Staro 30.08.2017., 22:56   #3301
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,553
Autor darkydark Pregled postova
Lightroom koristi samo jednu jezgru.
Sent from my Moto G Play using Tapatalk
lightroom cc 2015.6.12 snimili i sad leti, koristi svih 16
Staro 01.09.2017., 08:27   #3302
Old.machine
Old.machine's Avatar
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,455
Koja je stvar sa Ryzen segmentation faults greškom? To se događa samo na Linuxu, Windowsi nisu zahvaćeni? Kako se greška manifestira?
Old.machine je offline   Reply With Quote
Staro 01.09.2017., 13:21   #3303
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,265
Autor Old.machine Pregled postova
A kad to ves spominjes, navodno je na novijim revizijama ispravljena, kako da znamo dali je proc iz starije serije ili novije gdje je bug ispravljen?
Pitanje naravno nije upuceno tebi, nego opcenito, ali ako znas odg. slobodno pucaj
Slobodno me dodajte na PSN
Staro 01.09.2017., 14:02   #3304
HAL 9001
Poboljsana verzija
HAL 9001's Avatar
Postovi: 483
Autor Disco Pregled postova
Iskopao sam ovo:
Per the data gathered, if you don't have a CPU built on or after the last week of June, good chance you'll have this issue. This isn't a RAM, CPU, MOBO or VOLTAGE issue as the replacement chips work without changing anything.
Threadripper chips have UA1727+ Build Dates.
Reported Good RMA CPU Build Dates
UA1725SUS (mcl00@amdcommunityforums , fujii@amdcommunityforums, sat@amdcommunityforums, supercom32@amdcommunityforus, raydude@amdcommunityforums)
UA1730SUS (parttimehorse@reddit)
Reported Instance of bad CPU Build Dates
UA1706SUT (sat@amdcommunityforums)
UA1707SUT (supercom32@amdcommunityforums)
UA1707SUT (apache14@amdcommunityforums)
UA1707PGT (fujii@amdcommunityforums)
UA1707PGT (parttimehorse@reddit)
UA1707PGT (markh@amdcommunityforums)
UA1707SUS (xtronom@amdcommunityforums)
UA1708SUT (kaseki@amdcommunityforums)
UA1709PGT (bradc@amdcommunityforums)
UA1713PGT (raydude@amdcommunityforums)
UA1714SUS (xtronom@amdcommunityforums)
UA1714SUS (runningman@amdcommunitforums)
UA1714PGT (udamanfunks@amdcommunityforums)
UA1716PGT (fujii@amdcommunityforums)
UA1717PGS (dbdbdb@amdcommunityforums)
UA1717SUT (sat@amdcommunityforums)
UA1725SUS (sat@amdcommunityforums)
Prve dvije znamenke nakon UA označavaju godinu a druge dvije tjedan proizvodnje. Taj broj se može vidjeti samo na procesoru pa ako se nekome da skidati sve neka gleda
HAL 9001 je offline   Reply With Quote
Staro 01.09.2017., 14:06   #3305
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,265
Autor HAL 9001 Pregled postova
Iskopao sam ovo:
Hvala, al vraga cu ja to sad drljat, kad sam ga slozio burazu, neka se igra i uziva. Ovo mu vj nece nikad ni trebat, ali me samo zanimalo da znam.
Fala
Staro 01.09.2017., 14:53   #3306
Old.machine
Lokacija: ______
Postovi: 1,455
Hvala obojici na odg
Na ovoj stranici su upute kako reproducirati test. Treba samo dignuti Linux (bilo koja verzija Linuxa?) i pokrenuti taj Ryzen test (ovome sa te stranice greška se pojavila već nakon 88 sekundi, dok nekima trebaju sati testiranja)? Mene samo zanima da li je Windows zahvaćen...
Staro 01.09.2017., 19:58   #3307
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
http://forum.pcekspert.com/showpost....5&postcount=43
Programer
Staro 01.09.2017., 23:08   #3308
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Staro 01.09.2017., 23:13   #3309
Link 1: hijaoooo, a kad je Brko rekao da će kad tad Gnjidabajt (tm) BIOS usrat nekako, smijeha je bilo. Vidoviti Milan mi je rekao to i beše u pravu.
Link 2: mislim da ovo više govori o tome koliko su ljudi bili siti Intelovog masnog naplaćivanja reciklaža nego o tome koliko je ryzen zapravo dobar i jak (a je, i dobar i jak i dobro pogođen).
@mob
Staro 01.09.2017., 23:15   #3310
Manuel Calavera
Postovi: 14,584
Prodaja na švapskom portalu je logična - ide po isplativosti. Intel jedino drži i7 7700K kao naj gayming cpu, ostalih nema ni blizu vrha prodaje
In sharp contrast to AMD’s diverse lineup of highly popular chips, only a single SKU accounts for nearly half of all of Intel’s desktop unit sales and that’s the i7 7700K.
In the blue corner once again we see a single SKU, the i7 7700K accounting for the majority of the company’s desktop sales revenue.
Staro 02.09.2017., 23:04   #3311
Old.machine
Lokacija: ______
Postovi: 1,455
Znači problem je prisutan i na Windowsima. Naišao sam i na par slučajeva gdje govore da ovaj problem može biti uzrok rušenja kod Ashes of singularity u Dx12 benchmarku i da se i Shadow of Mordor zna srušiti zbog toga jer igra ima veliki CPU usage. Koliko je sad istine u tome ne znam...
Staro 02.09.2017., 23:25   #3312
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
..čuo si da može biti i da se zna desiti
..ja jedino što znam, je da mi komp radi stutter free 24/7 , iako su win ostali stari od intel mašine a molili su me da stavim friške.
..i jedino "restartam" komp kako mjenjam hardware tj grafičke u zadnje dane.
uglavnom se ljudi žale koliko vidim prilikom OCa na rame, ali nitko da mu išta šteka oko aplikacija u win, a već nas se je ohoho skupilo čak i na ovom forumu.
ono što želim reći, ok to je prijavljeni problem, i ako te dira dobro je znati, ali treba izbjegavati ovo čuo si da može biti da se zna desiti
MojSkuter
Zadnje izmijenjeno od: Eladio. 02.09.2017. u 23:40.
Eladio je online   Reply With Quote
Staro 02.09.2017., 23:31   #3313
Ne bi nikad rekao da problema nema. Vjerujem da ima. No stvarno, ali stvarno sam više puta upregnuo R5 1600 na 3.93GHz i ama baš ništa se nije negativno dogodilo.
Možda i ploče imaju određenih problema i dalje koji nisu skroz riješeni, stvarno nemam pojima.
Al da treba brusiti još tu platformu, treba.
@mob
Staro 03.09.2017., 18:01   #3314
Ninja_Zg
Ninja_Zg's Avatar
Datum registracije: Aug 2013
Postovi: 267
Pitanje za vidovitog Milana, ali koliki se price drop Ryzena/DDR4/MBO moze ocekivati do Bozica? Dolar bi isto mogao otici gore.
Planiram upgrade, a realno mi nije neka hica, mogu se strpit jos koji mjesec da ustedim nesto i da se eventualno ispeglaju neke sitnice na platformi.
Jos mislim da mi je najbolja opcija loviti Black Friday/Cyber Monday, uzimam hardver u USA.
Ninja_Zg je offline   Reply With Quote
Staro 03.09.2017., 18:27   #3315
Manuel Calavera
Postovi: 14,584
Dolar je u padu (barem bio do sad). A cijena rama bi još mogla rasti
Staro 03.09.2017., 18:29   #3316
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Nemas sta cekat, sve je izaslo sto je trebalo izać. Možda intel coffe lake malo poremeti cijene još eventualno, ali poznavajući intel on će biti skuplji i amd će možda samo malo podesiti price/performance line up po tome.
Ipak generalno ove godine to je to, sitne oscilacije su više vezane za dolar
Ps ddr4 ram ti ide gore, bar je takva najava, tako da tu može biti stvar još i gora nego sad
MojSkuter
Staro 03.09.2017., 20:03   #3317
Dolar i Euro su pali dok je turistička sezona. Za RAM je najbolje kupiti ga danas jer on malo po malo i dalje raste.
Ryzen i ploče neće drastično pasti. A za Božić je ionako sve skuplje
@mob
Staro 03.09.2017., 23:31   #3318
Litra
Litra's Avatar
Lokacija: Zagreb, Dubrava
Postovi: 502
Danas se malo poigro sam overeclockom ryzena 1600x. U 10 min postavio ga na 4.0 GHz na 1,35 i za sada stabilno sa svim stress testovima. Temperatura max je 63 c što je zadovoljavajuće. Vjerovatno ću se još poigrat s voltažom jer bi je htio maksimalno spustit, ali to je izazov za drugi dan.
Usput jedan dobar video za vlasnike asus c6h po kojem sam radio.
https://www.youtube.com/watch?v=pBmVf0S4UDs
Litra je offline   Reply With Quote
Staro 04.09.2017., 00:14   #3319
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,753
Pisao sam prije izvjesnog vremena i ovdje na forumu kako sam imao problema s vise od dva Display Port monitora na cjelokupnoj non-Quadro Pascal seriji kartica, od 1060 do Titana X. Nesto sto bi trebalo raditi jer je tako zamisljeno, a opet stvara probleme. Mislis da nVidiu boli q za mene i jos 100 budala koje eventualno imaju taj problem? Tesko. Jer su uzeli statistiku sa Steama, vidjeli da postoji par ljudi s takvim setupom (ako-ali) i zakljucili da im se ne isplati razmisljati o tome.
Slicno ti je i ovdje. Srusi se svaki 1.000 aparat u nekoj opskurnoj situaciji. Bude bilo popeglano u novijim verzijama a ako ce bas netko jako jesti govna, dobit ce novi CPU i bok-cao-papa.
Koliko to dugorocno pomaze AMD-u u plasmanu na trzista koja donose hrpu para? Nemam pojma. Calculated risk. Steta, jer procesor ipak u nekom price/performance odnosu za boraniju predstavlja fantasticnu pricu. Isprobao sam ga za Pix4D (dosta opskuran ali vrlo mocan softvercic za 3D mapiranje i slicna zazanja) i rezultati su, obzirom na ulozeni novac, fantasticni. Zelim li se kockati s time hoce li mi 10 dana vrcenja tog softvera puknuti nekada? E, i ne bas. Jer cu isplatiti 40% skuplji stroj za 30 dana. Po meni je tu AMD napravio pacersku gresku, kao i obicno. Bezrazlozno.
Programer
Staro 04.09.2017., 12:01   #3320
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Ako sam dobro skuzio, taj problem je rijesen u novijim verzijama Ryzena. Ako netko ima problema s tim, moze poslati CPU nazad AMD-u i dobit ce novi.
Staro 04.09.2017., 12:26   #3321
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Upravo to.
Bura u čaši vode.
Amd_Shill je offline   Reply With Quote
Staro 04.09.2017., 13:17   #3322
Što treba zavrtiti na kompu da se vidi je li CPU kojeg imam affected ili nije?
@mob
Staro 04.09.2017., 14:55   #3323
Postovi: 8,231
Uključiš Windows Subsystem for Linux (WSL) i pokreneš prethodno spomenutu ./kill-ryzen.sh skriptu s Phoronixa.
Staro 04.09.2017., 20:01   #3324
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Pošalješ ga Baneliju, ili još bolje - syssu, na "promatranje"
Pomelo mi sig -.-
Staro 05.09.2017., 14:31   #3325
Busola29
Da opće poznato da ne treba brzati (ma zašto i stavljati novi ako sve uredno radi sa starim...) sa stavljanjem novih BIOS-a što ljudi uporno rade...
Zanimljiv mi je taj zapad (Njemačka u ovom slučaju...). Njihovi grafovi i analize su mnogo puta vrlo nepregledni , nedostatak informatičara i ljudi koji imaju smisao za dizajn.
Koda je Njemcima sve kvalitetno ošlo u autoindustriju i strojarstvo...
Staro 06.09.2017., 06:21   #3326
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,265
@mob
I?
Tvoj mora da je ''zarazen'' posto si ga uzeo dosta rano.
Staro 06.09.2017., 08:04   #3327
Amd_Shill
Lokacija: Sat
Postovi: 1,119
I?
To će ga puno pogodit.
Sigurno svaki dan kompajlira pizdarije i gleda segfaultove.
Staro 06.09.2017., 08:30   #3328
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,265
Autor Amd_Shill Pregled postova
Za igre i Handbrake ce biti savrsen, ako sam dobro skuzio za sto Brcina koristi komp
Staro 06.09.2017., 09:04   #3329
I?
Nisam doma još par dana pa to neću moći provjeriti. Vjerojatno je affected. Uzeo sam R5 1600 5 dana nakon launcha. Ali ga ne mislim vraćati AMDu ne još... možda kad dođe Pinnacle Ridge
Baš...
Da. Do sada nisam imao CTD niti BSOD. Valjda više ne znam kako napregnuti komp kak se spada
@mob
Staro 06.09.2017., 13:00   #3330
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,265
A cuj, ja uz to dvoje jos koristim za net i YT, zato i ne mislim jos mjenjat ovog ivy-a.
