Staro 29.08.2006., 12:10   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Koji potenciometar za 5.25" utor?
Dakle, trebam potenciometar koji stane u utor za optiku, i da ima barem kontrolu za 4 venta...
Mislio sam piknut Zalman ZM-MFC1, ali neznam kakav je...
Jel ga ima mozda netko?
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 29.08.2006., 12:40   #2
bego2
bego2's Avatar
Postovi: 2,724
Zalman mi se čini najboljim.
bego2 je offline   Reply With Quote
Staro 29.08.2006., 12:54   #3
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
zalman zm-mfc1
nema dileme
imam ga...kakav je? odlican...
Ph03n1x je offline   Reply With Quote
Staro 29.08.2006., 13:01   #4
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Zalmana uzmi svakako jako dobar potencimetar,imam ga pa znam o čemu govorim...
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 29.08.2006., 13:10   #5
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
25kn sharkon uzmi 4 komada. Zbusi front panel i stavi si to. Najbolje, najjeftinije i najljepše. Nema dosadnih ledica. Velki je i nemoras ga napipavat noktima.
Staro 29.08.2006., 13:28   #6
raf
šlap
raf's Avatar
Lokacija: Zagreb, centar
Postovi: 939
imam zalmana i stvarno je odlican, ali problem je ako imas vrata na kucistu pa ga ona moras fiksirati par centi unutra, ali onda te ne smetaju ledice. a ledice su stvarno jake i mislim da ce ti jako smetat ukoliko ti je kuciste na stolu pa ce ti svjetlit u oci sto je stvarno bolno preko noci...
raf je offline   Reply With Quote
Staro 29.08.2006., 13:46   #7
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ja sam mislio uzeti ovoga:
http://www.feniks-kompjutori.hr/info.asp?id=0901051
Ali onda sam skužio da mi ni netreba kad sam kupio ploču sa vent regulacijom jer imam dva pod regulacijom i dva koja nisu ali jedan je od PSU i regulra se sam a drugi je 2500rpm Coolermster i nije bučan a radi taman propuha kolko treba...
Have a nice day...
Staro 29.08.2006., 13:55   #8
Lihto
Lihto's Avatar
Postovi: 3,945
Autor yedwy Pregled postova
moraš si provjerit sluh ak ti 2500rpm nije bučno,nego na abitici je i meni bilo fino rješeno samo ubodem u ploču i u biosu narihtam,al pošto toga nema na asusici morao si uzet zalmana i nije mi žao...
iPhone XR 128gb
Staro 29.08.2006., 16:41   #9
Panzer
Panzer's Avatar
Postovi: 1,814
Hm, izgleda da cu onda uzet ovoga kaj je yedwy mislio uzet.
Zalman je dost skuplji, a i te ledice... Ne volim light show na kompu.: baad :
Jedino me strah kod tak jeftinih stvari da se ne zdimi za par dana...
Fakat neznam sad, ovaj SPIRE Regulator - EE-SC02 ok zgleda, nema ledica i jeftin je. To kaj je pinky nema veze, tak cu ga u crno spricat. Strah me da nije full nekvalitetan...
Zalman je pak ok, sve super i onda te ledice...
Pocupat cu ih ako ga kupim.
UPGRADED...
Staro 29.08.2006., 18:29   #10
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Issss... Koja boja za spirea.
Znam kaj cu bubbi kupit za rodjendan
Ali i dalje ne kuzim zakej ne napravis ovo kaj sam ti ja reko.
