Staro 21.01.2008., 01:01   #1
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
dobri kutevi - malo love
ASUS PW201 2080kn
TFT-LCD Panel
Panel Type: TFT LCD (Anti-Reflection Glare Panel)
Panel Size: 20.1'' Wide Screen
Max. Resolution: WSXGA+ 1680 x 1050
Pixel Pitch: 0.258mm
Brightness (Max.): 350cd/?
Contrast Ratio (Max.): 800:1
Viewing Angle (H/V): 176°/176°
Display Colors: 16.7M
Response Time: 8ms (Grey to Grey)
ZBD (Zero Bright Dot): Yes
Inputs
Digital Input: 24-Pin DVI-D
Analog Input: 15-Pin D-Sub
Video Inputs: Composite x1, S-Video x1, Component x 1
Audio Input: R/L x 1
PC lin-in: 3.5mm Mini-jack
Earphone Jack: 3.5mm Mini-jack
Feature
USB2.0 Hub:Upstream x 1, Downstream x 3
Picture in Picture (PIP)
1.3 Mega-Pixel Webcam
Colors
Silver + Black
Speakers
3W x 2 Stereo
Ergonomic Adjustment
Tilt: +90° ~ -5°
Swivel: +60° ~ -60°
Pivot: 0° / 90° (Counterclockwise)
High Adjustment: Yes
Wall Mounting(VESA Standard)
100 x 100mm
Security
Kensington Lock
Power
Power LED: Blue (ON) / Amber (Stand-By)
Voltage Rating: AC: 100~240V
Consumption (Power-On): <80W
Consumption (Stand-by): <2W
Dimension (WxHxD mm)
560 mm x 496 mm x 280 mm
Weight
Net (Esti.): 9.7 Kg
Gross (Esti.): 12.7 Kg
Accessory
VGA-Audio-USB 3 in 1 cable
DVI cable
Power adapter
Power cord
Support CD (User Manual, Pivot®Pro, LifeFrame)
RCA cable
Quick Start Guide
Warranty card (optional)
Regulation Approval
gnomisa je offline   Reply With Quote
Staro 21.01.2008., 02:33   #2
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Autor gnomisa Pregled postova
ASUS PW201 2080kn
TFT-LCD Panel
Inputs
Feature
Colors
Silver + Black
Speakers
3W x 2 Stereo
Tilt: +90° ~ -5°
Swivel: +60° ~ -60°
100 x 100mm
Security
Kensington Lock
Power
Weight
Net (Esti.): 9.7 Kg
Accessory
DVI cable
Power adapter
Power cord
RCA cable
Quick Start Guide
Regulation Approval
Ha? si ti pusio nesto il sam ja?
Staro 21.01.2008., 03:05   #3
Audi45
Audi45's Avatar
Lokacija: Slav. Brod
Postovi: 491
Jos jedan kandidat za M&D
X:: Maus, E-100, T110E5, T57 Heavy Tank, 113, AMX50B, IS4, E-50M, Leopard 1, M48 Patton, 121, G.W. E 100, T92, Obj. 261, JagdPz E-100, WT auf E100, T110E4, T110E3,
IX::IS8 VIII:: Lorr. 155 51, AC Mle 48
PREM:IS6, T34, T26E4, Pz. IV Schmalturm, T-25, Ram II, T14, Matilda BP, 105 leFH18B2, Chi-Nu Kai, T15, T2 LT, T1E6, Tetrarac, LTP, T7 Combat Car, Light MK. VIC, Type 97 Te Ke
Audi45 je offline   Reply With Quote
Staro 21.01.2008., 03:07   #4
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
vjerujem da želi preporučiti ovaj ekran, a u preporuci se i ja pridružujem i odgovorno tvrdim da je ovo najbolji 20" ekran što se kod nas danas može nać na tržištu za te novce, a dođe mizernih 2000kn
Staro 21.01.2008., 08:45   #5
Postovi: 33,927
2.000kn za 20" monitor sa Zero Bright Dot garancijom, 1.3MPix webcamom i usb hubom? Bagatela. Jedino me malo smeta činjenica da ima ugrađene zvučnike - povećavaju dimenzije monitora, a nisu od neke koristi.
Staro 21.01.2008., 10:49   #6
gnomisa
gnomisa's Avatar
Postovi: 1,556
Autor Fleks Pregled postova
ne, ti si...i ona dole no**ina iz audija....dakle dužan sam objašnjenje uz prvi post (iz nekog razloga objašnjenje uz specifikacije iz prvog posta je negdje nestalo)..već su dečki ispod napisali dio odgovora a ja dodajem da se radi o monitoru sa m-pva matricom i "pravih" 16 mil boja....za malo love...dakle ovo je trebala biti dobra preporuka..
Staro 21.01.2008., 11:05   #7
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Steta kaj nemaju tak nekaj u 22" za cca 2500kn. Ili mozda imaju pa sam ja noob :-)
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 21.01.2008., 11:44   #8
gnomisa
gnomisa's Avatar
Postovi: 1,556
Autor elvis again Pregled postova
ima asus 22" al je TN đubre....hebiga morali bumo se strpiti za 22"-ere sa boljim matricama (da, ima onaj famozni lenovo al je opet natrpana reza a ima i najgoru matricu za gamere...za šljaku super)...
Staro 21.01.2008., 12:37   #9
jurbAs
jurbAs's Avatar
Postovi: 2,583
cuj lenovo tj VA matrice nisu lose za gaimere evo ja koristim vec 1god 971p koji im S-PVA matricu i nikad u zivotu nisam vidio ghosting u igri ili tome slicno.... drugi monitori poput dell-a imaju problema sa time tj neki primjerci ne svi...
ako si mislio na nesto drugo osim na ghosting onda sorry
Staro 21.01.2008., 13:10   #10
Terminator02
Terminator02's Avatar
Postovi: 602
Prvi put čujem za ovo kod računalnog monitora ?!?
Čemu to služi??
EDIT: Da, zanimljiv monitor! Baš je šteta što nije 22" za malo više kunića
Terminator02 je offline   Reply With Quote
Staro 21.01.2008., 13:24   #11
marq20
marq20's Avatar
Postovi: 620
Autor Terminator02 Pregled postova
Čemu to služi??
da gledaš seriju i surfaš u isto vrijeme
marq20 je offline   Reply With Quote
Staro 21.01.2008., 13:38   #12
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
Autor coconut Pregled postova
da još dodam PiP, odličan aluminijski stalak podesiv kud god hoćeš,
i matricu koja je najbitnija u cijeloj priči.
stvarno odličan monitor, ima odličnu sliku.
Staro 21.01.2008., 14:27   #13
gnomisa
gnomisa's Avatar
Postovi: 1,556
Autor jurbAs Pregled postova
mislio sam na input lag koji je znao biti nešto izraženiji na xVA matricama ali opet tvoje iskustvo (i još ponekih s neta) nam govori da nije kod svih isto...btw, ak se naviknem na burazov 20" LG onda uzimam ovaj iz naslova...100%...ak se ne naviknem onda ono đubre od philipsa, dvajsdva inčno...za igre..za šljaku nedam svog CRT samija ni pod razno...bil je 5 soma kuna kad je izašao...danas tolko i koštaju "ozbiljni" LCD-i
prad review za asus pw210 + dobre fotke...
http://www.prad.de/board/thread.php?threadid=26294
Quake3 na asusu
hehe pila i pol za "šaku dukata"
Zadnje izmijenjeno od: gnomisa. 21.01.2008. u 15:11.
Staro 21.01.2008., 15:12   #14
jurbAs
jurbAs's Avatar
Postovi: 2,583
heheh isto ko ja svog samija 971p makar kupujem 24''dell-a ali sumnjam da ce dell biti toliko dobar ko moj sami jedina mana je sto kod 16:9 filmova gubim po 20cm gore dolje ostalo je sve za 10
Staro 21.01.2008., 15:28   #15
gnomisa
gnomisa's Avatar
Postovi: 1,556
aghh sad sam našao da taj Asus ima glossy panel....našao sam u jednoj recenziji i kod jednog lika sa naših newsa..dakle bilo koje svjetlo a pogotovo upaljna lampa iza = refleksija na ekranu...šteta...uvijek neko s*anje s monitorom koji valja...
@jurbas - pazi kod tog 24" della imao je onaj banding problem...potvrdili su mi u Kodeksu
ukratko:
http://gizmodo.com/gadgets/monitors/...nts-174098.php
Staro 21.01.2008., 17:31   #16
jurbAs
jurbAs's Avatar
Postovi: 2,583
cuj gledaj znam za to sad sam u dilemi izmedu della i lenova makar bi mi bila glavna primjena monitora za filmove.... cekam lenova da vidim sto ce biti .... makar planiram posjetiti mikronis i pogledat oba monitora u zivo i vidjet koji je bolji..... pa tamo presudit da vidim di ce se bolje okretat HD.ovi drugo je sporedno jedina prednost dell-a sto je 2 puta lijepsi od tog lenova.... makar mozda cak i docekam reviziju dell-a koja ce biti 1300:1 kontrast i nadam se da ce banding i ostale kerefeke popravit...
Staro 21.01.2008., 23:53   #17
Zynaps
Lokacija: dalmacija
Postovi: 39
Kakav je ovaj asus za igre i jel moze onu foru smanjena reza a ostatak ekrana crni rubovi (hebiga kad grafičke brzo zastare, pa tko će ganjat visoku rezu)?
Zynaps je offline   Reply With Quote
Staro 22.01.2008., 00:05   #18
subtex
subtex's Avatar
Postovi: 329
Ja sam sa svojim prezadovoljan . To mi je prvi LCD monitor nakon crt-a, slikom sam jako zadovoljan, a kvalitetom izrade i više nego iznenađen, monitor je dosta težak (samim tim djeluje robusnije i čvršče), stalak je najbolji koji sam dosad vidio sa velikim mogučnostima podešavanja. Sve u svemu odličan monitor
Abit AB9 Pro \\ INTEL E6300 1.86Ghz & CoolerMaster Gemini II + 2X Xsilence RedWing 120mm \\ G.E.I.L PC26400CL5 2GB \\ Sapphire 3870 TOXIC 512mb
Seagate Barracuda 320GB 16mb SATA2 + 2x WD 500Gb, 16mb,SATA2 \\ DVD-RW SAMSUNG SH-W163A SATA & LITEON SHM-165S6S SATA
LCD Asus PW201 20,1" \\ Antec P160 Aluminium \\ Enermax Liberty 500W \\ MX518 + func 1030\\ Potenciometar ZALMAN ZM-MFC1 plus, sreberni 5.25"
subtex je offline   Reply With Quote
Staro 22.01.2008., 09:53   #19
gnomisa
gnomisa's Avatar
Postovi: 1,556
Autor subtex Pregled postova
hvala za info.....kakvo je stanje sa refleksijom obzirom na glossy panel? kakav se pokazao u igrama?
btw, evo još jednog solidnog reviewa sa slikama:
http://techgage.com/article/asus_pw201_20quot_lcd/
Zadnje izmijenjeno od: gnomisa. 22.01.2008. u 10:09.
Staro 22.01.2008., 14:00   #20
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,221
preheben monitor za te pare,meni je jedino mal gluooopo što je ovaj "obrub" mal deblji pa neznam kak to izgleda uziwo...
u svakom slucaju zanimljivo...
Staro 22.01.2008., 15:07   #21
Delta S4
She`s back...
Postovi: 983
Ne znam je li netko primjetio, kod ovog filmića na kojem tip igra Q3 vidi se kako je donji dio ekrana povremeno prekriven nečim što bih opisao kao kvadratni filter koji taj do slike čini žućim od ostatka.
Slika
Je li riječ o šugavoj grafičkoj kartici, lošoj igri, ghostingu, efektu kamere ili nečemu drugome?
Delta S4 je offline   Reply With Quote
Staro 22.01.2008., 15:12   #22
gnomisa
gnomisa's Avatar
Postovi: 1,556
Autor Delta S4 Pregled postova
Slika
možda grafulja...kvadratić mijenja veličinu....ghosting je nekaj sasvim drugo...sumnjam da je monitor..
Zadnje izmijenjeno od: gnomisa. 22.01.2008. u 16:36.
Staro 22.01.2008., 16:30   #23
gnomisa
gnomisa's Avatar
Postovi: 1,556
USB hub, kamera, dizajn, m-pva matrica, 20" wide, kvalitetno kućište i postolje, štelanje po visini, pivot, 2 iljade kuna....za istu lovu ti samsung uvali chimei tn matricu...i zakelji svoj u narodu cijenjeni brand....sjajno..samo da nije
It has a glossy screen - one of the most reflective we've ever seen at PC Pro - which is both its main strength and a major weakness. It adds a beautiful spark to colourful images and the sharpness of video is stunning, but even in just a reasonably lit room you'll see as much of yourself as of the action onscreen. In less harsh lighting, however, it won't be a huge issue.
Zadnje izmijenjeno od: gnomisa. 22.01.2008. u 21:37.
Staro 23.01.2008., 12:56   #24
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
gnomisa -
ta refleksija nije uopće strašna, ja sam nekoliko večeri radio na njemu i nisam ju primijetio. sa svjetlom iza sebe,
Staro 23.01.2008., 13:28   #25
gnomisa
gnomisa's Avatar
Postovi: 1,556
Autor Gabre Pregled postova
gnomisa -
tnx Gabre, ja ionak nemam svjetlo iza (niti smijem radi TrackIR-a ) i volim se igrat (pa i radit) dok je soba dosta zamračena....kakva je situacija po danu? ionak sam po danu (zimi) na poslu ali vikendom znam i po danu biti na kompu...i to uz dosta veliki prozor....btw, refleksija postoji i na CRT-u pa pretpostavljam da nije ništa gore od toga na asusu?
Staro 23.01.2008., 13:38   #26
subtex
subtex's Avatar
Postovi: 329
Meni je prozor s bočne strane monitora, i kad je monitor upaljen nema nikakve refleksije i može se najnormalnije raditi. A ako nemate izvor svjetlosti iza monitora ne trebate se uopće brinuti. A i ne znam kaj vas tak smeta ta refleksija, pa svaki CRT minitor ju je imao, a meni je ona samo dodatan plus monitoru, jer puno ljepše izgleda. Samo dalje prstima od nje i sve pet
Btw, monitor je dimenzijama (znači širina i duljina) veći i od 22" modela, i puno ljudi se prevari misleći da je to 22" monitor, točnije svi koji su ga vidjeli su mislili da je 22"
Staro 23.01.2008., 13:57   #27
Terminator02
Postovi: 602
Autor marq20 Pregled postova
Skužia sam, hvala!
Staro 23.01.2008., 14:00   #28
gnomisa
gnomisa's Avatar
Postovi: 1,556
da to sa CRT-om sam baš i spomenuo..znači nema brige...meni je svjetlo samo iznad na plafonu i to ne iznad samog monitora već na sredini sobe...dakle nema straha...nadam se, jer monitor je odličan..
EDIT: malo sam čitao prad-ov forum vezano za taj monitor...tamo jedan lik veli da bez obzira što ima dva velika prozora kraj stola na kojem je monitor - da nema problema sa refleksijom....
evo dole još jedan review (benchmark.co.yu)....njima je bolji stari TN samy
http://www.benchmark.co.yu/modules.p...News&sid=11484
Zadnje izmijenjeno od: gnomisa. 23.01.2008. u 22:38.
Staro 23.01.2008., 22:38   #29
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
velim ti, nemoj se brinuti, nije ništa gore nego CRT,
kupi dok ga još ima po toj cijeni!
Staro 23.01.2008., 22:58   #30
Zynaps
Lokacija: dalmacija
Postovi: 39
Spominju:
Test odziva je prošao zaista dobro, kašnjenja je teško primetiti, mada su ipak prisutna.
