Staro 25.06.2021., 15:27   #1
mandak
mandak's Avatar
Lokacija: Livno
Postovi: 371
Računalo za Windows 11
Specifikacije:
Kućište Andromeda Super silent 400 W power supply inclusive
Napajanje Corsair TX 650 W
Motherboard ASRock 970 Extreme3
CPU QuadCore AMD Phenom II X4 Black Edition 965, 3400 MHz (17 x 200)
GPU Sapphire Radeon HD 5570
RAM Memory SK hynix HMT41GU6MFR8C-PB (2x8 GB = 16 GB) DDR3 SDRAM
Monitor Acer V226HQL [22" LCD] (LXLEE0164207)
SSD INTENSO (AA000000000000003124) 256 GB
HDD WDC WD5000AADS-00S9B0 (WD-WCAV92705435) Green
HDD WDC WD1002FAEX-00Z3A0 (WD-WCATR4235844) Black
Audio Adapter Realtek ALC892 @ ATI SB900 - High Definition Audio Controller
S ovim specifikacijama moje računalo ne podržava Windows 11. Za novo računalo nemam novca. Postoji li neki način kojim bih mogao nekako izmjeniti konfiguraciju računala tako da računalo podržav Windows 11, ali da bi troškovi bili manji nego li kupiti novo računalo. Znam da je komplicirano, ali ako netko ima neku ideju, bio bih zahvaln.
Zadnje izmijenjeno od: mandak. 02.07.2021. u 17:31.
mandak je offline   Reply With Quote
Staro 25.06.2021., 15:51   #2
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,472
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 25.06.2021., 15:54   #3
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,491
Staro 25.06.2021., 15:59   #4
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,015
Postoji fix:
To fix the "TPM 2.0 is required" message when (inplace) upgrading, the tool renames the existing appraiserres.dll to appraiserres.dll.bak and puts in the dll from a 1703 (15063) ISO (already provided in the project folder).
Atm it's specifically made for use with 21996 only (recovery stuff won't work because there is no winrecfg available, fast install without it will work).
New: The tool now can also create a mixed build ISO, Win 10 ISO with the 21996 wim/esd in.
This will enable you to use the standard Win 10 setup when installing from boot.
How to use the tool:
For option 1:
- insert the 21996 ISO in the "Source_ISO\W11\" folder and run the cmd.
- insert the Win 10 ISO in the "Source_ISO\W10\" folder and run the cmd.
For option 2:
https://drive.google.com/file/d/1AYP...ew?usp=sharing
pw: MDL2021
Staro 25.06.2021., 16:23   #5
mandak
mandak's Avatar
Lokacija: Livno
Postovi: 371
Autor Renesis Pregled postova
Traži TPM 2.0 i graphic card DirectX 12.
Ja sam trikom instalirao Windows 11 kao dual boot s Windows 10. Koristio sam instalacijski paket od Windows 10. Iz njega sam obrisao Install.wim i umjesto njega ubacio Install.wim od Windows 11. Za sada radi dobro. Build je 21996.1.
Staro 25.06.2021., 18:06   #6
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,103
Nije samo TPM...
GPU driveri moraju biti minimalno WDDM 2.0, a grafa mora podržavati DirectX 12.
Iliti, sve starije od GCN arhitekture na AMD-u, ili Fermija na nVidiji, ne bu podržano od strane Winsa 11.
S druge strane, Win10 bu podržan do 2025. godine tak da preše
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 25.06.2021., 18:19   #7
Postovi: 23,593
Aha, znači novi val prisiljavanja na baci sve staro i kupi novo
skinite gaće, dozvolite da vas špijuniramo i zarađujemo na vama.
Još samo fali da se onemogući lokalna pohrana i da se forsira cloud gofno
Neka, ljudi će sad još više migrirati na Linux platformu.
Staro 25.06.2021., 18:39   #8
mandak
mandak's Avatar
Lokacija: Livno
Postovi: 371
Nisam spreman na veće ulaganje. Stoga sam i napisao ovaj komentar. Radije ću ostati na Windows 10 ili prijeći na Linix nego bacati novac na nešto što mi ne treba. Hvala svima za komentare na ovu temu.
Staro 25.06.2021., 20:39   #9
dadoremix
dadoremix's Avatar
Postovi: 4,737
Fakat se ms potrudio zahebat narod
Al rješit ce se i to
Kao i aktivacija uvijek
Staro 25.06.2021., 20:45   #10
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,219
Autor mandak Pregled postova
Ako te komp sluzi za ono za sto ga koristis zasto se zamarat sa Windows 11? Osobno gledam na upgrade OS-a kao "nice to have" feature al ak ide ok ak nejde, opet ok. Win 10 ce imat support do 2025 a i alternativa ima
Staro 25.06.2021., 21:03   #11
mandak
mandak's Avatar
Lokacija: Livno
Postovi: 371
Slažem se. Samo sam mislio ako mogu s manjim ulaganjem imati Windows 11 bio bih spreman na to, ali na veće ulaganje ni u primisli.
Staro 25.06.2021., 21:35   #12
Dottore
Dottore's Avatar
Postovi: 7,696
Uvijek moraš biti spreman.
Puno ti toga fali pod većeg ulaganja pod "moj komp". Za početak, ulaganje u SSD i druga grafička može izdržati.
Staro 25.06.2021., 21:56   #13
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,491
mislim, ryzen 5 1600 nije podržan, to je nevjerojatno
Staro 25.06.2021., 22:17   #14
mandak
mandak's Avatar
Lokacija: Livno
Postovi: 371
Autor Dottore Pregled postova
SSD je nov i ima 256 GB. Vidim da je najveći problem u matičnoj ploči, a time je problem i s CPU, GPU i RAM memorijom. Znači, skuplja pita nego tepsija.
Evo rezultata za moje računalo:
Zadnje izmijenjeno od: mandak. 25.06.2021. u 23:28.
Staro 25.06.2021., 23:38   #15
Dottore
Dottore's Avatar
Postovi: 7,696
Mislim da je problem zbog starijih čipseta ploče. Ovako je za sada u beti dok ne upotpuni minimum. Prikupljaju se podaci
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 26.06.2021., 00:56   #16
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,103
Ovaj tool koji koristiš je unofficial i ne prikazuje pravo stanje.
Drugo, stvari se budu ziher menjale, pogotovo kaj se tiče proca. TPM, SB i grafe razumijem, ima smisla i ne vidim problem, ali za proc da nebu podržaval nikaj starije od 8th gen intela i ryzena 2000 - apsolutna ludorija.
Opet, Win10 podržan je do 2025, i sigurno većina ne bu odma migrirala na Win11 dok ne riješe inicijalne dječje bolesti, ali opet treba uzet u obzir da velika većina juzera ima OEM mašine i laptope koje zadnjih 5-6 godina dolaze sa TPM-om i ne budu imale problema.
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 26.06.2021., 14:19   #17
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Na Youtubeu ima nekih divljih videa s Win11 na Core2Duo. Tako da, kroz godinu dvije očekujem kakvu takvu official podršku za korištenje istih featurea kao što trenutno imam na kombinaciji Win10 i Core2Quad.
Tako da će vjerujem i svi phenomi, čak i oni stariji, podržavati Win11. Možda bez spremanja broja kreditnih kartica i biometrije. Ali to mi na osobnom PCu ni ne treba. Možda neku novu grafiku kupim ako bude potrebno kao davno za aero. Ili bude TPM preko njih.
Službeni, vpn i razno razni serveri, to nek je firmi na brigu, tek nedavno su me na win10 migrirali..
Campeonato je offline   Reply With Quote
Staro 28.06.2021., 08:58   #18
Postovi: 34,046
Na kompovima u firmi ni nemam TPM konektor na mbo. Mislim da će instalacija W11 pričekati 2025.g.
btw, uspoređivao sam Asus TPM modul pinout sa GB mbo. Oblikom su isti, ali postoji razlika je u pinovim 18 i 19. Kod GB su označeni sa NC, dok kod Asusa CLKRUN i LPCPD.
Staro 28.06.2021., 10:20   #19
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,197
Svaki MBO maker ima drukciji TPM modul jer nije standardiziran:
Asus, MSI, Gigabyte, Asrock they TPM are not compatible with each other.
As far as I can tell as of 2020 there is no standard TPM header so you must buy TPM from the same vendor as motherboard and even in that case check how many pins you have.
https://superuser.com/questions/9250...he-same-vendor
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 28.06.2021., 10:54   #20
BojanZD
BojanZD's Avatar
Postovi: 1,398
Ostaneš na w10 dok ne prestane podrška, napravi DE CRAP za 10ku i boli te kuki za w11!
BojanZD je offline   Reply With Quote
Staro 28.06.2021., 11:05   #21
mandak
mandak's Avatar
Lokacija: Livno
Postovi: 371
Naravno da ću ostati na Windows 10. Jutros na Windos Insider Program sam dobio obavijest da ne ću moći Windows 10 nadograditi na preview verziju Windows 11 jer moje računalo ne zadovoljava minimalne uvjete za Windows 11.
Staro 28.06.2021., 13:04   #22
LeskiRM
LeskiRM's Avatar
Datum registracije: Feb 2015
Lokacija: Sveta Nedelja
Postovi: 706
Nevjerojatno da ryzen 5 1600 ne može imati win11, barem ne po sadašnjim informacijama.
Kaj sad?
Imam crosshair hero vi i 1080ti, koji processor uzet?
LeskiRM je offline   Reply With Quote
Staro 28.06.2021., 13:15   #23
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,129
Ne znam što dramite toliko. Microsoftu je cilj da što više korisnika prebaci na W11 i dobije što više feedbacka na početku. Već sad dobivaju feedback da većina računala nije kompatibilna. Ovi zahtjevi će biti prilagođeni većini kako se bliži release, a kad izađe, trebat će im opet godina dana da pokrpaju dječje bolesti.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 28.06.2021., 13:48   #24
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,737
Autor LeskiRM Pregled postova
Kaj sad?
Pa bilo koji iz druge ili trece serije...mozda naisplativije ryzen 7 2700x, ujedno se rijesis i cpu bottlenecka
Zadnje izmijenjeno od: vacs. 28.06.2021. u 14:06.
Staro 28.06.2021., 14:04   #25
Dottore
Dottore's Avatar
Postovi: 7,696
Autor 1v@n Pregled postova
Upravo tako.
Isto je bilo u početku 10.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 28.06.2021., 19:10   #26
b1tterman
Takozvani influenser
b1tterman's Avatar
Lokacija: Dublin
Postovi: 650
Kakva kolosalna glupost... dev preview radi uredno na prastaron Thinkpadu x230 bez ikakvih TPMova i Coffee Lake procesora...
b1tterman je offline   Reply With Quote
Staro 28.06.2021., 19:49   #27
Blue Spirit
Postovi: 2,197
Windows 11 to Ship Without TPM Requirement for 'Special Purpose' Systems
Not all Windows 11 installs are created equal.
Microsoft will allow some systems to ship without TPM 2.0 enabled, meaning that it will obviously have either a special ISO for those installs or a method to bypass the TPM restriction during installation.
Installing Windows 11 on a system without TPM enabled will require special approval from Microsoft. The company allows "OEMs for special purpose commercial systems, custom order, and customer systems with a custom image" to ship systems without TPM support enabled.
Microsoft's uneven application of the TPM requirement is probably designed to cater to countries that either forbid or don't use the TPM cryptoprocessor security functionality, like China (which receives its own special Windows builds already) and Russia, both of which don't use the technology for security reasons. (Both countries have their own alternative encryption algorithms/technologies.) It's also conceivable that some systems without the TPM requirement could ship into other areas of the globe for other uses, so we're following up with Microsoft for more details.
Microsoft's TPM requirement isn't popular, particularly because it doesn't enable any new functionality — all of the tech it enables already exists on Windows 10 systems that don't require TPM for installation. The primary difference is that Windows 10 users can opt to use those features by enabling TPM, or simply choose not to use them. Enterprising enthusiasts are already finding workarounds to install Windows 11 on systems without TPM support (we're aware of a few already). Still, it is unclear if those techniques will work on shipping versions of the ISO.
Unfortunately, it appears Microsoft is sticking to its guns on the Windows 11 CPU support matrix, too. The updated Windows 11 minimum requirements document doesn't outline any expansion of the current list of supported Intel and AMD CPUs. That means Windows 11 will not install on all CPUs before second-gen AMD Ryzen and eighth-gen Intel models. Curiously, many unsupported CPUs, like Skylake-X, support TPM functionality but aren't on the supported CPU list.
https://www.tomshardware.com/news/wi...urpose-systems
Zadnje izmijenjeno od: Blue Spirit. 28.06.2021. u 19:55.
Staro 28.06.2021., 20:05   #28
mandak
mandak's Avatar
Lokacija: Livno
Postovi: 371
Nadograđujem Window 10 na Windows 11. Mogu isprobati sve do finalne verzije, a kasnije povratak na Windows 10.
Staro 28.06.2021., 21:55   #29
Postovi: 8,496
OK, ali baci pogled na potencijalne probleme (1 - 2), jer ne trebaš pošto-poto biti live beta tester za Microsoft, pogotovo na računalu koje svakodnevno koristiš.
Staro 28.06.2021., 22:38   #30
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,361
Hoce li itko od admina vec danima pocistit ovaj nered s tri iste teme sa windows 11 ? Ne moze se to vise pratit…
