Staro 06.01.2022., 21:02   #781
epvpalucard
Yare Yare Daze
epvpalucard's Avatar
Datum registracije: Jan 2014
Postovi: 202
Ne dobijem nista,na kratko u cmd naslovu Bude ip. Tako stoji Koji 10 sec I vrati se na default cmd prozor bez I kakve poruke.
Eto sada kad sam resetiro ruter ovo dobijem
https://i.gyazo.com/c8b77c14ac857bc5...5ce4b8c3a3.mp4
to je sa main pc
MAIN RIG
● CPU: Ryzen 7 2700x
● MBO: ASUS PRIME B450-PLUS
● RAM: Samsung 4 x 16GB DDR4 3200Mhz
● SSD1: 1TB Samsung 980
● SSD2: 500gb Samsung 850 evo
● HDD: ST3000DM001-1ER166 3TB
● GPU: MSI RTX 2070 Ventus
● PSU: Seasonic CORE GM 650 Gold
● CASE: Fractal Define 7 XL R2
● OS: Win 11 Pro
MISC
KEYBOARD: Keychron V6
MOUSE: Redragon Perdition Pro M901P
HEADSET: RED DRAGON H710
MONITOR 1: AOC 24G2U 24" FHD 144hz 1ms IPS
MONITOR 2: AOC 22V2Q 21.5" 75hz 5ms IPS
epvpalucard je offline   Reply With Quote
Staro 06.01.2022., 21:19   #782
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,727
ok, jesi proba sad preko vanjske IP adrese?
Staro 06.01.2022., 21:26   #783
epvpalucard
Yare Yare Daze
Postovi: 202
Yup. Preko moba:This site can’t be reached '***' '.com refused to connect.
Try:
Checking the connection
ERR_CONNECTION_REFUSED
MAIN RIG
● OS: Win 11 Pro
MISC
Staro 07.01.2022., 12:27   #784
epvpalucard
Yare Yare Daze
Postovi: 202
rijesio sam problem,tako da sam maknuo qbittorrent i instalirao transmission.Nextcloud mi koristi https ali transmission ne ali mi barem radi nekako
MAIN RIG
● OS: Win 11 Pro
MISC
Staro 02.02.2022., 10:52   #785
Zero Cool ZG
Datum registracije: Aug 2021
Postovi: 254
Bok svima, što kažete da uzmem ovak nešto gotovo i to pretvorim u DIY NAS:
https://www.njuskalo.hr/pc-racunala/...oglas-34493923
Da li to ima smisla ili mi treba još nešto?
Ubacim svoje diskove i stavim TrueNAS gore?
Prva ideja mi je bila kupiti gotovi NAS, ali ispalo je da za ispod 2k nema ništa ok.
Zadnje izmijenjeno od: Zero Cool ZG. 02.02.2022. u 11:26.
Zero Cool ZG je offline   Reply With Quote
Staro 02.02.2022., 11:01   #786
Ivo_Strojnica
PRO
Postovi: 4,727
nema ništa na tom linku.
Staro 02.02.2022., 11:26   #787
Zero Cool ZG
Postovi: 254
Iz nekog razloga se skratio link, evo ispravnog:
Staro 02.02.2022., 11:47   #788
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 712
To je puno manje kućište od uobičajenih, po defaultu stane 1 disk, možda 2 ako izbaciš DVD, a i sama ploča je neki egzotični format pa teško da bi mogao prebaciti u neko mATX/ATX kućište.
Staro 02.02.2022., 17:37   #789
Postovi: 23,522
Ti SFF kompovi su prije za kakav x86/x64 router (doda se 2x ili 4x Intel mrežna),
konkretni model može za DIY NAS sa 2x 3.5" hdd (makne se dvd) + 1x 2.5" ssd / hdd,
ako tražiš za 4x 3.5" hdd onda moraš na nešto veće.
Samo napomena, gledaj da cpu ima AES-NI podršku jer se traži.
Evo ti sve gotovo, čuveni HP Gen8 > https://www.njuskalo.hr/serveri/hpe-...oglas-36084114
2.000 Kn
Staro 03.02.2022., 11:28   #790
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Vinkovci
Postovi: 2,767
Autor Zero Cool ZG Pregled postova
Autor Nikky Pregled postova
2.000 Kn
Baš sam sinoć malo gubio vrijeme na njuškalu i ima izbor i3 7100 i i3 8100 kanti za malo novaca (do 1500kn). Obična ATX i mATX kućišta, stane diskova, potrošnja relativno mala.
Ima čak i ultimate DIY NAS kućište s dobrim procesorom, ali skupo. Ne znam da li bi išlo ispod 2000kn bez monitora i HDD.
https://www.njuskalo.hr/pc-racunala/...oglas-35700112
U to kućište stane 6 diskova, ili 5 + M2 na ploču.
Samo što ploča nema dovoljno SATA priključaka.
Staro 03.02.2022., 11:46   #791
Zero Cool ZG
Postovi: 254
2.000 Kn
Ne bih veliki server, želim nešto dimenzijama malo i sa malom potrošnjom.
Nisu mi potrebna više od 2-3 diska unutra.
Razmišljao sam o ITX kučištima, ali ih nikad nisam vidio uživo. Mislim da stanu 3 diska unutra. Dva za storage i jedan za OS, npr.
1. Kučišta
- https://www.njuskalo.hr/kucista/bitf...oglas-36233144
- https://www.njuskalo.hr/kucista/bitf...oglas-26528058
2. Matična + CPU
- https://www.njuskalo.hr/maticne-ploc...oglas-10997951
- https://www.njuskalo.hr/maticne-ploc...oglas-35132865
- https://www.njuskalo.hr/maticne-ploc...oglas-30590845
Kako vam se to čini?
Staro 03.02.2022., 11:46   #792
SinfulSaint
SinfulSaint's Avatar
Postovi: 315
eo moj node 304 ide uskoro u prodaju ako nekoga zanima. tu je kupljen na forumu. 92mm ventovi mu nisu originalni i fali mu 1 nosac za diskove.
SinfulSaint je offline   Reply With Quote
Staro 03.02.2022., 11:48   #793
SinfulSaint
Postovi: 315
imam i jednu amd itx plocu s cpu i ramom mogo bi se nas slozit od toga.
Staro 03.02.2022., 13:02   #794
Postovi: 23,522
Onda ti sasvim odgovara onaj M90, napisao sam da unutra može 2x 3.5" + 1x 2.5", dvd izbaciš.
OS dižeš sa tog 2.5" ili sa internog USB stika.
Staro 07.02.2022., 09:40   #795
Zero Cool ZG
Postovi: 254
Da li je moguće da TrueNAS traži 16 GB RAM-a?
Imate koji NAS OS za preporučiti?
Staro 07.02.2022., 09:45   #796
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,234
Sto tocno zelis od nas-a, samo file share ili jos nesto ekstra?
Ako je file share mozes stavit bilo koju linux distru (sa/bez gui-ja), a ako ti trebaju jos kakvi pluginovi onda mozes instalirat OMV npr.
Staro 07.02.2022., 10:15   #797
Postovi: 8,214
Može raditi i s puno manje, ja sam za lab dizao virtualke s 4Gb, radio je TrueNas bez problema. Pogotovo ako nećeš voziti ZFS, radit će ti tip top. Ako ideš na ZFS, pogotovo ako je veliko polje, onda se preporuča više rama.
Staro 07.02.2022., 11:31   #798
Zero Cool ZG
Postovi: 254
Autor Cuky Pregled postova
Planiram ga prvenstveno kao file share, ali bih volio imati što više opcija out-of-box.
Čisto da ne moram previše razmišljati i kemijati ako poželim nešto mrvicu naprednije.
Staro 07.02.2022., 11:42   #799
Ivo_Strojnica
PRO
Postovi: 4,727
To ti je isključivo radi cachea za ZFS, piše ti u detaljima.
A i to nije issue, samo smanji cache ZFS-a.
Staro 07.02.2022., 12:51   #800
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
A i kad ustanoviš što ti treba, sve pomnoži sa 2, pa će ti trajati NAS preko 10 godina, ko meni
Staro 15.02.2022., 19:37   #801
Zero Cool ZG
Postovi: 254
Kako vam se čine ove komponente za DIY NAS? Cilj je da je kučište što manje i što manja potrošnja.
Matična ploča Asrock A320M-DVS R4.0 Socket AM4 micro ATX AMD A320 = 295 kn
AMD 7th Gen A6-9500E APU Procesor 3 GHz 1 MB L2, 35 W TDP = 387 kn
Kućište Akyga AK36BK computer case Micro Tower Black = 207 kn
G.Skill F4-2400C17S-4GNT memory module 4 GB 1 x 4 GB DDR4 2400 MHz = 139 kn
Napajanje Akyga AK-B1-400 power supply unit 400 W 20+4 pin ATX ATX Green = 127 kn
USB 3.2 32 GB (za OS) = imam
HDD Seagate IronWolf 3TB x2 = imam
Staro 15.02.2022., 21:04   #802
Postovi: 23,522
Ovisno koji os misliš dizati, provjeri jeli platforma podržana i kako.
Na mobu sam pa mi se sad ne gleda case,
bitno ti je da hdd - ovi imaju ok fiksiranje (vibracije, buka) i da po njima piri neki vent (temperature).
Sve drugo kao lako dostupno / hdd tray i sl. nije nužno (ali čoeka veseli).
Ima negdje u temi linkova za 4 - bay nas case iz DE,
isto tako od shuttle polu gotovo bundle rješenje.
Staro 15.02.2022., 22:36   #803
Postovi: 8,214
Daj si uzmi neko ok napajanje, ako je lova toliko problem, imaš sesonica polovnih već za 200kn na njušci.
Staro 15.02.2022., 22:40   #804
Ivo_Strojnica
PRO
Postovi: 4,727
potpis, uzmi polovno neko napajanje, malo kvalitetnijih osobina, jer ipak će ta ljepotica raditi 24/7.
@Nikky: još nisi uspija nikog nagovoriti na svoj shuttle
Staro 16.02.2022., 12:06   #805
Postovi: 23,522
Moj ??
Eh, kad bi to tako išlo.
Ni luk jeo ni luk mirisao a (opet) nahebo
Staro 04.03.2022., 09:09   #806
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,792
Jel netko kupovao komponente za DIY NAS možda sa ove stranice https://www.minipc.de ?
Zanima me kakva su iskustva.
tintin je offline   Reply With Quote
Staro 04.03.2022., 11:24   #807
Ivo_Strojnica
PRO
Postovi: 4,727
ja ništa, isključivo njuskalo ili sa tržnice.
Staro 05.03.2022., 10:37   #808
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,792
Planiram napraviti koliko je moguće fanless NAS.
MBO bi bila ova Asrock J5040 sa 2x8GB RAMa + 1 ssd za os i za početak 1 hdd za podatke.
Sve bi stavio u neko NAS Like kučište.
Nemam iskustva sa PicoPSU-ima i ciglama za napajanje pa molim pomoć oko odabira.
Bitno je da je kvalitetno i pouzdano.
Zadnje izmijenjeno od: tintin. 05.03.2022. u 11:08.
Staro 05.03.2022., 10:50   #809
Libertus
Libertus's Avatar
Lokacija: Vinkovci
Postovi: 2,767
Kada složiš sve pošalji pregled što, kako i gdje su uzeo.
Staro 05.03.2022., 16:44   #810
c-shadow
c-shadow's Avatar
Postovi: 3,477
Autor tintin Pregled postova
Razmisli o sfx napajanjima ako ideš na kakvo veće kućište. imaš ih i semi pasivnih, ne pokreću vent do nekih xx% opterećenja, a s tim cpu ćeš imati malu potrošnju i u teoriji to je dosta efikasno, obično su barem gold specifikacije.
Drugo, pazi od 4 sata porta, 2 su na posebnom kontroleru, neki asmedia.
