Lokacija: Livno
Postovi: 371
Računalo za Windows 11
Specifikacije: Kućište Andromeda Super silent 400 W power supply inclusive Napajanje Corsair TX 650 W Motherboard ASRock 970 Extreme3 CPU QuadCore AMD Phenom II X4 Black Edition 965, 3400 MHz (17 x 200) GPU Sapphire Radeon HD 5570 RAM Memory SK hynix HMT41GU6MFR8C-PB (2x8 GB = 16 GB) DDR3 SDRAM Monitor Acer V226HQL [22" LCD] (LXLEE0164207) SSD INTENSO (AA000000000000003124) 256 GB HDD WDC WD5000AADS-00S9B0 (WD-WCAV92705435) Green HDD WDC WD1002FAEX-00Z3A0 (WD-WCATR4235844) Black Audio Adapter Realtek ALC892 @ ATI SB900 - High Definition Audio Controller S ovim specifikacijama moje računalo ne podržava Windows 11. Za novo računalo nemam novca. Postoji li neki način kojim bih mogao nekako izmjeniti konfiguraciju računala tako da računalo podržav Windows 11, ali da bi troškovi bili manji nego li kupiti novo računalo. Znam da je komplicirano, ali ako netko ima neku ideju, bio bih zahvaln. Zadnje izmijenjeno od: mandak. 02.07.2021. u 16:31. |
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,463
ODUZIMAM VAM RIJEČ
Postovi: 13,279
Lokacija: Ivanić_Grad
Postovi: 2,009
Postoji fix: To fix the "TPM 2.0 is required" message when (inplace) upgrading, the tool renames the existing appraiserres.dll to appraiserres.dll.bak and puts in the dll from a 1703 (15063) ISO (already provided in the project folder). Atm it's specifically made for use with 21996 only (recovery stuff won't work because there is no winrecfg available, fast install without it will work). New: The tool now can also create a mixed build ISO, Win 10 ISO with the 21996 wim/esd in. This will enable you to use the standard Win 10 setup when installing from boot. How to use the tool: For option 1: - insert the 21996 ISO in the "Source_ISO\W11\" folder and run the cmd. + - insert the Win 10 ISO in the "Source_ISO\W10\" folder and run the cmd. For option 2: - insert the 21996 ISO in the "Source_ISO\W11\" folder and run the cmd. https://drive.google.com/file/d/1AYP...ew?usp=sharing pw: MDL2021 |
#5 | |
Lokacija: Livno
Postovi: 371
Traži TPM 2.0 i graphic card DirectX 12. Ja sam trikom instalirao Windows 11 kao dual boot s Windows 10. Koristio sam instalacijski paket od Windows 10. Iz njega sam obrisao Install.wim i umjesto njega ubacio Install.wim od Windows 11. Za sada radi dobro. Build je 21996.1. |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,050
Nije samo TPM... GPU driveri moraju biti minimalno WDDM 2.0, a grafa mora podržavati DirectX 12. Iliti, sve starije od GCN arhitekture na AMD-u, ili Fermija na nVidiji, ne bu podržano od strane Winsa 11. S druge strane, Win10 bu podržan do 2025. godine tak da preše ![]()
Postovi: 23,516
Aha, znači novi val prisiljavanja na baci sve staro i kupi novo + skinite gaće, dozvolite da vas špijuniramo i zarađujemo na vama. Još samo fali da se onemogući lokalna pohrana i da se forsira cloud gofno ![]() Neka, ljudi će sad još više migrirati na Linux platformu. |
#10 | |
Lokacija: München/Varaždin
Postovi: 4,808
Ako te komp sluzi za ono za sto ga koristis zasto se zamarat sa Windows 11? Osobno gledam na upgrade OS-a kao "nice to have" feature al ak ide ok ak nejde, opet ok. Win 10 ce imat support do 2025 a i alternativa ima ![]()
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / Fedora Workstation 42 |
#11 | |
Lokacija: Livno
Postovi: 371
Slažem se. Samo sam mislio ako mogu s manjim ulaganjem imati Windows 11 bio bih spreman na to, ali na veće ulaganje ni u primisli. |
Postovi: 7,638
#14 | |
Lokacija: Livno
Postovi: 371
SSD je nov i ima 256 GB. Vidim da je najveći problem u matičnoj ploči, a time je problem i s CPU, GPU i RAM memorijom. Znači, skuplja pita nego tepsija. Evo rezultata za moje računalo: ![]() Zadnje izmijenjeno od: mandak. 25.06.2021. u 22:28. |
Postovi: 7,638
__________________ |
#16 |
Lokacija: Bistra
Postovi: 5,050
Ovaj tool koji koristiš je unofficial i ne prikazuje pravo stanje. Drugo, stvari se budu ziher menjale, pogotovo kaj se tiče proca. TPM, SB i grafe razumijem, ima smisla i ne vidim problem, ali za proc da nebu podržaval nikaj starije od 8th gen intela i ryzena 2000 - apsolutna ludorija. Opet, Win10 podržan je do 2025, i sigurno većina ne bu odma migrirala na Win11 dok ne riješe inicijalne dječje bolesti, ali opet treba uzet u obzir da velika većina juzera ima OEM mašine i laptope koje zadnjih 5-6 godina dolaze sa TPM-om i ne budu imale problema.
#17 |
Premuim
Postovi: 1,748
Na Youtubeu ima nekih divljih videa s Win11 na Core2Duo. Tako da, kroz godinu dvije očekujem kakvu takvu official podršku za korištenje istih featurea kao što trenutno imam na kombinaciji Win10 i Core2Quad. Tako da će vjerujem i svi phenomi, čak i oni stariji, podržavati Win11. Možda bez spremanja broja kreditnih kartica i biometrije. Ali to mi na osobnom PCu ni ne treba. Možda neku novu grafiku kupim ako bude potrebno kao davno za aero. Ili bude TPM preko njih. Službeni, vpn i razno razni serveri, to nek je firmi na brigu, tek nedavno su me na win10 migrirali..
#18 |
Postovi: 33,943
Na kompovima u firmi ni nemam TPM konektor na mbo. Mislim da će instalacija W11 pričekati 2025.g. btw, uspoređivao sam Asus TPM modul pinout sa GB mbo. Oblikom su isti, ali postoji razlika je u pinovim 18 i 19. Kod GB su označeni sa NC, dok kod Asusa CLKRUN i LPCPD.
#19 | |
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,183
Svaki MBO maker ima drukciji TPM modul jer nije standardiziran: Citiraj:
![]() /connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv |
#21 |
Lokacija: Livno
Postovi: 371
Naravno da ću ostati na Windows 10. Jutros na Windos Insider Program sam dobio obavijest da ne ću moći Windows 10 nadograditi na preview verziju Windows 11 jer moje računalo ne zadovoljava minimalne uvjete za Windows 11. ![]() |
#23 |
The mighty pirate
Lokacija: London
Postovi: 9,067
Ne znam što dramite toliko. Microsoftu je cilj da što više korisnika prebaci na W11 i dobije što više feedbacka na početku. Već sad dobivaju feedback da većina računala nije kompatibilna. Ovi zahtjevi će biti prilagođeni većini kako se bliži release, a kad izađe, trebat će im opet godina dana da pokrpaju dječje bolesti.
#24 |
Lokacija: RH
Postovi: 1,733
Zadnje izmijenjeno od: vacs. 28.06.2021. u 13:06. |
#25 | |
Postovi: 7,638
![]() Isto je bilo u početku 10.
#27 | |
Postovi: 2,183
![]() /connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv Zadnje izmijenjeno od: Blue Spirit. 28.06.2021. u 18:55. |
#29 |
Postovi: 8,214
#30 |
Asshole
Lokacija: RH
Postovi: 2,358
Hoce li itko od admina vec danima pocistit ovaj nered s tri iste teme sa windows 11 ? Ne moze se to vise pratit… ![]() |
