Staro 30.12.2007., 23:58   #1
Ghostrid3r
Postovi: 42
L3 cache i TLB
Sto su to L3 cache i TLB?
Ghostrid3r je offline   Reply With Quote
Staro 31.12.2007., 00:14   #2
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,727
Autor Ghostrid3r Pregled postova
Tvoj omiljeni pretrazivac Interneta se rastepo ko Kirin pod pritiskom?
Ako te pak zanima sto se na tu temu dogadjalo konkretno u aemdeju ovih dana, baci oko na slijedece linkove
DailyTech - Understanding AMD's "TLB" Processor Bug
"How does the TLB erratum occur? All AMD quad-core processors utilize a shared L3 cache. In instances where the software utilizes nested memory pages, this processor will experience a race condition. "
http://www.dailytech.com/Understandi...rticle9915.htm
http://techreport.com/discussions.x/13721
http://techreport.com/discussions.x/13724
http://www.digitimes.com/mobos/a20071224PD200.html
Programer
Staro 31.12.2007., 00:17   #3
Baja 001
Baja 001's Avatar
Postovi: 7,504
OK, primjetio sam da imaš puno pitanja i puno otvorenih tema!
Google Is Your Friend
L3 cache = treće razredni "keš" dosta veći i sporiji od L2 cachea koji je isto dosta sporiji i veći od L1 cachea.
Translation Lookaside Buffer (TLB) is a CPU cache that is used by memory management hardware to improve the speed of virtual address translation. All current desktop and server processors (such as x86) use a TLB. A TLB has a fixed number of slots containing page table entries, which map virtual addresses onto physical addresses. It is typically a content-addressable memory (CAM), in which the search key is the virtual address and the search result is a physical address. If the requested address is present in the TLB, the CAM search yields a match very quickly, after which the physical address can be used to access memory. If the requested address is not in the TLB, the translation proceeds using the page table, which is slower to access. Furthermore, the translation takes significantly longer if the translation tables are swapped out into secondary storage, which a few systems allow.
ostatak članka
Staro 31.12.2007., 13:27   #4
Ghostrid3r
Postovi: 42
hvala
