Staro 13.04.2006., 11:35   #481
MOrdecai83
Keeper of the Nine Keys
MOrdecai83's Avatar
Postovi: 193
Autor Panzer
Neznam, meni se cini ok grafika kod mene... Nije mi sve na max, pola stvari je na sredini, osim drveca... Nije ukljucen hdr i aa, te af... sutra cu slikat sve na max...
koji driveri? mislim da je to do njih problem..
L-L-L-Look at you, Hacker. A pa-pa-pathetic creature of meat and bone, panting and sweating as you r-r-r-run through my corridors-s-s. H-h-how can you challenge a perfect, immortal machine? - SHODAN
CPU : AMD 64 X2 4600+ / 2400Mhz (Sckt AM2)
CPU COOLER : Stock
MOBO : Gigabyte GA-M59 SLI-S5 (BIOS - F8)
RAM : 2x1GB SuperTalent CL4 (4-4-3-8) PC6400 DDR2-800MHz
GPU : XFX 8800GT 512MB "Alpha Dog Edition" @ 710/1720/1030
POWER SUPPLY : Thermaltake Toughpower 600W PSU
CASE : Thermaltake Armor Jr
HDD : 2 x Seagate 320GB HDD SATA2
DVD-RW : Pioneer DVD-RW R-110
MONITOR : BenQ G2400W 24" 5ms LCD 1920x1200
MOrdecai83 je offline   Reply With Quote
Staro 13.04.2006., 11:43   #482
emoe
emoe's Avatar
Lokacija: RH
Postovi: 80
skinio sam jedan mod za grafiku i sad uopce nisu mutne texture u daljini iako se one male kockice i dalje vide...
===SHADOW MAN===
NVIDIA POWER
emoe je offline   Reply With Quote
Staro 13.04.2006., 11:53   #483
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Ja imam 84.25 modane... Skinuo sam mod za tekture svijeta ovo normalnog i border world-a, te nekaj za sjene u daljini. (Landscape LOD NormalMap) i puno je bolje s tim..
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 13.04.2006., 11:58   #484
Zmalamuth
Inquisitor DeathWatch
Zmalamuth's Avatar
Lokacija: Zagreb-Rijeka
Postovi: 918
mislim da je problem u .ini file
jer pretpostavljam da si po njemu nesto mijenjao i zato ti je podivljao.
a kod reinstalacije ti sve ostane isto jer ti on cita .ini sa C:/document and setings/my documents/my games/obilvion
a taj se ne obrise kod deinstalacije, probaj ga obrisat ili barem spremit negdje i onda instalirat nanovo.
Vjerojatno si stavio nekoliko modova koji su se medusobno pomlatili i zeznuli ti .ini file
i7 4770K cooled by Noctua NH-D14
Asus Sabertooth Z87
Corsair Vengeance Pro 2x8Gb 1866Mhz
EVGA GTX 1080 - 8gb -FTW GAMING
Logitech G500 & G510 Keyboard
OCZ Vertex4 256gb/Samsung SSD 850 Evo 500G /640Gb WD Black/2TB WD Black/3x2TB WD in sharkoon docking station
LG GH22
Corsair HX620W
Corsair Carbide 678c
Arctic Bionix F140mm x3
Phillips Brilliance 240PW - 24'''
Zmalamuth je offline   Reply With Quote
Staro 13.04.2006., 11:59   #485
emoe
emoe's Avatar
Lokacija: RH
Postovi: 80
Autor MOrdecai83
Istina ...ne izgleda ni meni bas nesto...a sve je postavljeno na max ovdje... eh ta fcuking nVidia.... ATi je car sto se tice kvalitete slike...a sada i performansi... shmrc shmrc...fali mi moja 9800pro sada...
e kolega isto je tako i kod mene samo sto sam mutne texture rjesio jednim modom pa sad izgleda ok...
al ostao je ovaj problem: stani na neku snježnu površinu i pogledaj prema dolje pa ces vidjeti kako je sve kockasto..mislim da se vidi cak na nekim slikama sto si postao ovdje..na trecoj slici..
i pri loadu mi se komp samo sledi nekada...ali ako loadm neki film prije toga da se ucita ffdshow onda radi ok..
po meni je ova igra trebala ostati na poliranju jos jedno 3 mjeseca da se rjesi bar vecina bugova..al rjesit ce to modovi i patchevi pa cu to zaigrat jos jednom za nekih godinu dana
===SHADOW MAN===
NVIDIA POWER
Staro 13.04.2006., 12:03   #486
emoe
emoe's Avatar
Lokacija: RH
Postovi: 80
Autor Zmalamuth
vjeruj mi sve sam probo a to među prvim..
kazem mod je to nekako rjesio a sto je najsmjesnije to mi se dogada samo na snježnim podrucjima(lose i kockaste texture) dok se ostatk igre graficki odvija vrlo dobro..
===SHADOW MAN===
NVIDIA POWER
Staro 13.04.2006., 12:08   #487
emoe
emoe's Avatar
Lokacija: RH
Postovi: 80
eo na 3. slici sto je MOrdecai83 postao obilježio sam kockaste texture na kamenu pa pogledajte,tako je i kod mene..
===SHADOW MAN===
NVIDIA POWER
Staro 13.04.2006., 12:33   #488
Zmalamuth
Zmalamuth's Avatar
Postovi: 918
jesi li u options smanjio velicinu textura sa large na medium ili small.
odi do nekog grada i pogledaj dali mozes citat natpise na trgovinama, ako ti je mutno onda su ti texture na "large".
Asus Sabertooth Z87
LG GH22
Corsair HX620W
Staro 13.04.2006., 12:48   #489
MOrdecai83
MOrdecai83's Avatar
Postovi: 193
evo jos par slika... to je sa novim 84.43 driverima i shaja modom... izgleda bolje nego one sto sam postao sinoc... ali kockasto je KOCKASTO!
CPU COOLER : Stock
Staro 13.04.2006., 12:53   #490
emoe
emoe's Avatar
Lokacija: RH
Postovi: 80
Autor Zmalamuth
pa texture i jesu na large..
===SHADOW MAN===
NVIDIA POWER
Staro 13.04.2006., 13:09   #491
MOrdecai83
MOrdecai83's Avatar
Postovi: 193
Autor emoe
cim su teksture vece to je jaca jasnoca i bolja grafika...pa neznam o cemu onaj prica...po njemu je bolja grafika "small" i brze radi...a kada je na large tj. po njemu losija onda radi sporije... ??? nema logike...
CPU COOLER : Stock
Staro 13.04.2006., 13:15   #492
emoe
emoe's Avatar
Lokacija: RH
Postovi: 80
znam zato sam i stavio ali kockice su se malo smanjile a svima bi preporucio sa jakim kompovima ovaj mod "lod_texture_replacement_by_shaja" jer uopce texture u pozdini nisu onako mutne..ima 20mb pa probajte a ja cu scrnshoot staviti kasnije da vidite kako to sad izgleda kod mene..
===SHADOW MAN===
NVIDIA POWER
Staro 13.04.2006., 13:18   #493
MOrdecai83
MOrdecai83's Avatar
Postovi: 193
Autor emoe
svima bi preporucio sa jakim kompovima ovaj mod "lod_texture_replacement_by_shaja" jer uopce texture u pozdini nisu onako mutne..ja cu scrnshoot staviti kasnije da vidite kako to sad izgleda kod mene..
postao sam ja gore 8 screenshota... nakon stavljanja shaja moda...
CPU COOLER : Stock
Staro 13.04.2006., 13:26   #494
MOrdecai83
MOrdecai83's Avatar
Postovi: 193
sorry na duplom postu... sve u svemu....ocekivao sam vise od Obliviona i BeThesde ...a vjerujem da nisam jedini...
CPU COOLER : Stock
Zadnje izmijenjeno od: MOrdecai83. 13.04.2006. u 14:22.
Staro 13.04.2006., 13:44   #495
maX
maX's Avatar
Postovi: 7,326
Autor MOrdecai83
od Obliviona i Bedhesde...
Be T hesde
Staro 13.04.2006., 13:46   #496
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
ja sam već prije napisao da su mi takve teksture, gledaj
http://img360.imageshack.us/my.php?i...enshot03pc.jpg
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
Staro 13.04.2006., 13:49   #497
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,040
Jel zna netko di se može dobit trening za armorer-a? Preskupo mi je više plaćat za popravak svih ovih magičnih điđa-miđa što ih imam po sebi, pa moram nabrzaka postat journeyman armorer, fali mi još samo 8 levela... U stvari škrt sam, imam preko 20 000 golda : bonker :
Staro 13.04.2006., 13:50   #498
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor MOrdecai83
sorry na duplom postu... sve u svemu....ocekivao sam vise od Obliviona i Bedhesde...a vjerujem da nisam jedini...
Meni je ok.
Dobro, vidi se da su se žurili i izbacili igru prije ali je igrivo i zabavno.
Nije baš lagano napraviti takvu interakciju likova, sve te silne detalje (uzmi na primjer samo knjige), animacije lica...
Zagriženim igračima takvih igara najvjerovatnije i nije nešto-meni njubari je u redu.
Kad se samo sjetim da sam COD2 odigrao za dva-tri dana po par sati a ovo ipak imaš kaj igrati...
Osim toga-igra je popularna i ne sumnjam da će biti hrpa packova i dodatnih questova.
Staro 13.04.2006., 13:58   #499
maX
maX's Avatar
Postovi: 7,326
Autor Jelc
Da se bacis na CoD2 multiplayer na nasem serveru bogme tesko da bi vise uhvatio Oblivion u ruke jer vjeruj mi nebi imao vremena... Ja sam stao na 7. levelu i dalje ne igram kad su sad praznici pa u skoro bilo koje vrijeme ima nekog na serveru...
Staro 13.04.2006., 13:59   #500
emoe
emoe's Avatar
Lokacija: RH
Postovi: 80
nesumnjam ni ja ali ja cu ovu igrat par godina tako da nezelim u kocke gledat al kao sto rekoh rjesit ce to modovi ko i za morrowind..
===SHADOW MAN===
NVIDIA POWER
Staro 13.04.2006., 14:00   #501
Andeo
Andeo's Avatar
Postovi: 455
Ja sam "prisiljen" igrati Oblivion zadnjih dana jer mi ping skače u nebesa na COD2 serveru. Jadan ja, moram igrati Oblivion po 4 sata na dan
RABBITS CLAN
Andeo je offline   Reply With Quote
Staro 13.04.2006., 14:21   #502
MOrdecai83
MOrdecai83's Avatar
Postovi: 193
Autor m4Dm4X
Be T hesde
: evil : misspelling
CPU COOLER : Stock
Staro 13.04.2006., 16:29   #503
Sky
Datum registracije: Apr 2003
Postovi: 4,085
Igrao COD2 na serveru, ekipa je super, ali igra sux&blows.
Ali opet, ja sam valjda jedini kojem je COD2 totalno smeće...
Staro 13.04.2006., 16:45   #504
Jelc
Super Moderators
Postovi: 17,485
Autor Sky
To je zato kaj u COD-u nema golda za pokupit/otet/zaradit i obogatit se a to se pravom ferengiju ne sviđa...ajd priznaj pošteno a ne igra mi je ovakva i onakva..
Staro 13.04.2006., 19:49   #505
emoe
emoe's Avatar
Lokacija: RH
Postovi: 80
dali znate kad ce nvidia omogucit hdr + aa?
===SHADOW MAN===
NVIDIA POWER
Staro 13.04.2006., 20:43   #506
MOrdecai83
MOrdecai83's Avatar
Postovi: 193
Autor emoe
da bas to zele mogli bi odmah...ali ocito je da ne zele...
CPU COOLER : Stock
Staro 13.04.2006., 20:58   #507
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
Autor emoe
nikad, mislim da je to na hardverskom nivou.
Asus X670 Prime
Windows 10 x64
Logitech G402
Razer Cynosa V2
Staro 14.04.2006., 01:59   #508
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
ah prešao sam oblivion prekratak al definitivno igra godine
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 14.04.2006., 03:08   #509
Jelc
Super Moderators
Postovi: 17,485
Autor Rainmaker-Lihto
Prešao si samo glavni quest, imaš još kaj igrati...putuj malo i istražuj...
Staro 14.04.2006., 09:18   #510
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
..može pitanje,koliko zatvaranje vrata utječe na tijek igre,ja sam zatvorio 4 zasad,level9 sam,evo 2mm fali do lv10 : cheers2 ..pa me zanima,ja bi zujao malo po mapi i riješavao miniquestove..popravio armor usput i igračke,sorry @all na gnjavaži...beginner problemi ,ipak sam se ja učio na snesu igrati..
dakle,skraćeno..da li je potrebno zatvarati gateove..počeli su me oni vatreni užasno živcirati makar sam darkelf (75% fire resist,i još 7% u armoru)....
hvala na odg,: roller :
