Staro 20.05.2020., 17:10   #3241
Postovi: 8,482
Puget Systems po običaju ima hrpu konkretnih testova, dok Gamers Nexus za razliku od jučerašnjeg Linus isprdka, baš i nije oduševljen stabilnošću nove platforme.
The Intel Core i9-10900K CPU is a drop-in replacement for the 9900K, and it shows: Anywhere we previously recommended the 9900K -- primarily gaming -- we could recommend the 10900K. Our biggest issue has been BIOS and the fact that these Z490 platforms feel equivalent to early Ryzen 1000 platforms. They’re buggy, applying settings doesn’t always work like it should, and the boosting behavior is inconsistent from one to the next. That needs to be fixed. The 10900K also begins to get us into the philosophical debate of how much CPU differences matter for gaming when at its level of performance, but we’ll talk about that more in the 10600K review getting published later today (likely to our YouTube channel first). Oddly, AMD has the more mature platform right now, despite Z490 being a direct Z390 reskin + WiFi in the chipset. The 3900X would be our go-to for production or rendering boxes. It’s cheaper and it’s more effective. The 10900K is objectively the ‘best’ in gaming benchmarks.
Švabi su već izlistali cijene za nove Comet Lake modele i bome cifre su taman paprene.
Staro 20.05.2020., 17:53   #3242
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
Ne znam jel bilo ali Stevo napravio receziju drloga.
https://www.youtube.com/watch?v=1O1nhAd7V9I
Staro 20.05.2020., 18:07   #3243
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,585
Opet će biti različitih recenzija. HUB Stevo kaže da mu na maximusici s MCE ide all core do 4.9ghz, a stock tj. MCE off all core je 4.3ghz. S druge strane mu na tomahawkici out of the box all core bude 4.9ghz stalno, a uz MCE 5.1ghz all core...
Staro 20.05.2020., 18:11   #3244
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
Ma ne valja niš...
edit
evo i Linus izvrtio, na drugoj temi kolege pričaju da je na platnoj listi od Intela pa ne treba ovaj video uzeti ozbiljno.
https://www.youtube.com/watch?v=mLsoJkQb0Cs
Zadnje izmijenjeno od: Mladenxy. 20.05.2020. u 19:54.
Staro 20.05.2020., 23:35   #3245
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,271
Ma ne valja niš...
edit
bas me cudi kako Linus ima super thermals haha
a Jayztwocents na kraju videa govori da proc gori
https://www.youtube.com/watch?v=COUu6xRlGLo
Staro 20.05.2020., 23:57   #3246
Postovi: 8,482
Linus nije ni testiral taj procesor, već je samo pročital unaprijed pripremljen scenarij od strane svojih zaposlenika. Orginalni naslov videa je izmijenjen, a glasil je u stilu: "You'll still buy Intel..."
Valjda je netko od njegovih skužil da su ipak malo preočiti, pa su brže bolje editirali naslov videa.
Uglavom, svi ostali su napravili normalne recenzije u kojima se lijepo vidi kak novi Intel teško diše, kad nije pod strogom kontrolom Thermal Velocity Boost čuda tehnike.
When running a wide range of CPU/system benchmarks and monitoring the reported CPU package power consumption using the Intel RAPL framework on Linux, the average CPU power consumption came in at 124 Watts.
Right in line with Intel's marketing of a 125 Watt TDP rating. But at least according to the RAPL framework reporting based upon the Intel CPU metrics recorded, the actual peak power consumption of the CPU went as high as 380 Watts in extreme cases.
Izvor: Phoronix
Staro 21.05.2020., 00:19   #3247
Psycho
Master Of Disaster
Psycho's Avatar
Postovi: 1,271
ma totalni smecarski osvrt.
Staro 21.05.2020., 16:06   #3248
lobo64
lobo64's Avatar
Postovi: 1,346
Za HC Intel klokere:
Overclocking
Leistungsaufnahme (CPU-Package)
Intel Core i9-10900K (mit Limits im PL1)
125.6
Intel Core i9-10900K (mit Limits im PL2)
222.8
Intel Core i9-10900K (ohne Limits)
225.7
Intel Core i9-10900K (5,2 GHz)
384.7
in Watts.
Custom WC Alphacool u vrijednosti 280+€ da bi se OC uopće mogao držati pod kontrolom.
Izvor HWLuxx.
Vishera se srami sam tak...
Uuu, jbt, kak volim bit zloban...
Staro 21.05.2020., 16:24   #3249
Manuel Calavera
Postovi: 14,585
To je sve ionako overclockirano out of the box (barem uz MCE opciju). Baš pogledao od Jay2Centsa "osvrt" (ne mogu to nazvat recenzijom), kaže njegov primjerak ne može ni mrdnuti, znači overclock 0 bodova, čak i undervolt za iste clockove na njegovom primjerku nije moguć. A ovi primjerci što mogu navući 100-200mhz - toplina i potrošnja toliko ode u krasni kuratz da nema nikakvog smisla
Također njegov zaposlenik ima i9 9900K, kaže isto ne može mrdnuti niti najmanji undervolt.
Takav je u globalu i ryzen 3000, s tim da se AMD uvijek može barem ohoho undervoltati.
Overclock je danas jednotavno mrtav. Konkurencija je tolika da se clock na stock postavkama i razna boost stanja guraju do maximuma, da tu jednostavno nema prostora za OC.
Staro 21.05.2020., 18:48   #3250
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
"nova" i7 bivši i9...hebeno dobar gaming proc, hebeno
https://www.youtube.com/watch?v=kk9JMtH3cm4
Staro 21.05.2020., 19:21   #3251
Postovi: 22,223
Hrabar ovaj majstor "l'll pass. To expensive just for gaming".
Obično lntel takve nagradi tako da im više nikad niš ne pošalje. A pošto kaže da ga je kupio a ne dobio, može reći što hoće. Za razliku od onog žutog šabana.
Šteta šta nije jeftiniji, 300 usd recimo. Pa bi i baba Su isto malo điknula cijene R7 i R9 procova
Staro 21.05.2020., 19:40   #3252
Manuel Calavera
Postovi: 14,585
Izrazito dosadne recenzije...
Pa znao sam kakve će perf. imati prije godinu dana. Znaš broj jezgri, jezgru tj. arhitekturu i onda još 100-200mhz gore koji su dali koji fps.
Ovaj i5 10600K je u biti i7 8700K + malo clocka, što je i sam rekao. Očekujem koji fps više kad izbaci review
Inače intel bi bio frajer kad bi stari cpu poput i7 9700K drastično pojeftinili, no kod njih tog nema...
Staro 21.05.2020., 19:56   #3253
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,604
Znači 8700K na 5GHz će poslužiti do 12-13. generacije Intelovih CPU-a sasvim fajn
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 21.05.2020., 20:18   #3254
Postovi: 22,223
Dok god budu reciklirali Skylake 14nm, miran si
Pare u Ampera sad na jesen i bog da te vidi na 250 Hz
Staro 21.05.2020., 21:36   #3255
Postovi: 8,482
Kak je tek njima (oba Stefana, Švabi, AnandTech i ostali koji to detaljno istestiraju), a znali su da je u pitanju paper-launch i da Comet Lake ne bude ništa posebno.
I opet su morali reći koju pametnu, a da ne ispadne hohštaplerska reklama u stilu Lajnusa i sl. bedaka.
U svakom slučaju, svaka im čast na trudu i iskrenosti, jer većina bi/je popušila Intelovu PR štoriju.
Staro 21.05.2020., 21:42   #3256
Manuel Calavera
Postovi: 14,585
Autor maXonja Pregled postova
Pa u globalu zašto nebi bio miran... Jedino što će ti resell value opasti (kao svih intel flagshipa nakon ryzena), ali sam cpu je i više nego OK
Staro 21.05.2020., 22:30   #3257
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
to se događa svim procesorima i samim ryzenima od izlaska ryzena. ne isplati se više ni prodavati staro.
Staro 22.05.2020., 12:40   #3258
Manuel Calavera
Postovi: 14,585
Intel’s 11th Generation, 14nm Rocket Lake-S 6 Core Desktop CPU With Up To 4.1 GHz Clocks Spotted
Inženjerski primjerak. Uglavnom glasine i dalje tvrde da ovo dolazi do kraja godine, ovaj 10th gen comet lake je doslovce stop-gap od par mjeseci
Staro 22.05.2020., 12:41   #3259
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,489
jel se planiraju ikad pomaknut sa 14nm
Staro 22.05.2020., 12:50   #3260
Manuel Calavera
Postovi: 14,585
Valjda bi taj alder lake (krajem 2021 ili početak 2022) trebao biti 10nm+. Tad će crveni već biti na 5nm TSMC (ekvivalent intelovim planiranim 7nm)
Staro 22.05.2020., 18:11   #3261
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
evo i 10400, naravno F model će imati još bolji uloženo dobiveno faktor
https://www.youtube.com/watch?v=lqxVCzYlDCA
Još jedan odličan gamerski CPU, 45W za jako puno FPS-a.
Staro 22.05.2020., 18:19   #3262
Manuel Calavera
Postovi: 14,585
E taj će pokreniti price war
Entry i5 je uvijek bio najbolji deal kod intela. Samo što mislim da će ga ryzen 3600 nam kraju cijenom učinit irelevantnim
Staro 22.05.2020., 18:21   #3263
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
Ako padne ryzen 3600 na cc 1000 kn onda svakako.
Staro 22.05.2020., 18:34   #3264
betlmaster
Postovi: 59
Misliš ovak kak je bilo jutros?
https://www.links.hr/hr/procesor-amd...alth-050600100
betlmaster
betlmaster je offline   Reply With Quote
Staro 22.05.2020., 18:35   #3265
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
Da, tak bi mogao biti uskoro pod normalno.
Staro 22.05.2020., 18:36   #3266
Postovi: 8,482
Koliko se ima prilike skužiti, skoro svi koji su recenzirali nove Intele imaju jako sličan vokabular, pa se često može čuti: Intel i dalje ima najbolje performanse u igrama, pa ako vam je to bitno, Intel je pravi izbor. AMD i dalje nudi najbolje performanse u svemu što nisu igre, mada i igre u AMD slučaju nisu loše, ali Intel je bolji. Igre su tak jasno testirane u 1080p da se vidi razlika između procesora, jer na 1440p ili 4K razlike jednostavno nema kad GPU odrađuje svoje bez pardona. Ovisno o kojem novom Intel procesoru je riječ, skuplji su od AMD-ovih pandana do te mjere da Intel 6C/12T zapravo zadire u AMD-ov 8C/16T teritorij, Intel 10C/20T je skoro 100$ skuplji od 3900X, i tome slično. I to prije nego ovi u AMD-u krenu sa spuštanjem cijena, Ryzen 4000 APU AM4 modelima, a Intel bude teško naći u bilo kakvom fizičkom obliku sljedećih mjesec dana.
Staro 22.05.2020., 18:40   #3267
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
Bez obzira na sve, i bez obzira kaj bu izgubio od ryzena 3600 cjenovno i bez obzira kaj izlazi na mrtvom socketu, 45w za taj rang performansi je po meni odlično i nema se kaj tko sramiti ako ga kupi i koristi idućih godina za igranje.
Staro 22.05.2020., 18:52   #3268
Manuel Calavera
Postovi: 14,585
Ne vjerujem da će 1000kn odmah biti (nekad hoće), al nekih 100-200kn dolje sigurno
BTW počeo se pojavljivat u ponudi
https://www.nabava.net/search.php?q=i5+10400
Staro 22.05.2020., 18:55   #3269
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
Ako F model bude 1300 kn koliko je bio i 9400F uz neku 600 kn MBO puna šaka brade.
Staro 22.05.2020., 19:47   #3270
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,557
45W? Ne kazem da si u krivu ali intel ark kaze 65W ako pricamo o TDPu
