#3303 | |
Prvoklasni Krkan
Postovi: 5,253
Pitanje naravno nije upuceno tebi, nego opcenito, ali ako znas odg. slobodno pucaj ![]() |
#3304 | |
Poboljsana verzija
Postovi: 482
Per the data gathered, if you don't have a CPU built on or after the last week of June, good chance you'll have this issue. This isn't a RAM, CPU, MOBO or VOLTAGE issue as the replacement chips work without changing anything. Threadripper chips have UA1727+ Build Dates. Reported Good RMA CPU Build Dates UA1725SUS (mcl00@amdcommunityforums , fujii@amdcommunityforums, sat@amdcommunityforums, supercom32@amdcommunityforus, raydude@amdcommunityforums) UA1730SUS (parttimehorse@reddit) Reported Instance of bad CPU Build Dates UA1706SUT (sat@amdcommunityforums) UA1707SUT (supercom32@amdcommunityforums) UA1707SUT (apache14@amdcommunityforums) UA1707PGT (fujii@amdcommunityforums) UA1707PGT (parttimehorse@reddit) UA1707PGT (markh@amdcommunityforums) UA1707SUS (xtronom@amdcommunityforums) UA1708SUT (kaseki@amdcommunityforums) UA1709PGT (bradc@amdcommunityforums) UA1713PGT (raydude@amdcommunityforums) UA1714SUS (xtronom@amdcommunityforums) UA1714SUS (runningman@amdcommunitforums) UA1714PGT (udamanfunks@amdcommunityforums) UA1716PGT (fujii@amdcommunityforums) UA1717PGS (dbdbdb@amdcommunityforums) UA1717SUT (sat@amdcommunityforums) UA1725SUS (sat@amdcommunityforums) Prve dvije znamenke nakon UA označavaju godinu a druge dvije tjedan proizvodnje. Taj broj se može vidjeti samo na procesoru pa ako se nekome da skidati sve neka gleda ![]() |
#3305 | |
Prvoklasni Krkan
Postovi: 5,253
Fala ![]() |
#3306 |
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,455
Hvala obojici na odg ![]() Na ovoj stranici su upute kako reproducirati test. Treba samo dignuti Linux (bilo koja verzija Linuxa?) i pokrenuti taj Ryzen test (ovome sa te stranice greška se pojavila već nakon 88 sekundi, dok nekima trebaju sati testiranja)? Mene samo zanima da li je Windows zahvaćen... |
#3307 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,751
#3308 |
Postovi: 14,578
#3309 |
Link 1: hijaoooo, a kad je Brko rekao da će kad tad Gnjidabajt (tm) BIOS usrat nekako, smijeha je bilo. Vidoviti Milan mi je rekao to i beše u pravu. Link 2: mislim da ovo više govori o tome koliko su ljudi bili siti Intelovog masnog naplaćivanja reciklaža nego o tome koliko je ryzen zapravo dobar i jak (a je, i dobar i jak i dobro pogođen). @mob |
#3310 | ||
Postovi: 14,578
Prodaja na švapskom portalu je logična - ide po isplativosti. Intel jedino drži i7 7700K kao naj gayming cpu, ostalih nema ni blizu vrha prodaje Citiraj:
#3311 | |
Lokacija: ______
Postovi: 1,455
#3312 |
..starija garda
Postovi: 3,278
..čuo si da može biti i da se zna desiti ![]() ..ja jedino što znam, je da mi komp radi stutter free 24/7 , iako su win ostali stari od intel mašine a molili su me da stavim friške. ..i jedino "restartam" komp kako mjenjam hardware tj grafičke u zadnje dane. uglavnom se ljudi žale koliko vidim prilikom OCa na rame, ali nitko da mu išta šteka oko aplikacija u win, a već nas se je ohoho skupilo čak i na ovom forumu. ono što želim reći, ok to je prijavljeni problem, i ako te dira dobro je znati, ali treba izbjegavati ovo čuo si da može biti da se zna desiti ![]()
__________________ MojSkuter ---------------------------------PEACE Zadnje izmijenjeno od: Eladio. 02.09.2017. u 23:40. |
#3313 |
Ne bi nikad rekao da problema nema. Vjerujem da ima. No stvarno, ali stvarno sam više puta upregnuo R5 1600 na 3.93GHz i ama baš ništa se nije negativno dogodilo. Možda i ploče imaju određenih problema i dalje koji nisu skroz riješeni, stvarno nemam pojima. Al da treba brusiti još tu platformu, treba. @mob |
#3314 |
Datum registracije: Aug 2013
Postovi: 266
Pitanje za vidovitog Milana, ali koliki se price drop Ryzena/DDR4/MBO moze ocekivati do Bozica? Dolar bi isto mogao otici gore. Planiram upgrade, a realno mi nije neka hica, mogu se strpit jos koji mjesec da ustedim nesto i da se eventualno ispeglaju neke sitnice na platformi. Jos mislim da mi je najbolja opcija loviti Black Friday/Cyber Monday, uzimam hardver u USA. |
#3316 |
..starija garda
Postovi: 3,278
Nemas sta cekat, sve je izaslo sto je trebalo izać. Možda intel coffe lake malo poremeti cijene još eventualno, ali poznavajući intel on će biti skuplji i amd će možda samo malo podesiti price/performance line up po tome. Ipak generalno ove godine to je to, sitne oscilacije su više vezane za dolar ![]() Ps ddr4 ram ti ide gore, bar je takva najava, tako da tu može biti stvar još i gora nego sad ![]()
#3317 |
Dolar i Euro su pali dok je turistička sezona. Za RAM je najbolje kupiti ga danas jer on malo po malo i dalje raste. Ryzen i ploče neće drastično pasti. A za Božić je ionako sve skuplje ![]() @mob |
#3318 |
Lokacija: Zagreb, Dubrava
Postovi: 502
Danas se malo poigro sam overeclockom ryzena 1600x. U 10 min postavio ga na 4.0 GHz na 1,35 i za sada stabilno sa svim stress testovima. Temperatura max je 63 c što je zadovoljavajuće. Vjerovatno ću se još poigrat s voltažom jer bi je htio maksimalno spustit, ali to je izazov za drugi dan. Usput jedan dobar video za vlasnike asus c6h po kojem sam radio. https://www.youtube.com/watch?v=pBmVf0S4UDs |
#3319 | |
E Pluribus UNIX
Lokacija: M82
Postovi: 6,751
Slicno ti je i ovdje. Srusi se svaki 1.000 aparat u nekoj opskurnoj situaciji. Bude bilo popeglano u novijim verzijama a ako ce bas netko jako jesti govna, dobit ce novi CPU i bok-cao-papa. Koliko to dugorocno pomaze AMD-u u plasmanu na trzista koja donose hrpu para? Nemam pojma. Calculated risk. Steta, jer procesor ipak u nekom price/performance odnosu za boraniju predstavlja fantasticnu pricu. Isprobao sam ga za Pix4D (dosta opskuran ali vrlo mocan softvercic za 3D mapiranje i slicna zazanja) i rezultati su, obzirom na ulozeni novac, fantasticni. Zelim li se kockati s time hoce li mi 10 dana vrcenja tog softvera puknuti nekada? E, i ne bas. Jer cu isplatiti 40% skuplji stroj za 30 dana. Po meni je tu AMD napravio pacersku gresku, kao i obicno. Bezrazlozno.
#3320 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Ako sam dobro skuzio, taj problem je rijesen u novijim verzijama Ryzena. Ako netko ima problema s tim, moze poslati CPU nazad AMD-u i dobit ce novi.
#3323 |
Postovi: 8,170
Uključiš Windows Subsystem for Linux (WSL) i pokreneš prethodno spomenutu ./kill-ryzen.sh skriptu s Phoronixa. |
#3325 | |
Zanimljiv mi je taj zapad (Njemačka u ovom slučaju...). Njihovi grafovi i analize su mnogo puta vrlo nepregledni , nedostatak informatičara i ljudi koji imaju smisao za dizajn. Koda je Njemcima sve kvalitetno ošlo u autoindustriju i strojarstvo... |
#3326 |
Prvoklasni Krkan
Postovi: 5,253
#3328 |
Prvoklasni Krkan
Postovi: 5,253
#3329 | ||
Nisam doma još par dana pa to neću moći provjeriti. Vjerojatno je affected. Uzeo sam R5 1600 5 dana nakon launcha. Ali ga ne mislim vraćati AMDu ![]() ![]() Citiraj:
![]() @mob |
