Staro 20.03.2007., 20:24   #1
Wolverine
Wolverine's Avatar
Postovi: 12,425
Question Može li Corsair HX620W nahranit 8800GTX SLI konfu sa QX6700 @3,5GHz
Odgovor potražite ovdje
http://www.legitreviews.com/article/462/1/
I was a bit skeptical of this considering NVIDIA has been telling the press since launch that the GTX in SLI requires a minimum 750w PSU.
After enabling SLI and rebooting I fired up 3DMark06 expecting to have a crash soon after. Surprisingly, I am still waiting for that crash now and it’s been nearly 2 weeks. I've spent a fair bit of that time gaming in Battlefield 2, Counter Strike: Source, Half-Life 2: Episode 1, Rainbow Six: Vegas, and Supreme Commander all at 2560x1600 resolution. Not once have I had a single problem with my setup
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 20.03.2007., 20:47   #2
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,774
glavno da ima takvih koji sumnjaju da moze nahraniti jednu 8800GTX...
Staro 20.03.2007., 20:56   #3
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
ja sam siguran da moj codgen 480W modded(promjenjeni ventovi) mogao bez problema pogonit moju staru konfu (E6600,P5b dlx 2x1gb i grafu koju sam trebao uzet 8800gts).
Te priče o napajanjima su samo markentiški trik koji jako dobro uspjeva pogotovo na amerikancima.
Smartguy je offline   Reply With Quote
Staro 20.03.2007., 21:18   #4
gorluk
Čovjek
gorluk's Avatar
Postovi: 1,166
Ma nVidia ga s*re opako. Intel Quad 6800 i 2x8800GTX u SLI troše oko 430W u max. loadu, znači napajanje poput Corsait HX 620W će pogoniti takvu konfu kao od šale.
Općenito su ljudima razni proizvođači utjerali strah u kosti, tako da nije ništa čudno vidjeti ekipu koja kupuije 800W napajanje za 7900GS i E6300, te jedan -dva diska.
gorluk je offline   Reply With Quote
Staro 20.03.2007., 21:35   #5
Wolverine
Wolverine's Avatar
Postovi: 12,425
BTW pazi rezoluciju
ne može se reč da lik ne kolje konfu
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 21.03.2007., 03:12   #6
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,299
Pa to je prava rezolucija - 30" .
BTW imam jednog poznainka (online) i covjek kupio isto 8800GTX 2 komada za SLI (neke XFX modele koji su jos overclockani tvrnicki) na QX6700@3Ghz da bi igrao MS Flight simulator ali u 5120*1600 rezi (2*30" LCD) i dobije citavih 30 fps kad sve podesi na full . I puno i malo u isto vrijeme s obzirom na rezu ali opet to su dvije 8800GTX i clockani Qx6700.
P.S. prodao je Quadro 4500 i od tih novaca kupio 2*8800GTX i ostalo mu love za igrice dok ne nabavi Quadro 5600 .
Staro 21.03.2007., 07:36   #7
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
prebrutalno to ja zovem iskoristit grafu
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 21.03.2007., 09:16   #8
TheProfiler
Gamer 2 the Bone
TheProfiler's Avatar
Lokacija: Zagreb, oko centra...
Postovi: 1,640
Autor Renesis Pregled postova
Naravno! Ne daješ 3500 ili 5000 kn za grafulju da ti radi sa 70% iskorištenja!
Iscijedit do kraja!
Vrijedi za cijelu konfu. Sve ima 2 ili 3 godine garancije...
- Nothing in this world is certain.
That's the only certain thing I know. -
Zadnje izmijenjeno od: TheProfiler. 21.03.2007. u 09:36.
TheProfiler je offline   Reply With Quote
Staro 21.03.2007., 09:58   #9
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
zato ja sve svoje pržim, pa makar i nemalo garanciju...
ali evo, napokon i da je neko pametan dokazao da ne treba 5kW napajanje da bi vrtilo komp...
Staro 21.03.2007., 11:53   #10
Kvaka22
Registered abuser
Lokacija: Tu sam negdje
Postovi: 59
Od kad to moras bit pametan da kupis dve kartice i ustekas napajanje u njih?!?
Samo treba novaca, a ovo je eksperiment, a ne neko pametno istrazivanje...
I covjeku jedino respekt sto ima SLi i za nista drugo...
Mislim da bi i ti bio pametan kad bi kupio dvije 8800GTX i probao da vidi hoce li raditi da ne moras kupovat i novo napajanje, ako radi, onda si pametan, ako ne radi onda nisi??
Molim te, razmisli prije nego napipses ista pametno...
Kvaka22 je offline   Reply With Quote
Staro 21.03.2007., 11:54   #11
darkijas
darkijas's Avatar
Postovi: 1,807
ja sa napajanjem codgen 400w (koje je zajedno sa kućištem prije dvije godine koštalo 200kn) bez problema vozim ath64 3000, k8nf-9, 2x512rama 160gb hdd, nec 3520a dvd prža, gainward 7900gs golden sample, web kamera, skener,kontroler. Jedino kad bi nešto od toga pokušao naklokat neznam kako bi izgledalo..
darkijas je offline   Reply With Quote
Staro 21.03.2007., 11:56   #12
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
Pardon, krivo sam se izrazio. Ljudi, kojima se obično vjeruje, napravili su taj test, da vide dal će konfa raditi sa napajanjem koje je dosta ispod preporuke proizvođača...
da je recimo drago napravio takav test, ja bi ga uzeo sa dobrom dozom opreza...
Staro 21.03.2007., 12:01   #13
Kvaka22
Registered abuser
Postovi: 59
E, "ljudi kojima se obicno vjeruje" i "ljudi koji znaju sto rade" bi bio ispravan termin...
Koliko sam skuzio "drago" je tu predmet neke sprdnje, ali ne znam zasto covjeku ne vjerovat... Svi imaju svoje bisere, pa sto?
Staro 21.03.2007., 12:04   #14
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,506
Autor Kvaka22 Pregled postova
Imati bisere i konstantno pričati gluposti nije isto! Nećemo OT!
Staro 21.03.2007., 16:02   #15
Wolverine
Wolverine's Avatar
Postovi: 12,425
Da ali neki ovdje spomenuti ih imaju preko 5 stranica A4 u samo godinu dana
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 21.03.2007., 21:10   #16
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
glavno da smo sve skontali...
