What's inside???
Postovi: 370
batch
ocu si napravit batch za flashanje grafe s izbornikom yes/no ja sam napravil to na sljedeci nacin: @echo off echo Do you wish to flash your graphic card? echo ======================================= echo. echo 1 - stop buging me and flash the damn card echo 2 - I've changed my mind, don't flash it if errorlevel 2 goto no if errorlevel 1 goto yes goto done :yes cls atiflash -p 0 r9kpro.f2 echo. echo flashing completed goto no :no cd.. echo. echo. echo Press CTRL+ALT+DELETE to restart your computer. sad bi to sve bilo ok da to radi i kad ja zbutam komp sa win 98/me boot disketom! onda mi pocne govorit nes ala unknown command i tome slicno, dok mi u ms-dos prompt-u sve radi (osim kaj ne flasha posto se treba biti u dos-u). posto nemam pojma kaj se programiranja tice, molim pomoc ![]() |
Datum registracije: Aug 2003
Postovi: 3,193
@echo off echo Do you wish to flash your graphic card? echo ======================================= echo. echo 1 - stop buging me and flash the damn card echo 2 - I've changed my mind, don't flash it CHOICE /C:12 /N if errorlevel 2 goto no if errorlevel 1 goto yes goto no :yes cls atiflash -p 0 r9kpro.f2 echo. echo flashing completed goto no :no cd.. echo. echo. echo Press CTRL+ALT+DELETE to restart your computer.
What's inside???
Postovi: 370
nope! ne radi! .... I've changed my mind, don't flash it Bad command or file name Invalid directory i nakon toga ode na "no"... inace kad sam imao obican batch bez izbornika je sve radilo ok, napisao sam samo ati i on mi je automatski preflasho (tada sam imao samo atiflash -p 0 r9kpro.f2) i onda sam isao dodat taj izbornik i sve je otislo u qrac ![]() btw. bez izbornika sve normalno radi |
Postovi: 3,193
Treba ti choice.com program. On standardno dolazi s MSDOS-om. Postoji rjesenje za XP ali onda ti nece raditi u DOS-u ![]()
