Staro 29.05.2006., 21:26   #61
trpi
ak ona tolko puno(to je dosta za jednu grafičku, ne?, bar uspoređujući sa potrošnjom moje sada 6600gt), kolko onda 1900gt ak ona troši još više?
Staro 29.05.2006., 21:46   #62
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor trpi
Nemam pojma.
AIW 1900 ima isto 256 MB kao i X1900 GT, potrošnja je u loadu oko 287.
X1900 GT ima 4 pajpe i 12 pixel shadera manje od AIW. (GT ima veći takt meme)
Pa si otprilike možeš izračunati.
Staro 30.05.2006., 11:44   #63
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor trpi
... recite mi još ovo za potrošnju?
http://sg.vr-zone.com/?i=3335&s=8
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 30.05.2006., 13:52   #64
Mailman
Mailman's Avatar
Postovi: 1,606
http://www.pureoverclock.com/review.php?id=36&page=1
1900GT, 7900GT, 1800XT, 7800GT
HQAF...: nuts :
Mailman je offline   Reply With Quote
Staro 30.05.2006., 14:19   #65
Mailman
Mailman's Avatar
Postovi: 1,606
Autor Jelc
Ma daj, kakav je to test???
Oblivion sa HDR-om i BEZ AA??????
Pa to na ekranu izgleda da se usereš od jada...
Mislim-kaj nisu stavili 4xAA i 8xAF+bloom, onda bi to na nešto ličilo.
Glavno da su stavili 2xAA 16xAF u F.E.A.R.-u....joj...
best playable settings?
Apples to Apples is more typical to what you'd see at other website's. Settings for all the cards are the same, and we do not enable advanced features such as transparent AA or high quality AF. We do enable normal AA and AF where possible (Oblivion being the exception). Typically these will be 4x for AA and 16x for AF as these are currently well established settings for those who like the best image quality. We leave driver settings at defaults, but it should be noted that Nvidia do default there drivers with some aggressive optimizations enabled, though i'm yet to see any reason to turn them off. A good optimization that improves performance but doesn't degrade quality should not be switched off in my opinion.
a hebiga...ne bi vidio razliku ni da stavi atija u quality mod pa opet nije....
Staro 30.05.2006., 14:37   #66
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor Mailman
HQAF...: nuts :
Ovo mi baš i ne liči na 1,4ns čip....više na 1,1ns
http://www.pureoverclock.com/review.php?id=36&page=2
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 30.05.2006., 15:14   #67
Jelc
Super Moderators
Postovi: 17,485
Tip kenja bez-veze...
F.E.A.R. sa 1280x960/16xHQAF/4xAAA daje oko 46fps-a.
A sa 2xAAA kako je on benchao 58.
I sa svim postavkama na High Quality a ne kao kod Nvidie ili ATI CCC-a gdje je po defaultu High.
A kod Obliviona je AF JAKO bitan kaj se tiče kvalitete slike.
Totalna je idiotarija benchati samo sa HDR-om...
Staro 30.05.2006., 15:33   #68
Jelc
Super Moderators
Postovi: 17,485
Autor Wolverine
Stvar je u tome da ti na PCB-u grafe nekaj fali....
Pa ne možeš nafrljiti i GPU i memu kako bi htio.
Ili možeš ali je pitanje koliko dugo.
Uzmi RivaTuner ili ATITool pa pogledaj koliko ti očitava vrc/A vrijednost.
Pod punim opterećenjem.
Svinjski overclock bi mogao izdržati samo jedno vrijeme-a to ti se ne isplati.
Staro 30.05.2006., 15:37   #69
Wolverine
Wolverine's Avatar
Postovi: 12,425
ne ja velim samo da je na onoj slici 1,1ns samsung a ne 1,4ns samsung kako je naveo u tekstu
http://www.samsung.com/Products/Semi...K4J52324QC.htm
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 30.05.2006., 15:51   #70
Jelc
Super Moderators
Postovi: 17,485
Autor Wolverine
A kaj da ti velim?
Grafa nema stabilno/jače napajanje kao XT/XTX, možda možeš dobiti dobar clock za bench ali je pitanje vremena kad bi nekaj crklo ako bi je duže vrijeme tako držao....
Da se može popuniti ono prazno mijesto na PCB-u....to bi bila zvijer....
X1800XT ili X1900XT/XTX se hoće zblokati (pri overclocku) u drugom testu 05, ova ako pretjeraš-u trećem.
Pa ti sam izvuci zaključak.
Staro 30.05.2006., 15:59   #71
Wolverine
Wolverine's Avatar
Postovi: 12,425
znam ja o ćem ti govoriš...
no ti nisi bio shvatio moj post
kako sam čitao onaj review vidio sam pogrešku pa sam je iznio..nisma komentirao taktove niti OC potencijal već ovo:
''The memory found on the Connect3D X1900 GT was Samsung 1.4ns GDDR3 which is theoretically capable of 700Mhz, so perhaps a little overclocking headroom exists, we'll find out soon enough.''
X1900 GT memory
ova izjava uz navedenu sliku ne ide zajedno!
post ranije sam dao link na tablicu sa tim čipom
evo samo sam to htio komentirati...tj zabunu (vjerojatno slučajnu) u tekstu
ili su krivu sliku uploadali ili je naveo krivu memoriju
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 30.05.2006., 16:16   #72
Jelc
Super Moderators
Postovi: 17,485
Ma vidio sam, samo te nisam quotao riječ po riječ...mislio sam da budeš skužio o čem pričam.
Manja je greda taman da i je ta mema gore (dakle da je tip skinuo hladnjak i poslikao a ne koristio sliku iz arhive).
Ali je veći problem kaj toj grafi ne možeš osigurati stabilno napajanje pri jačem overclocku (na duže vrijeme)
Ovim apeliram na naše testere da skinu hladnjak i poslikaju memu..
Da vidimo čija nana crnu vunu prede i koja firma stavlja 1.4 a koja 1.1/1.2ns
Staro 30.05.2006., 17:28   #73
Wolverine
Wolverine's Avatar
Postovi: 12,425
ma znam ja na kaj si ti pucao
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 30.05.2006., 18:50   #74
LARN81
ghotic warrior
LARN81's Avatar
Lokacija: Jastrebarsko
Postovi: 398
Joj daj tak sve jedno kaj kupis obje grafe su dobre cemu komplicirat zivot s +/- 5-10 Fps-a? Kupi ono kaj ti je trenutno financijski isplativije ionako kad dojde DX10 mozes mjenjat
LARN81 je offline   Reply With Quote
