#5971 | |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,725
Vidi vraga, čemu to? AMD Adrenalin Edition 25.10.2 drops Windows 10 support Al ovdje imaju verziju za desetku, ali u release notes piše Citiraj:
Ne kužim. Jel to opet neki clickbait? Zadnje izmijenjeno od: kopija. 30.10.2025. u 17:19. |
#5972 |
Postovi: 8,568
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#5973 |
Postovi: 23,629
Ako nije, brzo će kao sa w7/8/8.1, sve je to u dogovoru sa M$ bandom, ne treba ponavljati jer smo već sve rekli. |
#5974 |
Lokacija: Rijeka / Grobnik
Postovi: 4,473
jizus. znaci mogu se ja slikat sa LTSC-om za gaming, opet ce me shebat zbog drivera. gamad.
"We all must hang together, or surly we will hang separately." AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140 AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64 |
#5975 |
White Rabbit
Postovi: 5,369
Bilo je za očekivati iskreno. Stari driveri će raditi, nije da sustav neće biti upotrebljiv al novih ažuriranja neće biti. Samim time s vremenom novije verzije aplikacija neće više raditi. Tako da će IOT LTSC biti opcija zaista samo za uređaje za koje je namijenjena (IOT uređaje). |
#5976 |
DIY DILETANT
Postovi: 3,725
#5978 | |||
DIY DILETANT
Postovi: 3,725
Bio sam malo preoptimističan, barem što se Nvidije tiče. Citiraj:
#5979 |
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,461
![]() Nakon BIOS updejta dočekala me ova poruka. Stisnuo sam N i tako mogu ući u Windowse (Win10) ali kod svakoga restarta dočeka me ponovno ta poruka. U Windowsima Bitlocker mi je isključen. Da li ja mogu stisniti Y ili trebam još nešto podesiti u Windowsima ili BIOS-u? |
#5980 |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,823
Pa rekao bih da da, samo budi baš dobro siguran da ti nije bitlocker slučajno upaljen ![]() https://www.reddit.com/r/buildapc/co...ing_about_tpm/
#5982 |
Postovi: 23,629
Ha, qwertY en raspored ![]() |
#5983 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,119
#5984 |
DIY DILETANT
Postovi: 3,725
#5986 |
Datum registracije: Jun 2024
Lokacija: Space
Postovi: 788
Kako bi produzenje na 3 godine bila glupost bez obzira na koji naci se došlo do iste? Enterprise IoT LTSC verzija je podrzana do 2032. Mogu se kljucevi naci kao u za standardne verzije.
Miquella is mine and mine alone. |
#5987 | |||
White Rabbit
Postovi: 5,369
I tu ne pričamo o ovim licencama po 10 Eura. Imam osjećaj da je postalo normalno pričati o ilegalnim verzijama softwera kao da se radi o legalnom načinu dobave istog...e dečki dečki... Citiraj:
#5988 |
Lokacija: Bistra
Postovi: 5,119
Ja hoću reči da džabe support kad aplikacije i servisi budu prestali podržavati Win10 daleko prije 2032. godine.
#5989 | |
DIY DILETANT
Postovi: 3,725
Support može biti tri godine. Normalni user je širok pojam, npr neki još uvijek koriste XP i Firefox fork koji ga podržava. Ja sam u zadnjih par mjeseci spasio tucet W10 korisnika od patnje i gluposti kupovine novog kompa zbog te W10 EOL situacije. To je ekipa kojoj je use case Facebook, email i slično. Kad browseri prestanu podržavati W10 fino bum im instaliral W11 LTSC IOT koji radi na pretpotopnim kompovima. |
#5990 |
Lokacija: Space
Postovi: 788
tomek@vzZnam proces dobijanja tih kljuceva ali ako nazivamo kupovinu istih ilegalno, onda nemamo ni win10 pro legalno. Hajd da budemo iskreni, ko je od nas dao ove pare za windws 10? ![]() Mislim, ko je platio sa foruma windows 11 200€? To sto je bio upgrade na windows 10 free, jeste prije deset godina na konfikuraciji koje se ni ne sjecam. Svi smo mi uzimali kljuceve sa key sajtova. Slazem se sa tobom da je siva zona, ali ne pricamo ni o aktivatorima. Slazem se sa kolegom da je normalni korisnik sirok pojam. Ali nije nemoguce koristiti IoT LTSC.
#5991 | |
Postovi: 4,476
Edit ako nekome treba link za jeftino i legalno kupovanje Zadnje izmijenjeno od: Mladenxy. 08.11.2025. u 14:59. |
#5994 | |
DIY DILETANT
Postovi: 3,725
Da upotrijebim Bubbin nježni izraz, većina "takve ekipe" je "mentalno podkapacitirana", što se ogleda u činjenici da nisu sposobni savladati ni osnove korištenja Windows operativnog sustava. A i Linux je također podkapacitiran na svoj način, tako da ga nebih laka srca preporučio ni akademskim građanima. |
#5995 | ||
White Rabbit
Postovi: 5,369
Siva zona kolega. MS se jednostavno ne zamara s tim. Što bi bilo da netko prijavi njih ili PCE je upitno. Za privatne korisnike prolazi. Za firme gdje postoji kontrola takvih stvari - ne. Citiraj:
Gle...da postoje informatički pismeni korisnici koji neznaju koristiti Windows koji je na barem 95% osobnih računala - ne vjerujem. Stare napaljene bakice i dedeki koji ionak neznaju da nebreju kliknut na bilo kaj je Linux bolja solucija jer kako je već navedeno - za jednostavne zadatke uvrh glave a kad klikne na reklamu za viagru ili nešto slično nema posljedica i poziva korisničkoj podršci koja ionak nema volje po tome zahebavat (nesretan pojedinac koji je to slagao). Za onu nekolicinu koja svjesno prelazi na Linux iz svojih razloga, bez obzira dal to bila privatnost, izbjegavanje bloatanog softwera, developement (ne, WSL je ok ali nije uvijek zamjena za normalnu Linux instalaciju) ili nečeg trećeg - ha gle - svakom svoje. No činjenica je da su recimo Linux admini bolje plaćeni (bez diranja DevOps segmenta) - jedan od razloga je naravno kompleksnost sustava a istovremeno fleksibilnost istog raditi stvari koji Windows admini mogu samo sanjati - ako Linux admin poznaje i shvaća koncept Linux OS-a i ima isti u malom prstu. Ne moje riječi, već riječi jednog vrlo sposobnog kolege, inače Windows konzultanta koji ima 30 godina administracija Windows/Exchange baziranih sustava u malo većim i svjetski poznatim tvrtkama iza sebe. A sad vidi kakve to ima veze sa akademicima i korištenju Linuxa. |
#5996 | ||
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,800
#5997 | |
jedan i jedini :D
Lokacija: novi zagreb
Postovi: 5,295
Iz vlastitog iskustva, ekipa koja nije u stanju savladat win je itekako sposobna savladat linux. Govorimo o osnovnim potrebama (internet, office, multimedija). I s te strane bih ga preporucio svima. |
#5998 |
White Rabbit
Postovi: 5,369
Mislim na egzibicije tipa: Primjer 1: migracija sustava na novi OS (dual boot metodom) na istom hardware-u (ne virtualke) sa preuzimanjem svih relevantnih podataka (baze, configovi, specijalni moduli gdje svaki server vrti sve od Apache+Tomcat+Lighthttpd+SMB+NMB+Winbind+Webdav+Postfix+IMAP+LDAP+LPD + još hrpa ostalih servisa) sa Downtime-om od 30 minuta po serveru. Prvi puta je bilo OpenSuse 10.3 > 42.3, drugi puta 42.3 > 15.4. S tim da se radi o Opensuse (interni codename: Frankenstein) koji su naravno interno prilagođeni za projekt za preko 300 custom RPM paketa. I to na 270 Servera . Sustav migracije, jednom razvijen i testiran bilo je startanje skripte i lean back princip. Primjer 2: migracija tih istih sustava na novi hardware. Downtime: 1 dan po serveru (uključujući preuzimanje podataka korisnika - 5-10TB po serveru). Mi smo riješavali unutar 6 sati najčešće - po 5-7 Servera dnevno. Kloniranje nije bilo u igri jer smo kao pripremu dan prije radili kompletan image starog sustava i drmali na novi server te dok je server bio offline preuzimali samo razlike u bazama i svemu ostalome. Također - par skripti i deri, cijeli proces je mogla odraditi osoba koja se kuži u IT ko ja u višu matematiku. Opet - na 260 Servera sve prošlo bez softwerskih problema (10 je ostalo na starom hardware-u). Za oba slučaja su oba Senior Windows admina (znači likovi kojima ta titula nije samo naljepljena reda radi) potvrdili da ovakvi experimenti sa njihove strane nisu mogući jer OS takve stvari jednostavno ne dopušta. Zadnje izmijenjeno od: tomek@vz. 09.11.2025. u 06:01. |
#5999 | |
Uptime 99.99%
Postovi: 2,739
Inace mint instaliram, ali nekad davno je taj laptop dosao sa Ubuntom 10.10, pa sam ga samo stavio na 24.03 LTS. Sigurno sad i radi bolje nego neki low budget windows 11 laptop, jedino ga muci rezolucija 720p, i5 sa 6gb rama i ssdom odlicno radi na Ubuntu. Sent from my SM-S931B using Tapatalk
“Those who surrender freedom for security will not have, nor do they deserve, either one.” Zadnje izmijenjeno od: Bono. 09.11.2025. u 09:45. |
