KLOhNing xprt
Lokacija: Gama stvarnost
Postovi: 63
Jel vridi ova konfiguracija
Napravia san konfiguraciju do 7.000 Kn. Slobodno recite sta ne valja! -procesor AMD Athlon XP 2800+ Thoroughbred 2.083 GHz, socket 462, 333 MHz FSB, BARTON CORE -Hladnjak Thermaltake Volcano 7+ - A1254 CPU cooler za Socket 462 -Memorija Infineon Samsung 512 MB DDR PC3200, 400 MHz -Matična ploča Sapphire K600ASA-A28 SL VIA KT600/8237 chipset, 266/333/400MHz FSB (up to Athlon XP 3200+), DDR-400 x 3, 5PCI, 1 AGP 8x, 6 channel audio, LAN, 8x USB2.0, S-ATA, H/W mon, ATX -Hard disk Seagate 80GB Barracuda S-ATA V, ST380013AS, 7200 RPM, Serial ATA, 8 MB -Floppy NEC FD1231H 3.5" 1.44 MB, black -CD recorder LG GCE-8520B 52x CD/24xCD-RW/52x CD-R, IDE, interni, black, bulk -DVD-ROM Samsung SD-616 TEBB 16x DVD/48x CD, ATAPI, black, bulk -Grafička kartica Sapphire Radeon 9600 XT 128Mb DDR AGP VGA / TVO / DVI-I, TSOP memory, 500/290 MHZ, retail -Creative Sound Blaster SBS250 Zvučnici 2x2,5W RMS, Black -Modem US Robotics interni 56k V.90 fax-modem, interni, PCI -Monitor Samsung 753DFX 17", FLAT, 0.20D/P, H(30-70kHz), V(50-160Hz), P(110MHz), 1280x1024@65Hz, 1024x768@85Hz Black -Kućište Logic Master III LU-Black middle tower, 400W, 4 x 5,25", 5 x 3,5”, USB, Black! -Tipkovnica Key Tronic KT-1000 Black PS/2 -Mis Logitech M-B58 Wheel Mouse Optical 2 tipke, scroll, USB & PS/2 (black) |
crnjo
Postovi: 1,907
Re: Jel vridi ova konfiguracija
IMHO: Stavi Bartona 2500+ na Abit NF7-S plocu, cijena je cini mi se podjednaka u totalu, a ionako ces ga moc clockat bez po frke i gubitka stabilnosti. Mozes jos ustedit na ploci ako uzmes Epox 8RDA+ ili recimo Soltek 75FRN2 u toj klasi... Cak bi i memoriju mogo 2x256 KingMAX SuperRAMa na 433 mhz, super osnova za clockanje, a cijena u par kuna razlike ako se ne varam... Floppy izbaci osim ako ti stvarno ne treba... Ovo ostalo je sve oke, iako ako imas sta vise love, uzmi 17" Samsung NF varijantu ili LG700P, koji vrte 1280x1024x85 Hz. Kuciste OBAVEZNO s bocnim ventilatorom, to ce ti spasit dusu ako budes overclockao, i radije uzmi crap kuciste sa dobrim napajanjem nego neko "gotovo" za 250 kn...
9900K-32GB-5TB-3060TI |
Datum registracije: Sep 2002
Postovi: 2,721
svakako bi trebao uzeti Abit nForce2 ploču ili Epox 8rda+ i 2/256 kinmax DDR433 RAM-a. Ako kupuješ sve u jednom dućanu, nemoj. Rađe kupi na više mjesta, pa ako ne znaš sam, nađi nekog ko će ti to složit. Ostavi floppy, to uvijek treba. I ako ti nije bad dat 300 kuna za cooler, kupi Thermalright pasivnjaka i papst 19 ili 24db vent. Puno bolje od Vulcana. PS Jel to kupuješ u Autronicu? Pitam jer me zanima jesu li oni jedini u ZG-u (ili Hrv) koji prodaju Logic kućišta? |
Postovi: 1,610
Stavi bolji cooler i miša s više tipki (dušu dale za surfanje netom)
Kirk: "Spock, you want to know something? Everybody's Human." Spock: "I find that remark... insulting." |
#5 | |
Night shift
Datum registracije: Jul 2002
Postovi: 884
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again." --uoɥʇʎd ʎʇuoɯ-- |
Feldwebel
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
Tek se rijetko u tvojoj konfiguraciji može naći nešto što vrijedi. Užasno je složena. Ajde što su komponente loš izbog ali i međusobno nisu na istoj razini. Za 7000 kn se može složiti puno bolji stroj.
Tih kao mačka Brz kao gepard Jak kao lav Elegantan kao leopard Nisam to ja, to je moj komp. |
KLOhNing xprt
Postovi: 63
Evo napravia san iz 3 tvrtke za 7.250 Kn! Sta kazete na ovu: -Matična ploča Abit NF7-S nVidia nForce2 Ultra 400, AGP 8x, 400MHz, SATA-R/ATA133, Sound SoundStorm 5.1 + LAN 10/100 + Firewire o/b, 3x184pin DC DDR 400, USB 2.0 847,64 kn -procesor AMD Athlon XP 2800+ 2.083 GHz, L1 128kB, L2 cache 512kB, socket 462 (SOCKET A), 333 MHz FSB, BARTON 1.045,42 kn -Cooler Thermaltake TR2 Series TR2-M3 za AMD Duron, Thunderbird i Athlon XP (socket A), 2500 okr/min, up to AMD XP3400+, 21dBA (Super Silent) 141,27 kn -Memorija KingMax 2x256mb DDR 256 MB 184 pin, 400MHz, SuperRAM, 604,12 kn -modem Fax modem interni (software) 56k V.90 SVD PCI Conexant (Rockwell) PRO-NETS /HPI56SP II 56,51 kn -Graficka kartica ATI (original) Radeon 9700 128MB DDR, TV-out, DVI-out, AGP 8x, bulk 1.571,24 kn -Hard disk Seagate 80GB Barracuda S-ATA V, ST380013AS, 7200 RPM, Serial ATA, 8 MB 639,00 kn -Floppy NEC FD1231H 3.5" 1.44 MB, black 57,00 kn -DVD-ROM Samsung SD-616 TEBB 16x DVD/48x CD, ATAPI, black, bulk 257,00 kn -CD-RW Sony CD pisač 52x 32x 52x SONY, bulk, crni 315,00 kn -multimedia Creative Sound Blaster SBS250 Zvučnici 2x2,5W RMS, Black 128,00 kn -Monitor Samsung 753DFX 17", FLAT, 0.20D/P, H(30-70kHz), V(50-160Hz), P(110MHz), 1280x1024@65Hz, 1024x768@85Hz SilverBlack 1.099,00kn -Kućište Logic Master III LU-Black middle tower, 400W, 4 x 5,25", 5 x 3,5”, USB, Black! 268,00 kn -Tipkovnica Key Tronic KT-1000 Black PS/2 109,00 kn -Miš Logitech M-B58 Wheel Mouse Optical 2 tipke, scroll, USB & PS/2 (black) 98,00 kn P.S. Nebavim se OverClockom pa uzmite to u obzir. |
Datum registracije: Apr 2003
Postovi: 4,085
-Uzmi neko kućište sa poštenim napajanjem (Chieftec, AOpen...) -Bježi od ThermalTake-a (imao V9, više ga nemam, imao SmartCaseFanove, više ih nemam... naučio sam cijeniti tišinu). Thermalright SK7+neki tihi vent -Proc slobodno uzmi 2500+ i klokni ga ( da, znam da se ne baviš klokanjem, ali svejedno ga klokni kad možeš) na 3200+ postavljanjem FSB-a na 200 -Uzmi SuperRAM 433, 400 je lošija serija. Malo je skuplji, ali puno bolji. - monitor je ajd, sjedi, dovoljan, ali ga sebi ne bi kupio. Na monitoru se ne isplati štedjeti. -uzmi MX500 mišonju, znam što pričam. Eto, toliko |
KLOhNing xprt
Postovi: 63
Stvar je u tome da ne kupijem ja nego smo ja i prijatelj slagali konfiguraciju za njegovu curu kod koje ce on igrati! Da ga ja uzimam ucinija bi isto ovo sta si mi reka! P.S. Uzimacu i ja novi za 3-4 miseca pa se javljam opet ode! |
Headbangig Grunf!
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Zemi si ABIt NF7-Sl jer je jeftinija a razlika je jedino u S-ATA adapteru koji tak i tak nicem ne sluzi. SB ti ne treba jer ploca ima Soundstorm Proc Barton 2500+ Napajanje Chieftec 360W DVD si Zemi Hitachi je rje Samsung glasan kad vrti DVD ko da turiras auto i to ide na nerve. Memoriju KIngmaxSuperram 433 u Ve-milu 260kn Monitor pa sad s usparinim novcima si radje uzmi 755 MB ili 757 NF
Porsche 6cyl.boxer se hladi zrakom komp se hladi vodom! Chairman of G.M.S. , Heavy Metal Thunder!Former member of PCE 100+kg demolition squad Grunf je moj idol! Moji Grunf type modovi NB:Mini Monster NB,VGA:Ye Monster C!, Ye Monster D!,Abit NB:Abit mini Monster,PSU:Ultra Monster! ![]() Alfisti site, Alfisti forum |
#11 | |
KLOhNing xprt
Postovi: 63
SB su zvucnici malo bolje gledaj. Da memorija nije 310kn |
Feldwebel
Lokacija: bolnica
Postovi: 3,739
Kak to sada ljepše zgleda. Cooler - sve osim TT-a Pogledaj što drugi kažu Proc - Barton Monitor - 755 DFX Modem - nađi rabljeni externi za kikiriki novce DVD - Pioneer CD-RW - Sve samo ne to Onda će to biti dobro. Mislim da nismo puno digli cijenu. Znali smo biti i gori.
#13 | |
Headbangig Grunf!
Postovi: 4,373
KLOhNing xprt
Postovi: 63
Lik kaze da klokiranje ne dolazi u obzir bez obzira jel mu se isplati ili ne. Zanima ga jel mu vride komponente bez obzira na buku i brzinu i zagrijavanje samo ga zanima jel stvaraju probleme. Sta se tice memorije, zasto 433 ako mu maticna to ne podrzava, prckanje po biosu ne dolazi u OBZIR! Ne namjerava izvodit nikakve perverzije sa strojom. |
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,473
a dobro ako neće prčkat po biosu, iako bi puuuno dobio... onda možeš i slabiji ram... |
#16 | |
Night shift
Postovi: 884
#17 |
Headbangig Grunf!
Postovi: 4,373
Ak će sve držat na Default ond se ne isplati zet DDR 400 jer moraš vrtit asinkrono da bi bio na 400Mhz, a to je loše jer je sporo u tri čoška. Bolje uzeti recimo Infineon 333 RAM to je kvalitetna memorija. Ja sam imao Infineon 266 i stvarno nemam niš za reć protiv nje osim kaj nije za OC, al to u ovom slučaju nije bitno. Abitova ploča NF7-SL s nF2 je bolja od bilo koje VIA-e Kingmax 400Mhz je loša memorija i treba uzet ili Infineon 333 ( jer je brža ak se vrti sinkrono s procesorom) ili pak Kingmaxa 433 Barton 2800+ je OK Cooler:; ja imam frenda koji je isto to brijao:znači Buka nije Faktor sad mi se žali da mu cooler ide na živce jer zuji ko lud. Dakle poanta je uzeti neki cooler koji hladi OK a nije bučan u tri čoškađ Spire Whisperrock, Falconrock, GlacialTech Igloo, Coolermaster Aero7+, nema smisla davat preko 300KN za cooler u ovom slučaju. 755DFX je Ok iako ja preferiram MB zbog Magicbrighta DVD nemoj uzet Samsung jer kao što sam već rekao pri čitanju DVD-a je Bučan, HItachi je tih Pioneer je isto OK Pržilica Samsung je meni OK, LG, LiteON( uvjetno), nemoj Sony je rniš nevaljaju!
#18 |
Postovi: 4,085
Preporuka mu je da uzme Playstation (1, ne 2) kad ne želi prčkat niš po BIOS-u i hoće se igrati. Uzima neke komponente koje su vrhunski klokeri ( Barton) i uparuje ih sa napola šrot memorijom, hoće brzi SATA disk(koji usput samo TEORETSKI radi na 150, dakle samo u laboratoriju i u burstu), a zašto, da bi ostatak kompa bio brži, a on ga ne želi podesiti u BIOS-u!?!?:confused: Matična mu podržava i daleko brže memorije, samo to on ne zna. Ali štedi na monitoru, napajanju... ali glavno da ima Barta na 2800+...kojeg ne želi klokati, ali hoće brz komp...i još ubacuje TT kao cooler...KATASTROFA... edit: sad vidim da me Raven pretekao. Poslušaj ga, dobro govori. |
#19 | |
Administrator
Lokacija: Sesvete
Postovi: 15,964
Ma nek kupi PSX kao što Sky reče ![]() |
#20 |
KLOhNing xprt
Postovi: 63
Pa sta niste procitali da kompjuter kupuje cura od prijatelja! Ne mozemo mi sad njoj i njenim roditeljima prckat po PC i govorit joj da zbog toga i toga uzima skuplje napajanje, coolere itd. Vi clockiranjem ste uvik uz PC, a tip ne moze doci u cure i clockirati ga i onda ga ostaviti da se sprzi. Zato smo rekli da Clockiranje ne dolazi u obzir. Ali necemo vise o tome samo jos neka pitanja: Koja je razlika izmedu Kingmax SuperRam i Kingmax obicne memorije i koja je bolja za default postavke? I kakav je Plextorov DVDrom? |
#21 |
Headbangig Grunf!
Postovi: 4,373
Kingmax superram 433 je bolji od 400, i na defultu je brži od 400 i s njime nema problema s 400MHz verzijom je bilo porblema. Ali pošto će sve bit na default nema smisla kupovat 433 MHz RAM koji će radit asinkrono a s time i sporije od 333Mhz verzije zato uzet Infienon ili Samsung 333Mhz Gle napajanje bi svakako uzeo Chieftec jer je kvalitetno a nije toliko skupo 310W za 290KN, a Maxpower 400W je 200Kn a i pitanje je hoće ili neće spalit komponente a ventilator nakon 10 tak mjeseci postne nepodnošljivo glasan. Neznam za Plextorove drivove osim za pržilice, ja bi ipak zel ili LG. Hitachi ili Pioneer MIš može bit i Trustov imam ga ja i Čist je OK jer koliko para toliko muzike.
#22 |
Postovi: 4,085
Čuj, radije slabiji komp nego osrednji monitor, tipkovnica, miš i napajanje. To kupi kvalitetno, za ostalo koliko para ostane. Možeš imati ne znam kakav proc/memoriju/grafu, ali kad te oči peku i ruke bole poslije sat vremena rada za kompom, ***eš takav komp. Nemoj uzimat TT (zapravo uzmi, evo imam jedan V9, kupljen u Ve-Milu u 4 mjesecu, još pod garancijom, apsolutno ispravan, za 100 kn. Pogodi zašto ga prodajem... )Nemoj uzimat šrot napajanje jer ti se ne ispalti zbog razlike 100-200 kn ugrožavati investiciju od 7000 kn. |
#23 |
KLOhNing xprt
Postovi: 63
Nisam mislio na razliku izmedu 433 i 400, nego na razliku izmedu Kingmax SuperRama i Kingmax obicnog rama? |
#24 |
KLOhNing xprt
Postovi: 63
Jos par pitanja: 1. Mozete li mi preporuciti kuciste zasebno i napajanje zasebno koje odgovara tom kucistu za ovu konfiguraciju: -Hard disk Seagate 80GB Barracuda S-ATA V, ST380013AS, 7200 RPM, Serial ATA, 8 MB -Floppy NEC FD1231H 3.5" 1.44 MB, black -Zvucnici Creative Sound Blaster SBS250 2x2,5W RMS, Black -Grafička kartica Sapphire Radeon 9600 XT 128M DDR AGP VGA / TVO / DVI-I FIREBLADE, BGA,128-bit, 500/300 MHz, Overdrive Ready, lite retail -Monitor Samsung 753DFX 17", FLAT, 0.20D/P, H(30-70kHz), V(50-160Hz), P(110MHz), 1280x1024@65Hz, 1024x768@85Hz Black -Kućište Logic Master III LU-Black middle tower, 400W, 4 x 5,25", 5 x 3,5”, USB, Black! -Tipkovnica Key Tronic KT-1000 Black PS/2 -Miš Logitech M-B58 Wheel Mouse Optical 2 tipke, scroll, USB & PS/2 (black) -Matična ploča Abit NF7-S nVidia nForce2 Ultra 400, AGP 8x, 400MHz, SATA-R/ATA133, Sound SoundStorm 5.1 + LAN 10/100 + Firewire o/b, 3x184pin DC DDR 400, USB 2.0 -DVD/CD-ROM Plextor PX-116A DVD 16x/CD 48x, 256Kb buffer, podržava SVE trenutne industrijske formate zapisa, black panel, ATAPI IDE, bulk, CRNI -CD-RW Samsung CD pisač 52x 32x 52x SAMSUNG, bulk, crni -Memorija KingMax 2x256mb DDR 256 MB 184 pin, 433MHz, SuperRAM, -Procesor AMD Athlon XP 2600+ BOX (128K L1+512K L2 on-chip cache, FSB 333MHz), Barton, Socket A 2. Koje je vase misljenje o ovom skeneru: TrustScan. TRUST Easy Webscan, USB, 48 bit, 19200 dpi (600x1200dpi optic.rez.) (12388) 491,00 kn i mozete li predloziti neki bolji do 500kn? |
#25 |
Postovi: 4,085
Koliko si spreman dati za kućište i napajanje? Okvirno. |
#26 |
KLOhNing xprt
Postovi: 63
Do 500 Kn. |
#27 |
KLOhNing xprt
Postovi: 63
Jos jedno pitanje: Dali je 310W Chieftec dovoljno za prije navedenu konfiguraciju, cuja san da mi graficka crpi do 200W, a gdje su jos ostale komponente? |
#28 |
Headbangig Grunf!
Postovi: 4,373
Čisto dosta pa pogledaj kod SKY-a on ima 300W Aopen. 200W grafička? Brijem si da je to malo puno previše. Za 500kn nečeš dobit bolji skener jedino polovni, Trust proizvodi stvari kod kojih štima cijena jer toliko i vrijede. Ja imam Samsungovu pržilicu i OK je. A da zemiš recimo LG DVD a Plextor pržilicu? Gle Kingmax na 433Mhz se zove Superram ( dobro zvuči) tak da ti je sve već napisano. 400Mhz je problematična zna bit pokvarena nestabilna ukratko neisplativo 433Mhz je Kingmaxov povratak jer je pouzdana a cijena je odgovarajuča nije to Corsair ili Marushkin, al po testovima je bolja od G.E.I.L.-a koji je puuuno skuplji
#29 |
KLOhNing xprt
Postovi: 63
Sto mislite o: -CD-RW TEAC CD-W552E, Black 52/24/52 speed, Tray, ATAPI IDE, 2Mb buffer, Buffer Underrun Prevention, CD-TEXT, bulk, BLACK -DVD/CD-ROM Plextor PX-116A, Black DVD 16x/CD 48x, 256Kb buffer, podržava SVE trenutne industrijske formate zapisa, black panel, ATAPI IDE, bulk, CRNI ? |
#30 |
KLOhNing xprt
Postovi: 63
I jos dali ja bolje uzet ovu maticnu: Soltek 75FRN2-RL, Socket A, NVIDIA nForce2 Ultra400 SPP+MCP, FSB 400/333, UDMA133, IDE RAID, SATA, SATA RAID, 5PCI, AGP8x, 3DDR (Dual Channel, 400/333MHz), 6 channel sound, USB 2.0, ATX cuja sam da je ona isto kvaliteta. |
