Staro 12.09.2022., 20:34   #5281
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,371
imate ios temu za ios da ne spemamo tu
http://forum.pcekspert.com/showthrea...32190&page=145
Staro 12.09.2022., 23:28   #5282
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,371
Battery capacities for the iPhone 13 lineup:
iPhone 13 mini: 2,406 mAh
iPhone 13: 3,227 mAh
iPhone 13 Pro: 3,095 mAh
iPhone 13 Pro Max: 4,352 mAh
Battery capacities for the iPhone 14 lineup:
iPhone 14: 3,279 mAh
iPhone 14 Plus: 4,325 mAh
iPhone 14 Pro: 3,200 mAh
iPhone 14 Pro Max: 4,323 mAh
Staro 13.09.2022., 11:25   #5283
Dottore
Dottore's Avatar
Postovi: 7,653
Po ovome 13 pro max najveći. Ostali novi modeli imaju blago povećanje kapaciteta, valjda bude bilo napredaka.
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 13.09.2022., 11:28   #5284
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,371
meni nije jasno, ak napraviš 4nm, i procesori imaju uštedu valjda na svim jezgrama
kako je moguće da baterija na ajfonu 14 pro ne traje 2h dulje
po njihovom webu, traje gotovo isto ko 13 pro
Staro 13.09.2022., 11:34   #5285
Dottore
Dottore's Avatar
Postovi: 7,653
115mAh više ima 14 pro. Trebala bi protegnuti 1 sat više.
Treba vidjeti review.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 13.09.2022., 16:29   #5286
FerrZG
FerrZG's Avatar
Datum registracije: Oct 2016
Postovi: 171
Ekran nudi dosta jaci peak brightness(cak 2000 nits, naspram 1200 ako se ne varam na 13 pro), a i opcenito je vjerojatno dosta jace osvjetljen nego prosle godine.
Samsung se kurci ove godine, a ekran cucla najvise baterije
Zato je mozda toliko mala razlika u trajanju baterije.
Zadnje izmijenjeno od: FerrZG. 13.09.2022. u 17:30.
FerrZG je offline   Reply With Quote
Staro 13.09.2022., 17:28   #5287
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,096
iPhone mobiteli - 2. dio
Toliki peak brightness je realno koristan za što? Osim kao “flash” za one kojima moraju okidati selfije u mrklom mraku
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 13.09.2022., 17:30   #5288
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,559
Ljeti po suncu?
Staro 13.09.2022., 17:36   #5289
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,371
meni ljeti po suncu može imat i 10.000 nitsa, kad će ionako dimmat ekran jer će se ugrijat, i nebudem vidio apsolutno niš
Staro 13.09.2022., 20:58   #5290
goran1985
Ili jesi ili nisi
Datum registracije: May 2011
Lokacija: vrgorac
Postovi: 736
Znam samo da mi je 13 mini bio najgori mobitel kojeg sam imao po pitanju vidljivosti na suncu (uz auto brightness uključen). Čak sam sumnjao da mi je to zbog kaljenog stakla ali isto je bilo i sa skinutim.
S druge strane, žena mi ima 13 obični i nisam baš primijetio taj problem a na papiru su isti ekrani zar ne?
goran1985 je offline   Reply With Quote
Staro 13.09.2022., 23:25   #5291
spawn
spawn's Avatar
Postovi: 8,423
Nikad nije isto. Ista stvar je sa 12 i 12 pro. Sve isto a nije. Uvijek oni ustede negdje gdje mogu. Jel to staklo na ekranu,premaz, nits itd.
Btw,jel netko zna kako pristupiti internoj memoriji iz koje npr Signal moze promijeniti ringtone? Pristup s pca naravno. U Documents na mobu imam sve sto sam prebacio s P30 ali ne znam kako doci do tih foldera s PCa: 3u tools ih ne nalazi. Workaround je poslat ringtone na mail pa download u files i onda ucitat u Signal. Great
Zadnje izmijenjeno od: spawn. 13.09.2022. u 23:42.
Staro 14.09.2022., 06:32   #5292
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Stavio sam iOS 16. Osim ovih par vizualnih promjena na prvu, čini mi se fluidniji nego 15.6.1
Kod mene baterija valjda pada sa svakim updateom. 15.6.1 s 94% pala na 93%. Sinoć sam prvo išao vidjeti bateriju i očekivano na 92%.
Riječ je o 12 običnom. Od 7. mjeseca 2021. ga imam.
XR prije toga godinu dana 100%.
To je sve odokativno kako iOS odabere čini mi se 😬
Di sam stao?
Staro 14.09.2022., 07:34   #5293
SPLiFF
SPLiFF's Avatar
Postovi: 2,101
Autor aski Pregled postova
Fluidniji je, promijenili su neke animacije, ubrzali, druge možda malo tweakali.
Staro 14.09.2022., 08:42   #5294
dadoremix
dadoremix's Avatar
Postovi: 4,717
Meni upgrade na 16.0 ždere bateriju
Ip 11 pro
Uvijek mi se baterija isprazni do 75%
Jucer 49% a sigurno i manje koristio
Blah
Staro 14.09.2022., 08:58   #5295
SPLiFF
SPLiFF's Avatar
Postovi: 2,101
Ništa čudno, uvijek nakon major update mob vrti nešto u pozadini, neko indexiranje, photos skenira lica itd... Potraje to 2-3 dana
Staro 14.09.2022., 15:47   #5296
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,371
Staro 14.09.2022., 15:59   #5297
Postovi: 33,982
Staro 14.09.2022., 16:04   #5298
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,371
naježim se kad linkaš index članak
cijene su poznate od petka 9.9., kada je puštena prednarudžba
Staro 14.09.2022., 20:27   #5299
delavi
Datum registracije: Apr 2020
Postovi: 978
Mislim, upgrade sa 13ce na 14cu se ne isplati. Isti mob, sitne promjene. Jedna jezgra više na gpu, lagani BT update....sve drugo ili isto ili minorna promjena. Svašta. Još nikad nije bilo tak.
Staro 14.09.2022., 20:45   #5300
Dottore
Dottore's Avatar
Postovi: 7,653
Autor delavi Pregled postova
Misliš obična 14? Da, isti cpu , povećana baterija. Pro modeli nisu isti.
Staro 15.09.2022., 09:22   #5301
rodriguez
rodriguez's Avatar
Postovi: 2,062
Sa 16.1 cemo moci i mi sa Minijem imati postotak baterije u kutu Iphona
Thinkpad T430 running
Staro 15.09.2022., 09:25   #5302
Postovi: 16,847
Autor coconut Pregled postova
18 hiljada kuna za mobitel? Pa tko je tu lud?
Staro 15.09.2022., 12:03   #5303
locks
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,610
To je kod nas. U SAD-u imaju normalne cijene, ako se to tako uopće može nazvati, jer pričamo o mobitelu...
locks je online   Reply With Quote
Staro 15.09.2022., 12:07   #5304
Postovi: 16,847
Autor locks Pregled postova
Pa ne bi se složio.
Upravo sam se vratio iz Amerike i cijene su gotovo iste.
Ovaj mobitel od 17 500kn u RH je u americi 1600$ bez poreza i davanja. Tako da, i u USA je preko 15000kn.
Običan 14 PRO 128GB je 1000$ bez taxi u USA, kod nas je ispod 10k kn. Ako dodaš takse na ovo u USA, evo te na 1200$ što je preko 9000kn.
10-15% je jeftinije, što nije više nešto wow. Kad je dolar bio ispod 6kn, da, ali sada kada je isto kao EUR, nope.
Sve u svemu, previše, gdje god da kupio.
Staro 15.09.2022., 12:15   #5305
locks
Lokacija: Vukovar
Postovi: 3,610
Ok, nisam znao....A opet je to njima lakše platiti s obzirom na standard.
Staro 15.09.2022., 12:19   #5306
Postovi: 16,847
To svakako, bez dileme.
Staro 15.09.2022., 12:36   #5307
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,371
bome budu sad poneki ameri kupovali mob van USA, ako žele sim utor, a čitam po netu da oće utor taj
Staro 15.09.2022., 13:01   #5308
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,770
Ukratko, cijene iste ko prošle godine...
Staro 15.09.2022., 13:03   #5309
Postovi: 8,300
Pitanje je vremena kad kompletno (iz upotrebe) izbace smartphone uređaj kao takav, uvjere sve korisnike da im to ne treba, kao i punjač i tome slične sitnice, sve skupa zapakiraju u NFT i prikažu kao ekološku osviještenost.
Svi sretni i zadovoljni, rekordne zarade, korisnici imaju virtualne sličice uređaja, nitko ne zagađuje okoliš (na stranu da NFT gluposti ne rade branjem tratinčica), a ostali proizvođači po uzoru na Apple brže-bolje prigrle novi zeleni val.
Eventualno se uvede i neki danas jako popularni pretplatnički model za virtualne sličice smartphone uređaja i to je to. Ljudi se fino mogu svađati tko ima jače/bolje specifikacije i čiji NFT je skuplji.
Zajebanciju na stranu, ali sve ostalo im je ionak već palo na pamet, tak da ni ovo nije Sci-Fi, obzirom na (metaverse) vremena u kojima živimo.
Staro 15.09.2022., 13:03   #5310
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,371
u ameriki, kod nas cca 200€ skuplje
13pro - 9609 prošle godine
14pro - 10979 ove
