Staro 30.12.2009., 16:04   #2611
Router
Hejter
Postovi: 6,521
Mene su zamolili kod jedne zamjene da im posaljem poklopac za baterije i receiver od misa
Staro 30.12.2009., 16:25   #2612
olly
olly's Avatar
Datum registracije: Dec 2009
Lokacija: Omiš
Postovi: 268
ima li ikakav topik ovdje vezano za to kako najefikasnije poslat nesto, jer mislim ja sam uvijek do sada slao pouzećem, ali to mi je sporiji način i tako, pa me zanima gdje se oko toga mogu konzultirat da na neki drugi nacin saljem i da mi se salje ?
olly je offline   Reply With Quote
Staro 30.12.2009., 17:40   #2613
Hrjax
Postovi: 307
Hrjax je offline   Reply With Quote
Staro 30.12.2009., 18:16   #2614
Facelessone
Facelessone's Avatar
Postovi: 4,205
Meni za novi MX Revolution nisu ništa tražili.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 31.12.2009., 18:47   #2615
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Maksimir / Dugave
Postovi: 4,016
Autor Tomy no.1 Pregled postova
Ovo mi je stiglo zadnje,poslije te molbe.
Dear Mr. Glavašic,
I've processed the replacement for your mouse, you will receive MX1100 within 7-10 business days.
If you have any other concern regarding your product, feel free to email us back. You can also visit our website at www.logitech.com.
Kind Regards,
Valentine Seguira
Logitech Europe SA
European Customer Care
like like like.
Sad mi preostaje samo čekati ili? Što da radim s ovim mišem,jel to ja njima šaljem ili ce me zamoliti da ga uništim kao što su neke ljude prije (ako se dobro sjecam neka g15 je bila u pitanju)?
Hvala svima
Mene su za mx revo zamolili da im pošaljem stick od miša. Što ti možeš i ne moraš napravit, nitko ti neće ništa reć, tak i tak nitko ne vodi evidenciju o tome. Al bi bilo u redu, fer, ono. Naravno, ako to traže. Al Facelessonea nisu niš pa možda neće ni tebe. A nedavno sam ti dao linkove kako popravit miša...
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 31.12.2009., 19:47   #2616
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
Autor fanATIk Pregled postova
AKo budu tražili mislim da cu poslati,jer su stvarno ispali fer i korektni.Još sam ja predložio ovog mišonju (skoro sam ga i kupio koji mj.prije),ako ne budu trazili budem popravio i ovog,a onda Logi x2 u novoj godini.
Sve najbolje svima
Staro 05.01.2010., 17:41   #2617
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
Sve najbolje svima
evo jutros se probudim,vani snježi,pogledam u dnevnoj stoji paket pod borom.
Došla pošiljka Oversasom (2 dana ranije od datuma dostave), mama je preuzela i tako evo meni novog mx1100.Nitko me iz logitecha nije ništa pita za stari mx610 (nevjerujem da hoće),tako da im svaka čast.Svakome preporučam njihove proizvode i svakako će moja sljedeća kupovina ukoliko bude prilike biti vezana uz Logitech company.
Staro 05.01.2010., 22:03   #2618
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
ej ekipa. Kakva je fora sa corsairom iz LINKSA, piše garancija konkretno za vx450 napajanje 24 mjeseca...jer uzet cu burazu napajanje, a covijek kaze da mu na racunu pise 24 mjeseca, a da su mu na pultu rekli 5 godina...
Za mog vx-a je 5 godina u ADM-u odnosno u esys-u
thx
Staro 05.01.2010., 22:12   #2619
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Autor Halos Pregled postova
thx
2 godine Links, i onda preostale 3 godine garancije ostvarive u esysu.
C L O W N I N G A R O U N D
Staro 05.01.2010., 23:13   #2620
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Ok, ako je to 100% onda: thx Clown
Staro 05.01.2010., 23:28   #2621
Doink the Clown
Postovi: 6,214
Pa trebala bi na kutiji od napajanja biti naljepnica-jamstveni list od esysa na kojem piše da PSU ima garanciju 60 mjeseci, kada budeš kupovao napajanje provjeri ako je taj jamstveni list na kutiji.
Zadnje izmijenjeno od: Doink the Clown. 05.01.2010. u 23:45.
Staro 05.01.2010., 23:35   #2622
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
je, razumijem ja sve. Sve 5, istu naljepljcu imam ja na svom, samo me to sa Linksom mucilo, g***a trgovina i njohovih 24 mj.
Staro 06.01.2010., 00:00   #2623
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
jeli to ovo?
Napajanje 450W, CORSAIR VX Series CMPSU-450VXEU, ATX2 v2.2, 120mm vent.
raspoloživost: ZG: RI ZD ST OS VŽ
60 mjeseci 565,00
Staro 06.01.2010., 00:21   #2624
d^_^b
d^_^b's Avatar
Lokacija: Sarajevo
Postovi: 474
Nadam se da se netko od vas razumije u zakone u BiH
Steta je vec nacinjena, ali me zanima samo za ubudue, cisto da znam kako postupiti.
Moja bivsa graficka, 4850 mi je crkla tacno na dan kad joj je isticala garancija... Znaci, graficka je crkla nedjeljom tako da je nisam nikako mogao odnijeti na servis, tj. vratiti je... Sad me zanima da li bi mi se uvazilo da sam odnio graficku na servis 1 dan nakon sto je istekla garancija i rekao im kakva je bila situacija?
BTW. jos jednom se je potvrdilo pravilo da proizvod ispravno radi samo dok mu traje garancija xD
d^_^b je offline   Reply With Quote
Staro 06.01.2010., 00:27   #2625
JuVe
JuVe's Avatar
Postovi: 702
sve se može kad se hoće, ovisi najviše gdje ti je garancija... rekao bih da ti u 80% slučajeva neće uvažit reklamaciju pogotovo ako se radi o većim trgovinama. ovih 20% se odnosi na neke manje trgovine koje ti žele izać u susret ili znaš nekog tko radi tamo
JuVe je offline   Reply With Quote
Staro 06.01.2010., 00:32   #2626
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Autor d^_^b Pregled postova
Neznam tamo zakone, no mislim da si pokriven jer to sto oni ne rade nije tvoj problem jer ih nisi mogao obavjestiti za kvar.
Ono sto se oni vade i jedino na sta mogu se vaditi je da lazes i da ti je grafa krepala u vremenu od zadnjeg dana (znaci 00:00) do vremena kad si prijavio.
Cak sam citao da su i auto kuce priznavale takve kvarove unutar praznika i slicno....
Nadam se da imas jos nesto iz tog shopa skupo placeno, a istice uskoro garancija i moli da to "krepa".
Staro 06.01.2010., 00:44   #2627
maX
maX's Avatar
Postovi: 7,326
Autor Alfa_R Pregled postova
Ili se neka moli, ili se neka potrudi...
Staro 10.01.2010., 15:20   #2628
w0lfram_
Rasvjetno tijelo
w0lfram_'s Avatar
Postovi: 374
imam jedno pitanje
kartica koju sam kupija u hardveraju baca artefakte, kad zavrtim bilo sta u 3d odma se pojavi bsod, znaci odlazi u vjecna lovista, na kutiji od graficke na naljepnici pise da je uvoznik nekakav elkotech, al kad sam gugla ispalo je da elkotech vise ne radi, odnosno pise ovako
Slijedom odluke o zatvaranju Elkotech d.o.o. obavještavamo Vas nažalost da smo od 03.08.2009 prestali raditi distribucijske aktivnosti u RH.
Vaš ELKO
sad mene zanima jel to znaci da je jedino sta mi je preostala zavitlat grafulju u smece?
Pošteni trgovci: 1, 2, 3, 4, 5, 6, 7, 8, 9,10
w0lfram_ je offline   Reply With Quote
Staro 10.01.2010., 15:40   #2629
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Autor w0lfram_ Pregled postova
imam jedno pitanje
Vaš ELKO
mogu ti ju ja odnjest u ljubljani u elko.
Staro 10.01.2010., 15:58   #2630
Postovi: 34,070
Ako ti to ne upali, jedino drugo rješenje je da se javiš direktno proizvođaču i objasniš situaciju.
Staro 10.01.2010., 22:14   #2631
borny
Too much busy
borny's Avatar
Postovi: 1,540
Corsair jamstvo
odnedavno sma ponosni vlasnik corsaira cx400.
imam jamstco 5god preko adm-a ili esys-a.
e sad, kutija mi treba za poslati drugo napajanje forumašu, pa me zanima mogu li jamstvo ostvariti i bez kutije?
logično mi je da mogu, ali pitam za svaku slučaj.
Staro 10.01.2010., 22:38   #2632
Doink the Clown
Postovi: 6,214
Autor borny Pregled postova
Ja bih si ostavio kutiju na tvom mjestu jer na njoj ti je s/n napajanja, za ostvarivanje garancije bi ti trebao biti dovoljan onaj žuti jamstveni list od esysa koji je zalijepljen na kutiju ali kao što rekoh bolje ti je čuvati i kutiju od PSU-a, nikad ne znaš što ovi u trgovini mogu izmisliti ako dođe do reklamacije.
Staro 10.01.2010., 22:48   #2633
borny
Too much busy
borny's Avatar
Postovi: 1,540
a ništa, napajanje maX-u šaljem u kutiji za cipele
Staro 14.01.2010., 16:27   #2634
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Evo kako ne bi bilo da ljudi imaju samo problema sa hardwareom evo moje priče od ovih dana.
U ghetaldusu je prije nove godine bila akcija staro za novo. Daš stari okvir i dobiješ novi. Pošto imaju očito jako sposobni marketing/web mastere nisu napisali uvjete po kojima se to može obaviti. Shodno tome ja sam donio stare naočale i stare papire na kojima je recept (dioptrija) i iznos za koji su kupljene naočale. Tamo sam zaposlenici Ghetaldusa dao stare naočale i objasnio da im dajem te i da želim nove ali po dioptriji koja mi je na trenutnim naočalama te sam joj dao te naočale koje su mi trenutno na nosu. Ona je klimnula glavom i kao sve 5. Dolazim po naočale ali nije sve ok jer su ZAJEBALI i napravili mi naočale po starim dioptrijama te sam jučer otišao reklamirati. Reklamacija je zaprimljena i dobio sam neki papirić. Danas me zove ta ista zaposlenica te mi objašnjava kako njezina šefica ne priznaje reklamaciju. Znači ONI su zahebali stvar jer su ne sposobni i ne slušaju što im klijenti govore te onda pokušavaju krivnju svaliti na njih!
Radi se o 1200kn i ne namjeravam to popušiti. Ima tko kakav savjet ili je možda imao slično iskustvo?
Staro 14.01.2010., 17:07   #2635
gunther
Postovi: 1,368
Uff...
Zeznuto...
Najvise mrzim stakla kupovat za naocale...
Nikakav papir/recept nemas nego se sve svodi na tvoju rijec protiv njihove?
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je offline   Reply With Quote
Staro 14.01.2010., 17:26   #2636
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Standardno - skeniraj svu papirologiju i prijava inspektoratu.... Oni se nadaju da ljudi to nece raditi...
Staro 14.01.2010., 17:40   #2637
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Imam papire izrade naočala ovih novih koje su trenutno na reklamaciji. Podatci po kojima su oni napravili naočale se razlikuju od onih koje ja imam i po kojima sam tražio da se naprave nova stakla. Svi su toga svjesni samo se prave grbavi i ne žele priznati.
Staro 14.01.2010., 20:18   #2638
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Pa lijepo im objasni da ćeš ih dati u novine,prijaviti Državnom inspektoratu,
prijaviti Obrtničkoj komori i naravno opozovi se na Zakon o zaštiti potrošača i da ćeš svoja prava potražiti na sudu uz neko verbalno uvjeravanje obično se svi smekšaju, a oni koji neće, sjedneš za komp sastaviš par mail-ova-prijava i šalješ redom.
Barem je to danas besplatno naštetiti ti nemože ukoliko neuspiješ normalnim putem.
Staro 14.01.2010., 20:44   #2639
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
A gle ici cu na razgovor i vidjeti jesu li razumni tj. dali će priznati da je njihova djelatnica pogriješila što naravno i je. Meni je jasno da je moderno i popularno zavaljavati klijente ali eto ja nisam taj kojeg će uspjeti zavaljati.
Staro 14.01.2010., 21:25   #2640
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Aaa došla maca na vratanca.
Bacite oko na sliku.
http://img218.imageshack.us/img218/5561/evoga.jpg
Pogledajte dioptriju i pogledajte OS tj. AXIS NEMA je, a ja imam astigmatizam...divno. Idioti definitivno napravili krive naočale. Sada jedva čekam susret sa idiotima.
Mmmmo ovo će biti predivno.
