Staro 13.09.2006., 19:18   #1
Postovi: 7,568
Question G80...nagađanja i glasine
It's a 90 nanometre chip with GDDR4 memory support and that it is diss-unified marchitecture and that it is taped out but a release date is an enigma caught in a graphics processor engine dilemma.
The first working sample of a chip carries A0 revision, while companies usually launch A2 revisions commercially. It usually takes several – up to 10 – weeks to build a new chip revision, which means that it is unlikely that the G80 would be production-ready by September.
The arrangement of the chip, it is about a 400mm die. One of the reasons it is so big is the whole dual core rumor that has been floating around. G80 is not going to be a converged shader unit like the ATI R500/XBox360 or R600, it will do things the 'old' way.
nVidia is heavily downplaying the DX10 performance, instead shouting about DX9 to anyone who will listen. If the G80 is more or less two 7900s like we hear, it should do pretty well at DX9, but how it stacks up to R600 in DX9 is not known. R600 should annihilate it in DX10 benches though. We hear G80 has about 1/3 of it's die dedicated to DX10 functionality.
The G80 chip now looks like a late 2006 chip and it will fight the R600 beast also scheduled for a very late 2006, when even the mice slumber. It should hold the performance crown until ATI's RD600 is released sometime around November/December. The G80 is shaping up to be a patchy part. In some things, it may absolutely scream, but fall flat in others. The architecture is looking to be quite different from anything else out there, but again, that may not be a compliment. In either case, before you spend $1000 on two of these beasts, it may be prudent to wait for R600 numbers.
Izvor: Inquirer, MVKTech, AnmarTech i X-bit Labs
Staro 19.09.2006., 16:40   #2
Postovi: 7,568
G80 = GeForce 8800GT/GTX
GeForce 8800GT/GTX kartice:
  • Unified Shader Architecture
  • Support FP16 HDR+MSAA
  • Support GDDR4 memories
  • Close to 700M transistors (G71 - 278M / G70 - 302M)
  • New AA mode : VCAA
  • Core clock scalable up to 1.5GHz
  • Shader Peformance : 2x Pixel / 12x Vertex over G71
  • 8 TCPs & 128 stream processors
  • Much more efficient than traditional architecture
  • 384-bit memory interface (256-bit+128-bit)
  • 768MB memory size (512MB+256MB)
  • Two models at launch : GeForce 8800GTX and GeForce 8800GT
  • GeForce 8800GTX : 7 TCPs chip, 384-bit memory interface, hybrid water/fan cooler, water cooling for overclocking. US$649
  • GeForce 8800GT : 6 TCPs chip, 320-bit memory interface, fan cooler. US$449-499
G80 gonna be unified shader after all. It should be pretty close to the truth and it explained the mystery of the strange DRAM capacities that INQ reported previously. Expect G80 to be out somewhere in mid November along with Kentsfield.
Izvor: VR-Zone
Staro 19.09.2006., 17:22   #3
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Interesantno. Vrlo interesantno. Bit će zanimljivo oko Božića
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline   Reply With Quote
Staro 19.09.2006., 18:47   #4
bozzomfeeder
bozzomfeeder's Avatar
Lokacija: Sinj
Postovi: 1,080
to se čeka : goood :
bozzomfeeder je offline   Reply With Quote
Staro 19.09.2006., 19:04   #5
Quake2
Quake2's Avatar
Lokacija: pž
Postovi: 1,291
Pa koliko će se onda tek g80 zagrijavati kad ima oko 700m tranzistora,takt jezgre do 1.5ghz,proizveden sa 90nm,a za r600 su rekli oko 180w...A r600 ima oko 500m tranzistora te je 80nm
Quake2 je offline   Reply With Quote
Staro 19.09.2006., 19:05   #6
malba
schwere panzerspitze
malba's Avatar
Postovi: 313
Autor Zvijerko Pregled postova
taman da se do tada isplate krediti za hižu i t55...: : bonker :
usput, ima li kakvih glasina o potrošnji? spominjalo se 150w? nek 2 takva gpu-a spoje u 1 karticu ako su face
i to za core clock do 1,5 ghz mi je malo previše ako su sad na koliko? 650 sa 7900gtx-om?
malba je offline   Reply With Quote
Staro 19.09.2006., 19:13   #7
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
Autor Quake2 Pregled postova
ja sam negdje vidio da ce R600 gutat 250W
danij3l je offline   Reply With Quote
Staro 19.09.2006., 19:55   #8
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Mene samo zanima, jel ce bit toga na AGP-u... : nuts :
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 19.09.2006., 20:04   #9
Quake2
Quake2's Avatar
Lokacija: pž
Postovi: 1,291
@danij3l:To je inq najprije napisao,ali danas je bila vijest da je to laže i da trože do 180w...
Staro 19.09.2006., 20:21   #10
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Autor Panzer Pregled postova
čisto sumljam,za AGP bi onda trebalo oko 4 konektora za napajanje na grafu brutalno....hahahahaha
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 19.09.2006., 20:51   #11
domy_os
domy_os's Avatar
Postovi: 18,894
Ti već kuješ planove za kupovinu... Neće bit na AGP-u!
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 19.09.2006., 21:48   #12
marauder16
upgrading...
Lokacija: Zagreb->G.Dubrava
Postovi: 438
takvu karticu stavit na agp, to bi ju ugusilo
aj dobro da nije 250W, kaj bi trebali imat bar 1kW da sve to napajamo na OCu, 180W je jos razumljivo...
to understand...
marauder16 je offline   Reply With Quote
Staro 19.09.2006., 21:50   #13
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
180W nije malo dečki. Vidjet ćete kolko će se to grijat, pogotovo kada se za ovu 8800GTX piše da će je valjda hladit voda...
Staro 19.09.2006., 21:58   #14
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
We heard that G80 will be in time for launch in June during Computex and the process technology is likely to be 80nm at TSMC. In the recent statement, NVIDIA has said that they will be backing the 80nm "half-node" process by TSMC where it allows reduction of die size by 19%. We have previously mentioned that G80 is likely to take on the Unified Shader approach and supports Shader Model 4.0. G80 is likely to be paired up with the Samsung GDDR4 memories reaching a speed of 2.5Gbps. As for ATi, the next generation R600 is slated for launch end of this year according to the roadmap we have seen and the process technology is 65nm. It seems that the leaked specs of the R600 that surfaced in June last year is pretty likely.
According to Xpentor, NVIDIA G80 will make ATI stumble on April. Quad SLI itself can be implemented on a single card with two chips solution because it will carry the first dual core GPU ever with the support of DirectX10 and Shader Model 4.0. The development of G80 is also mentioned as being running very intensive since NVIDIA's acquisition over ULi. As for the upcoming G71, there will be 32pipes, increase in ROPs and a little speed bump over the core clock.
* 65nm
* 64 Shader pipelines (Vec4+Scalar)
* 32 TMU's
* 32 ROPs
* 128 Shader Operations per Cycle
* 800MHz Core
* 102.4 billion shader ops/sec
* 512GFLOPs for the shaders
* 2 Billion triangles/sec
* 25.6 Gpixels/Gtexels/sec
* 256-bit 512MB 1.8GHz GDDR4 Memory
* 57.6 GB/sec Bandwidth (at 1.8GHz)
* WGF2.0 Unified Shader
blup
mc_fish je offline   Reply With Quote
Staro 19.09.2006., 22:04   #15
Postovi: 7,568
Ma nek se grije, nek troši, nek košta...glavno da kartice tipa 7900GS, 7900GT, X1900GT/X1950Pro i X1900XT (nakon izlaska i dolaska G80 i R600) još "malo" pojeftine. S ovim cijenama i potrošnjom G80 bude (ako ništ drugo, onda bar u prvom mahu nekolko mjeseci) rezervirana za DFP konfiguracije. Valjda (jer kak je krenulo, ko zna de im je kraj s tim zahtjevima) budu kasnije stigli derivati kolko-tolko normalnije/prihvatljivije potrošnje i pristojne cijene i zadovoljavajućih performansi.
Staro 19.09.2006., 22:23   #16
bozzomfeeder
Lokacija: Sinj
Postovi: 1,080
bože sačuvaj : stoopid
Staro 20.09.2006., 00:20   #17
Panzer
Panzer's Avatar
Postovi: 1,814
Autor domy_os Pregled postova
Yup, mora se...
A onda nista... Mogu se samo nadat da ce neka okrljastena verzija izac...
UPGRADED...
Staro 20.09.2006., 08:32   #18
peroW1
peroW1's Avatar
Lokacija: Croatia Čk
Postovi: 551
Mozda Gainward opet iznenadi ajd ne mora biti GTX, ali ipak...
A za jezgru mi se cine malo preoptimisticni, no ako bude sve kao sto sad stoji na papiru, bit ce to stvarno veliki napredak u odnosu na sadasnje...
i5 2550K 4.1GHz *Gigabyte Z77-D3H, 32 GB RAM KINGSTON HYPER X FURY, ASUS GTX 1060Ti , SSD 1TB, CoolerMaster 850W, ASUS 32'' 4K
peroW1 je offline   Reply With Quote
Staro 06.10.2006., 09:38   #19
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Tipovi na Dailytech su se uspjeli dočepati 8800GTX i 8800GTS kartica. Specifikacije 8800GTX bi trebale biti slijedeće:
-jezgra na 575MHz
-768mb DDR3 (?) memorije na 900MHz na 384-bitnoj sabirnici (oko 86GB/s)
-128 unified shadera koji rade na 1350MHz
- preporučeno napajanje za ovu karticu je 450W
Za 8800GTS:
-jezgra na 500MHz
-640MB DDR3 na 900MHz i na 320-bitnoj sabirnici (oko 64GB/s)
-96 unified shadera koji rade na 1200MHz
- preporučeno napajanje za ovu karticu je 400W
Detaljnije ovdje
EDIT: Na dailytechu bi se danas-sutra trebalo naći i objašnjenje arhitekture. Meni je kao i mnogima zapelo za oko ono na koliko radi chip, a na koliko unified shaderi
I5 3350P
XFX XTR 650W
Silencio 650
Staro 06.10.2006., 23:08   #20
Kimi
Kimi's Avatar
Postovi: 652
-jezgra na 575MHz
Za 8800GTS:
-jezgra na 500MHz
Detaljnije ovdje
ddr3 memorija??????????....šta neće ići GDDR4...to je 100% neka greška: nono :
Kimi je offline   Reply With Quote
Staro 06.10.2006., 23:42   #21
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Pa zato je taj upitnik kraj toga. To i mene jako iznenadilo.
I5 3350P
XFX XTR 650W
Silencio 650
Staro 07.10.2006., 01:51   #22
kalixius
...carpe diem...
kalixius's Avatar
Lokacija: Zagreb - okolica
Postovi: 1,363
pa nek samo pojeftine DX9 grafe i milina.
: cheers2
kalixius je offline   Reply With Quote
Staro 21.10.2006., 14:07   #23
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Eto prvi preview 8800GTX i 8800GTS kartica. Više ovdje na engleskom, a na njemačkom (original) ovdje
I5 3350P
XFX XTR 650W
Silencio 650
Staro 21.10.2006., 21:03   #24
Svabo
Svabo's Avatar
Postovi: 69
tu se isto spominje gddr3 mema??? el moguce da su i oni pogrijesili?
Svabo je offline   Reply With Quote
Staro 21.10.2006., 23:12   #25
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Moguće je da je GDDR3 jer koliko sam čitao da je samsung zeznio neke GDDR4 i da prijeti nestašica istih.
I5 3350P
XFX XTR 650W
Silencio 650
Staro 22.10.2006., 01:11   #26
smoks1
smoks1's Avatar
Postovi: 343
tko ce imat novcica za to?!
Za te novce mora da mi,kavu kuha i pravi sendvice!!
smoks1 je offline   Reply With Quote
Staro 22.10.2006., 12:11   #27
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Uvijek je netko spreman dati novce za to. Nije ništ puno jeftinija bila ni 7800GTX kad je izašla. IMHO te kartice nije pametno kupovati prije izlaska ATi-jevog R600 jer sumnjam da će nešt posebno past cijena do tad
I5 3350P
XFX XTR 650W
Silencio 650
Staro 23.10.2006., 10:47   #28
Dexxy
jos nigdje nema nekakvih testova...
Staro 23.10.2006., 12:48   #29
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Bit će nakon 8.11. kada NVidija namjerava i pustiti karticu u prodaju
I5 3350P
XFX XTR 650W
Silencio 650
Staro 23.10.2006., 19:50   #30
peroW1
peroW1's Avatar
Postovi: 551
Ma polako. To ce cudo imat paprenu cijenu, oko 5kila kuna sigurno.
A nakon mjesec-dva, najvise 3 ce vec izaci poboljsanje verzije od inicijalne koja tek treba izaci.
