Staro 01.04.2025., 20:02   #3601
snake29o3
snake29o3's Avatar
Lokacija: Croatia - Kutina
Postovi: 211
Autor Tirkiz Pregled postova
Što visočije na čistinu i da nema prepreka između routera i tornja, to bolji radio uvjeti a time i signal i brzine
Al naravno, ne tjeram te sada da ideš dizati stup od 50 m da objesiš Zyxela na 50 m da bude ravnopravan sa telekom tornjem
Ma imao sam prije za lokalni ISP Mikrotik antenu na cijevi iznad krova... Onda bilo nevrijeme jedno ljeto, pa led, pa to sve smrdalo.. I onda kad sam slagao 5G router sam rekao da ide pod krov, na sigurno hahahaah
Ali dobar je i ovako signal, ne smeta mu crijep ni nista.
Sent from my OnePlus 12 using Tapatalk
CPU: INTEL Xeon E5450 3.0 GHz 12 MB Cache
Cooler: Scythe Grand Kama Cross
Mainboard: Asrock P43DE3
RAM: 4 x 4 GB DDR3 1600MHz
GPU: XFX 8800 GT 512 MB DDR3 Alpha Dog XXX Edition
HDD: Kingston HyperX Fury 120 GB (OS) + ( 4 x Toshiba DT01ACA050 500 GB 32 MB (RAID 10) )
PSU: InterTech SL-500A
Case: Antec P180
OS: Proxmox VE
Cooler: Spire Kepler Rev.2
Mainboard: Gigabyte GA-965P-DS4
RAM: 4 x 2 GB DDR2 Kingmax 1066MHz
GPU: Palit GeForce 8400GS 512MB DDR2
HDD: Hitachi 160 GB (OS) + ( TOSHIBA 3 TB 64 MB DT01ACA300 + Toshiba 3 TB 64 MB HDWD130 (ZFS RAID1)
PSU: Xilence 420W
Case: Generic Midi Tower
OS: CentOS 7
Manufacturer: HP
Model: Z440
CPU: INTEL Xeon E5-1650 v4 3.6GHz ( 4GHz Turbo ) 15 MB Cache
RAM: 4 x 8 GB DDR4 ECC 2400MHz
GPU: nVIDIA Quadro P4000 8 GB
SSD: 2 x 240 GB RAID 1 + 256 GB
HDD: 2 x 3 TB RAID 1
Monitor: HP LA2405wg 24" 1920 x 1200
OS: openSUSE Tumbleweed MATE x64
BRAND: ASUS N705FD
CPU: Intel Core i7 8565U 1.8 GHz ( up to 4.6 GHz with TurboBoost)
RAM: 2 x 8 GB DDR4 2400 MHz
GPU: Intel® UHD Graphics 620 Integrated + nVidia GTX 1050 4GB DDR5
SSD: Crucial Micron 1100 256GB
HDD: Seagate ST1000LM035 1 TB 128 MB Cache
Screen: 17.3" 1920 x 1080
BRAND: HP Notebook 15-ba006nm
CPU: AMD Quad-Core A10-9600P (2.4 GHz, up to 3.3 GHz, 2 MB cache)
RAM: 4 GB DDR4 1866 MHz + 8 GB DDR4 1866 MHz
GPU: AMD Radeon R7 M440 Graphics 4 GB DDR3
HDD: 1 TB 5400 rpm
Screen: 15.6" 1920 x 1080 FullHD
OS: Windows 10 Pro x64
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
snake29o3 je offline   Reply With Quote
Staro 01.04.2025., 20:33   #3602
Tirkiz
Poludrago kamenje
Tirkiz's Avatar
Datum registracije: Apr 2023
Lokacija: Ogulin
Postovi: 321
Autor swlroby Pregled postova
pozdrav
ima li za NR7302 program da radi pod win 11 ili samo ZYXEL AIR za android ?
https://service-provider.zyxel.com/a...Air/index.html
Piše samo da ima za Android i Apple mobove, nema za PC.
Na PC-u se možeš ulogirati preko browsera u Zyxel
Tirkiz je offline   Reply With Quote
Staro 01.04.2025., 20:50   #3603
snake29o3
snake29o3's Avatar
Postovi: 211
pozdrav
Imas web sucelje gdje se ulogiras u router i imas hrpu postavki za podesavanje.
U android app nemas toliko puno mogucnosti.
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 02.04.2025., 09:12   #3604
Ivan357
Datum registracije: Jun 2020
Postovi: 161
Autor snake29o3 Pregled postova
moj ZTE je također u potkrovlju, kroz krovni prozor gleda direktno u baznu stanicu udaljenu cca. 500m
Ivan357 je offline   Reply With Quote
Staro 02.04.2025., 16:43   #3605
tpm4
tpm4's Avatar
Postovi: 326
Stigao novi frimware za NR5103E, verzija V1.00(ACDJ.1)b7_D1
Meni je brzina i konekcija ista koliko primjetim.
Promjenu vidim u prikazu signala, sada u "Cellular Info" pokazuje svaki cell odvojeno sa jacinom signala prema svakom cellu.
tpm4 je offline   Reply With Quote
Staro 02.04.2025., 19:33   #3606
Nikox
Nikox's Avatar
Datum registracije: Aug 2017
Postovi: 1,230
Autor tpm4 Pregled postova
I ne radi ti skripta najvjerojatnije.
Staro 02.04.2025., 20:55   #3607
Jadran3
Datum registracije: Apr 2024
Postovi: 18
https://community.home-assistant.io/...gration/871628
Ako se bolje ko razumije dal se isplati eksperiment sa ovim za Xiaomi 5G CPE Pro?
Jadran3 je offline   Reply With Quote
Staro 03.04.2025., 09:44   #3608
snake29o3
snake29o3's Avatar
Postovi: 211
Otkrio sam što mi je zblesiralo Zyxela NR7302 neki dan....
Prvo sam bio podesio APN, Wireless, IP Passthrough.... I onda sam kasnije ovo bio prebacio na Indivudial... i nakon toga se modem boota i resetira i tako u krug....
Uspije se dobiti na minutu dvije webGUI i to je to... Ali jučer sam bio uspio preko webGUIa na brzinu ga resetirati na tvorničke postavke i onda opet sve radi...
Našao sam na Talijanskom forumu da ako se želi prebaciti na Individual Setting da se to mora napraviti odmah nakon što se prođe Wizard kod prvog pokretanja....
Također je tamo pisalo da je razlika između Individual i Standard u tome što Standard odmah postavlja neke predefinirane vrijednosti za APN settings i da se može disableati IPv6 464XLAT translation... Sad sam postavio na Individual pa ću vidjet ima li neke razlike....
Od jučer vidim da A1 sada isto nudi paket od 2 SIM-a za turističku... tako da naručeno :-D
https://www.a1.hr/tourist-offer/en
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Zadnje izmijenjeno od: snake29o3. 03.04.2025. u 11:20.
Staro 03.04.2025., 10:43   #3609
tpm4
tpm4's Avatar
Postovi: 326
Autor Nikox Pregled postova
Da, ne radi. Vjerojatno je drugi format signala sada.
Staro 03.04.2025., 11:03   #3610
Ivan357
Postovi: 161
javi da li se tarifa automatski obnavlja ako ima dovoljno novaca na računu, po ovome ne:
What do I do if I spend my 10 days package and my vacation is not over yet?
You need to top up your prepaid account with the amount you want and activate a new 10-day package for 7,90 € by sending a free SMS containing 10DAYS to the number 13220. If you don’t need a new 10-day package, you can activate the Daily 5G package for €3 with unlimited traffic valid for 24 hours by sending an SMS containing DAILY to the number 13220.
Staro 04.04.2025., 08:02   #3611
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
Je li onda Zyxel NR7302 (ili 01 ili 03?) dobar i pouzdan izbor za nasa tri operatera?
U kombinaciji s nekim WLAN AP-om "iza" samog 5G-a?
Ako da, gdje ga je najbolje kupiti?
sNNooPY je offline   Reply With Quote
Staro 04.04.2025., 12:07   #3612
snake29o3
snake29o3's Avatar
Postovi: 211
Autor sNNooPY Pregled postova
Ja ga još testiram... Kupio na njemačkom Kauflandu online i došao je sa Deutsche Telekom firmware-om ( nema eSIM support).
Ima ih na eBayu i Amazonu isto.
Ja sam ga prebacio na Customized settings, uključio Bridge mode, ugasio Firewall i stavio Cell Lock i uštekan je u Xiaomi AX3000T sa openWRT-om.
Za sada mi se čini da radi ok. Trenutno sam na HT Turističkoj, stiže mi A1 Turistička pa ću i nju probati.
U usporedbi sa ZTE MC889 sa DNA firmwareom, imam bolji upload.
Kaj se tiče firmwarea, Nikox ima švedski, isto nema eSIM... Na talijanskom forumu sam vidio da Austrijski A1 firmware ima eSIM ako ti je to bitno.
Također na tom forumu su pisali da su imali problema u Router modu da im je pucala veza nakon cca 4 sata i tak neka općenito pucanja veze. U Bridge modu da nije bilo problema.
Trenutno mi je 24h veza online ( kad jos čačkam po njemu pa ga resetiram).
Isto tako Talijanin su testirali 5G agregacije i radi im N38 + N78 agregacija... Kod nas nema tih bandova pa ne možemo probati.
Prednost je Cell Lock sto možeš listu dodati.
Ja sam npr. dodao B3 na 2 tornja koja lovim dobro pa se spaja uvijek na jedan od ta dva. Na ZTE preko skripte možeš samo jedan lockati.
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 04.04.2025., 12:23   #3613
snake29o3
snake29o3's Avatar
Postovi: 211
Autor Ivan357 Pregled postova
https://ssc.a1.hr/documents/10307706...offer-v1.1.pdf
Stigle kartice i ovo su upute gdje piše da se obnavlja automatski ako imaš na računu.
Isprobam pa javim kod prve obnove radi li.
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 04.04.2025., 14:08   #3614
the chosen one
the chosen one's Avatar
Postovi: 755
A jel znaš da ti kod A1 turističke nakon 100GB smanje brzinu? Tj internet je Flat što se tiče s njihove strane, a to kaj je za surfanje skoro neupotrebljiv to je drugi par rukava.
the chosen one je online   Reply With Quote
Staro 04.04.2025., 16:29   #3615
snake29o3
snake29o3's Avatar
Postovi: 211
Autor the chosen one Pregled postova
Baš sam pitao A1 o tome, pa kažu da više nema tog ograničenja.
Al budem downloadao nekaoj preko 100GB pa ću vidjeti
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 04.04.2025., 23:02   #3616
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
Hvala na komentaru.
eSIM ili fiz. sim realno nije toliko bitno.
Ima li mogucnost remote monitoringa ako je u bridge modeu (i "iza njega" obicni router s WLAN-om, itd.)?
Ako da, kako? VPN? Neki njihov cloud servis? ...?
P.S. Gdje ga najbolje kupiti? EU-based shop? Amazon.de? …
Zadnje izmijenjeno od: sNNooPY. 06.04.2025. u 11:26.
Staro 04.04.2025., 23:49   #3617
expresso
Datum registracije: Oct 2018
Postovi: 22
Evo javljam se mjesec ipo dana nakon sto sam kupio Xiaomi 5G Cpe pro, i otkad je tcom kod mene ugasio 3G mrezu.
Tada su mi 4g i 5g frekvencije bile samo b3+b20...ovih dana sam slucajno skuzio da mi se jednom pojavio b8 nakratko.
Sad mi nesto se odspojio ruter,pisalo nema mreze. Ja resetiram ruter i vidim neku promjenu u frekvencijama i na 4g i 5g.
Evo slike:
4g - https://ibb.co/nNMSvV7C
5g - https://ibb.co/Q7yngz5X
Sto se dogada sad to? Tcom poceo pustati signal na frekvencijama gdje se pustao 3G ili ? Brzine su mi za sad jednake nista bolje
expresso je offline   Reply With Quote
Staro 05.04.2025., 01:24   #3618
Tirkiz
Poludrago kamenje
Tirkiz's Avatar
Lokacija: Ogulin
Postovi: 321
Autor expresso Pregled postova
Valjda si prespavao zadnjih pol godine ovog foruma koliko smo pisali o ovome
Taj B8 (900 MHz) je band sa ugašene 3G mreže - prebacuju ga na 4G ali ne odjednom nego toranj po toranj pa si ga sada i ti očito dobio.
Isti je kao i B20 i B28 al toranj ti sada ima jednu frekvenciju više tako da rastereti B20.
Btw. ako si u Osijeku kako ti piše, Osijek već mjesecima ima B8 band, vjerojatno si tek sada primijetio B8 jer je možda B20 zagušen pa je toranj počeo tvom Xiaomiju govoriti da koristi B8 umjesto B20 banda u agregacijama.
A to što ti piše malo 4G, malo 5G, to ti je sve 4G dokle god pod "Frekvencijski pojas" ne ugledaš najmanje jedan N band
Staro 07.04.2025., 10:22   #3619
snake29o3
snake29o3's Avatar
Postovi: 211
Ima i Telemach na tom tornju gdje se spajaš na HT isto 5G. A1 ima na 1231 tornju i na 1297 5G
Ovo su ćelije koje lovim sa Zyxelom....
Trenutno mi je A1 turistička u njemu i uspoređujem PCI i RFCN sa onim što je oko mene u Kutini i vidim da se PCI sa ovim skeniranim i onim na CellMapperu ne poklapaju... izgleda da bi trebalo updateati mapu...
A1 mi se spaja na B28, B1, B3 ali brzine oko 100 Mbita
A što se tiče A1 5G, ne lovim niti jedan N28 signal od A1... kao da to nije aktivno u Kutini.
Jedini 5G koji lovim je ovaj od HT-a:
ID:	28129   Click image for larger version
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 07.04.2025., 16:08   #3620
axo
Datum registracije: Sep 2017
Postovi: 1,431
Sta nije kutina kao grad gaminga od a1?
Bila je spika da je tamo neka gaming škola/kamp te su medu prvima dobili 5g.
Morat ces azurirat sa karticom u mobu cellmapper, tako t je najlakse.
Staro 07.04.2025., 16:50   #3621
snake29o3
snake29o3's Avatar
Postovi: 211
Autor axo Pregled postova
Ne... to je Novska
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 07.04.2025., 19:37   #3622
Nikox
Nikox's Avatar
Postovi: 1,230
snake29o3
Sva tri operatera kod tebe imaju 5G
A1- 1236 i 1231 tornjevi
Telemach - 4091 i 40758
HT - 150851, 150156 i 150170
Koji PCI ti se ne poklapaju?
Staro 10.04.2025., 13:25   #3623
Tirkiz
Poludrago kamenje
Tirkiz's Avatar
Lokacija: Ogulin
Postovi: 321
Ste primijetili da je HT noćas povećao bandwidth na B1 bandu i promijenio EARFCN (bitno onima koji rade cell lock na HT B1 band)?
Sada imamo nešto sitno veće brzinice
I opet moramo mapirati
Staro 16.04.2025., 13:58   #3624
lexman
Datum registracije: Aug 2009
Postovi: 37
Odabir routera
Ekipa,
u ljetnim mjesecima na moru mi treba Internet (područje u blizini Starigrada-Paklenice). Plan mi je kupiti turistički ili neki sličan SIM i zaseban router. Na njuškalu sam našao ove opcije:
  • XIAOMI 5g CPE PRO
  • ZTE 5G MC801A
Koja je od tih opcija bolji odabir? Postoji li neki treći uređaj koji mogu nabaviti u istom cjenovnom rangu (ispod 200€) koji bi bio pametniji odabir?
Unaprijed hvala svima!
lexman je offline   Reply With Quote
Staro 16.04.2025., 21:01   #3625
Nikox
Nikox's Avatar
Postovi: 1,230
Autor lexman Pregled postova
Ekipa,
  • XIAOMI 5g CPE PRO
  • ZTE 5G MC801A
ZTE MC801A definitivno ili vanjska jedinica Zyxel NR7302 ako su ti tornjevi dalje od 1.5km
Staro 17.04.2025., 00:05   #3626
snake29o3
snake29o3's Avatar
Postovi: 211
snake29o3
Nikak uloviti vremena da ti ovo pošaljem.
Evo ovo su Cell-ovi koje lovim sa Zyxelom, a ispod su Cellovi kako su označeni na ta dva A1 tornja na Cellmapperu.
Vidiš da se niti jedan PCI koji ja lovim ne nalazi na Cellmapperu.
A 5G Cell mi lovi isključivo ovaj od HT-a: PCI: 80 RFCN: 634080
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 17.04.2025., 09:57   #3627
Ivan357
Postovi: 161
Ekipa,
  • XIAOMI 5g CPE PRO
  • ZTE 5G MC801A
samo bih se nadovezao, da obavezno vanjska jedinica i pokušaj uhvatiti toranj na hotelu, a ne onaj preko puta kod Vinjeraca ili Ražanaca, kolko gledam na cellmapperu sva tri operatera imaju tornjeve na istim mjestima
frend ima istu potrebu, ali nažalost nema optičku vidljivost na taj toranj na hotelu
p.s. vjerojatno će uskoro moj mc889a u prodaju ako mi ht uspije posložiti sve kako treba, ne znam kolko ti je hitno za nabavku modema
Staro 17.04.2025., 10:57   #3628
Nikox
Nikox's Avatar
Postovi: 1,230
Nisu ti frekvencije na tornjevima ažurirane još ima na b3 (1749) i na b1 (500) stare EARFCN. A toranj 1231 je ok samo nisu svi smjerovi ćelija mapirani. Imaš na predhodnoj strani spisak EARFCN jedino na tom spisku ht nije 525 nego 500
Zadnje izmijenjeno od: Nikox. 17.04.2025. u 11:21.
Staro 17.04.2025., 12:24   #3629
lexman
Postovi: 37
Uskoro bih trebao ići prema Starigradu i volio bih sve riješiti do tada. No vidjeti ću, ako se plan promijeni - javim se.
Zadnje izmijenjeno od: lexman. 17.04.2025. u 12:39.
Staro 17.04.2025., 12:28   #3630
the chosen one
Postovi: 755
Ekipa,
  • XIAOMI 5g CPE PRO
  • ZTE 5G MC801A
Seline?
Ne znam jel sam tebi ili nekome drugome već objašnjavao, bio sam ljetovao tamo blizu kampa pa sam malo i testirao...
Kak je već netko napisao, toranj na hotelu gađaj, i uzmi router koji ima cell lock da ga možeš zaključati, a ne da skaće s jednog tornja na drugi
