Staro 24.10.2006., 00:42   #31
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Et, prve konkretne informacije od ASUS-a. Cijena za 8800GTX 540$ (!!!), a za 8800GTS 410$.
Model             EN8800GTX/HTDP/768M
Graphics Engine             GeForce 8800GTX
Video Memory             768MB DDR3
Engine Clock              575MHz
Memory Clock              1.8GHz (900MHz DDR3)
Memory Interface            384-bit
Max. Resolution             Up to 2560 x 1600
Bus Standard              PCI Express X16
VGA Output              YES, via DVI to VGA Adapter
HDTV Output              YES, via HDTV Out cable
TV Output               YES, via S-Video to Composite
DVI Output               DVI-I
Dual DVI Output             YES
HDCP Compliant             YES
Preuzeto s LINK i LINK
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline   Reply With Quote
Staro 24.10.2006., 01:39   #32
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Ništa od GDDR4...
Matth€w je offline   Reply With Quote
Staro 24.10.2006., 02:15   #33
West
West's Avatar
Postovi: 268
Ma bude i GDDR4 dosao.....s vremenom
West je offline   Reply With Quote
Staro 24.10.2006., 21:45   #34
Vey
Postovi: 89
Stalno slusam price ,pa me zanima jel zna ko jel istina da ce vjerojatno nove maticne trebati dx10 kartice??? (navodno nije pce express utor. Iko cuo nesto takvo?
Vey je offline   Reply With Quote
Staro 24.10.2006., 21:50   #35
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Uskoro izlazi(sad se sprovodi) PCI-E 2.0 tokom iduće godine... e sad... neznam dal to ima veze s tim...
Staro 24.10.2006., 23:42   #36
dDario
dDario's Avatar
Datum registracije: Jun 2004
Postovi: 1,567
IBM T43 > Centrino M750 > 2GB DDR2 > 60GB > DVD-RW > 14" XGA
Atom 230 > D945GCLF > 1GB Buffalo > 120GB > DVD-RW > HP L1940
Atom 330 > D945GCLF2 > 2GB G.SKILL > 160GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > GB DDR2 > 80GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > 2GB DDR2 > X1600Pro > 250GB > DVD & DVD-RW > SM932B
X4 9950 > AM2NF3-VSTA > 2x2GB G.SKILL > Parhelia 256 > 2x 640GB > DVD-RW > 2x SM205BW
E6300 > ASUS P5B > 2xGB kingmax > X1900AIW > 2x320GB > DVD-RW & DVD-RW > LG 194WT
dDario je offline   Reply With Quote
Staro 24.10.2006., 23:45   #37
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Uf, baš me zanima kako će to ići, jer sve si kontam da će to biti moja slijedeća kartica (ali naravno tek kad R600 dođe i cijene još malo padnu, te izađu kojekakvi Golden Sample i slično )
@Vey
Nije to vezano. G80 izlazi za PCI-e sasvim normalno, a koliko sam shvatio PCI-e 2.0 bi trebao pinski biti jedanak, ali nuditi veću propusnost i fizički ne bi trebalo biti razlika kod kartica.
I5 3350P
XFX XTR 650W
Silencio 650
Staro 25.10.2006., 00:46   #38
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Staro 25.10.2006., 00:53   #39
Wolverine
Wolverine's Avatar
Postovi: 12,433
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 25.10.2006., 01:48   #40
Dexxy
bome je dosta brza od 7900gtx i x1950....sad dali je to istina,ko zna
Staro 26.10.2006., 00:25   #41
West
West's Avatar
Postovi: 268
Autor Dexxy Pregled postova
najbolje da nije
Ova 4 molexa koja vire iz G80 izgledaju zastrasujuce
Za takvu zvijer ce trebati neko djubre od 1kw, recimo ovo : goood :
http://www.pcpower.com/products/view...SR&view=photos
Zadnje izmijenjeno od: West. 26.10.2006. u 00:37.
Staro 26.10.2006., 09:14   #42
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Evo i prvih pre-ordera s masnim cijenama
GTX i GTS
I5 3350P
XFX XTR 650W
Silencio 650
Staro 29.10.2006., 02:07   #43
ante2
ante2's Avatar
Postovi: 1,313
ma sve je to supr 3D Mark ovaj 3D onaj ali ko sta je neko vec reko "ja se u 3D marku ne mogu igrat" ko recimo sa Oblivienom ili DooMom ili Q4 i slicnim programima za dobro gubljenje vremena
a sada pitanje sta je sa DX9 i inom kompatibilnoscu G80, jer ne zelim da mi se dogodi da G80 radi sporije od recimo 9750 GT u DX9 (i win XP 32)okruzenju koje ca ga docekat (mislim na G80) kada izadje
jeli se negdje o tome da procitat ? (onako povrsno): sweating
MSI Z77 MPower
Intel i5 3570K @4,2GHz, NOCTUA NH-U12S
Gigabyte GTX 1070
DDR3 16GB (4x4GB) 1600Hz Corsair Vengeance
Carbide Series Air 540, Corsair RM750i
CREATIVE LABS X-Fi Titanium-Kingston HyperX Cloud
DELL U2515H
Synology DS413
ante2 je offline   Reply With Quote
Staro 29.10.2006., 03:02   #44
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,419
Čisto pumpanje sirove snage .... moglo bi se lako dogoditi da prođe kao NV30 vs R300 s obzirom na DX10 kompatibilnost.
Staro 29.10.2006., 12:19   #45
Wolverine
Wolverine's Avatar
Postovi: 12,433
Mislim da je sad nezahvalno govorit o perf kartice u bilokakvom okruženju.
Kad se nađu prvi normalni review-i onda ćemo moć raspravljat a do tada je sve ovo samo nagađanje.
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 01.11.2006., 18:27   #46
Postovi: 7,568
Sources in Taiwan again confirmed that Nvidia's upcoming GPU (graphics processing unit) GeForce 8800 (formerly codenamed G80) is designed to fully support Microsoft's DirectX 10 Shader Model 4.0 technology. Nvidia is scheduled to officially launch the new GPU on November 8, the sources said.
The sources also revealed that two expected versions of the GeForce 8800, the GeForce 8800 GTX and the GeForce 8800 GTS, will vary in features such as the number of stream processors (128 and 96, respectively), core clock (575MHz and 500MHz) and shader-engine clock (1350MHz and 1200MHz). Both versions will be SLI ready, with 16x full-screen antialiasing and 128-bit floating-point high dynamic-range (HDR) lighting technology.
Using Nvidia's reference designs, makers will roll out graphics cards equipped with a recommended 768MB or 640MB of on-board memory for the GeForce 8800 GTX and the GeForce 8800 GTS, respectively, the sources stated. With a different memory clock (900MHz versus 800MHz) and memory interface (384-bit versus 320-bit), the cards will vary in memory bandwidth (86.4GB/s versus 64GB/s) and texture fill rate (36.8 billion versus 24 billion texels per second), according to the sources.
Taiwan-based graphics-card makers are now completing their last-minute preparations to launch their own products in line with Nvidia's launch in the middle of next week, the sources said.
Izvor: DigiTimes
Staro 02.11.2006., 16:24   #47
Postovi: 7,568
The 8800 launch is a hard one, so expect partners to have boards in store for the big day's press conference at 11AM on the 8th. The board delivery will go in several waves, with the first two separated by days. The boards were designed by ASUSTeK, and feature a departure from usual suspects at Micro-Star International. This is also the first ever black graphics card from nVidia. Bear in mind that every 8800GTX and 8800GTS is manufactured by ASUS.
Both GTS and GTX are maxing out the CPUs of today, and even Kentsfield and upcoming 4x4 will not have enough CPU to max out the graphics card – G80 chip just eats up all the processing power that a CPU can provide to them.
Having said this, expect fireworks with AMD's 4x4 platform once that true quad-core FX become available.
Članak
Gainward will be amongst the first to have the Geforce 8800 GTX ready for the market.
Staro 03.11.2006., 16:15   #48
Postovi: 7,568
Performanse 8800GTX kartice
Expect NVIDIA’s GeForce 8800GTX and 8800GTS graphics cards to be available next week. As NVIDIA has had plenty of time to ramp up production and ship out cards, this will be a hard launch with immediate availability.
Izvor: DailyTech
EDIT:
Leadtek will be the first manufacturer to offer two variants of GeForce 8800GTX and GTS boards.
Launch version of PX8800GTS TDH
Modified version of PX8800GTS TDH
The new cooler offers small holes in the front, cooling the part of the PCB with power regulation as well. It seems that these boards could overclock a bit higher, since recorded temperatures in this part of the PCB have always been record high.
Izvor: Inquirer
Staro 06.11.2006., 20:42   #49
Postovi: 7,568
As reported by bit-tech this morning, there are in fact problems with new GeForce 8800 GTX cards in the field and this does include North America. The problem is related to one single resistor on the 8800 GTX. It seems that after 3 to 4 hours of solid gameplay, the 8800 GTX will possibly hard-lock your entire system. The 8800 hard-launch is scheduled for this Wednesday and we are hearing that NVIDIA is doing everything possible to pull all of the cards back in, get them repaired, and then shipped back out to retailers.
While we could not get any public comments currently from North America add-in-card partners, it is our understanding that NVIDIA is taking the issue head-on and reacting in the ways needed in order to fix the issues. For those of you that are not in the know, it has become commonplace for Flextronics in China to build the first runs of high-end new-release video cards for NVIDIA that are then dealt to the AIC partners for branding. So yes, this resistor problem does impact “all” of the cards in North America and Europe.
It was however explained to us that this problem is not present on the first-run 8800 GTX cards that went out to reviewers, so reviews that you read on Wednesday should not reflect the issue. Certainly we will keep you up to date. But is seems that NVIDIA is doing everything possible to make sure this problem does not manifest itself in the hands of its early adopters of GeForce 8800 technology. This problem does not extend to the GeForce 8800 GTS.
Ujesh Desai, NVIDIA’s General Manager of the GPU group, had this to say when we asked him for comment on the story.
You got it 100% correct. Some GeForce 8800 GTX boards that were built through our contract manufacturer had a simple BOM error - wrong resistor value. GeForce 8800 GTS boards are not affected by this. We have been working with our Add-In-Card vendors to change the resistor to the correct value. We should still be able to hit our hard launch this week (Nov 8th) with the new GeForce 8800 GTX boards, so this should not be an issue for end users.
Izvor: [H]ard|OCP
Staro 08.11.2006., 15:59   #50
Postovi: 7,568
nVidia is set to announce its G80 GeForce 8800 series graphics processors today. The new G80 GeForce 8800 series graphics processors introduce new features such as unified shaders, nVidia’s GigaThread technology, Quantum Effects physics processing, 128-bit floating point HDR lighting, 16x anti-aliasing and full support for Microsoft’s upcoming DirectX 10 with shader model 4.0 support.
  • eVGA today will release its GeForce 8800 GTX and 8800 GTS based graphics cards as well. As with most nVidia graphics card releases, the eVGA e-GeForce 8800 GTX and e-GeForce 8800 GTS match nVidia’s reference specifications. Nevertheless, the eVGA e-GeForce 8800 GTX and e-GeForce 8800 GTS feature dual dual-link DVI outputs and TV output capabilities. The TV output capabilities include component, S-Video and composite video outputs.
  • ASUS announced one GeForce 8800 GTX and another GeForce 8800 GTS card earlier this morning. Both cards will be bundled with Ghost Recon Advanced Warfighter. ASUS is also one of the few manufacturers that openly claims HDCP support, even though the compliance is present on all 8800-series cards launching today.
  • MSI will also be releasing GeForce 8800 GTX and GeForce 8800 GTS based products. The MSI NX8800GTX and NX8800GTS follow nVidia specifications like eVGA. Nevertheless, the cards support dual dual-link DVI and HDTV outputs. MSI NX8800GTX and NX8800GTS graphics cards feature Dual CoreCell technology and include MSI specific utilities. These utilities include MSI StarOSD for tweaking and MSI Advanced Live Update Online for automated BIOS updating.
The GeForce 8800 powerhouse was announced earlier today with much fanfare, but it appears as more products are already in the pipeline. According to internal NVIDIA roadmaps released yesterday, the company is expecting at least one more G80 derivative in February of 2007.
Leadtek i eVGA 8800GTX Review
Renderiranje i 8800GTX kartica...Adriane Curry na zadatku
Izvor: DailyTech i Inquirer
Staro 08.11.2006., 19:38   #51
Postovi: 7,568
Brutala za mase...DFP ergela
SPARKLE Computer Co., Ltd., the professional VGA card manufacturer and supplier, today releases next generation firepower by announcing Calibre P880+ GeForce 8800 GTX and Calibre P880 GeForce 8800 GTS video cards. With unparalleled gaming firepower and high efficient TEC active cooler system for aerospace integrated, the two new flagship products from SPARKLE, Calibre P880+ and Calibre P880 video cards elevate hard-core gamers' experience to the next plateau of DirectX 10 era.
Topla voda...
Besides all these advanced features, Calibre P880+ and Calibre P880 video cards are fused with the high efficient TEC active cooler system co-developed by MACS Technology Inc and SPARKLE, which creates your ultimate gaming experience. This high efficient TEC active cooler system co-developed by MACS Technology Inc and SPARLE absorbs aerospace technologies used in NASA's space shuttle cooling territory. It employs aerospace technologies such as thermal transducer, aerodynamics, heat transfer and embedded software control for cooling the possibility of overheat problem on G80 GPU. This high efficient TEC active cooler system includes thermal electric cooler, quad heatpipes and dual 8 cm fans to create your ultimate gaming experience.
Crvenokosa kanađanka dijeli neke sličnosti, a možda i kupuje u istom dućanu.
Članak: 1, 2
Review: 1, 2, 3
Izvor: DailyTech, Madshrimps, Gamepyre, TweakTown i GotFrag Hardware
Staro 08.11.2006., 23:51   #52
Jelc
Super Moderators
Postovi: 17,485
Staro 09.11.2006., 10:37   #53
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,882
Staro 11.11.2006., 13:00   #54
Postovi: 7,568
Review:Izvor: OCWorkbench i Legit Reviews
Staro 12.11.2006., 18:53   #55
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Et, da ne otvaram novi topic, stavit ću to ovdje. Shamino (s vr-zone) se malo igrao s 8800GTX i EVGA 680i pločom, rezultate možete vidjeti ovdje
I5 3350P
XFX XTR 650W
Silencio 650
Staro 13.11.2006., 19:25   #56
Postovi: 7,568
Pet nadolazećih G80 derivata
Nvidia has already taken steps to reduce the amount of data leaks from their software. But, apparently they forgot about a leaked version of ForceWare 96.94. Nvidia provided this driver to the G80 reviewers and it seems that someone leaked it out. If you will open a file called “modes.txt” from the ForceWare 96.94 package, you will notice a few new G80 strings:
That particular file contains Resolution settings and Refresh Rates for the entire GeForce family. As you can see in the screenshot above, you will see five new settings of an unnamed G80 based GPU. Yes, I’m talking about: G80-200, G80-400, G80-600, G80-850 and G80-875. Every one of these devices already appears in the “modes.txt” file and has a unique device ID. Since there are already records, we can assume that nVidia is currently testing these and have plans for them.
Izvor: NGOHQ.com
Staro 20.11.2006., 16:25   #57
Postovi: 7,568
Pada interes za G80...čeka se G84 i G86
nVidia's launch of its DirectX 10-compliant GeForce 8800 GPU (codenamed G80) earlier this month seems to have failed to significantly stir up demand for high-end graphics cards, although the new chips took a lead in 3D computing processing, according to sources at Taiwan-based graphics card makers.
Since the G80 is preliminarily targeting the high-end sector, the sources pointed out that nVidia's forthcoming G84 and G86 GPUs for the entry-level and mid-range segments are likely to play a key role in the GPU market, with the two new GPUs expected to debut in the first quarter of 2007.
Although details of the G84 and G86 are still not available, nVidia has completed the roadmap for the two chips, with local graphics card makers likely to receive product samples in January or February of next year.
The introduction of the G84 and G86 will help nVidia extend its DirectX 10-compliant GPU lineup and strengthen its ability to effectively compete with ATi's upcoming DirectX 10-enabled R600-series GPUs. The market generally expects ATI Technologies to launch its R600-series GPUs in the first quarter of 2007.
Izvor: DigiTimes i Madshrimps
Staro 05.12.2006., 17:11   #58
Postovi: 7,568
G80
The overclocked G80 will eventually see daylight. The only question is when the manufacturers are going to win this fight. Realistic date, would be January 2007. This would allow Nvidia to give manufacturers a chance to make a faster clocked card and the market is here to embrace it.
G84
We only know that the chip is derived from G80 and will have less real pipelines and of course will end up smaller. It is scheduled for late March or early April 2007 introduction and we can also confirm that AMD won't have its mainstream DirectX 10 to compete with this in time. So this one might once more be the dominant mainstream chip in the market.
This means the birth of $199 to $249 DirectX 10 part is not that far away after all. End of 2007 will be DirectX 10 hardware for everyone as both Nvidia and ATi will full switch to DX 10 compatible chips and will try to get rid of the DirectX 9 parts as soon as it gets.
Izvor: Inquirer
Staro 06.12.2006., 10:37   #59
bozzomfeeder
bozzomfeeder's Avatar
Lokacija: Sinj
Postovi: 1,080
hehe,čeka se 8600 : goood :
bozzomfeeder je offline   Reply With Quote
Staro 10.12.2006., 23:13   #60
Postovi: 7,568
Overclockirane OCZ G80 kartice
OCZ Technology Group, a leading supplier of memory modules aimed at overclockers and performance computing enthusiasts, plans to re-enter the graphics cards business in the forthcoming weeks by launching graphics card products based on the GeForce 8800-series chips running at speeds beyond recommended by Nvidia Corp.
OCZ Technology pulled out of the graphics cards market back in 2001 with the pre-overclocked GeForce 3-series graphics cards that have never become popular. This time the company seems to be confident about its success on the market. Nvidia Corp. currently does not allow to pre-overclock the flagship GeForce 8800-series graphics cards to its partners following the scandal with broken pre-overclocked GeForce 7900-series boards. However, a source close to OCZ pointed out that the company would not pre-overclock the cards, but would pre-test the boards for overclocking.
Izvor: X-Bit Labs
