#182 |
Prečupavi mod
Postovi: 9,108
Ufff... ko ce cekat to sve ![]() Nego jedan prijedlog moderima - preimenovat topic u "vijesti iz Intel svijeta" ili nekako slicno i eventualno okacit kao sticky... jer se ipak najavljuju i nove ploce i chipseti ovdje, a ne samo C2D procovi ![]()
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
#183 | |
Premium moderator
Postovi: 4,600
![]() Ovaj thread dakako to zaslužuje. McG ![]()
__________________ |
#184 | |
Prečupavi mod
Postovi: 9,108
![]() ![]() Itekako, u zadnje vrijeme niti ne pratim ostale vijesti samo tu i tamo otvorim ovaj thread... McG-u pivetina i od mene ![]()
#185 |
Premium moderator
Postovi: 4,600
Jel' sad bolje? ![]()
#187 | |
Spiderpig
Postovi: 2,043
#188 |
Postovi: 7,568
Gigabyte P35C-DS3R DDR2/DDR3 ploča i Core 2 Extreme X7800 i X7900 procesori
Gigabyte P35C-DS3R This mainboard inherits the best of the P35-DQ6 we reviewed before. Users usually do not have a good feeling about hybrid products. Gigabyte did not disappoint us with its flexibility, performance and ovreclockability. Generally, the performance of this board is on par with the P35-DQ6. It supports the newer 1333FSB processors including all mutli core processors including the 45nm processors. It also support ASync DDR2-1066 through overclocking. We are able to overclock the E6300 to 6 x 525MHz on Air cooled. ![]() Intel Core 2 Extreme X7800 i X7900 This September Intel is expected to unveil the Intel Core 2 Extreme X7800 and X7900 chips with 2.60GHz and 2.80GHz clock-speeds respectively as well as 4MB cache and 800MHz processor system bus (PSB). The new chips will have two processing engines and the model X7800 will cost $851 at launch. Intel is already shipping special Intel Core 2 Duo T7600G processors with unlocked multiplier and processor system bus speeds to personal computer makers planning who want to offer their customers some additional performance by pre-overclocking the microprocessors in their notebooks. Izvor: OCWorkbench i X-Bit Labs |
#189 |
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,399
Molim malu pomoć i objašnjenje zagriženom amdeovcu. ![]() Kakav je to procesor Intel® Core™ Duo T2350 CPU 1.83 GHz L2 Cache: 2048K, FSB 533 MHz jer ga na intelovim stranicama nemogu pronaći. http://www.intel.com/products/proces...rt/coreduo.htm
#190 | ||
Postovi: 7,568
#192 |
Postovi: 7,568
Abit P35 ploče
Abit has launched its new motherboard series based on Intel's new P35 chipset. The new series contains three models; IP35-E, IP35 and IP35 Pro. The first is the budget version and has four SATA ports, not RAID or FireWire, while IP35 has 6 SATA ports and both RAID and FireWire. IP35 is also cooled by Abit's patented Silent OTES 2 technology. Abit IP35 Pro is in turn the top model of the series and offers a bit more than the others. On top of all dual Gb Ethernet circuits, an external CCMOS switch, quick buttons for power/reset, optic S/PDIF in and two eSATA connectors. Last, but absolutely not least we have the µGuru circuit, which clearly shows which board that is for the enthusiast. All cards have 8 channel HD sound, support for Intel's coming processors with 1333MHz bus, up to 8GB RAM, CrossFire (16+4) and solid-state capacitors. ![]() ![]() ![]() Izvor: NordicHardware, OCWorkbench i Abit |
#193 |
Postovi: 7,568
X38 chipset s IHS-om
It seems like Intel X38 Express chipset has a heatspeader on it and according to motherboard makers, it runs pretty hot when running dual graphics cards in x16/x16 mode. It runs up to more than 60 degrees in this case. However, motherboard makers will be designing fancy heatpipes for this board so there isn't too much a worry about heat. We will be seeing quite a number of X38 boards at Computex and there will be some designs that supports Intel Turbo Memory. ![]() Izvor: VR-Zone |
#196 |
Spiderpig
Postovi: 2,043
#198 |
Prečupavi mod
Postovi: 9,108
Ahhh, brings back memories ![]() ![]() ![]()
#199 | |
Postovi: 7,568
#201 | |
Lokacija: Varaždin/Zagreb
Postovi: 1,846
je kak bi se inace 2 kile bakra drzalo za plocu...cudim se kaj nisu 4 rupe napravili ![]() Citiraj:
![]() ma ja vam kazem nece bit nist strasno od toga...grijat ce se al vjerujem da nece biti nista pretjerano |
#202 | ||
Postovi: 7,568
![]() EDIT: Citiraj:
#203 |
Premium moderator
Postovi: 4,600
#207 |
Prečupavi mod
Postovi: 9,108
Sumnjam ![]()
#208 |
Taiketsu Master
Lokacija: Suzuka, Japan
Postovi: 150
To je bilo očekivano da će izbaciti neke novitete. Kako su krenuli sa 6320 i 6420 tako i sa ovima. Ma, uglavnom to sve ide tako brzo naprijed da se komotno može kupovat novi komp svakih šest mjeseci (skoro). Ne bih se čudio da u bližoj budućnosti budemo imali priliku vidjet novitete svakih mjesec dana ![]() |
#210 |
Postovi: 12,425
Ja jedva čekam da u prodaju kod nas dođu novi Celeroni (Conroe-L) jer koliko vidim vani su full jeftini a gadovi su poprilično brzi. P.S. ne mogu vjerovat da se meni napokon neki Intelov Celeron sviđa ![]()
