Staro 11.03.2025., 15:34   #481
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,394
Preletio samo TPU recenziju, to je to podebljani 9800X3D, kome treba mrcina za igru i rad.
Više manje je u igrama kao 9800X3D.
Slobodno me dodajte na PSN
Staro 11.03.2025., 18:52   #482
Postovi: 8,568
Super je kaj se sad sve optimizacije za 9950X3D fino preslikavaju na 7950X3D, jedino je zajeb da Arrow Lake i dalje ispada ni vrit ni mimo, unatoč i usprkos Intel popravcima.
AMD Ryzen 9 9950X3D delivers excellent performance for Linux developers, creators & technical computing
Generationally the Ryzen 9 9950X3D came out 25% faster than the Ryzen 9 7950X3D overall making it still a very nice generational upgrade with being able to leverage the same AM5 motherboard and DDR5 system memory. Heavy hitting gains for the Ryzen 9 9950X3D in AI workloads like OpenVINO, TensorFlow, and Llama.cpp. HPC / technical computing workloads with ASKAP, easyWave, CloverLeaf, Incompact3D, SPECFEM3D, OpenFOAM, OpenRadioss, GROMACS, and more all benefited handsomely from 3D V-Cache. Some server workloads like the ClickHouse database and srsRAN all benefited a great deal too from the increased cache size. Beyond just gaming that is widely promoted as being a big winner with 3D V-Cache on Ryzen, there are many other workloads able to make great use of the expanded cache size on the Ryzen 9 9950X3D.
Izvor: Phoronix
Zadnje izmijenjeno od: The Exiled. 11.03.2025. u 19:17.
Staro 12.03.2025., 18:20   #483
Dr. Strange
Datum registracije: Aug 2020
Postovi: 899
Minuta šutnje za ona 2-3 preostala Intelova fana, ili koliko ih je već ostalo na ovom planetu:
https://wccftech.com/amd-ryzen-9-995...-package-ever/
Staro 12.03.2025., 18:45   #484
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,536
9950x3d skoro soma evra kod nas, nois
Staro 12.03.2025., 18:45   #485
Postovi: 8,568
Autor Dr. Strange Pregled postova
IMHO netko bude moral redefinirati ironiju ukoliko TSMC, AMD, nVidia i ostatak veselog društva preuzmu Intel.
UserBenchmark, Frame Chasers i sl. već testiraju novi 18A proces.
Futura IT ih ima za 830€, kaj čak i nije toliko loše, jer se 7950X3D prodaje za 800€.
Staro 12.03.2025., 19:44   #486
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,222
Bez AMD-a ovog pristanka i potpisivanja novog ugovora o licenciranju (broad cross-licensing agreemen) x86 i 64 procesora i patenata ništa od lakog preuzimanja dok je Intel na koljenima ...
AMD could block the sale of Intel due to a cross-licensing agreement
AMD and Intel have a broad cross-licensing agreement (in fact, multiple agreements, with the most recent signed in 2009) that allows both companies to use each other's patents while preventing lawsuits over possible infringements.
This covers their entire portfolios, including CPUs, GPUs, and other innovations. AMD can produce x86-based processors with Intel's instruction set extensions, while Intel can incorporate AMD's innovations into its own CPUs.
However, neither can develop processors that work with the other's sockets or motherboards., and the agreement has strict conditions for termination. If either company merges, is acquired, or enters a joint venture that alters ownership, the deal ends immediately. In the event of one of these triggers, the two companies must negotiate a new licensing arrangement.
https://www.tomshardware.com/pc-comp...sing-agreement
TSMC and Broadcom explore deals to split Intel's foundry and chip design wings, says report
Trump is 'unlikely' to support TSMC running Intel's fabs — US gov't downplays chances of TSMC takeover
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 12.03.2025. u 19:49.
Staro 12.03.2025., 19:46   #487
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,536
nop nop to nije X3D
Staro 12.03.2025., 19:52   #488
Postovi: 8,568
Evo ga, dok im običan 9950X ide za kakvih 740€.
Da, ima tu svega, a obzirom na Intelovu situaciju, ništa čudno ne bi bilo da se na kraju i AMD odluči pristati.
Staro 12.03.2025., 19:53   #489
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,536
aha takva je šema, čudi me da ta najniža keš/net banking cijena nije malo istaknutija
Staro 13.03.2025., 07:11   #490
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,394
AMD i/ili nV nema šanse da preuzmu Intel. Jedino ako ovaj narančasti retard promijeni te zakone...a to je najgora opcija za svih osim dvije spomenute korporacije.
Staro 13.03.2025., 09:21   #491
Postovi: 8,568
Evo, svjedočimo tome da TSMC nudi AMD-u i nVidiji da zajedno budu u tome, dok TSMC zapravo vodi sve kak spada, makar ta Intel priča je već toliko žalosna da je sve moguće, a realno ni jedna od tih firmi ne treba izaći u susret Intelu. I sad kad imaju (opet) novog direktora, lako bi se mogle kojekakve kombinacije izvrtjeti.
EDIT:
Nije dugo trebalo.
Zadnje izmijenjeno od: The Exiled. 13.03.2025. u 22:33.
Staro 14.03.2025., 15:47   #492
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,227
Jel ima vlasnika 9800X3D voljni napraviti jedan mali test?
Zanima me na koliko vam skoči temperatura procesora tijekom Cinebench R23 multicore testa. Usporedbu radim samo. Kod mene sa 360 AIO dođe na 85 stupnjeva. A vama?
Download link za Cinebench:
https://www.guru3d.com/download/down...cinebench-r23/
Staro 17.03.2025., 19:10   #493
jucca
jucca's Avatar
Postovi: 1,708
Autor PR3DA70R Pregled postova
CPU max 64
CPU packgage max 75
Ventovi gotovo na silent.
Ide to i nize. Sjecam se kad sam tek slozio sistem i testirao sa ventovima na full, milsim da je mozda jos i 10st dolje, ali je bucno
AIO je ASUS RYUYIN III 360 u push-pull sa LianLi SF120 na cca 800rpm te Kryonaut pastom u NZXT H9 kucistu.
Staro 17.03.2025., 21:19   #494
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,227
Hmm ček malo.
Ovu MBO tablicu nisam ni gledao. Tu meni niti nema package, a CPU pokazuje max 53.
Nije to baš točno.
Pogledaj što ti kaže hwinfo baš na CPU tablici.
Staro 17.03.2025., 21:27   #495
medo
#erase startup-config
medo's Avatar
Postovi: 3,733
Nažalost to nije dobro za nikoga osim trenutno za dioničare AMDa. Imat ćemo visoke cijene i mršav napredak te sve više i više marketinških muljanja.
Staro 17.03.2025., 21:35   #496
Dottore
Dottore's Avatar
Postovi: 7,706
Autor medo Pregled postova
Imali smo kod Intela tika-taka preformanse kroz 10nm+++++ i puno muljanja.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 17.03.2025., 21:38   #497
Postovi: 8,568
AMD ovaj put ima više konkurencije, tak da se ne budu doveli u situaciju kakvu su imali prije 20 godina, dok Intel s novim direktorom opet obećava sve i svašta, a ništa konkretno.
Sudeći po Zen 6 najavama, AMD ne planira usporiti ni prestati s daljnjim napretkom i inovacijama, dok se društvo u Intelu i dalje tješi da su na korak do povratka na staru slavu.
Staro 17.03.2025., 22:14   #498
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,525
Hmm ček malo.
Nije to baš točno.
Ventove ne cujem na low postavkama
https://postimg.cc/jwpzd4rx
https://postimg.cc/sG3gcMYP
https://postimg.cc/64z51Bck
Ocisti radijator ispusi ga ventove kuciste ,pasta nova na proc pa probaj opet to mi se cini malo previse.
Staro 17.03.2025., 23:11   #499
jucca
jucca's Avatar
Postovi: 1,708
Hmm ček malo.
Nije to baš točno.
Isto je. Uzima za CPU package temperaturu jezgre koja je najtoplija
Zadnje izmijenjeno od: jucca. 17.03.2025. u 23:20.
Staro 17.03.2025., 23:47   #500
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,227
Zanimljivo. Jer frendu se popne i do 90, no on ima 240 aio.
A brzinskom pretragom na netu vidim da i drugima bude oko 85, pa i 90+.
Ne mogu probit u čemu je caka.
Komp je čist ko suza, sve friško očišćeno iako nije ni bio nešto prašnjav. Nova termalna pasta.
Case je 011 popunjen sa 120 ventovima. 6 intake dole i bočno plus 3 na vrhu na aio koji tjeraju van zrak kroz hladnjak.
Jeste vi čačkali šta u biosu? Meni je sve default što se CPU tiče.
Edit: evo par linkova od ovog što sam pretražio
https://forums.guru3d.com/threads/no...800x3d.455386/
https://www.overclock.net/threads/98...temps.1814346/
https://linustechtips.com/topic/1596...ith-360mm-aio/
Ovaj na LTT namjestio PBO pa mu je palo na 71-72. Da nemate i vi tak u biosu pa zato imate tako male temp?
Da stvar bude bolja vidim da vam je i score bolji za 1-2k bodova. Miriše mi na uV nekakav?
Nakon sto godina sam opet u crvenom taboru. Podijelite info ako ima nešto što ne znam.
Zadnje izmijenjeno od: PR3DA70R. 17.03.2025. u 23:57.
Staro 18.03.2025., 03:15   #501
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,525
Da Undervolt mo sad je -30
https://youtu.be/2oD4ISZYjbA?si=HM-zQ2oOhyL4Gzqo
Probaj nista te ne kosta osim 10 min vrimena
Poslano sa mog SM-S918B koristeći Tapatalk
Staro 18.03.2025., 09:41   #502
jucca
jucca's Avatar
Postovi: 1,708
Kod mene sve na stock, osim XMP1, te sam smanjio ventove.
Sent from my SM-S928B using Tapatalk
Staro 18.03.2025., 10:43   #503
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,227
Okej mislim da sam otkrio throttle onda. Zato sam vas tražio ako možete testirati.
Meni daje 20k bodova i temp je 86-87 stupnjeva stock.
Iako još nisam probao uV. Budem kad dođem doma.
Bit će da je problem aio star skoro 5 godina. Otvorio sam RMA pa ćemo vidjet šta kažu.
Staro 18.03.2025., 14:43   #504
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
Ja svoj sutra nosim na garanciju. Izgleda da je odapeo, komp se zaledio u nedjelju, i što god da sam pokušao, ne mogu doći do posta. Fizičkog oštećenja nema.
Staro 18.03.2025., 15:17   #505
Postovi: 8,568
Lako moguće da ovo u pitanju, pa novi BIOS ili flashback popravlja situaciju.
Staro 18.03.2025., 18:47   #506
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,227
Autor Tajl3r Pregled postova
Evo rezultata samo sa curve optimizerom.
-30
-20
Razlika je mizerija. Nisam zadovoljan... Čitam u komentarima na videu likovima pala temp nakon -20/30 za cirka 20 stupnjeva.
Nešto tu ne štima, a glavna sumnja je AIO. Čekam da mi se javi support za RMA ticket koji sam otvorio.
Staro 18.03.2025., 18:56   #507
Postovi: 8,568
U BIOS-u imaš sve opcije da CPU ograničiš na Tjmax 75°C, 105W TDP i 142W PPT, a po potrebi pomoću Curve Optimizera dodatno kasnije samo fino podesiš.
Staro 18.03.2025., 19:09   #508
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,227
Ma stari ne može imat tolike razlike. Radi se o 360 AIO i fantastičan airflow.
Još k tome temperatura prostora trenutno 15C. AIO ne hladi kako spada očigledno.
Evo i stock:
Frekvencija na stock padne na 5.0GHz time naravno i rezultat R23 lošiji, znači da throttla.
Staro 18.03.2025., 19:12   #509
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,525
-30
-20
Hmm neznam nesto tu ne štima,ja korstim još
Thermalright AM5 Secure Frame na procu sad dali on stvara nekakvu temperaturnu razliku cisto sumnjam više je za ono da pasta ne upada .Aio je očito po meni nema šta, isparila voda ,pumpa dali se čuje? Ako kvrcka znači fali vode ..mislim može da je sam proc čorak ali ovi 9800x3d su baš binani posebno da svaki bude pobjeda silikon lutrije
Staro 18.03.2025., 19:16   #510
Postovi: 8,568
Još k tome temperatura prostora trenutno 15C. AIO ne hladi kako spada očigledno. Frekvencija na stock padne na 5.0GHz time naravno i rezultat R23 lošiji, znači da throttla.
OK, ako je to hlađenje dalo svoje, nemaš druge nego kupiti nekaj novije i bolje. I kasnije opet možeš ograničiti CPU da ne ide temperaturom nebu pod oblake, a zadržiš sve performanse.
