Staro 26.04.2006., 00:07   #1
blondie
blondie's Avatar
Lokacija: split
Postovi: 198
mp3 player
ovako, ja se odlučila na kupnju mp3 playera (512 MB), i nakon duljeg razmatranja zaključila da je dobar ovaj
MP3 Player Speed Player USB 2.0 512Mb LC
Specifications:
USB Flash Drive: USB 2.0 Specification with standard Mini-USB connection
MP3 Player: MP3 & WMA Music Format
Digital Voice Recorder: ADPCM
Language Education: A-B Repeat Function
Internal Memory: 128 / 256 / 512 MB
LCD Display: Sky-Blue Backlight, LCD Display show the statues, ID3 TAG Support
Bit Rate: MPEG 1 Layer 3, Supports 32kbps`256kbps and VBR
Internal FM Tuner: 87.5`108MHz (Auto Scan, 20 presets
Audio Output: 6mW
Audio S/N Ratio: 95dB
Reading Speed: 3200kb/sMas(USB2.0)
Writing Speed: 2000kb/sMas(USB2.0)
Equalizer: Normal/Rock/Jazz/Classical/POP
Voice Sampling Rate: LP 16.0Khz (LP=Extended Recording), HQ 44.1Khz (HQ=High Quality Recording)
Voice Recording: More than 8/16/32 Hours 128/256/512MB)
Timer Setting: Off, 1" 2" 5" 10" Min
Output: 3.5mm Earphone (32Ω)
Power Source: AAA (x1) 1.5 Volt Battery
Battery Life: More than 16 Hours with AAA Alkaline Battery (Continuously)
Data Retention: 10 years
Dimension: 84.5mm x 35mm x 13.5mm
Weight: 36g (Without Battery)
EMI Compliance: FCC, CE, EMI, EMS
Os Support: No Driver needed for windows2000/ME/XP, Driver needed for Windows 98/98SE
**Strongly suggested to install Software under all OS. **
Features:
Aluminum Housing design
FM Radio Range 87.5MHz~108.0MHz (Auto Scan, 20 presets)
MP3 & WMA Music Player
USB Flash Drive (Mini-USB)
Digital Voice Recording
FM Recorder (wav format)
Graphic LCD Display, ID3 TAG (Sky-blue Backlight)
Multi-Language Display
Joystick controller (Volumn+/-, Manu, RW/FF)
Build in 128 / 256 / 512 MB
Repeat Play: Normal/Repeat1/Repeat all/Random/Random All
Digital Tempo Control at Voice Mode (Normal/Slow speed)
Equalizer (Normal, Rock, Jazz, Classical, and POP)
Auto Power Offt
Digital Volumn Control
Utility Program (Format Program, Windows 98 Driver Program)
Je li ima itko iskustva s njim, je li može dobro snimat glas ili vi predložite bolji ako znate
CPU AMD Athlon64 BOX 3200+sck939 // MB Gigabyte K8N-SLI s939 nForce4 SLI // Powercolor Radeon x800gt // 2x256 MB RAM // HDD Seagate 120 GB s-ata150 // DVD+RW/-RW NEC ND-3550ABL // Codegen midi tower 6205L-CA, 400W // Mon. Samsung SM793DF 17" DynaFlat // ASUS TV TUNER My Cinema P7131H Dual
blondie je offline   Reply With Quote
Staro 26.04.2006., 02:35   #2
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
Vjerojatno je OK..
ja imam ovaj :
5666 EUROCOM 512MB MP3 Player, FM-Radio, BLUE 431,29 479,21 1 god. [Proizvod je dobavljiv po narudžbi u roku od jedan do dva dana] Ubaci u košaricu
http://www.ve-mil.hr/cjenik.aspx?GrupaOznaka=mp3playeri
http://www.omisys.com/en/products_se...e=MP3%20Player
Nije los, pogotovo su slusalice koje dodju s njim dosta upotrebljive.
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 01.05.2006., 07:51   #3
blondie
blondie's Avatar
Lokacija: split
Postovi: 198
pa je li ima itko ovaj speed player??????
je li dobar?????
Staro 01.05.2006., 10:03   #4
nicko
Postovi: 4,190
svi ti no-name po cijeni oko 500kn za 512mb su ti isti...samo drugo pakiranje..
ako vec kupujes ja bi ti preporucio Creative Muvo
nicko je offline   Reply With Quote
Staro 01.05.2006., 13:36   #5
immortal
Kernel panic
Postovi: 522
Ja imam Creativa MuVo od 512 MB i radi OK.
Keyboard error or no keyboard present
Press F1 to continue, DEL to enter SETUP
immortal je offline   Reply With Quote
Staro 09.05.2006., 12:56   #6
atha
atha's Avatar
Postovi: 9,069
Sto se tice mp3 playera do kilokuna, bas si malo gledam.
Apple-ovi su preskupi, a imaju samo 512Mb. Svidja mi se Creative Zen Nano+,
Creative Muvo, a nesto manje Teac Mp-200-1.
Ima li tko kakvih iskustava sa ovima ili slicno? Za sada Zen Nano+ izgleda kao prvi izbor.
Btw, sto je sa ovim Lobox-ima sto se nude po Pevecu? MP4 podrska.
___________
Just atha
x
Staro 09.05.2006., 13:05   #7
domy_os
domy_os's Avatar
Postovi: 18,960
Ja sam imao MuVo V200 - prejeben player, posebno mi se sviđa što se može spojit bez kabla, zvuk je jako dobar, jedino mi se ne sviđa što je ekran sitan i player je malo poveći. Pogledaj također iAudio...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 09.05.2006., 13:15   #8
nicko
Postovi: 4,190
ja sam takodjer imao V200, bas mi se svidio....
sad sam na Sony-u E-405, predobar mi je...
iRiver je isto odlican, samo neznam kako se cijene krecu....
a taj ching-chu MP4....radje nemoj.....kinesko smece...ako je to onaj na koji mislim...
Staro 09.05.2006., 13:17   #9
atha
atha's Avatar
Postovi: 9,069
Gledao sam iAudio u HgSpotu, cijena je ok, sve ok,
samo sto su PREglomazni. 65x45x17. Vise me podsjeca na walkmane iz sredine 90ih godina.
___________
Just atha
x
Staro 09.05.2006., 13:32   #10
domy_os
domy_os's Avatar
Postovi: 18,960
Veličine je ko Creative, a ima sve što će ti ikad trebat na playeru od line-ina, 5-6 formata, baterija traje u 3 pm...
http://eng.iaudio.com/product/product_G3_feature.php
Staro 09.05.2006., 14:20   #11
atha
atha's Avatar
Postovi: 9,069
Evo, uzeo sam i njega kao opciju.
Jos slusam preporuke, picite....
___________
Just atha
x
Staro 09.05.2006., 14:26   #12
nicko
Postovi: 4,190
rekoh ti, iRiver, a pogledaj si i Sony-eve malo u ve-mulju....
Staro 13.05.2006., 20:19   #13
blondie
blondie's Avatar
Lokacija: split
Postovi: 198
onda, koji bi vi player ocijenili kao best buy
šta mislite o sony-evom beanu???
Staro 13.05.2006., 20:40   #14
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
creative sine, creative...
baterija na muvu tx fm (aaa varta) traje 12-15 sati, velichinu znate, nije prevelik, odlichne komande&ergonomija (ekran nije premali-prikazuje sve shto treba, ali zato odlichne slike i osvjetljenja), odlichna oprema (fm radio vrlo osjetljiv, diktafon, graf.eq s 5 frekvi, naravno i dosta dobrih setupa...), iznimno dobar zvuk=bolje zvuchi on s mp3-cama na 80-96 neg canyon&co s mp3cama na 128-192 (ali pazite slushke-na nekima zna bit TIIIIIIIH...) itd.
i dobio je moj prestizhni Certifikat Neunishtivosti!
e sad to primjenite na aktualne muve v200&co...
a igrao sam se i sa zenom micro i sve SUUPPEERRR, samo onaj touchpad....ja ga jednostavno nevolim
Staro 13.05.2006., 20:56   #15
nicko
Postovi: 4,190
potvrdjujem za muvo....sto je taj sve prosao i radi jos ko novi...definitivno best buy
Staro 17.05.2006., 23:05   #16
blondie
blondie's Avatar
Lokacija: split
Postovi: 198
evo vidim sad da je u Bugu bio test mp3 playera (br.154, 09/2005) pa može li netko, tko ima taj broj skenirat taj članak, odnosno test i postati thumbnail na forum, ako nije problem
Staro 18.05.2006., 02:09   #17
West
West's Avatar
Postovi: 268
Evo blondie ja sam se potrudio i skenirao cijeli test sa svim mp3 playerima koji ima 17 stranica, bilo bi previse linkova kad bi ih postao, file je tezak oko 9.2Mb pa sam ti stavio u jedan folder i skines si sa ovog linka:
Pobrisan link
Cak sam ti napisao redom stranice (od 0-16) kako idu po casopisu
Uzivaj!
Zadnje izmijenjeno od: Costa. 19.05.2006. u 01:11.
West je offline   Reply With Quote
Staro 18.05.2006., 09:12   #18
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
ima još neš u pcchipu kolko se siječam....možda stavim ak bum imal cajta
thuNdeR je offline   Reply With Quote
Staro 18.05.2006., 14:34   #19
blondie
blondie's Avatar
Lokacija: split
Postovi: 198
Autor West
Pobrisan link
Uzivaj!
Hvala, stvarno si se potrudio!
Staro 18.05.2006., 18:41   #20
West
West's Avatar
Postovi: 268
No prob, i drugi put
Staro 18.05.2006., 23:36   #21
SofaSurfer
Lokacija: Mirkograd
Postovi: 4
Autor West
Pobrisan link
Uzivaj!
Svaka čast majstore! :clap: :clap: :clap:
SofaSurfer je offline   Reply With Quote
Staro 19.05.2006., 01:13   #22
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
