#31 |
Datum registracije: Mar 2010
Postovi: 165
Da, izgleda da cu morati, nadam se da ce ovaj setup izdrzati iduci tjedan. Dal bi bila ova ok za moju konfiguraciju? https://www.instar-informatika.hr/ma...m_medium=click Zadnje izmijenjeno od: xraven13. 14.12.2025. u 13:21. |
#33 |
Postovi: 8,568
Moguće da je do bajnog Windows OS-a, jer mu se prilikom otvaranja foldera aktivira hardverska akceleracija uz pripadajuće spikeove. Ne bi bilo loše isprobati neku od popularnih Linux distribucija, čisto da se OS i općenito softverski dio (driveri) eliminira.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 14.12.2025. u 14:00. |
#34 |
Postovi: 165
Moguce, iako cini se da dosta ljudi ima problema bas s ovom kombinacijom graficke i maticne: https://www.google.com/search?q=X670...hrome&ie=UTF-8 Users with MSI X670E Tomahawk boards and Nvidia RTX 5090s report issues like black screens (especially on DisplayPort), system crashes under load, and boot failures, often linked to PCIe Gen 5 instability, VBIOS/BIOS compatibility hiccups, or driver conflicts, with solutions involving BIOS updates (AGESA/PCIe fixes), forcing Gen 4 in BIOS, using HDMI instead of DisplayPort, and sometimes needing to check power delivery or even swapping motherboards. |
#35 |
Postovi: 8,568
Da, ko i uvijek ima svega diljem Interneta, ali OS dio priče lako eliminiraš pomoću Linux provjere, pa ako je i dalje isti slučaj, onda kreneš s promjenom hardvera. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#36 | |
Postovi: 165
![]() EDIT: Probali smo Linux sa nvidia driverima preko PopOS, odmah se pojavili graficki artifakti, stekanje i onda se smrznulo sve Zadnje izmijenjeno od: domy_os. 14.12.2025. u 17:41. Razlog: spojeni postovi |
#37 |
Postovi: 8,568
Ništ, nažalost moral budeš neku drugu ploču izabrati, možda istu ovu koju ima Blue Spirit, pošto tvoja kartica radi kak spada u njegovom računalu.
#38 |
Postovi: 165
Testirali sada drugu memoriju, isti problem. Procesor drugi - radi sve u win i linux, cak i sa gen5 u biosu! Vratili procesor - opet isti problemi. Zadnje izmijenjeno od: xraven13. 14.12.2025. u 16:54. |
#39 |
Postovi: 8,568
OK, onda prije reklamacije, možete tvoj CPU isprobati u njegovoj ploči, čisto za svaki slučaj, da ne ispadne kak je sve zapravo ispravno, jedino je do kombinacija ploče i procesora.
#40 |
Postovi: 165
Probali smo moj CPU u njegovom racunalu i opet isti problem sa GPU. Znaci onda mora biti do procesora. |
#41 |
Lokacija: Cro
Postovi: 1,042
#42 | |
Postovi: 165
Kod mjerenja u benchmarku consumption je bio oko 750W ako se ne varam. Njegovo napajanje je ovo: https://imgur.com/mGD4kHe |
#43 | |
PRO
Postovi: 4,890
#44 |
Postovi: 17,143
Koliko ja shvaćam, MBO nije problem, CPU je. |
#45 |
Postovi: 165
Predan CPU ADMu na servis. |
#46 |
Postovi: 17,143
Sretno, javi što su našli. |
#47 |
Postovi: 165
Hvala i budem ![]() Inace da nije bilo Blue Spirita, ne znam kako bih i kada ovo rjesio, sumnjalo se prvo na napajanje, pa na GPU, pa na maticnu... A ja uz rokove za projekt nisam mogao priustiti da racunalo ide na servis. Tko bi uopce ocekivao da ce netko sa foruma doci i potrositi 2 popodneva da se ovo istrazi, te mi na kraju samoinicijativno ponuditi da posudi svoje racunalo tako da ja mogu raditi dok je CPU na servisu. ![]() Ako ovo ne zasluzuje najlegendarniji status i max reputaciju onda ne znam sto zasluzuje. ![]() Naravno hvala takodjer svima koji su brainstormali moguca rjesenja ovdje. Od Reddita, umjetne inteligencije, i svega ostalo, ovaj forum mi je uvijek dao najbolje rjesenje za sve PC probleme. Zadnje izmijenjeno od: xraven13. 16.12.2025. u 15:50. |
#48 |
Postovi: 1,030
Respect kolegi Plavom Špiritu ![]() |
#49 |
Datum registracije: Aug 2016
Lokacija: Bestovje,Sv.Nedelja
Postovi: 2,850
Da, dosta procesora u današnje vrijeme "šteka" ili sa ramom ili sa grafom ili mu se ne sviđa m.2 disk .... Neke stvari se riješe sa updejtom biosa, dok kod drugih je zamjena proca .... Mislim da nebi bilo nismo znali, isti proc, na drugom tipu ploče radi normalno ... Tako da te kombinacije danas .... uffffff .... |
#50 | |
Lokacija: Cro
Postovi: 1,042
Uglavnom zašto isti procesor radi na drugim matičnim pločama je što je VSOC različit. Vjerojatno da je dignut VSOC bi mu bilo stabilno. Ima dijagrama razvoda napona na ploči, treba vidit koji su sve. VSOC je sigurno, možda još koji. |
