Staro 24.10.2007., 22:28   #181
Z-man
Z-man's Avatar
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
O Ganci pa i ti si tu, pozz
Vidimo se onda na vasem serveru.......... btw. ja sam cK^No.12^
Z-man je offline   Reply With Quote
Staro 27.10.2007., 12:11   #182
FlowMaster
FlowMaster's Avatar
Postovi: 232
Autor Z-man Pregled postova
daj si malo bolje podesite server...
tj. updejtajte si CVAR i MD5 chekove...
kicka me zbog rednering device a to je stari AASA chek ako se ne varam...
FlowMaster je offline   Reply With Quote
Staro 28.10.2007., 16:45   #183
supertovar
supertovar's Avatar
Postovi: 56
Možete li mi savjetovat da ne skidam bezveze najnoviji Americas Army...ako ne mogu vrtit na mom računalu, ako može hitan odgovor hvala!!!
Sadašnje requirments su:
The current Recommended System Requirements for AA:SF (Overmatch) are as follows:
  • 3-D graphics card with 256 MB memory and support for hardware transformation and lighting
  • 3.0 GHz processor or equivalent
  • English version of Windows(r) 2000/XP Operating System with all updates
  • 1 GB RAM
  • 3.5GB of uncompressed hard disk space for game files
  • 4X DVD-ROM (not required for downloaded installation)
  • Windows 2000/XP compatible system (including compatible 32-bit drivers for CD-ROM drive, video card, sound card, mouse and keyboard)
  • DirectX(r) 9.0
  • 100% Compatible DirectX 9.0 soundcard
  • Broadband Network Connection
  • Nvidia nForce? or other motherboard/soundcards containing Dolby Digital Content Encoder required for Dolby Digital audio.
A ja imam:
Processor
Model : AMD Athlon(tm) XP 2600+
Speed : 1.92GHz
Model Number : 2600 (estimated)
Performance Rating : PR2848 (estimated)
Cores per Processor : 1 Unit(s)
Threads per Core : 1 Unit(s)
Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size
L2 On-board Cache : 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size
Mainboard
Bus(es) : ISA AGP PCI USB FireWire/1394 i2c/SMBus
MP Support : No
MP APIC : No
System BIOS : Phoenix Technologies, LTD 6.00 PG
Mainboard : nVidia-nForce
Total Memory : 1.5GB DDR-SDRAM
Chipset 1
Model : Nvidia Corp nForce2 AGP Controller
Front Side Bus Speed : 2x 167MHz (334MHz data rate)
Memory Bus Speed : 2x 167MHz (334MHz data rate)
Video System
Monitor/Panel : Plug and Play Monitor
Adapter : ATI Radeon 9600 / X1050 Series
Adapter : ATI Radeon 9600 / X1050 Series Secondary
Imaging Device : Logitech QuickCam Messenger
Physical Storage Devices
Removable Drive : Floppy disk drive
Hard Disk : Maxtor 6L160P0 (153GB)
Hard Disk : Maxtor 6Y160P0 (153GB)
Hard Disk : ST3802110A (75GB)
Hard Disk : M600i USB Device
Hard Disk : USB Flash Memory USB Device
Hard Disk : Maxtor 6 Y080L0 USB Device
Hard Disk : Sony Eri Memory Stick USB Device
CD-ROM/DVD : PIONEER DVD-RW DVR-111D (CD 63X Rd, 8X Wr) (DVD 8X Rd, 1X Wr)
CD-ROM/DVD : KB3323I MDM317G SCSI CdRom Device (CD 32X Rd) (DVD 4X Rd)
MultiMedia Device(s)
Device : NVIDIA(R) nForce(TM) MIDI UART
Device : Standard Game Port
Device : Realtek AC'97 Audio
Device : NVIDIA(R) nForce(TM) MCP Audio Processing Unit
supertovar je offline   Reply With Quote
Staro 28.10.2007., 20:11   #184
Z-man
Z-man's Avatar
Postovi: 1,079
@ganci, primjetio sam da kika ljude zbog toga, budem se baš čuo sa glavnim adminom za srver (S@ky-em) pa če on to riješit i vidjet.....javim ti situaciju...
@supertovar - radit če, ali u nekih 30-40 fps-a, možd malo više (kako u kojoj sitaciji i mapi)
- procesor če te malo kočit ali probaj.......
Inače, ja sma novi komp kupio samo zbog AA-a
Staro 28.10.2007., 20:25   #185
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Ono..ja prasim samo BORDER, nekad sam samo Moutmckenu...
NIck: NEF-kljaja_CRO_ hehe
POZZ
Staro 28.10.2007., 21:07   #186
radoznalko
Lokacija: dubrovnik
Postovi: 289
Autor supertovar Pregled postova
  • 1 GB RAM
  • DirectX(r) 9.0
A ja imam:
Processor
Speed : 1.92GHz
Mainboard
MP Support : No
MP APIC : No
Chipset 1
Video System
ja sam do prije neki dan imao sličnu konfiguraciju kao i ti..
imao sam bartona 2500+. nforce 2 matičnu, gigu rama i nvidiu 6600..
mogao sam igrati sasvim solidno..
igrao sam na rezoluciji 1024x768 i postavke normal (isključi sjene, lightning i neke gluposti)
tvoja grafička je malo slabija od moje bivše no ja sam igrao i sa 9200 ati (prije ove) a znam da i danas neki ljudi igraju na 9600..
jedini problem biti će ti možda najnovije mape koje su dosta zahtjevnije
a americas army se sastoji ja mislim od jedno 50-60 mapa ako ne i više..
moj savjet ti je da provaš u nekoga posuditi dvd americas army-a ako ima već snimljeno u compu..
pozdrav
radoznalko je offline   Reply With Quote
Staro 28.10.2007., 23:33   #187
supertovar
supertovar's Avatar
Postovi: 56
Hvala na odgovoru radoznalko i ostali, probat cu pa sto bude ...ja sam ==JUBA== zadnji put sam igrao 2005 imam 46 honor
Staro 29.10.2007., 12:32   #188
radoznalko
Lokacija: dubrovnik
Postovi: 289
ja imam 96 honor..igram aa već jedno 3-4 godine
ratni vojni invalid sam, neradim, pa onda tako ubijam vrijeme uz protivnike te liječim posttraumatski
omiljene mape su mi...dusk, pipeline, urban assault, sf courtyard, od novijih old town i rummage..
Staro 29.10.2007., 21:08   #189
Newmie
Postovi: 1,389
Autor radoznalko Pregled postova
daj javi nick pa da se nađemo na pipelinu jednom...
Newmie je online   Reply With Quote
Staro 30.10.2007., 21:10   #190
supertovar
supertovar's Avatar
Postovi: 56
Di mogu skinut ovu igricu na njihovom oficijelno ima milijun linkova ali svi se placaju po apr dolara da se skine to sve...ima neko aternativu, direct link, torrent, isl...sve dobrodoslo samo da je brzo i free...
Staro 30.10.2007., 22:03   #191
Newmie
Postovi: 1,389
Staro 30.10.2007., 22:39   #192
supertovar
supertovar's Avatar
Postovi: 56
Hvala, hocu ako uspijem, ne znam je li dobar procesor za ovako nesto...a i nadam se da je u Urban Assult omgucen izbor SF oruzja, znam da kad sam igrao prije par godina bilo zabranjeno, a mozda i uzmem novi pc ako mi se dopadne jer sam inace jako lud bio za ovom igrom cak sam jednom u komadu oderao 30 sati igranja...
Staro 30.10.2007., 22:45   #193
Pezzaa
Pezzaa's Avatar
Lokacija: TZ
Postovi: 296
Igram I ja... ehehhehe MorBid_DeSire-.... vecinom SF Hospital i CSAR ej remix team ja sam ti jaran s Terzzom....
Pezzaa je offline   Reply With Quote
Staro 30.10.2007., 22:48   #194
Newmie
Postovi: 1,389
Autor Pezzaa Pregled postova
ah terzza, to je legenda! pozdravi ga ako ga ja ne vidim prije
Staro 31.10.2007., 22:48   #195
FlowMaster
FlowMaster's Avatar
Postovi: 232
Čast se vratila
Za sve vas koji niste primjetili, nas novi server je postao honor. Dakle imamo 26 slotni honor server sa lokacijom u Hrvatskoj i radi odlicno. Nisam siguran, ali mislim da je to trenutno jedini honor server u Hrvatskoj ( ako sam pogrijesio slobodno me ispravite)
Svi vi koji citate vijesti na ovim stranicama ste pozvani na napucavanje na serveru bez laga i malim pingom, i ono sto je najbolje, bez adolescentnih admina i bezrazloznog kikanja. Evo, cak i LuDi su dobrodosli
Server mozete pronaci na adresi 193.198.109.29:1716
Takodjer, mozda malo preuranjeno, ali svejedno lijepo je za znati, pripremite se na jos ugodnih iznenadjenja iz Trokyjeve radionice. O kakvim iznenadjenjima se radi vrlo skoro cete doznati.
isprike
BRUTAL ima honor server u HR... aa.iskon.hr:6666 ako se ne varam
sve to i jos vise na www.ri051.com
Staro 31.10.2007., 23:35   #196
supertovar
supertovar's Avatar
Postovi: 56
Molim da mi netko napiše što moram da isključim a da imam najbolje performanse a opet da mogu igrat normalno...hvala
Koja reza itd...
Staro 01.11.2007., 11:36   #197
FlowMaster
FlowMaster's Avatar
Postovi: 232
Koja reza itd...
narafno to sve ovisi o tvojoj konfiguraciji...
Staro 01.11.2007., 16:48   #198
supertovar
supertovar's Avatar
Postovi: 56
Autor FlowMaster Pregled postova
Pa piše gore
Može li netko reć zašto mi se igra nakon 30 min igranja cca (nekad manje nekad više) ugasi odjednom i cijeli PC, odjednom zapiči na shut down a isključio sam sve živo i neživo???
Staro 01.11.2007., 17:00   #199
FlowMaster
FlowMaster's Avatar
Postovi: 232
Pa piše gore
Texture Detail: LOWEST.
Character Detail: HIGHEST.
World Detail: LOW.
Physics Detail: LOW.
Dynamic Mesh LOD: HIGHEST.
Decal Stay: High.
Character Shadows: None.
Decals: ON.
Dynamic Lighting: ON.
Detail Textures: OFF (ON if you have powerful pc *64bit minimum).
Trilinear Filtering: ON (unless you have old card).
Projectors: ON
VSYNC: OFF (unless you use info in armyops.ini tweaks below).
Note having these video settings will allow you to see enemies better outdoors.
The higher player detail set up with the lower world detail makes the player stick out like a sore thumb.
Also makes you able to see through fog easier and makes your night vision clearer.
a to sto ti se sve pogasi i zblesira, mislim da je problem u memoriji iliti preopterecenju sistema...
nemoram niti spominjat da pogasis sve AV programe koje imas, isto kao i messenger i sve tome slicno dok igras
Staro 01.11.2007., 17:24   #200
radoznalko
Lokacija: dubrovnik
Postovi: 289
Koja reza itd...
evo ti link pa prouči..nadam se da znaš engleski bar malo
http://www.tweakguides.com/AASF_1.html
Staro 01.11.2007., 17:30   #201
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Porucit cu to No.3. Iako je sve jos u podesavanjima.
Staro 15.12.2007., 12:47   #202
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
da malo dignemo temu medju "žive"
evo bliže se praznici, vljda medju svim tim pijakama bude i nekog mjesta za neki okršaj u AA.
pisiekspertovci ajmo se dogovorit za neko match
none
Staro 15.12.2007., 12:50   #203
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Ja sam za...
Vracam se aktivnom igranju sad kad dobijem 8800GT XFS Alpha Dog... Inace, trenutno sam cK^IceMan^ .
Staro 15.12.2007., 12:59   #204
FERRYS
FERRYS's Avatar
Postovi: 2,159
Autor Ice Demon Pregled postova
Ja sam za...
čoviječe pa ti mijenjaš te klanove ko žvakaće gume.....
aaa 8800gt se čeka, onda bu to letilo
none
Staro 15.12.2007., 13:11   #205
Pezzaa
Pezzaa's Avatar
Lokacija: TZ
Postovi: 296
evo i ja sam za igru.... hihihihi ja sam rekreativac ali nema vezze.... MorBid_DeSire
Staro 15.12.2007., 13:15   #206
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor FERRYS Pregled postova
A sta cu...
Ocito negativno utjecem na njih. Kud god dodjem, klan se raspadne.
Staro 15.12.2007., 13:36   #207
bruno_x
bruno_x's Avatar
Lokacija: split
Postovi: 240
huuaaaa
daj jel ko zna kako proc onaj test za padobrance?
i tribaju mi šalabahteri za bolnicara.....
bruno_x je offline   Reply With Quote
Staro 15.12.2007., 16:48   #208
Newmie
Postovi: 1,389
Evo rješenja za bolničara:
Airway management: A, A, A, C, C, B, A, B, D, B, A, E, A, C, C, A, A, D
Control bleeding: B, B, A, B, C, D, A, C
Treat shock: B, D, B, C, B, B, B
Staro 15.12.2007., 17:19   #209
Arthas
Arthas's Avatar
Postovi: 374
Autor Newmie Pregled postova
to si mu trebao dati na PM, to je za citere hehe
btw, ja sam konstantno na Borderu, pa se mozda vidimo tamo, [MN]_--=firefly=--
1) P4 Prescott 3.0 on Abit IC-7 MAX3 with 2GB DDR400 ST
2) P4 Northwood 2.6 on PX865PEC Pro v2.0 with 1GB DDR400
3) HP Compaq nx6125 with 1256MB DDR333
4) AMD Athlon 950Mhz on MSI K7T Turbo2 with 768MB SDRAM
5) PIII 600E on Procomp BVC2B with 384MB PC100 Win98
6) PIII Celeron 1300 on Asus TUEP2-M with 384MB PC100 Linux
Arthas je offline   Reply With Quote
Staro 15.12.2007., 17:24   #210
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Evo, rezervirana 8800GT POV.
