Staro 28.08.2006., 18:27   #1
Vasili
Vasili's Avatar
Lokacija: Križevci
Postovi: 307
6800GS u ultru
Jel je ovo dobar opis kak se otključava 6800GS u ultru:
SOFTMODDING
Softmodding for GPUs is basically defined as tweaking the card using a certain softwares to enhance performance. The softmodding I am talking about here is limited to unlocking of masked pipes on your GPU. I recommend the use of Riva Tuner for softmodding as well as overclocking. The latest version is V2.0 which supports the latest nVidia WHQL 77.72 drivers.
How to unlock pipes ?
Well to start with, unlocking means using extra pipes that the GPU supports but have been masked by the manufacturer for either commercial or other reasons. Now the chipset is fully capable of using these pipes. Unlocking of pipes is best for LE editions, NU cards and stepped down or underclocked versions of higher cards.
Quote:
1. Run RivaTuner and look at the main tab. You'll see your current graphic processors configuration and amount of active pixel / vertex units in device status string, for example: NV40 (A1,12x1,5vp).
2. Click "Customize" button located at the right of device status string to activate device customization toolbar.
3. Click "Graphics subsystem diagnostic report" button in device customization toolbar to activate RivaTuner's diagnostic module.
4. Scroll down "Report categories" list and tick "NVIDIA VGA BIOS information" report category.
5. Click "Capture report" button in the "Report preview" window to refresh report.
6. Scroll down "Report preview" window and find "NVIDIA VGA BIOS information" manually or simply double click "NVIDIA VGA BIOS information" category name in the "Report categories" list to automatically navigate to "NVIDIA VGA BIOS information" in the "Report preview".
7. Look at line displaying "SW units mask". If you see "none" there, it means that VGA BIOS allow activating all non-hardware masked GPU pixel / vertex units, so your configuration is determined by hardware. In this case, I strictly recommend you to forget about softmodding if you are beginner and if you don't understand what do you do exactly. Power users may proceed and try to activate hardware masked units. If you see something different there (for example, pixel 0001b, vertex 000000b) - you have high chances to unlock software locked units.
8. Click "Low-level system settings" button in device customization toolbar to activate "Low-level system tweaks" panel.
9. Select "NVStrap driver" tab.
10. Press "Install" button if you never installed the driver before. If you already have it installed after the previous version of RivaTuner, ensure that you have followed RivaTuner's warning and updated driver when RivaTuner offered you to do it. If you have mistakenly ignored the warning, simply press "Reinstall" button to update the driver manually.
11. If you are a power user, if you have read the previous questions carefully and understand what does the "Allow enabling masked units" option do, and, the most important, if you understand what side effects can it cause - enable this option. Otherwise proceed with enabling software masked units only.
12. Select "Custom" in the "Active pixel/vertex units configuration" list to activate the "Customize" button, then click it to activate "Custom graphics processor configuration" dialog.
13. Tick all disabled pixel and vertex units and click "OK".
14. Reboot system when prompted.
16. Start RivaTuner and look again at your current graphics processor configuration and amount of active pixel / vertex units in device status string. If you see no changes there - the units you tried to unlock are hardware masked and you have not enabled "Allow enabling hardware masked units" option. Otherwise, if you see desired configuration, - proceed with system stability testing to ensure that unlocked units are really fully functional.
Whew ! That was quite a lot...
OVERCLOCKING
Compared to softmodding, overclocking is somewhat easier !
Note: Overclocking can be more dangerous than softmodding and I don't take any responsibility for problems caused due to overclocking.
Overclocking in 5 simple steps :
1.Open Riva Tuner and under driver settings locate low level system settings.
2. There you will see you your current clock settings. Select Performance 3D from the menu.
3. Then slowly increase your core clock by about 10 Mhz and memory clock by about 15-17 Mhz depending on your card.
4. Click on the test changes button and wait for it to test the stability of your card.
5. Keep doing this till you find your system unstable and thn revert back to the best settings. Use games like Far Cry, Doom 3 and software like 3D Mark to test the stability of your overclock.
Malo sam n00b u ovome pa me prosvijetlite : sweating
E sad: ovo SW units mask ja nigdje nemrem nać?!
Tick all disabled pixel and vertex units and click "OK". meni je tu takvih još 20, nije to malo previše?
Jel je sve ovo stvarno tak opasno kako je autor teksta napisao?
Ne bi baš htio novu grafu skurit...: suicide
Vasili je offline   Reply With Quote
Staro 28.08.2006., 18:35   #2
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Ako ne vidiš SW units mask pročitaj ovaj dio malo bolje:
Otključavanjem ne možeš skuriti grafičku, ali ti se mogu početi pojavljivati artefakti. Ako ti se to dogodi, znači da oni zaključani pajplajnovi nisu ispravni te ih trebaš ugasiti i sve se vraća na staro.
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline   Reply With Quote
Staro 28.08.2006., 18:36   #3
Red_Dragon
Lost soul still wondering
Red_Dragon's Avatar
Lokacija: Aiur
Postovi: 474
Daj ti napiši koju karticu posjeduješ. Jel to 6800 GS pci-e? Ako je nemaš što tu otključavati.
EDIT:
vidio sam tvoj post u drugom topicu. Zaboravi ovo gore.
Da nije nas bile za grabu bi spal
Zadnje izmijenjeno od: Red_Dragon. 28.08.2006. u 18:51.
Red_Dragon je offline   Reply With Quote
Staro 28.08.2006., 18:53   #4
Vasili
Vasili's Avatar
Lokacija: Križevci
Postovi: 307
Da, kad je ovo ˝none˝ pod navodnicima onda sam mislio da će pisati none pod SW units mask... Ma dobro, nema veze. Uglavnom, jel me to sprečava da otključam pipove?
Imam AGP Gainward Bliss 6800GS. Znam da se pci-e verzija neda otključat.
Staro 28.08.2006., 18:59   #5
Vasili
Vasili's Avatar
Lokacija: Križevci
Postovi: 307
Dragon, kak to da ti GPU radi na 520MHz, a memorija na 1200?
Meni memorija radi na preko 1300, ali GPU nejde iznad 470-480.
BTW, s grafičkom sam dobio EXPERTool za fan-control i overclocking. Jel je bolje to sve raditi u Riva Tuneru?
Staro 28.08.2006., 19:07   #6
Red_Dragon
Red_Dragon's Avatar
Lokacija: Aiur
Postovi: 474
Zato kaj je to nv 42 (jezgra) koji je izgrađen u manjem proizvodnom procesu i dobro se clocka default je 425. Jel ti isto imaš nv 42, mislim da je na tvojoj nv 40 ali nisam siguran. Moja kartica je pci-e, a memoriju neću silovati previše. Riva tuner je dobar za clockanje, ja osobno clockam iz modanih xg drivera.
Staro 28.08.2006., 19:20   #7
Vasili
Vasili's Avatar
Lokacija: Križevci
Postovi: 307
Ja imam nv41.
Dajte mi samo onda još recite za ono ˝Tick all disabled pixel and vertex units and click "OK".˝ Znači moram obilježit svih 20?
Staro 28.08.2006., 20:36   #8
maX
maX's Avatar
Postovi: 7,326
Samo gdje ti pise pokraj Vertex Unit i Pixel Unit tamo treba biti sve oznaceno, 6800GS je 12,6 kolko ja znam, pa ti pokraj jednog Vertex Unita nema kvacice i pise ti pod State: Disabled... ako ce ti raditi bez artefakata mozes i modat bios i preflashat grafu tako da ti "zauvijek" ostane otkljucana
Staro 28.08.2006., 21:53   #9
Vasili
Vasili's Avatar
Lokacija: Križevci
Postovi: 307
Evo kak to meni izgleda.
Ja tu ne vidim više ništa disabled!
Staro 28.08.2006., 23:18   #10
CRO_VET
CRO_VET's Avatar
Lokacija: Šestanovac
Postovi: 398
nema šanse vasili...6800 gs je sam po sebi poseban proizvodni proces,vidiš da ti u grafu ništa ne piše da je masked,poredak je takav kakav je..
CRO_VET je offline   Reply With Quote
Staro 28.08.2006., 23:38   #11
Vasili
Vasili's Avatar
Lokacija: Križevci
Postovi: 307
Oćeš reć da ja tu više nemam šta otključat ili...?
Svi mi cijelo vrijeme govore da se gs da otključat pa sam malo zbunjen
Staro 29.08.2006., 17:59   #12
Brain32
Brain32's Avatar
Postovi: 498
Nazalost nemaš kaj otkljucat...
Brain32 je offline   Reply With Quote
Staro 29.08.2006., 18:22   #13
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Autor Vasili Pregled postova
Ja imam nv41.
Nemaš što, NV40 i 45 imaju 16 pipelineova,dok 41 ima 12 i točka
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
