Zaključane teme
Staro 15.03.2006., 08:39   #31
Facelessone
Facelessone's Avatar
Postovi: 4,204
al ak vec smanjuju cijene nek onda smanje pakete na 5gb=49kn i da paket od 2gb bude minimum znaci 20kn
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Facelessone je offline
Staro 15.03.2006., 09:35   #32
atha
atha's Avatar
Postovi: 9,067
bernardinho je spominjao gore shto bi bilo kada bi flat stajao 200kn? i sa najmanjom brzinom, bio bih medju prvima koji bi uzeo flat.
a vjerujem i mnogi drugi koji su na 2gb i 5gb paketima. a mozhda bi se i ovi sa 512mb paketima, ako ih ima, prebacili. a t-cumovcima bi i to bilo jako isplativo.
ali shto, kad su samo novci bitni, a zadovoljstvo korisnika - sasvim im nevazhna stvar.
___________
Just atha
x
atha je offline
Staro 15.03.2006., 10:01   #33
pizdun
d(O.o)b
Postovi: 223
Early 2007 the first 10,000 customers will be able to enjoy their 1000MB connections, at first they will have to pay about €90 a month but since the net is open and therefore invites competing isp's the prices will drop dramaticly in the first year.
Sweden was first with 10MB And 100MB connections and will be first again with the 1000MB connection. Sweden continues to be the world leader says JB of Labs2!
Labs2 je inace svedski ISP
pizdun je offline
Staro 15.03.2006., 10:20   #34
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
I ja sam se nadao kad su krenuli Optima i H1 - i kaj se dogodilo - T-com i pateći Iskon (koji i ne može drukčije) malo podigli brzine s tim da je upload još u banani a o cijeni da ne pričam. Sad se novi hvale sa WiMax-om - kolko je trebalo da postoječi operateri GSM-a kolko tolko pokriju cijelu (uvjetno rečeno) Hrvatsku. A i te koncesije su okolo na okolo. U Zagrebu i Zagrebačkoj županiji T-com nalupava največu zaradu iz razumljivih razloga ( od državnih institucija pa nadalje ).
I sad dolazimo do kvake 22 - ko ima koncesiju za WiMax za to područje - ZG????
Za ostatak telefonije - da postoji onaj ured za Istraživanje ruda i gubljenje vremana koji kao uvodi reda u monopol ali postoji i valjda 10000 pravnika T-coma koji su sve "dobre" odluke blokirali u petlju - neko se žali na T-com - ide tužba za uvredu i ostalo - ured veli OK T-com mora to manje love biti npr. interkonekcija - T-com se žali na odluku - ured veli ali.. - T- com se žali na ali.. - i sa pravne strane je stvar jasna - ide to odagađanje u nedogled pa i zastaru itd.
Kad neko skupi m... i razhebe tu petlju - nešto će se pokrenuti . Da li ove godine ili ...... mala priča iz budučnosti - deda, deda kaj niste vi plačali tolko i tolko za to? Jesmo ali to mora da je sada jeftinije - hmm deda pa baš i nije - evo friške cijene dial up-a od samo 10000 erua mjesečno. Koji crni dial up dijete - pa dsl pa wimax pa.... A pita dijete - što je to????!!!!
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO!
1oo1
NOOB - POWER IN NUMBERS!
Good judgment comes from bad experience and a lot of that comes from bad judgment.
MisterM je offline
Staro 15.03.2006., 10:34   #35
atha
atha's Avatar
Postovi: 9,067
hehe MM....
nego, pizdun....smanji sig, moliti chu lijepo. imash announcement na forumima u svezi toga.
___________
Just atha
x
atha je offline
Staro 15.03.2006., 11:35   #36
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,735
ja za mjesec dana odo na flat cable...reko fak of t scum
Hamm je online
Staro 15.03.2006., 11:51   #37
Delta S4
She`s back...
Postovi: 983
[QUOTE=bernardinho]A koji paket imaš sada? Evo, jedno pitanjce za sve:
Šta vi mislite koliko bi bila ajmo reć optimalna mjesečna naknada za flat?
Ako netko ne zna, sada je 299 kuna.
Misliš 299kn + PDV? = 378kn, kompa...
Flat paket(512) za 200 kn(sa uračunatim PDV-om) mjesečno, mislim da bi to bilo u redu.
Ovaj smajli koji bljuje po T-u je zakon! Glasam da ga se ubaci među ostale službene smajlije PC-Ekspert foruma (mislim da je interes korisnika za njim velik) : goood :
Delta S4 je offline
Staro 15.03.2006., 12:09   #38
bernardinho
Lokacija: velika mlaka
Postovi: 6
[quote=Delta S4]
Autor bernardinho
: goood :
Ne, mislim 299 kuna SA PDV-om. 79 kuna plaćaš za brzinu 512/128 i to ti daje tih 378.
bernardinho je offline
Staro 15.03.2006., 12:19   #39
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
Koju god cijenu da stave ja ostajem na najslabijem paketu jer si drugo jednostavno ne mogu priuštit.
@bernardinho: ako si tako mislio i na 200 kuna za flat, dakle 200+79 za brzinu imho to je još uvijek previše. Flat na najmanjoj brzini može komotno doći 100kn, sa pretplatom i svime. Uostalom jeste li opće razmislili čemu pretplata? Zašto plaćam istu bakrenu žicu dvaput, jednom za telefon, drugi puta za dsl?
Pomo je offline
Staro 15.03.2006., 12:27   #40
bernardinho
Postovi: 6
Autor Pomo
Da, tako sam mislio. 200 za flat +79 za brzinu. To bi bilo 100 kuna manje nego do sada. E sad, ne kažem ja da ne bi moglo biti i jeftinije, ali... Ja osobno bih si uzeo flat po ovoj cijeni od 200 + 79 kuna. Više im ne dam, iako bih mogao.
A o pretplati, tj. mjesečnoj naknadi uopće nema smisla raspravljati. teško se s rogatima bosti
Staro 15.03.2006., 12:35   #41
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
Autor bernardinho
LOL ja im ne dajem više od 100kn za net, više i ne mogu, a prva konkurencija kad naiđe lete iz moje kuće i za fiksnu telefoniju i za net, pa makar cijelu stvar plaćao više nego t-scumu.
Pomo je offline
Staro 15.03.2006., 12:44   #42
Delta S4
She`s back...
Postovi: 983
[QUOTE=bernardinho]
Autor Delta S4
Imaš pravo..moja greška.: evil :
Ali i u tom slučaju internet mjesečno ne plaćaš 299kn, nego 378 kn...
Delta S4 je offline
Staro 15.03.2006., 12:50   #43
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
[QUOTE=bernardinho]
Autor Delta S4
Kao da je bitno da li tih 79kn placas za brzinu ili za "Čika Tomine Cipele" kad ih svejedno placas i kad sve ulazi u UKUPNU cijenu FLAT paketa? Jer, nisam vidio da oni u Njemackoj na onih 30€ placaju jos nesto i za brzinu.......... : evil :
Borba protiv T-Com-a kod nas izgleda ovako -> : quake2 :
Tko je ovdje korisnik, zakljucite sami...
JC Denton je offline
Staro 15.03.2006., 13:17   #44
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Sada dajem 200kn za 192/64 flat. Fer brzina za te pare bi bila min 512/128. Al kad nema (zdrave) konkurencije. Ne bi mi bilo toliko krivo davat tih 200kn za 192k, ali pazi ovo, ako predjes 20GB mjesecno smanje brzinu na 128k ako predjes 30GB smanje na 64k!!! I oni to lijepo zovu FLAT!
Od WiMaxa, ovog, onog, petog desetog, H1, Optima...bla bla nece bit nista jer ipak je T-Com glavi i imaju love koliko hoce. Problem je sto nema nitko tko ce T-Comu rec "slusaj, ne smijes naplacivati koristenje petlji, vodova, ovog onog, ne moraju uopce imati pretplatu za fixni telefon da imaju DSL.."...
MadBoY je offline
Staro 15.03.2006., 14:26   #45
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Autor MadBoY
16000kbit downlaod 1024kbit upload... cijena jos nema tek uvode uslugu.
6016kbit/576kbit - 35eur - 255kn
2048kbit/192kbit - 30eur - 220kn
1024kbit/128kbit - 27eur - 198kn
Sve FLAT paketi. Flat im kosta 9,95eur - 72kn + pretplata za pakete.
http://dslcenter.telekombusiness.de/...eisuebersicht/
I Bernardinho nam bez imalo stida priča kako bi 200kn bilo ok za flat paket na našoj naj slabijoj brzini : Drone : : boxers :
damir1 je offline
Staro 15.03.2006., 15:00   #46
bernardinho
Postovi: 6
Autor damir1
a zašto bih imao stida? ja govorim u svoje ime. I tih 278 kuna bih dao.Bolje mi je dati 278 nego 378 kuna. Zapravo, mogu ja dati i 378 ali ne želim.
Naravno da je i 278 kuna puno, ali meni bi bilo prihvatljivije.
A ova usporedba s cijenama u Njemačkoj nema nikakvog smisla.
I Golf je jeftiniji i kvalitetniji u Njemačkoj nego u Hrvatskoj, pa opet se kod nas kupuje ko mutav.Uspoređivati nas s Nijemcima meni je, u najmanju ruku smiješno. Stoga, Damire : bonker :
Staro 15.03.2006., 16:46   #47
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Usporedba s Njemačkoj nije niti najmanje smiješna. Sasvim je opravdana. Telekomunikacijske usluge bi se trebale naplačivati po standardu (odnosno koliko toliko pratiti standard). U Njemačkoj je standard za cca 5 puta bolji nego u RH. Tako da nema smisla da su tamo telekomunikacijske usluge imalo jeftinije. Nažalost jesu jer imamo drago nam monopoliste koji su došli iz iste te Njemačke u kojoj bi vraga mogli raditi ovo što ovdje rade.
Iako smo si za ovakve cijene sami krivi. Jer da nema dovoljno ljudi koji su spremni dati toliko novaca za te usluge, cijene bi sigurno bile manje. Al, hebiga, neke stvari su potreba i moraš ih uzeti i platiti koliko koštaju.....
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline
Staro 15.03.2006., 17:15   #48
kiki89
kiki89's Avatar
Lokacija: n/a
Postovi: 228
danas sam citao u jutarnjem da je stigla neka nova mreza info-nova ili tako nesto. uglavnom sada nude net samo za tvrtke od 1MB pa na dalje. kasnije ove godine prelaze i na davanje usluga gradjanima za 99KN 1MB flat. jedva cekam!!
a do tada se selim u svedsku
kiki89 je offline
Staro 15.03.2006., 17:45   #49
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Autor bernardinho
po golfa mogu otići u dojč a po DSL ne mogu.ni ne mislim se uspoređivati(bar ne na taj način) ali me niti ne može nitko ubijediti, kako će mi švabo eto to dati jeftino i ja trebam biti sretan ko nova godina.
S obzirom da će nam biti kako oni žele a ne mi,nećemo se tući nego : cheers2
damir1 je offline
Staro 15.03.2006., 19:25   #50
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Kod nas je net skup jer smo mi ljen narod. Jako. Mrsko nam je otic pred tekom i tamo bit par dana dok oni lijepo ne spuste cijene...ali tko ce to? ma lakse je placat skupi internet nego se malo strpit...neka, netko drugi ce to rijesit...
MadBoY je offline
Staro 15.03.2006., 23:12   #51
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
6016kbit/576kbit - FLAT
Kad ovo bude 300 kn sa PDV-om kod nas onda možemo pričati.
Ali kako onda stvarivati 1000000% profita plus izvlačiti Siemens Croejša Telekominikation koji bi propao da mu T- com nije uletio
1oo1
MisterM je offline
Staro 16.03.2006., 00:37   #52
piNheaD
piNheaD's Avatar
Lokacija: Senj
Postovi: 636
Autor MisterM
Potpuno se slažem...
Suck Satan's cock
piNheaD je offline
Staro 22.03.2006., 18:30   #53
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
http://www.bug.hr/vijesti/index.asp?id=71535
Naime, kroz proširenje svoje telekomunikacijske infrastrukture vrijedno oko 3 milijarde eura DT će do kraja sljedeće godine u 50-ak njemačkih gradova ponuditi VDSL (Very-high-bit-rate Digital Subscriber Line) usluge koji omogućuju brzine pristupa Internetu do 50 megabita u sekundi
A pola toga su zaradili na nama.... : quake2 :
Ima da nama daju min 1024/256 vezu!!! Inace im idem rusit sve centre!
MadBoY je offline
Staro 22.03.2006., 18:46   #54
NITROS
NITROS's Avatar
Lokacija: Varaždin - Zagreb
Postovi: 874
Evo pocelo se nesto u Varazdinu pricati da cemo tuziti T com da nam vrate infrastrukturu. Mislim grad Varazdin ce ih tuziti. I ako dobimo infrastrukturu natrag imat cemo manje cijene : CoolRamb
Sada da nebi bilo nekih koji bi se javili sa postovima tipa, A kaj ste vi to napravili da bi vam se vratile infrastrukture. Samo cu reci da je ovo grad Varazdin stavljao unutra i kupovao je opremu.
MacBook Pro 15" (late 2011), 16GB RAM, Quad 2.2 i7
Asus PA246Q
Wacom Intuos 4 M
NITROS je offline
Staro 22.03.2006., 18:56   #55
MAHER
Postovi: 1,583
pa i svi ostali su stavljali svoje infrastrukture,pa je to nekako došlo pod tcom,naši prokleti poličitari(sve ih treba streljati,nije važno lijavi ili desni,gamad) su i i to uspjeli prodati,ali ajde super navijam za vas,ako vi uspijete valjda će se i zagreb i ostali gradovi čupati
MAHER je offline
Staro 22.03.2006., 22:22   #56
malba
schwere panzerspitze
malba's Avatar
Postovi: 313
s obzirom da smo mi kikiriki/avokado/banana država najniže klase u kojoj je sudstvo rak-rana najpodložnija korupciji i političkim utjecajima od te tužbe neće biti ništa. ili će si neki sudac u Varaždinu kupit novu S-klasu a predmet poslati svojoj babi na island da potpaljuje vatru ili će vlada to pomesti pod tepih zbog potrebe privatizacije preostalog djela ht-a da bi nahranila raspomamljene, povampirene i zapjenjene penziće.
malba je offline
Staro 22.03.2006., 22:58   #57
glista
crni pas
glista's Avatar
Postovi: 786
imam određene poslovne kontakte sa T-HT ekipom i imao sam priliku vidjeti kako razmišljaju.....što i nije teško za pretpostaviti......al si čovjek ipak nekak misli da nisu takva gamad....ali doslovce se iživljavaju i svršavaju eksploatirajući nas i to rade s užitkom, moderni kapitalizam je nemilosrdan dapače, u nekim segmentima mnogo je suroviji od raznih bivših totalitarnih sistema.....i to je naša stvarnost, tržište nam se revitalzira a nemaju nikakve konkurencije i to uvelike iskorištavaju....nove tehnologije uvode sporo i vrlo promišljeno, sve su proračunali u cent.....ono što je u cijeloj priči ipak dobro što dio te love ipak izavrši u fondu za branitelje...
glista je offline
Staro 22.03.2006., 23:13   #58
Sky
Datum registracije: Apr 2003
Postovi: 4,085
Autor bernardinho
Da ti odmah ispravim tu zabludu. Golf je jeftiniji u Njemačkoj za Nijemca jer je proizveden u Njemačkoj tako da Nijemac ne mora plaćati carine i ostale uvozne naknade. A sad jedna za razmišljanje. U Italiji je jednako opremljen Golf jeftiniji negu u Njemačkoj. A ti razmisli zašto je tako ( hint : Italija-autoindustrija-konkurencija). Monopol je predivna stvar dok traje, a kako stvari stoje, kod nas će još dugo trajati...
Sky je offline
Staro 22.03.2006., 23:38   #59
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Autor glista
Svaka čast tim ljudima, ali meni to ama baš ništa ne znači. Čak sam i protiv toga. Realno gledajući, mnogi ni ne trebaju dobivati neke novce, a kamoli tolike svote. Evo jedan čovjek živi do mene, ima 30-tak godina. Ima komad šrapnela u nozi i svakodnevno igra nogomet, a navodno je nesposoban za rad i prima dobrih 7000kn mirovine na teret mojih roditelja koji rade i dobiju 2500kn.
Što se tiče T-coma (da se vratim na temu), davno se moglo zaključiti da je ta prodaja jako upitna. Jer, ja na katu svoje kuće MORAM imati kablove, ako su državni. Ne može mene niti jedna jedina privatna firma natjerat da ja to tamo držim. Odnosno, ako mi prdne, mogu im to počupat i ostavit pred kućom. Bar bi tako nekom logikom moralo biti, iako naravno u RH logika ne pali
I5 3350P
XFX XTR 650W
Silencio 650
Zvijerko je offline
Staro 23.03.2006., 12:26   #60
MAHER
Postovi: 1,583
Autor Zvijerko
gle ovo je hrvatska,foliranta i varalica koliko hočeš,ali trea dati braniteljima,ovaj tvoj je folirant,ali meni susjed nema nogu pa dobije kakvih 5000kn mirovine,jbg mislim da mu se nije isplatilo,ali može mu se barem malo pomoći,zabrij kak bi on prošao da je po tebi
MAHER je offline
Zaključane teme
