Staro 28.03.2006., 02:42   #121
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Datum registracije: Sep 2004
Postovi: 1,163
meni je ljepse da imam AA umjesto HDR, jer kad se priblizis nekom vojniku il tak nesto puno je ljepse sa AA.Makar iskreno i ne kuzim neku posebnu stvar u HDR, to je neko kao bolje osvjetljenje il kaj, al AA mi se cini puno bolja stvar.
Inace na mom kompu. radi na 1024x768 na 2xAA i svi oni distanci na Full Water na Medium, Mislim da kad bi na vise stavio da bi pocelo stekuckat pa nisam.
JVC HX-Z10 je offline   Reply With Quote
Staro 28.03.2006., 10:40   #122
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Čuj jedino grafičke tipa x1800/x1900 i 7800/7900 bi jedine trebale radit solidno s HDR-om
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 28.03.2006., 11:18   #123
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Postovi: 1,163
Autor Rainmaker-Lihto
mislis na prikaz ili brzinu?
Meni otprilike isto brzo radi sa 2AA ili sa HDR al mi je slika ljepsa na AA.
Staro 28.03.2006., 12:19   #124
Lihto
Lihto's Avatar
Postovi: 3,945
Autor JVC HX-Z10
pa na brzinu recimo meni je puno ljepše na HDR ono zbog svijetla
iPhone XR 128gb
Staro 28.03.2006., 13:52   #125
Postovi: 7,568
Exclamation
There is a bug in the game where a skill can become locked and no longer be advanced for the rest of the game. This bug was found on the PC version. Any information related to the Xbox version is appreciated. Please note that I am a professional software engineer and amateur MW modder (soon OB too). I am very thorough on tracking things down. Please note it is impossible to clearly state the bug without spoiler information, but I tried in the next section to do so.
The no spoilers bug description:
There are a certain few quests that provide a certain kind of reward. This certain kind of reward causes a skill to never be able to learn or advance moving forward from that point. The skill is 'stuck' if you will. I have spent a couple of hours making sure there was no way around it except for not completing the quest. Unfortunately, I have no workaround. My digging into the quests in the construction set reveals a bug that needs developer attention. The only work-around in the construction set is to alter the reward to not be the certain special kind. Not a big deal to actually perform this mod, but a bummer in removing something interesting.
Spoiler description additions - skip if you understood the above:
There are quests (including Ftrs Guild rats, rescuing a girl, and a few more) that give as a reward levels up in a skill. The rescue a girl quest gives a boost of 5 levels in Mercantile. Afterwards, the Mercantile skill is forever stuck. I found no condition that I could get the Mercantile skill to be unstuck after receiving my reward. It has nothing to do with leveling up, sleeping, stat values or anything else under player control. There is a call within a number of scripts (ModPCSkill) that itself is not a script. That would indicate internal game code that modders don't have access to.
Izvor: ElderScrolls
Staro 28.03.2006., 14:22   #126
hsmolic
OPTIMUS
hsmolic's Avatar
Postovi: 167
Ja s ovim iz siga igram na 1024x768, skoro sve max i ide prekrasno. Za igrivost dosta je 20-30 FPS što je odlično. Imam uključen HDR jer i meni se više sviđa taj efekt od AA, pogotovo u onim vlažnim podzemljima...
Gigabyte K8NSPro | AMD64 3000+ | 1GB Kingmax Superram | EVGA 6800gs AGP (12/6) 395/1080 | Neovo 19'' LCD | Fortron 350W SS
hsmolic je offline   Reply With Quote
Staro 28.03.2006., 14:27   #127
zovi5
Datum registracije: Jul 2003
Lokacija: Đakovo
Postovi: 134
Ako netko nije vidio ove tweak-ove:
http://www.elderscrolls.com/forums/i...&t=299166&st=0
Meni je dosta ubrzalo igru.
Stavio sam ovaj .ini :
Oblivion HDR: Higher settings for HDR, this looks better, but lower FPS
ASRock 939dual-sata2--2x512 TwinMoss
3200+ athlon 64--PoW 7600 gt 256 mb
160 gb seagate-Nec3540a - Antec P150
zovi5 je offline   Reply With Quote
Staro 28.03.2006., 14:42   #128
Lihto
Lihto's Avatar
Postovi: 3,945
Autor hsmolic
ja sam na 1280x1024 samo zbog monitora nekak mi je mal tvoj fps recimo meni je oko 50fsp al nekad padne na 25 i tak moram malo još poštelat igru
iPhone XR 128gb
Staro 28.03.2006., 16:45   #129
E.T.
E.T.'s Avatar
Postovi: 2,458
Ja igram na 1024x768 na 17" CRT-u... Stavio sam nove drivere XTreme-G 84.25 i vidljivo je ubrzanje (nekoliko fps-a ali svakako veseli) te texture size stavio na normal, no shadows,no windows reflectiones, no hdr (samo bloom), no aa,iscrtavanje trave prilicno blizu, ali s ukljucenom vodom (nepodnosim kad je voda nerealna) na high i ostalim detaljima (water reflection i sl.)... Uglavnom imam igriv framerate sa tek povremenim usporavanjima (u "zahtjevnim" scenama) ...
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 28.03.2006., 17:05   #130
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Ajd, budem i ja počeo igrat da vidim kak to zgleda... Morrowind nisam ni igrao....
Staro 28.03.2006., 17:29   #131
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
Ko je ono pametan bio reko da igra neće bit zahtjevna kad sam ja rekao da ne vjerujem u onaj test?
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
Staro 28.03.2006., 17:57   #132
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
Autor Jelc
heretice jedan... cccc
moram nabaviti taj oblivion a bolestan sam pas mater....
.i.
Razer Blade 15
Staro 28.03.2006., 19:18   #133
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Autor Cali
nisam pametan, što vi mislite da me koči u ovom slučaju?
Vjerojatno performanse 6800GT chipa u shaderskim performansama. Buduci da AA nema tolikog utjecaja na FPS, vjerojatno nije problem memorijska propusnost graficke. As simpe as that...
Staro 28.03.2006., 20:35   #134
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,316
..ma to je strasno,izadje nova igra i svi oni koji su kupili grafe prije par mjeseci moraju gasiti 50% detalja u igri da bi dobili normalnu igrivost,pa ako 6800 nije ok grafa onda zbilja ova politika nema smisla vise,uzet x box ili playu i gotovo
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 28.03.2006., 21:29   #135
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Postovi: 1,163
ma 6800 je dobra graficka za tu igricu, jebiga, nemres sve do kraja odšerafit, al opet je super i brzina i slika.
A kaj se onih Bugova tice kaj je neko napiso gore negdje:
Da si opet otkljucas te skilove posluzis se sa konzolom, dignes si taj blokani skil za 1 i onda bi se trebalo odblokat.
Staro 28.03.2006., 21:44   #136
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
PUNO HVALA Facelessone!!!
Evo ja sam je maloprije dobio, sad da vidim kak to ide... Isto nisam igrao morrowind, ali volim taj tip igre...
Puno hvala Facelessone, na igri.: cheers2
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 28.03.2006., 22:26   #137
Cali
H2TB
Cali's Avatar
Postovi: 363
Autor JVC HX-Z10
dobro, istini za volju, stvarno je visoka rezolucija (1280*1024) na kojoj se fpsi vrte na oko 25.... jebiga, ako smanjim rezu, slika mi zbog monitora postane nekako mutna, pa me to smeta više od svega....
inače na 1024 klizi sve super....
Cali je offline   Reply With Quote
Staro 28.03.2006., 23:12   #138
Nijoe
Postovi: 257
Vrtim ga na 1024x768, 4xAA i zadovoljan sam. Treba mi još RAMa u svakom slučaju.
Nijoe je offline   Reply With Quote
Staro 29.03.2006., 11:22   #139
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,169
Ja je jucer konacno poceo malo igrat
Igra mi je super sa grafikom cu se jos malo igrat,jer igram na nekim default postavkama
Inace ne volim RPG-ove iz prvog liva ali mi je ova zakon i odmah sam se priviknuo za razliku od Morowinda na kojega se nisam mogao nikako priviknut
A malo je pomoglo sta igram COD 2 svaki dan,jer kakav antitalent sam prije bio za igre iz prvog lica uzas
Inace sam neki battle mage-ili tako neto sa iskemijao sa postavkama
Staro 29.03.2006., 16:41   #140
Panzer
Panzer's Avatar
Postovi: 1,814
Di se to rihta tak detaljno? Ja sam nasao neke slidere u igri pod video, i kad se igra pokrece pita me koja rezolucija HDR i te stvari...
EDIT: Nasao sam, bedak nisam vidio da ima jos slider za dolje...
@E.T. jel jako vidljiva razlika izmedu normal i high textures?
UPGRADED...
Zadnje izmijenjeno od: Panzer. 29.03.2006. u 17:11.
Staro 29.03.2006., 17:30   #141
Jelc
Super Moderators
Postovi: 17,485
Instalirao i išao malo pogledat to čudo, 2.5 sata
Prvi put sam zaigrao nešto takvog žanra (osim starih igara na Amigi)...meni to brat-bratu liči na žanr avantura, jedino kaj ima više šore...
Prvi dojam je ok.
Staro 29.03.2006., 17:36   #142
LuXor
Datum registracije: Jul 2004
Lokacija: Bjelovar
Postovi: 752
Joooooooooooj, još ju nemam.
Ali za dva-tri dana...
LuXor je offline   Reply With Quote
Staro 29.03.2006., 18:06   #143
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Ide OK na 1280 i sve na ultra high osim AA jer mi neda da ga uključim kad je uključen HDR
Nemam više lema!!!
Staro 29.03.2006., 21:25   #144
E.T.
E.T.'s Avatar
Postovi: 2,458
Autor Jelc
Prvi dojam je ok.
Cccc..Tako iskusan FPS-ovac i gamer pa jos nije upoznao sve podvarijante RPG-a...
Autor Panzer
Imho vidljiva, probaj sam...jedan restart i pogledaj...
Ja cu na kraju reci samo bemti Bethesdu i njihovo optimiziranje...kad sam napokon bio siguran da cu moci igrati "normalno" usetao sam u Imperial city po noci i frameovi su mi pali na 14-20...KATASTROFA! Sve sam detalje "odrezao", doslovce je magla oko mene koliko je mali view distance a trava se iscrtava na pol metra od mene-sad moram odluciti hocu li igrati tako ili odustajem! I tu ne mislim radi grafike... nije u problem u njoj vec sta zbog pada frameova borba sa vise od jednog protivnika postaje frustrirajuca...
Staro 29.03.2006., 22:46   #145
LorD ClockaN
od LemilicE
Postovi: 4,712
6600 je jako slaba.
meni je igra sama po prvom pokretanju namjestila ultra high detail, a ja sam digo rezu na 1280 i uključio shadows of grass
Nemam više lema!!!
Staro 29.03.2006., 22:49   #146
Panzer
Panzer's Avatar
Postovi: 1,814
Autor LorD ClockaN
6600 je jako slaba.
I super ti ide?! Sreckovic jedan!!!
Kaj mene usporava? Rami, proc ili grafa? Ide full ok sve nafrljeno, dok se ne upali trava...
@E.T. Je, vidljiva je razlika i to dosta...
Na kojem ste levelu? Ja sam na drugom...
UPGRADED...
Staro 29.03.2006., 23:07   #147
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
Imaš 512MB manjka RAM-a i ak ti proc nije clockan onda je i on problem.
Asus X670 Prime
Windows 10 x64
Logitech G402
Razer Cynosa V2
Staro 29.03.2006., 23:14   #148
Panzer
Panzer's Avatar
Postovi: 1,814
Autor OveRkiLL
Sutra stizu jos 512MB i moram pod hitno kupit novu plocu... Znaci grafa nije problem?
UPGRADED...
Staro 30.03.2006., 00:02   #149
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,316
....stigla stigla.....veceras probajem !!!!
Staro 30.03.2006., 00:26   #150
Facelessone
Facelessone's Avatar
Postovi: 4,204
meni radi na 1024*768/bloom/high u 30-40fps, jedino nekad zna na sekundu zašteknut kad treba učitat nekej........eh da mi grafa ima 256 mb
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
