je Sync isključen Kako padne FPS u Furmarku kad se nešto drugo sa Alt+Tab stavi u prvi plan, sa EVGAom prikazanom 35 FPSa, a kad je Furmark u prvom planu FPS je 90-100
blaa |
prof.dr. gospodar svemira
Postovi: 419
Dobar programcic, posebno mi se svidja sto se za razliku od Riva Tunera mogu clockovi direktno upisati (kod Rive iskljucivo koristenje slidera). Ono sto mu nedostaje i zbog cega ostajem na Rivi je podesavanje ponasanja automatske regulacije brzine ventilatora: ![]() S njom se ventilator moze ubrzati (ranije dize brzinu i ranije dostize 100%) sto je mrak za overclock, a jos uvijek radi tiho kada je bez opterecenja. Ili je netko ipak otkrio nacin kako to u Precisionu napraviti (ne sa 10 profila i sl. nego cista automatika)? |
#16 | |
Postovi: 682
Vidim da imamo istu grafu pa bih te molio ako mozes navesti sve svoje vrijednosti u riva tuneru. ![]() Mislim na duty cycle min, max, Tmin, Tmax ..itd... (ne vide se sve vrjednosti na slici :P) Htjeo bih to podesiti i na svojoj grafi jer ventilator prakticki ne ubrzava dok ne dodje do 85C sto je po meni previse s obzirom da ima stvarno dobar hladnjak koji nije i previse bucan. Zadnje izmijenjeno od: Verbum. 29.03.2009. u 14:59. |
#17 | |
Postovi: 419
To napravis da podesis kao u ovoj slici: ![]() Dakle, pod Power User tabom nadjes parametar Riva Tuner / Fan -> AutoFanSpeedControl i postavis vrijednost 3 Nakon toga odes u podesavanje ventilatora, cekiras kao u onom mom prethodnom postu i stavis ove vrijednosti: Duty Cycle Min - 40 Duty Cycle Max - 100 T min - 40 T range - 32 T operating - 110 T low limit - 0 T high limit - 110 Ono sto ovakve vrijednosti donose: - ventilator radi po defaultu na 40%. Tako je na najnizoj vrijednosti kod normalnog koristenja (surfanje, 2D). Idllanje, surfanje i sl. daju temeperature 40-45'C ovisno o sobnoj temperaturi - brzina ventilatora se pocinje dizati na 48'C - ventilator postize brzinu vrtnje od 100% negdje oko 78'C Ja sam ovako podesio jer je kartica lagano overclockana (648/1404/1134), a volim da je hladna. Takodjer, kada se brzine pocinju dizati to je obicno za vrijeme igranja, a tada imam slusalice, pa nista ne cujem ![]() Najvise sto sam vidio pod gornjim vrijednostima je 75'C i tada se ventilator vrtio pod 94% brzine. To je bilo kada sam "silovao" karticu Furmarkom da bi vidio stabilnost overclocka. Za vrijeme igranja ne moze doci ni blizu tim vrijednostima (Crysis na 1680*1050, high setting ju dize do nekih 65-66'C). Doduse, moja kartica radi u lijepo hladjenom kucistu (Stacker), ali joj drustvo radi Q6600 B3 clockan na 3,2GHz, pa vjerovatno i on salje u okolinu finih celzijaca. Ako hoces malo vise vidjeti o podesavanjima vrtnje ventilatora pogledaj ovaj post: http://www.vaguetech.com/index.php?p...207#advcontrol Scrolaj malo nize da dodjes do dijela gdje se ovakav nacin objasnjava. Ono sto bi mene zanimalo je kako ono gore sto sam napravio u Riva Tuneru za ventilator "kopirati" u NiBiTor kod eventualnog editiranja i nakon toga flashanja BIOS-a ![]() |
#20 |
Lokacija: VG
Postovi: 1,758
izasla nova verzija... EVGA Precision v1.6.1 (2009-04-1)
#21 | |
Lokacija: Čazma
Postovi: 1,728
To to to!!! |
#22 | |
Postovi: 7,326
#23 |
Jack of all, master of none
Lokacija: Matulji - Rijeka
Postovi: 6,214
Jučer sam prvi put koristio ovaj tool i neusporedivo je pregledniji i lakši za korištenje od Riva Tunera, a tek mogućnost manualnog utipkavanja frekvencija a ne zajebavanja sa sliderima, milina... Uglavnom, sve što mi može trebati smješteno je unutar jednog prozora i stvarno je prelagano za koristiti. Sve u svemu što se OC-anja GPU-a tiče mislim da sam našao svog favorita. Good stuff ![]()
![]() C L O W N I N G ![]() |
#25 | |
Lokacija: NaN
Postovi: 3,438
EVGA Precision 1.8.1 released Citiraj:
http://www.toomanydownloads.com/inde...=425&Itemid=54 |
#26 |
Lokacija: Čazma
Postovi: 1,728
EVGA Precision 1.9.0 Nove zanimljive mogućnosti: -Added videomemory usage monitoring for NVIDIA graphics cards under Forceware 185.xx and newer drivers -Added GPU usage monitoring for NVIDIA GT2xx and newer graphics cards under Forceware 185.xx and newer drivers -Now you can save screenshots from your favorite games! Download link: http://majorgeeks.com/EVGA_Precision_d6209.html |
#27 | |
Postovi: 6,214
EVGA Precision X Updated to Version 3.0.2
![]() ![]() http://www.techpowerup.com/163927/EV...ion-3.0.2.html
