Staro 22.05.2008., 13:54   #31
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Viđao sam već po forumima kao su je dizali i na 620fsb, ali ipak prvi put kod nas.
Čestitam razer. Ajde sad digni multy i zapali taj procesor!
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 22.05.2008., 14:15   #32
Z-man
Z-man's Avatar
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
Autor Bullet1 Pregled postova
boji se dat soka
a dao je susjedovom e4400 1.8 V
@Razer, ponovno nemaš mira,
Z-man je offline   Reply With Quote
Staro 22.05.2008., 14:28   #33
Razer
Razer's Avatar
Postovi: 11,642
Autor Swarm dude Pregled postova
gg Razer
Autor Matth€w Pregled postova
GJ Razer
Autor MP950 Pregled postova
Razer faco
Autor timmy75 Pregled postova
svaka cast, cestitam...
Znao sam da necu pogrijesiti s tom plocom kad sam je uzimao Svaka cast na rezi...
Autor razor i2c Pregled postova
respekt i svaka čast
Autor maX Pregled postova
doobar dooobar
svaka cast
Hvala svima
Autor Mortal Pregled postova
Hvala Inače...ploča svakako može više, koliko sam vidio max te ploče oko 650MHz+, tako da tu ovisi koliko je dobar primjerak procesora. Koliko vidim ovaj je dosta dobar
Autor Z-man Pregled postova
Tnx, i btw bio je cimer, sa 1.9v
P.S. baš sam se dogovorio s kolegom s foruma, budem uskoro otkupio taj procesor,
jer znam da je u njemu ostalo još za iscjediti, pogotovo s ovom pločom
Staro 22.05.2008., 14:53   #34
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ne znam jesi spomenuo, kakav je chipset na "prst metodu"? Opekotine 3.stupnja kad ga dodirnes?
Bravo na stiskanju gasa DFI-jki, bajdvej ja sam se jucer konacno malo zaigrao za stare dane i konacno naganjao svog flagija preko 4GHz Cudno mi je kako je Presler 945 bez pol frke sisao preko 4.2GHz, samo laganim overvoltanjem i to stabilno za 24/7, a ovaj Core je bas tvrd orah.
Staro 22.05.2008., 14:56   #35
Razer
Razer's Avatar
Postovi: 11,642
Daleko od toga. Mlak na dodir. Naravno, kako sam spomenuo, po njemu puše 120mm vent.
Pri tim brzinama i voltažama nije baš za igrati se s temperaturama.
Staro 22.05.2008., 14:58   #36
LUXX
Vodenjak :)
LUXX's Avatar
Lokacija: Križevci
Postovi: 667
Svaka cast Razer.
Strpaj to sve u frižider i udri po voltaži
LUXX je offline   Reply With Quote
Staro 22.05.2008., 15:01   #37
Razer
Razer's Avatar
Postovi: 11,642
Autor Vin EuroDizel Pregled postova
Sad vidjeh edit...tnx...koji napon mu daješ? Koliko ti je GTL i VTT? Nastaviti na temi s reviewom
Autor LUXX Pregled postova
Svaka cast Razer.
Hvala. Umjesto fržidera, najbolje rješenje je hladno zimsko vrijeme u Požeškoj kotlini
Zadnje izmijenjeno od: Razer. 22.05.2008. u 15:18.
Staro 22.05.2008., 15:07   #38
LUXX
Vodenjak :)
LUXX's Avatar
Lokacija: Križevci
Postovi: 667
Autor Razer Pregled postova
Hehe.
Komp na balkon i peri po naponu
Staro 22.05.2008., 15:24   #39
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
WOW efekt (ne mislim na World of Warcraft). Stvarno odlicni rezultati, odlicna je ova ploca. Po meni je najbolja od P35 za klokanje.
I ja imam na ploci.
Staro 23.05.2008., 04:14   #40
teofil
Udaram Ljude Za Pare
teofil's Avatar
Lokacija: BEHIND YOU
Postovi: 835
svaka cast majstore ja sam svoju ganjao bas do 600fsb ali zgleda da me hebe cpu pa nisam mogao dalje od 570.naponi nisu pomogli a ne zelim vjerovati da ploca ne ide dalje.
btw;koji bios si koristio??
teofil je offline   Reply With Quote
Staro 23.05.2008., 04:19   #41
Razer
Razer's Avatar
Postovi: 11,642
Hvala.
Koristio sam zadnji BIOS. Kolike si napone koristio za SB/NB/PLL?
Staro 23.05.2008., 04:50   #42
teofil
teofil's Avatar
Postovi: 835
e to ti malo teze mogu reci jer sam davno radio ali cu opet probati kad se vidim s njom ploča je prva liga ima stvarno opcija koje nisam u zivotu vidio mozda sam i tu nest izostavio pa cu malo detaljnije to obaviti.
inace u prvom planu mi je neki dobar cpu serije 8 et sam da malo napravim pomutnje u super piju.
vidim da si uveo dosta reda i vatre po nekim podforumima i to je odlicno.motivira. nemas bezveze S klasu od admina
pohvale razeru jos jednom
Staro 23.05.2008., 15:00   #43
Razer
Razer's Avatar
Postovi: 11,642
Hehe
Inače ploča je svakako odlična, čekamo reze sa E8x00, ako budu u rangu onih koje si svojevremeno imao sa E6600, bit će gusto
Staro 23.05.2008., 19:08   #44
kian
kian's Avatar
Datum registracije: Oct 2001
Lokacija: Velika Gorica
Postovi: 600
Odlicno Razer
Staro 26.05.2008., 03:12   #45
Space
ASUS
Space's Avatar
Lokacija: Beograd
Postovi: 263
Svaka čast za FSB , odličan prcesor stari
Space je offline   Reply With Quote
