#271 |
Premium moderator
Postovi: 4,600
Mislim da više neće biti pojeftinjenja tako skoro.
__________________ |
#273 |
Postovi: 7,568
26.8 budu predstavili i pustili u prodaju E2180 i E4600, pa se onda malo poravnaju cijene modelima (koji budu još dobavljivi) ispod i to je to. |
#274 |
Postovi: 12,433
jesu što pričali za Celerona 460? vidim nigdi ga nema a znam da postoji jer sam ga imo u rukama (iako inžinjerac ali ipak....)
#275 |
Postovi: 7,568
Ama baš ništ. Ja sam za taj procesor prvi put čul ono kad si ga ti imal i testiral. Posle toga ni traga ni glasa, samo se spominju 420, 430 i 440. |
#278 |
Postovi: 7,568
Asus i Gigabyte X38 ploče
Asus P5E3 Deluxe Asus is finalizing its X38 Express based motherboard for shipping early next month. The upcoming P5E3 Deluxe supports all LGA775 socket processors, including the upcoming Penryns. The board only accepts DDR3 memory. Asus opted to implement two PCIe x16 slots for ATi CrossFire multi-GPU support. Unlike some other X38 Express based boards with three PCIe x16 slots, the Asus P5E3 Deluxe is unable to take advantage of three-way or even four-way ATi CrossFire configurations. Expect the Asus P5E3 Deluxe to show up in retail next month. Gigabyte GA-5BXWV-RH Based on Intel’s X38 (Bearlake-X) chipset, Gigabyte GA-5BXWV-RH is designed for single processor based platform in entry level, general purpose workstation, especially for small/middle level business user, graphic editing service, engineering 3D graphic processing, and advanced workstation user or game player. It features one PCIe x16 slot for advanced high-performance visualization, and 4 PCI slots for legacy PCI devices such as sound cards. Note that Gigabyte GA-5BXWV-RH is an inexpensive solution. It cannot boast any sophisticated chipset cooling systems onboard and is equipped with a four-phase processor voltage regulator. Izvor: DailyTech i X-Bit Labs |
#279 |
Rambus 3xtr1m
Postovi: 2,694
![]() Evo usporedbe wolfdale i c2d u koliko ga nadjačava http://images.anandtech.com/reviews/.../wolfvscon.png Zadnje izmijenjeno od: Mortal. 21.08.2007. u 20:36. |
#281 |
Lokacija: n/a
Postovi: 6,128
Ni meni. Ali se vidi da se moze na anand-u nac ![]() http://www.anandtech.com/cpuchipsets...oc.aspx?i=3069 |
#283 |
Postovi: 7,568
E2180 je na Ve-milovom cjeniku 693 kn, ostali budu valjda uskoro slijedili. E4600 još ni traga ni glasa. |
#285 |
I Love AMD and nVida
Datum registracije: Feb 2003
Postovi: 410
Intel CoreDuo neki Quad IGIGABYTE GA-P35-DS3L 4x2048 Corsair Ati nešto 1x 36Gb WD Raptor, 2x750Gb Samsung (raid 0) |
#286 |
Postovi: 7,568
Intel DX38BT "BoneTrail" ploča
Intel X38 is around the corner and over at Chinese hardware forum Chiphell they've published pictures of a late samples of an Intel X38 reference board. As with most Intel reference boards there are no heatpipes, just huge gray fins and heatsinks, not to mention the black PCB and blue PCIe x16 ports. Nothing fancy, which makes it even more appealing in the opinion of yours truly. The solid state voltage regulators are all cooled by two big heatsinks and unlike some other motherboards we've run into recently, Intel has managed to place the 8-pin ATX power connector really well in the upper left corner of the board, with the 24-pin ATX power connector close to the right side of the board. Intel X38 sports PCI Express 2.0, dual PCIe x16 slots and overclocking potential like no other board seen up till today, or so the story goes. Izvor: NordicHardware |
#287 |
Lokacija: Varaždin/Zagreb
Postovi: 1,846
čekam da se je dočepaju ovi na XS-u...pa da padnu prvi reviewi. da vidimo kaj zapravo nudi taj X38. onda ćemo odlučiti hoće li BT zamijeniti BX2 ![]() inače jako dobar layout ima... |
#288 | |
Postovi: 7,568
Penryna i memoriju nabavim od Toscanini podružnice i Photoshop igre mogu početi. ![]() Šalu na stranu, čini se ko čist pristojna ploča, dostojna da preuzme štafetu. Još se gore udomi neki procesorček (na defaultu ) i kaj će ti više. |
#290 |
Postovi: 7,568
Nema potrebe, procesori se tak i tak prilikom kupnje biraju oko 2.0GHz, ali grafičke su zayebana stvar. Nabiju te taktove ko da nema sutra, pa se ti onda snalazi. ![]() EDIT: Ma kak ne bu. Pa su Penryna prvi put za IT novinare, druga Valića i spam po inboxu, spasali na tvoju ploču. BIOS i par žičica su sredili i odma je po cijelom netu bilo kak Intel ima 45nm procesor. Ja bum ih lepo zamolil da i meni srede ploču i to je to. ![]() |
#291 | |
Postovi: 1,846
![]() ![]() bumo vidli...proc ionak nebum mijenjal...e6300 mi je i previše ah...a i ko je lud da kupuje DDR3 memu za bonetrail sad ![]() |
#292 |
Postovi: 1,846
Prvi review ES-a Gigabyteove GA-X38-DQ6 ploče: It is hard to find any faults with the X38 chipset at this time. Even though we are working with an engineering sample that has been around the block a few times and an early engineering BIOS that is designed more for debugging the chipset than providing top performance, it still manages to outperform a fairly mature P35 equipped motherboard that offers excellent performance in its own right. Izvor: Anandtech Zadnje izmijenjeno od: Ph03n1x. 04.09.2007. u 21:22. Razlog: Gigabyte GA-X38-DQ6 ES review |
#293 |
Extreme Air Cooler
Datum registracije: Sep 2004
Lokacija: Kastav & Rijeka
Postovi: 491
---= The eternal mistake of mankind is to set up an attainable ideal =--- |
#294 | |
Lokacija: rijeka
Postovi: 3,884
to samo meni slike ne otvara ili ih nema?? s ananteha,starnica 3 memory test,čini se da ostale rade,nema veze nego do kolko se može više ili manje nasvirati fsb u odnosu na p35-dq6??na p35-dq6 je oko 520 top.Zadnje izmijenjeno od: demetrius. 11.09.2007. u 21:05. |
#295 | |
Lokacija: Međimurje
Postovi: 175
evo i reviewa "sestre" Gigabyte GA-X38T-DQ6... http://www.bit-tech.net/hardware/200...nd_intel_x38/2 |
#296 |
Extreme Air Cooler
Postovi: 491
#297 |
teta Mraz
Lokacija: hr
Postovi: 1,596
nije mi jasno, jel toj ploci nesto fali ili??? ja pored svoje p35-dq6 i ne pomisljam na bolju, jer znam da bi mi isto radila svaka, kad malo bolje razmislim trebo sam uzet ds3...al dobro tvoj izbor, ja osobno za tu premium nebi dao ni kolko sam dao za dq6, a p35 cipset sljaka odlicno i ne vidim razlog prelaska na bolji, za sada...
#298 | |
Extreme Air Cooler
Postovi: 491
![]() Nikad nisam potpuno zadovoljan trenutnim, te uvijek tezim ka boljem, i ako imam love, to si nastojim i priustiti. Kuzim ja da ce netko biti zadovoljan istom opremom i performansama na neko neodredjeno vrijeme (nekom duze, nekom krace), i nema tu nista lose. A onda, kad malo zagrebes ispod te nepregledne mase mediokriteta, nalazis malobrojne, ali opsjednute frikove koji trose nemile pare u svoje hobije, i nalaze zadovoljstinu samo u vrhunskim rezultatima. Odnos ovih prvih i drugih je, gle slucajnosti, svemirski univerzalnih 98:2 %. Gosp. Nietzscheu, Kantu i Einsteinu se sada vjerojatno stuca... Dosta van-topika, ajmo komentirat cijene i perf. CPUa i chipseta.
#300 |
Postovi: 7,568
Videl si cijene Wolfdale i Harpertown serverskih primjeraka, tak da od toga i nemaš neke velike koristi. Osim ako ne planiraš kupiti Tyan ploču i sprijateljiti ju s dva (ili više) quad izdanja za popodnevnu šetnju kroz Photoshop. Kaj se tiče desktop područja, navodno bude 45nm Yorkfield na 3.33GHz u ekstremnom izdanju koštal kojih $1.000. Ostalo bude valjda procurilo na net u predstojećim tjednima, tj. kak bude se službeno predstavljanje bližilo. Teško da bu cijena Q6600 pala, prije budu procesori nestali s tržišta. Slično kak je i E6600 nestal s dolaskom E6050 serije, a cijena (bar na web-cjenicima) mu je još paprena. |
