Postovi: 1,816
Pouzdanost trenutnih PSU?
Evo malo sam gledao po netu i nasao sam jednu statistiku koja me potpuno iznenadila: "Today, we obtained the failure rate of power supplies recorded by a major French e-commerce. These statistics include products in shops since the first April 2006.A minimum if at least 100 units have been sold. Statistics per brand are based on a minimum sample of 500 units: Fortron: 0.7% Hiper: 1.2% Seasonic: 1.4% Thermaltake: 1.6% Tagan: 2.8% Enermax: 3.0% Antec: 9.5% Fortron comes first in the list followed by Hiper and Seasonic. Thermaltake is next and is the last manufacturer to have an acceptable failure rate. Tagan, Enermax and most of all Antec are above the limit. For Antec the entire power supply range has very high failure rates: 21.6%, 18.1% and 17.3% for the Antec SmartPower 2.0 500, 350 and 400 Watts. Not a single product has a rate below 2% and the best one is the Neo HE 430 watts at 2.6%. For Fortron, the figures are a bit more disparate from 0% for the most reliable model to 1.5% for the "least" reliable. Hiper's rates oscillate from 0.4% and 3.8%. The two models above 2% are the modular R 580 watts. For Seasonic, the leading products S12-500 and 600 are respectively at 1.8% and 0.9%. Thermaltake's rates vary from 0% to 2.5% except for the Silent Power 680 Watts which is at 6.6%. Tagan's figures are relatively stable from 2.3% to 3.3%. Finally, Enermax' rates oscillate from 1.8 to 5.1% (Liberty EL620AWT)." Prema ovome najskuplja napajnja su najsklonija da odu i neka mi sada netko objasni po cemu bi netko morao dati toliko love za Tagana, Enermaxa a da ne govorim da bi itko trebao i pomisliti o nabavki novog Anteca? Statisika govori da se Tagan i Enermax 4 puta cesce kvare od jednog Fortrona!!!
Stupid is as stupid does |
Lokacija: n/a
Postovi: 6,128
Jucer ili prekjucer sam ovo postao na Wolv-ovu temu o napajanjima. Anteca hebe losa SP serija, a Tagan je danas drek. Nije to ni T od nakadasnjeg Tagana... Iznenadio me je Hiper, po ovome bi se reklo da su to vrlo pouzdana napajanja, mada bas i nisu nesto. |
#3 | |
Postovi: 1,816
Edit: Hiper definitivno izgleda dobra lovina!
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
pa necudime statistika jer vjerovatno ljudi vani kupuju vise ova skuplja napajanja nego jeftinija. plus sta ova skuplja napajanja se u pravilu vecinom stavljaju u zesce konfe...
#5 | |
Postovi: 12,602
![]() ![]() Ja: Jel imas Tagan ili Seasonic napajanja? trgovac(talijan): Kako molim?? --------------- Ja: Uzimam za jednu zensku nes jeftino, Asrock plocu, Semprona, 2x256 rama, daj mi neko napajanje.... trgovac (isti): Za zensku, evo bas su stigla napajanja Hiper, tako lijepo roza boje, 580w ![]() Ja: Hvala, drugi put ![]() Sorry za OT...
#6 | |
Postovi: 4,190
#7 | ||
Postovi: 12,425
Jerry to je već bilo postano ovdje http://forum.pcekspert.com/showthrea...t=48485&page=2 no meni je iskreno najzanimljivija Jonny-eva reakcija ![]() Citiraj:
Lokacija: Glina
Postovi: 55
___________________ |^^^^^^^^^^^^^|____ | Network Impact... | '|";\,___. |_..._....._____===|=_|__|...,]| "(@)'(@)****|(@)*(@)***(@) |
Datum registracije: Feb 2004
Postovi: 1,303
Ne mozes uzet te podatke kao nesto jako sigurno, u jeftine konfiguracije koje nisu gladne snage se stavljaju jeftinija napajanja koja onda i nisu pod nekim opterecenjem dok se brandovi pretezno stavljaju u mrcine koje vuku struje ko Petrokemija. Ta napajanje se kupuju da bi ih se gazilo pa ak koje rikne nije bas neko cudo, treba im samo zamjerit ako povuku koju komponentu sa sobom |
