Staro 07.09.2017., 16:06   #3331
LeskiRM
LeskiRM's Avatar
Datum registracije: Feb 2015
Lokacija: Sveta Nedelja
Postovi: 705
Je li stock cooler za ryzen 1600 dostatan ili da uzmem onaj fsp windale 4?
LeskiRM je offline   Reply With Quote
Staro 07.09.2017., 16:11   #3332
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Za stock i OC do 3.6 i možda 3.7ghz je
Staro 07.09.2017., 16:35   #3333
LeskiRM
LeskiRM's Avatar
Postovi: 705
Uzeo sam onaj fsp windale 4.
Jako je slaba ponuda coolera koji su out of the box am4 ready.
A kakav sam ja, htio bi se igrat sa oc malo a i volio bih sto tisi cooler. Nisam imao prilike cut taj amd-ov u full loadu
Zadnje izmijenjeno od: LeskiRM. 07.09.2017. u 16:53.
Staro 07.09.2017., 18:22   #3334
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Amd wraith koji sam dobio s ryzen 5 1600 je stvarno ok. Nemas sta cuti, i super hladi. Ne pada mi ga napamet mjenjat, iako lako meni kad sam i sa stock postavkama zadovoljan
MojSkuter
Staro 07.09.2017., 21:51   #3335
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Autor LeskiRM Pregled postova
Dostatan je
Amd_Shill je online   Reply With Quote
Staro 08.09.2017., 16:05   #3336
Uključiš Windows Subsystem for Linux (WSL) i pokreneš prethodno spomenutu ./kill-ryzen.sh skriptu s Phoronixa.
blabla@KANTA: /mnt/c$ ./kill-ryzen.sh
./kill-ryzen.sh: redak 7: sintaksna greška kod neočekivanog simbola „newline”
./kill-ryzen.sh: redak 7: `'
Što sad?
Inače, kolega HAL 9001 je iskopao ovo:
Per the data gathered, if you don't have a CPU built on or after the last week of June, good chance you'll have this issue. This isn't a RAM, CPU, MOBO or VOLTAGE issue as the replacement chips work without changing anything.
Threadripper chips have UA1727+ Build Dates.
Reported Good RMA CPU Build Dates
UA1725SUS (mcl00@amdcommunityforums , fujii@amdcommunityforums, sat@amdcommunityforums, supercom32@amdcommunityforus, raydude@amdcommunityforums)
UA1730SUS (parttimehorse@reddit)
Reported Instance of bad CPU Build Dates
UA1706SUT (sat@amdcommunityforums)
UA1707SUT (supercom32@amdcommunityforums)
UA1707SUT (apache14@amdcommunityforums)
UA1707PGT (fujii@amdcommunityforums)
UA1707PGT (parttimehorse@reddit)
UA1707PGT (markh@amdcommunityforums)
UA1707SUS (xtronom@amdcommunityforums)
UA1708SUT (kaseki@amdcommunityforums)
UA1709PGT (bradc@amdcommunityforums)
UA1713PGT (raydude@amdcommunityforums)
UA1714SUS (xtronom@amdcommunityforums)
UA1714SUS (runningman@amdcommunitforums)
UA1714PGT (udamanfunks@amdcommunityforums)
UA1716PGT (fujii@amdcommunityforums)
UA1717PGS (dbdbdb@amdcommunityforums)
UA1717SUT (sat@amdcommunityforums)
UA1725SUS (sat@amdcommunityforums)
Srećom pa imam fotke od procesora prije ugradnje da ne moram sad niš raskapati Na mom procesoru piše: UA 1707PGT, dakle kao i ovi boldani gore u quoteu. Znači da je affected. OK, budemo ga reklamirali AMD-u kad izađe Pinnacle Ridge
Zadnje izmijenjeno od: Brko. 08.09.2017. u 16:17.
Staro 08.09.2017., 17:49   #3337
ksonofre
Datum registracije: Apr 2015
Postovi: 18
Što sad?
To je obicno error kada scripta ima krive line endingse. Na githubu je skripta sa Unix pa ih trebas promijeniti vjerojatno u Windows line endings.
ksonofre je offline   Reply With Quote
Staro 08.09.2017., 18:15   #3338
Ok, ali što nebi to trebalo biti isto budući preko basha dobivan "unix" based linije i to?
U svakom slučaju nemam pojima što da radim dalje
Ali eto, prema ovim datumima gore sam 100% siguran da je proc affected jer je to prva serija 1600-tki i kupljena je par dana nakon NDA lifta.
@mob
Staro 08.09.2017., 20:06   #3339
ksonofre
Postovi: 18
Da trebalo bi biti ali sam pretpostavio da je to zbog Windows Subsystem for Linux (WSL) (nikad nisam koristio zato samo pretpostavljam). Inace, u skripti u 7. redu nema charactera ` zbog toga je problem ili u new line endings ili u nekom hidden characteru.
Ako ces htjeti mozes promijeniti line endings preko Windows Command Prompt-a:
TYPE kill-ryzen.sh | MORE /P > kill-ryzen_wle.sh
i pokrenuti drugu skriptu:
./kill-ryzen_wle.sh
Za hidden character je malo teze, ali skinuo sam skriptu za svaki slucaj ponovno s GitHub-a (https://raw.githubusercontent.com/su.../kill-ryzen.sh) desni klik -> Save as... i uredno prolazi 7. red u virtualnoj Ubuntu masini.
Staro 08.09.2017., 20:33   #3340
Postovi: 8,360
/mnt/c$ znači da si pokrenul skriptu iz Windows foldera, a WSL između ostalog kreira kompletan Ubuntu podsistem koji se nalazi u C:\Users\USERNAME\AppData\Local\Lxss\home\USERNAME.
Skini cijeli ryzen-test-master, pa ga smjesti, raspakiraj i pokreni unutar Ubuntu podsistema. Phoronix Test Suite također može poslužiti za reproduciranje segmentation greške.
Možeš i bootati neku od popularnijih distribucija, pa "nativno" pokrenuti kill-ryzen, samo ne znam koliko ti se isplati zajebavati s tim - čisto zajebancije radi.
Ne moraš se zamarati. Moj R5 1600 je kupljen 01.09. i ima UA 1718PGS oznaku, tak da je u prodaji još uvijek starija zaliha.
Staro 08.09.2017., 20:55   #3341
shar
Overclocker
shar's Avatar
Datum registracije: Nov 2016
Postovi: 523
Nisam u potpunosti upratio zašto mijenjaju procesore?
shar je offline   Reply With Quote
Staro 08.09.2017., 20:59   #3342
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
pa ja imam zorin OS, u teoriji bi to mogao lako na brzinu testat ..
ima li negdje neki jednostavni how to tutorial kako se to na linuxu bez previse petljanja po terminalu to moze napraviti?
MojSkuter
Staro 08.09.2017., 21:57   #3343
Postovi: 8,360
Autor shar Pregled postova
Greške/pucanje prilikom kompajliranja na *nix sustavima.
Autor Eladio Pregled postova
Jednostavnije od pokretanja ./kill-ryzen.sh u terminalu? Drag'n'drop kill-ryzen.sh u terminal?
eladio@mycomp: cd /ryzen-test - ili bilo koji folder u kojem se nalazi kill-ryzen skripta
eladio@mycomp: ~/ryzen-test$ ./kill-ryzen.sh
Zadnje izmijenjeno od: The Exiled. 08.09.2017. u 22:09.
Staro 09.09.2017., 02:19   #3344
blabla@KANTA:/mnt/c$ ./kill-ryzen.sh
Install required packages
Reading package lists... Done
Building dependency tree
Reading state information... Done
build-essential is already the newest version (12.1ubuntu2).
0 upgraded, 0 newly installed, 0 to remove and 110 not upgraded.
Create compressed ramdisk
modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/modules/4.4.0-43-Microsoft/modules.dep.bin'
modprobe: FATAL: Module zram not found in directory /lib/modules/4.4.0-43-Microsoft
Koji je sad to qrac?
Budemo probao iz knoppixa. Ako to nebu išlo, budem upiknuo neki HDD, digao gore Ubuntuta i okinuo onda. Baš me zanima što se dogodi
Zadnje izmijenjeno od: Brko. 09.09.2017. u 02:30.
Staro 09.09.2017., 11:56   #3345
Postovi: 8,360
Requirements
To successfully finish a round of 16 builds more than 16Gb of RAM are required because GCC is a large software package.
However, with only 16Gb RAM, this configuration might still run out of memory. 4 loops with 4 threads each is a safe choice on machines with 16Gb RAM.
./kill-ryzen.sh 4 4
Staro 09.09.2017., 12:19   #3346
Grunf_TNT
Postovi: 9
Editiraj skriptu i stavi USE_RAMDISK=false.
Ja sam vrtio nekih pola sata nije izbacilo seg fault.
The Answer to the Great Question Of Life, the Universe and Everything Is...
Forty-two
Grunf_TNT je offline   Reply With Quote
Staro 09.09.2017., 12:29   #3347
Grunfe, sad oće hvala. Zakucao svih 12 threadova i sad maže. Da ga pustim da drnda i koliko dugo?
UPDATE:
[loop-0] Sat Sep 9 11:43:50 DST 2017 build failed
[loop-0] TIME TO FAIL: 897 s
[loop-1] Sat Sep 9 11:43:53 DST 2017 build failed
[loop-1] TIME TO FAIL: 900 s
[loop-3] Sat Sep 9 11:43:54 DST 2017 build failed
[loop-3] TIME TO FAIL: 901 s
[loop-2] Sat Sep 9 11:43:56 DST 2017 build failed
[loop-2] TIME TO FAIL: 903 s
[loop-5] Sat Sep 9 11:43:56 DST 2017 build failed
[loop-5] TIME TO FAIL: 903 s
[loop-4] Sat Sep 9 11:43:57 DST 2017 build failed
[loop-4] TIME TO FAIL: 904 s
[loop-6] Sat Sep 9 11:43:57 DST 2017 build failed
[loop-6] TIME TO FAIL: 904 s
[loop-7] Sat Sep 9 11:44:02 DST 2017 build failed
[loop-7] TIME TO FAIL: 909 s
[loop-8] Sat Sep 9 11:44:03 DST 2017 build failed
[loop-8] TIME TO FAIL: 910 s
[loop-10] Sat Sep 9 11:44:03 DST 2017 build failed
[loop-10] TIME TO FAIL: 910 s
[loop-9] Sat Sep 9 11:44:04 DST 2017 build failed
[loop-9] TIME TO FAIL: 911 s
[loop-11] Sat Sep 9 11:44:04 DST 2017 build failed
[loop-11] TIME TO FAIL: 911 s
To je to
Zadnje izmijenjeno od: Brko. 09.09.2017. u 13:39.
Staro 09.09.2017., 13:53   #3348
Makic10
Makic10's Avatar
Datum registracije: Apr 2017
Postovi: 47
morat ću i ja svoga testirat, kad dođem doma, već dva miseca nije upaljen.
Makic10 je offline   Reply With Quote
Staro 09.09.2017., 14:08   #3349
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,566
Jesu li 1700tice pogodjene ? UA 1725PGT tocnije ?
Staro 09.09.2017., 15:07   #3350
Postovi: 8,360
Zahvaćeni su svi Ryzen modeli. UA 1725PGT znači da je CPU proizveden u 25. tjednu (19.06. - 25.06.2017.), tako da možda spada u novu seriju.
Staro 09.09.2017., 18:24   #3351
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,566
Dakle pred istek garancije ce se svi cpu-i reklamirati? Dobar posao u italiji
Staro 09.09.2017., 18:50   #3352
Sa AMDom uvijek neke pogodnosti za kupce
@mob
Staro 09.09.2017., 19:29   #3353
Postovi: 8,360
U slučaju da netko stvarno hoće reklamirati procesor čisto zato, jer može na temelju testa koji dokazuje da postoji greška prilikom nečega čime se većina ne bavi, onda RMA ide direktno preko AMD-a.
Dućan u kojem je kupljen i popratna garancija ne igraju ulogu. I nakon svih AMD-ovih probajte ovo, pa probajte ono - korisnik mora poslati stari/nesipravni Ryzen natrag. Tek onda stiže novi Ryzen.
Staro 09.09.2017., 19:30   #3354
shar
Overclocker
shar's Avatar
Postovi: 523
Spomenuo ovo kolegi, eno ga već trlja ruke razmišljajući kako će dobit novi proc umjesto blago degradiranog 1800x nakon silovanja pod ln2.
"Ne možeš ti našeg čovika zajebat"
Staro 09.09.2017., 19:36   #3355
Tak jasno. Procesor nije neispravan. Ne valja za nešto što 99% korisnika neće ni primjetiti da ne valja.
A što se tiče reklamacije AMD-u, jasno je da treba prvo CPU poslati njima da oni mogu poslati novi. Zato velim da ću pričekati sa time da Summit Ridge bude EOL pa da u zamjenu pošalju Pinnacle Ridge
Staro 09.09.2017., 20:16   #3356
Litra
Litra's Avatar
Lokacija: Zagreb, Dubrava
Postovi: 502
Jel mi netko može objasnit proces testiranja na najlakši mogući način?
Čitam po redditu i ostalim stranicama ali nije mi baš jasno koji je proces tj, tj koraci. Skino sam kill ryzen i phoronix i sad na znam što dalje.
Litra je offline   Reply With Quote
Staro 09.09.2017., 20:22   #3357
Litra:
Prvo ovo:
Onda ovo: (kill-ryzen.sh otvoris u notepadu i izmjeniš ovo)
Autor Grunf_TNT Pregled postova
I nemres fulat. Čak sam i ja uspio kome ne Linux špansko selo.
@mob
Staro 10.09.2017., 09:44   #3358
Postovi: 8,218
Autor xulos Pregled postova
To je sad feature kad je AMD u pitanju, a kad je nvidia sjebala, onda su bile teorije zavjere i pljuvanje. E moj xulos
Staro 10.09.2017., 13:02   #3359
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Autor Pupo Pregled postova
Neusporedivi slučajevi.
Staro 10.09.2017., 13:04   #3360
Litra
Litra's Avatar
Postovi: 502
Litra:
Prvo ovo:Onda ovo: (kill-ryzen.sh otvoris u notepadu i izmjeniš ovo)I nemres fulat. Čak sam i ja uspio kome ne Linux špansko selo.
@mob
Instaliro sam Ubunto on windows ali ne mogu ništa pokrenut oz njega.
Nije me tražio ni username ni password kad sam ga instaliro.
Ne znam šta dalje.
