#61 |
Datum registracije: Aug 2003
Postovi: 3,193
Za prvi izgled: http://www.hydrogenaudio.org/forums/...dpost&p=439039 Za drugi izgled (kod mene je to kombinacija prvog i drugog): http://www.hydrogenaudio.org/forums/...dpost&p=437898 Prvi izgled chupa covere iz cover direktorija i oni moraju biti 80x80 PNG dok drugi chupa iz direktorija samog albuma i coveri mogu biti bilo koje velichine ili formata (lik je stavio PNG no ja sam promjenio u JPG).
#62 |
Postovi: 7,568
.... Zadnje izmijenjeno od: McG. 13.01.2012. u 01:07. |
#64 |
Postovi: 3,193
Nema tu .fcs filea jer je u pitanju single columns playlist. Imash na ona dva linka sve objashnjeno. Evo lista komponenti: amip.dll, foo_abx.dll, foo_ac3.dll, foo_adpcm.dll, foo_albumlist.dll, foo_amipwrapper.dll, foo_audioscrobbler.dll, foo_autoplaylist.dll, foo_burninate.dll, foo_cdda.dll, foo_common.dll, foo_converter.dll, foo_cwb_hooks.dll, foo_dbsearch.dll, foo_dsp_continuator.dll, foo_dsp_crossfeed.dll, foo_dsp_std.dll, foo_dumb.dll, foo_freedb2.dll, foo_gep.dll, foo_infobox.dll, foo_info_samurize.dll, foo_input_monkey.dll, foo_input_shorten.dll, foo_input_std.dll, foo_lnk.dll, foo_lock.dll, foo_lunar2.dll, foo_masstag.dll, foo_midi.dll, foo_osd.dll, foo_out_ks.dll, foo_playlist_manager.dll, foo_pqview.dll, foo_psf.dll, foo_rgscan.dll, foo_run.dll, foo_sic.dll, foo_sid.dll, foo_tradersfriend.dll, foo_uie_albumart.dll, foo_uie_albumlist.dll, foo_uie_lyrics.dll, foo_uie_playlists_dropdown.dll, foo_uie_quicksearch.dll, foo_uie_single_column_playlist.dll, foo_uie_trackinfo_mod.dll, foo_ui_columns.dll, foo_ui_std.dll, foo_unpack.dll, foo_utils.dll, foo_verifier.dll, foo_vis_samurize2.dll, foo_winamp_spam.dll, foo_write_http.dll, libpng13.dll, zlib1.dll
#65 |
Postovi: 1,530
@ luxor pogledaj ovdje iza plave crte imas objasnjeno single column @mcg hvala na linku evo moga, nikako da se priviknem skroz na ovaj single column kod ovog dolje track infa ne sljaka pauza i volume bar prikazivanje covera sam manje vise sredio, radi i sa modificiranim crnovim pluginom za samurize...doduse ne bas savrseno, ali radi ![]() |
#66 | |
Lokacija: Sveta Nedelja
Postovi: 129
evo moga --> ![]() ovaj dolje pause i meni nije šljakal jer je greška u kodu - treba dolje na kraju di se nalazi red Citiraj:
#67 |
Postovi: 3,193
Mozhe se koristiti Pause, a mozhe i Play or pause. Za kontroliranje glasnoche zvuka mozhe se slozhiti Volume up i Volume down, npr. naprave se 2 prozirna PNG-a velichine onog volume bara i na jedan se stavi naredba za pojachavanje a na drugi za stishavanje. Seekbar se mozhe slozhiti preko naredbi za premotavanje (sekunda, 5, 10, minuta i sl.) - npr. seek ahead by 5 seconds.
#68 |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
meni se glupi foobar opet resetirao, i opet sam na nuli... tako glupav program da glava boli. Glupav zbog toga što ne možeš snimiti svoj setup file, i da nakon instalacije, ili slučajnog za***a, možeš odmah vratiti sve na staro. Dok ne bude to u mogućnosti, meni neće na komp. Media monkey me u potpunosti zadovoljava. |
#69 | |
Postovi: 1,530
vec slozenih setupa, ako nesto idem mrdati po njemu mogu vratiti na staro u roku 15 sekundi. (a najmanje 5 puta sam pisao kako i sto) Znaci mozes vratiti sve na staro vrlo brzo i jednostavno. Mozes snimiti setup file. Nije niti foobar za svakoga, zato i postoje winamp, helium, mediamonkey. |
#70 | |
Lika u mom srcu
Postovi: 9,887
#71 |
Postovi: 1,530
#72 |
Postovi: 1,530
#73 |
Chipokemon
Postovi: 339
Piracy helps stop global warming.Insted of driving to get CDs, buying pre-packaged software from megacorporations and wasting energy,you can help fight Global Warming by using P2P.Help save resources,fight pollution and save the enviroment. -It`s what Jesus would do. |
#74 |
Lokacija: /
Postovi: 2,053
#76 |
Lokacija: /
Postovi: 2,053
dobra zamisao sam daj ga još malko popravi ![]() dodaj slike albuma jer se ovak teško kuži koja pjesma kojem albumu pripada.... ![]() i malo "stisni" foobar da nema ovih crnih sa strane... : goood : http://img215.imageshack.us/img215/8...titled1yq0.jpg ![]() |
#78 |
Postovi: 7,568
#79 |
Lokacija: /
Postovi: 2,053
sry. na OT al može wallpaper : lol2 : |
#81 |
Kostolomac
Postovi: 1,482
eto moga. kad dosadi mijenjam ![]() ![]() EDIT: ako neko hoće ovakav foobar, evo linka: http://www.hydrogenaudio.org/forums/...howtopic=49783 Zadnje izmijenjeno od: d0X. 05.11.2006. u 14:42. |
#82 |
Postovi: 7,568
#83 | |
Postovi: 1,530
Sad bi se trebala napraviti import-export skripta koji ce omoguciti lako backupiranje i razmjenjivanje setupa. (vise ovdje ) Korak u pravom smjeru ![]() |
#84 |
Lokacija: /
Postovi: 2,053
![]() složio si ja drugi setup al sad nailazim na par problema... zakaj mi se redni brojevi pjesma "skraćuju" odozdo? - btw. imam instaliran Calibri Font zakaj mi se rating pjesme pokaže tek kad kliknem na nju, a kad idem neku drugu slušat sa ove stare se onda ne prikaže...kužite kaj hoću reć? hehe i zakaj nemrem gore onaj Track Info Mod "proširit" malo za dolje...jednostavno mi foobar ne da...why? hvala ![]() |
#85 |
Lokacija: /
Postovi: 2,053
evo uspel sam ![]() kak napravit ovakav skin ??? - btw. rađeno po ovom topicu... ja sam si to sve sredil i zbiksal i ovaj .zip sadrži sve potrebne componente (sve koje će vam (valjda) ikad trebat...hehe), slike za ovaj skin te .cfg odnosno configuration file....pa uživajte ![]() http://rapidshare.com/files/2541766/...WMP11.zip.html - oko 5MB |
#86 |
Darth Pope
Lokacija: localhost
Postovi: 225
evo novi fooić ![]() ![]() prilicno standardna konfiguracija sa single column pluginom i album listom na auto hide. @morph: sto tocno treba da se dobije ovakav setup http://www.imagesforme.com/viewer.php?id=476f2k.jpg, koji fcs, track info, akko se sređuje ovaj rating i kako dodati hebene buttone. ![]()
#87 |
Postovi: 1,530
Naravno da nisu preteska pitanja : sweating Windows Vs je foton Autor Foobar setupa je spex04 i mozes ga naci ovdje (da sad ne c/p-am cijeli post ovdje) Tu imas sve kodove, layout i images za download. Samo ubaci kodove u single column playlist i track info mod i raspakiraj images u odgovarajuci folder. Da bi ti ovi buttoni u track info modu funkcionirali moras imati foo_cwb_hooks plugin. Sto se tice ratinga on je u kodu od single column playlista, zvjezdice se dodaju automatski ovisno o tome koliko je puta pjesma poslusana. Ako bude problema napisi (samo sto preciznije)pa cemo probat rijesiti. |
#88 |
Postovi: 1,530
#89 |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,772
pozdrav ljudi. puklo i mene jučer ušminkati foobar, mešutim kako nemam dume to napraviti sam, išao sam na hydrogenaudio i uzeo http://img120.imageshack.us/img120/3673/3nc4.png taj. međutim, problem mi je što se onaj gornji prikaz, znači brojke na kojoj je trenutno pjesma minuti/sekundi, uopće ne vrte, tj pomaknu se ako stisnem na one zvjezdice/srčeka znači tek se onda refresha. nije problem samo u ovom modu, probao sam još jedan, i isti slučaj. zna li netko možda rješenje problema? thx ![]() |
#90 |
...carpe diem...
Lokacija: Zagreb - okolica
Postovi: 1,363
