Can You Hear Me? 142.8 dB
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
Quad Core in Waterchill Kandalf + lil' mods
pao je imageshack uplaod slika pa zato fali dosta slika iz topica.... no evo ovako to izgleda sada: 42'' G10 plazma + 22'' LCD Dell E228WFP ( 0ms input lag) Intel Quad core 6600 Watercooled 4GB DDR2 1066 MHz DFI UT P35 T2R mobo HD5850 VTX 1024 MB ddr5 Watercooled 3x750GB WD black + 640GB WD black + 32 GB SSD Seasonic S12 II 500W PSU Pioneer DVR212 DVD+/-RW UPS 1300 VA (model: PW-4130M) ANTEC P182 case update slika na stranici 3 (link) i novije, na stranici 6 (link) te još novije na stranici 10 (link) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() quad at 4.1 GHz ___________16895 3DM06_________Top10 Lista________Top10 Lista___ccccccccccccccccccccccccc_______ ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() _____Raid0 300MB/s @ 5.9ms RAT_______________________________SSD ![]() ![]() ![]() ![]() FROZEN quad core + cold VGA ![]() ![]() ![]() ![]() brušeni C2Quad + cooler ![]() ![]() video: http://www.youtube.com/watch?v=uj6Amq_MGfE .
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() ![]() Zadnje izmijenjeno od: TomRi. 29.06.2010. u 18:34. |
Postovi: 2,073
lcd windows ![]() moze i drukcije, screensaver s pokretnim 3D ribicama... (skinuto: http://simaquarium.com/ ) ![]() UPDATE 13.2. : uzeo LCD Samsung 19'' Black ![]() i 27.2: Sharkoon 5.1 USB slusalice iduci dan vec raskopane... (klik) ![]() 6.3.: RAID setup, 640 GB (2x 320 GB Seagate 7200.10 SATA II ) + 120 GB Seagate USB external ![]() ![]() 10.3 nova ASUS Commando maticna, i sve radi kako spada... ![]() ![]() ![]() ![]()
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() ![]() Zadnje izmijenjeno od: TomRi. 24.03.2007. u 14:31. |
Postovi: 2,073
update 21.3. Zalman VF900Cu (cooler za VGA) ![]() ![]() ![]() 1.4. VGA Waterblock, DDR2 Heatsinkovi, Kensington gel... ![]() ![]() evo još par modova... dosadno zeleni router ![]() ne zadugo.. ![]() ![]() ![]() ![]() uz vec otprije opisane: Eksterni USB HDD blue led + shut down relays, LCD, keyboard... vibra mouse laptop i da, ova ponuda još stoji.. puno je toga rečeno, ali nitko nije dao dokaz... http://forum.pcekspert.com/showthread.php?t=40865
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() ![]() Zadnje izmijenjeno od: TomRi. 01.04.2007. u 21:43. |
herr Flick
Postovi: 2,085
.:S:T:A:L:K:E:R:. ![]() ![]() nema vise zippacha ![]() |
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,463
6700.... |
Lokacija: ZGB
Postovi: 55
di si kupio taj mali LCD, i kako si ga spojio na komp Zadnje izmijenjeno od: LiNuXeR. 08.02.2007. u 09:50. |
AutoCad & Allplan expert
Postovi: 2,159
mnogo lijepo ![]() neg di je taj c2d na 5ghz? daj malo vise slika tok kandalfa, temperature itd...
none |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
C2D na 5Ghz (možda 2x2.5Ghz : stoopid) ? Ja vidio takve primjerke samo sa faznim / LN2 / dryice hlađenjem. Samo benchabilno, o stabilnosti nema niti govora... Ostalo je super. Fora je ovaj mali ekrančić ![]()
#13 | |
Spiderpig
Postovi: 2,043
![]() ![]() Ako je išao 2x2.5ghz onda mora da radi u autronicu : lol2 : |
Prečupavi mod
Postovi: 9,118
Mene isto zanima taj mali LCD.. gdje, kako, koliko itd ![]() ![]()
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
Lokacija: Vukovar
Postovi: 436
Odlican posao stvarno nemam rijeci!puno truda,dobrog rada ali i dosta novaca ulozeno!!! Daj reci kako 5Ghz stavi neku screenshot da mi to vidimo performanse to mi je previse 5Ghz!!! I naravno i mene zanima taj LCD koliko platio,di kupio i kako spoio?? E da da ti usput kazem odlicna Fabia predobra stvarno si majstor: goood : : cheers2 |
#17 |
Lokacija: Vukovar
Postovi: 436
Da sve je lako kad se ima novaca i ja da imam toliko love sredio bi auto i komp ludo!!! Da i ja zelim da odgovori na moje postavljeno pitanje koji su vec neki i prije men postavili u vezi LCD: hello2 : |
#18 | |
Postovi: 2,073
ajde, ma nije to nis posebno, kladim se da pol vas ima brze konfe, posto sam ja ovo samo malo vizualno uredio a vecina vas izvuce i zadnji atom performansi iz sustava, a ja nemam bas znanja o tome, pa da nes ne shebem- ne petljam ![]() odgovor ti je: izmjerio sam ti i napisao u onom topicu koliko cm ima za ventove, i ne stanu ti tvoji od 3.5 cm. a ona mrezica kaj si pitao tamo se moze skinuti ali moras prvo i cooler i ventove odsarafit da dodjes do nje. jer se izvana nis ne vidi, sve fixirano skriveno-iznutra... ne kuzim se previse u te core duo proceve, imao sam prije komp 2.8 P4 i imao je povremene 'hitches' u unrealu2004, pa mi to islo na zivce. i htio nesto jace, znaci preko 3ghz. onda sam dosao u links i rekao da mi sloze nekaj jace. pa mi rekli da ovo ima 5ghz i da je grafika dobra, pa da ne smije trzat. i fakat ne trza. ![]() framerate u unrealu ima od 400-500 naspram prijasnjih 100njak, ali najbitnije je da ne trza kad pocnu letit rakete i slicno. LOL hladjenje je i vise nego zadovoljavajuce. drzi konstantno oko 25-28C. ma nije to nis posebno, ima jos puno skupljih proceva i jacih, ali ovo je ok za igranje. za sada... a za to i sluzi ![]() 7'' LCD, ma toga imas po cijeloj hrvatskoj, oni spartak ducani: 800 i kusur kn. prodat cu ga pa uzeti veci glavni LCD 19'' sad su im fakat pale cijene ![]() u vezi auta, isto thnx, nije nis posebno, ima daaaleko boljih po Hrv, ovo je niš. ali samo treba volje i dosta vremena i sve se moze napraviti...
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() ![]() Zadnje izmijenjeno od: TomRi. 21.03.2007. u 17:07. |
#19 | |
Avocado
Postovi: 7,856
Spoiler alert! |
#20 |
Lokacija: Vukovar
Postovi: 436
Auto ti je predobar jedan od boljih koji sam vidio nije pretjerano sa puno nebitnih stavri nego je bas lijepo i uredno sredjen meni se osobito ajko svidja jer je bas odlicno smisljeno i napravljeno bas imas ukus Svaka cast majstore: cheers2 |
#21 |
Postovi: 2,073
ali fakat mislim da nema potrebe da mijenjas te ventove... pogotovo zato sto nemaju bas neku ulogu u hladjenju... vise ima pumpa koja stalno vrti vodu od proca do coolera. ipak je zima pa je sobna temp niza nego proc..i to je dovoljno za izmjenu topline u cooleru po ljeti ne znam ![]() tj sada mogu raditi na minimumu, 5-7V, gdje ti je razina buke zaista nemjerljiva. jer ih ja ne cujem ni ovako dok rade na 12V osim kad otvorim ta vratasca, a onda struji zrak u lice...
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() ![]() |
#22 |
Lokacija: ZGB
Postovi: 55
kako si ga spojio, da ti radi i veliki i mali LCD |
#23 | |
Avocado
Postovi: 7,856
Spoiler alert! |
#24 |
Postovi: 2,073
nije to nista specijalno... samo ustekas u neki od konektora, bez kemijanja.... http://ati.amd.com/technology/Avivo/index.html 7 konektora S-video ulaz, obicni chinch ulaz, S-Video izlaz, chinch izlaz, YPrPb component izlaz i dupli DVI izlazi izgleda poput ovoga
#25 |
Ex-Gastarbajter
Postovi: 5,463
samo jedna stvar tom, ovaj core duo ti ne radi na 5ghz, nego je riječ o procu sa dvije jezgre, pa onda vole trgovci pomnožit takt sa jezgrama... |
#26 |
Spiderpig
Postovi: 2,043
#27 |
Postovi: 2,073
ma bitno da radi sve glatko kaj meni treba, pa makar ovi u Intelu to izveli i s 5x po 1 GHz, to mi nije bitno, samo ono sto ja dobijem kao end-user, brzinu i stabilnost u jednome ![]()
#29 |
Postovi: 2,073
kako mislis veće? http://www.thermaltake.com/product/C.../vd4000bws.asp pa skoro 40 cm je visok : flyingey hladnjak je veći neg što škoda fabia ima coolera/heater cijele kabine. a blok za VGA je narucen kad i komp, ali stize u ducan tek krajem mjeseca.
#30 |
Lokacija: Varaždin, Bronx
Postovi: 1,097
Tipa cool eksterno. Imam vodeno veličine IBM-ovog servera, 2 kilera od stoleta, 4 12cm venta. Neonke, i ostale điđe miđe. Još je bolje moddano neg cijeli komp ![]() ![]() |
