Staro 22.06.2022., 13:43   #3331
Bradobradi
Datum registracije: Dec 2020
Lokacija: Visegrad, BiH
Postovi: 212
Autor Nbdy32 Pregled postova
Evo ti klokovi za micron memoriju i FLESHANE kartice ...
Citao sampo nekim forumima da sad moze core da se spusti na 1100 bez hubitka mhs... probao i radi.... a na ove dvije mi je plafon 910 mem pokusavao sam vise sa raznim kombinacijama voltaze i core.. ovo je najbolje sto sam uspjeo (sad sam smanjio radi temp)... dok za powercolor ide na 945 bez problema i daje 59mhs... ali imam osjecaj da nekako bolje radi ovako na 57 sa mem 930...
Bradobradi je offline   Reply With Quote
Staro 24.06.2022., 12:18   #3332
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,627
Ima tko kakav info o rebel forku etha?
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 24.06.2022., 14:47   #3333
Bradobradi
Postovi: 212
Autor maXonja Pregled postova
Nista nisam cuo za "rebel"... sta bi mu ga to trebalo biti pod kojim EIP se vodi?
Staro 24.06.2022., 14:51   #3334
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,627
A rebel fork testnet has successfully been launched. With 100% of the nodes working as expected. Ready to be deployed.
1. The Ethereum POS stake holders funds will be vaulted.
2. The difficulty bomb has been removed.
3. The London fork burning code will be reverted.
The rebel fork will be supported by some of the biggest exchanges in the world.
The best news of the rebel fork is that Vitalik Buterin's funds will be deleted. Together with all the POS lovers. Slava Ukraine!
All ethereum holders that haven't locked their funds will receive the same amount ethereum in the rebel fork. 1:1. The Implementation is done by a team of old Bitcoin devs.
You will get Ethereum lightning, dynamic blocksize to avoid expensive gas price (gwei) (We don't like that people in power control the gas price ), adding ethash+gpu minable randomx POW to avoid asic attacks, refactor codebase to avoid buffer attacks- ++
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 24.06.2022., 15:14   #3335
Bradobradi
Postovi: 212
kao sto ime i kaze rebel ili ti pobuna... onako na prvu - to je samo bunt nekih mjenjacnica da probaju neki svoj fork odraditi...
bez EIP-a nista nemoze da prodje na ETH mrezi....
a i sta je upisano u blok tako ostaje.. nema vracanja...
a sve je objasnjeno u trecem citatu....
posto u trecem citatu navode da ce POS biti ukinut i da im smetaju PoS ljubitelji.. namece se zakljucak da ovo organizuju neki majneri... i posto im smeta jos to sto je Vitalik Rus.. zele da ga izbace iz ETH-a (mada je osnivac) i navodi se slava Ukrajini....
zakljucak se sam namece... grupa revoltiranih majnera zele da zadrze PoW i usput da spomenu Ukrajinu nebi li dobili na njhov racun dobili jos malo pristalica... sto neiskljucuje mogucnost ukljucenosti i ukrajinskih minera...
tako to ja vidim....
i da... ne bilo koji majneri nego iskljucivo GPU... jer zele ASIC resistance....
Zadnje izmijenjeno od: Bradobradi. 24.06.2022. u 15:20.
Staro 29.06.2022., 15:06   #3336
Bradobradi
Postovi: 212
Narode...
imam jednu Asus RX 570 4GB... sa njom kopam ETC (nekad TSF ali je isti eth-etc algoritam)
do prije par dana kopala nekih 29-30MH/s
sad se krece od 15 do 20mh/s dosta varira....
mjenjao bios.... mjenjao podesavanja.... mjenjao miner.. samo jos nisam riser... ali i to cu danas...
imate li neki predlog.... da nije odradila svoje.. da je se rijesim dok jos radi...
Staro 29.06.2022., 15:09   #3337
Nbdy32
Datum registracije: Aug 2016
Lokacija: Bestovje,Sv.Nedelja
Postovi: 2,852
Nekaj ne štima sa samom grafom ... obavezan pregled ....
Nije do minera, niti risera ...
Daj postavke
Nbdy32 je online   Reply With Quote
Staro 29.06.2022., 15:23   #3338
Bradobradi
Postovi: 212
Daj postavke
Staro 29.06.2022., 16:11   #3339
Bradobradi
Postovi: 212
Daj postavke
Nasao sam sta je
kada odem u shell miner... vidim da mi je fan rpm 0 i amd-info vidim da nije usao u state sa postavkom od 1100 nego salta izmedju state 1 i 2 na brzinama core 613 - 700
Zadnje izmijenjeno od: Bradobradi. 29.06.2022. u 16:16.
Staro 29.06.2022., 17:08   #3340
Nbdy32
Postovi: 2,852
Izvaditi van iz riga, probati solo na ploči, vidjeti kak se onda ponaša ....
Staro 30.06.2022., 13:10   #3341
Bradobradi
Postovi: 212
dok iskopam neko napajanje.... sve sam upogonio
sinoc se popelo na 22mhs.. jutros opet 19... kao da smanjuje na toplinu.... mada pokazuje 60C
Staro 30.06.2022., 15:50   #3342
Nbdy32
Postovi: 2,852
Možda ga memorija zeza, ta temperatura je temperatura jezgre, memoriju na tim karticama ne očitava ni jedan linux sistem ...
Izvaditi, probati solo, ili izvaditi, promjeniti padove i pastu (odma kad je vani) i vratiti nazad pa vidjeti ...
A i pitanje kad si fleshao da li si dobar bios stavio ???
Staro 20.07.2022., 09:43   #3343
Bradobradi
Postovi: 212
meni ovih dana na posao stize optika pa sam mislio malo upregnuti mysterium...
da li je ko kopao i kakve su isplate.. zarade i sl?
Zadnje izmijenjeno od: Bradobradi. 20.07.2022. u 10:08.
Staro 20.07.2022., 10:35   #3344
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,699
Nisam znao nit da postoji to.
Baš budem danas isprobao pokrenuti na optici doma.
Staro 20.07.2022., 11:14   #3345
Bradobradi
Postovi: 212
naletih i ja slucajno na yt...
radi za VPN... das adresu da preko nje moze ici VPN za tvoju zemlju i daju ti para ako ko koristi... koliko sam skontao....
meni bi islo preko firme tako da me zabole ako neko ljevi koristi protok i IP za VPN... za kucnu varijantu razmislite.. pogotovo posto je HR u EU pa radi downloada preko vase IP i sl. nelegalno sta ide na VPN....
Staro 04.08.2022., 17:02   #3346
Nixis
Casual gamer
Nixis's Avatar
Postovi: 802
Radi selidbe se riješavam stvari pa poklanjam stalak za mining rig.
Više detalja i fotke:
https://www.njuskalo.hr/kucista/okvi...oglas-37925662
Nixis je offline   Reply With Quote
Staro 08.08.2022., 19:48   #3347
frezer
frezer's Avatar
Datum registracije: Jan 2018
Postovi: 519
Ide u 9 mjesecu neki "merge" na ETH-u. Hoće li se i dalje moći majnati ili je to to?
Nije baš da rasturam engleski, pa mi teško razumjeti sve one pojmove
frezer je online   Reply With Quote
Staro 08.08.2022., 21:30   #3348
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,695
ETH je gotov s majnanjem kad merge bude. To kad je do sad bio sirok pojam, vidit ćemo.
Ostaje etc,ergo,flux i dosta drugih coina,al profitabilnost ce bit uzasna. Dok ne nikne i ako nikne nesto novo.
Staro 08.08.2022., 21:47   #3349
frezer
frezer's Avatar
Postovi: 519
Da, kad silni hash sa eth-a dođe na ostale coine, moći će majnati samo onaj koji ne plaća struju.
A ništa, "motaj kablove"
Staro 09.08.2022., 13:18   #3350
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,328
Autor frezer Pregled postova
Nije baš tako crno bijelo.
SetH je offline   Reply With Quote
Staro 09.08.2022., 15:09   #3351
MAHER
Postovi: 1,583
a i famozni merge kad bude jos nije uklesano u kamen. vitalik vec ima kasnjenja na kasnjenja
MAHER je offline   Reply With Quote
Staro 12.08.2022., 17:56   #3352
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,844
https://twitter.com/VitalikButerin/s...7MBOXxziw&s=19
The terminal total difficulty has been set to 58750000000000000000000.
This means the ethereum PoW network now has a (roughly) fixed number of hashes left to mine.
https://bordel.wtf predicts the merge will happen around Sep 15, though the exact date depends on hashrate.
Staro 12.08.2022., 18:35   #3353
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Profitabilnost ETC-a će bit taman koliko treba, tj ako ne bude isplativo odmah prodavat, mineri (oni koji to mogu priuštiti) će hodlat i cijena će rasti
Staro 14.08.2022., 14:28   #3354
Bradobradi
Postovi: 212
za pocetak 17.08. ispadaju asic mineri od 5GB sa ETH-a i prelaze, vjerovatno, na ETC...
poslije prelaska na PoS... nije bas da nece biti isplatljivo.. mislim nece se isplatiti uci u mining.. ali oni koji su opremu vec odplatili samo ce biti profit... pa koliko god da bude....profit je...
meni je sve odplaceno... svejedno cunesto kopati i cekati povoljan trenutak za prodati....
Staro 14.08.2022., 17:54   #3355
Nbdy32
Postovi: 2,852
Da a jesi li si u to uračunao struju koju ćeš potrošiti ...
Tako da to s time kaj si si otplatio ili ja kaj sam si otplatio, baš i nema veze ako ću rudariti s minusom ...
Staro 14.08.2022., 18:02   #3356
frezer
frezer's Avatar
Postovi: 519
Ja računam da kartice ispod 50mhs će kopati sa minusom. Skupa je struja nama. Ima puno onih sa daleko jeftinijom strujom i puno nižim standardom tako da će se tamo nagomilati hasha.
Bar će gameri doći na svoje
Staro 14.08.2022., 22:01   #3357
MAHER
Postovi: 1,583
belobradi je u bih i ima jeftiniju struju
Staro 15.08.2022., 09:27   #3358
Bradobradi
Postovi: 212
Da naravno postoji granica... sve se svodi na to da li mozes izgurati struju dok neskoci cijena da se isplati prodati... jos cemo da vidimo sta nosi noc a sta dan......
Autor MAHER Pregled postova
Bradobradi ne belobradi
Staro 19.08.2022., 10:09   #3359
Bradobradi
Postovi: 212
vec se osjeti dobro kada je dobar dio 5GB ASIC upao na ETC mrezu...
do prije 20 dana mreza je bila oko 24000GH/s a jutros je 44000GH/s
ja sam sa 370MH/s pravio 2 ETC na 7 dana.. sada je 0.967 ETC
Staro 19.08.2022., 10:33   #3360
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,725
Lagana panika u Nvidia HQ, molitvene grupe zazivaju bogove da THE MERGE bude opet otkazan na par godina.
