Staro 13.04.2017., 19:45   #2221
Nidjo89
Ovisnik o nikotinu
Datum registracije: Sep 2010
Lokacija: Međimurje<->Švabija
Postovi: 114
Autor BladeRy Pregled postova
Ma OCat sam siguran 90% da necu ni pokusavat. Proslo je doba kad sam cijedio svaki CPU do zadnjeg atoma snage. Sad sam sretan ako radi stabilno i tiho.
Hynix cipovi su kao losi za OC ili...
A prokleti ram je otisao u nebo. Da me vise dodje 2 sticka rama nego maticna ploca... ono wtf.
Lošiji od samsunga za kojim ekipa preko bare luduje al zato i dosta jeftiniji.
Al ak se ne planira OC, onda sam provjeri dal je mema na QVLu. S novijim biosima vidim da su se liste dosta proširile tak da mislim da ne bu problema.
Više lurkam nego pišem...
Nidjo89 je offline   Reply With Quote
Staro 13.04.2017., 20:00   #2222
BladeRy
BladeRy's Avatar
Datum registracije: Aug 2008
Postovi: 2,000
Well, ova je "f4-3200c16d-16gvkb", a zasad podrzana na listi je "f4-3200c14d-16gfx".
Koliko mu znaci ova zadnja 16xxxx, to neznam.
BladeRy je online   Reply With Quote
Staro 13.04.2017., 20:06   #2223
Colossus
Colossus's Avatar
Postovi: 379
Evo mozda nekima koristan info sa OC foruma:
For Europe the X370 Prime Pro is a solid choice.
https://geizhals.eu/?cat=mbam4&xf=317_X370
Gigabyte Aorus GA-AX370-Gaming K3 ~ € 142 --- overpriced RGB board with a BCLK that is not going to help with a weaker B350 - level VRM
MSI X370 SLI Plus ~ € 147 --- supposed to be okay VRM (same as X370 Pro Carbon) but everything else is cut down (audio is ALC892, LAN is Realtek , 2nd M.2 slot gone, etc)
ASUS Prime X370-Pro ~ € 159
ASRock X370 Killer SLI ~ € 160 ---- typically weaker VRM than X370 Prime Pro , weaker audio ALC892 , missing USB 3.1 Gen2 on specsheet
MSI X370 Krait Gaming ~ € 160 supposed to be okay VRM (same as X370 Pro Carbon) but everything else is cut down (audio is ALC892, LAN is Realtek , 2nd M.2 slot gone, etc) , difference to X370 SLI Plus is mainly better capacitors
ASRock Fatal1ty X370 Gaming K4 ~ € 162 ---- typically weaker VRM than X370 Prime Pro , adds post code debug LED
Gigabyte Aorus GA-AX370-Gaming K5 ~ € 178 --- it's a very overpriced RGB board with BCLK that is not going to help with a weaker B350 - level VRM , Intel LAN is only major difference to K3
MSI X370 Gaming Pro carbon ~ € 180 --- supposed to be same VRM as X370 SLI Plus
Biostar X370GT7 ~ € 184 --- top tier VRM , with Realtek LAN
Gigabyte Aorus GA-AX370-Gaming 5 ~ € 208 --- extras that add on to the price (dual LAN/audio , RGB), the VRM is on par with ASUS Prime X370 Pro
Gigabyte Aorus GA-AX370-Gaming K7 ~ € 248 --- extras that add on to the price (dual LAN/audio, RGB), the VRM is on par with ASUS Prime X370 Pro , BCLK gen
ASRock X370 Taichi ~ € 252 --- top tier VRM , BLCK gen , wifi+BT, overkill memory VRM uses TI NexFET components in 2 phase configuration
ASUS ROG Crosshair VI Hero ~ € 258 ---- top tier VRM , BLCK gen
ASRock Fatal1ty X370 Professional Gaming € 287 = Taichi + 5GBps LAN + power/reset buttons
MSI X370 XPower Gaming titanium € 300 = decent VRM, hilariously bad pricing
Colossus je offline   Reply With Quote
Staro 13.04.2017., 20:28   #2224
Nidjo89
Ovisnik o nikotinu
Postovi: 114
Q:
What is G.SKILL memory’s naming convention/nomenclature?
A:
For example: F3-12800CL9D-8GBXL
Breaks down to F3 / 12800 / CL9 / D / 8GB / XL
Memory type:
F1 = DDR
F2 = DDR2
F3 = DDR3
F4 = DDR4
FA = For Mac
Frequency:
8500 = 1066MHz
10600/10666 = 1333MHz
12800 = 1600MHz
14900 = 1866MHz
17000 = 2133MHz
19200 = 2400MHz
CL Timing:
CL9 or C9 = CL timing (tCL) is 9, CL 9-x-x-x
Modules per kit:
S = Single module kit (x1)
D = Dual module kit (x2)
Q = Quad module kit (x4)
Q2 = Eight-module kit (x8)
T = Triple module kit (x3)
T2 = Six-module kit (x6)
Total capacity:
2 / 4 / 6 / 8 / 12 / 16 / 24 / 32 / 64 / 128 GB
Series:
VR / VB / VK / VS / VG = Ripjaws V (Red / Blue / Black / Silver / Gunmetal Gray)
RR / RB / RK = Ripjaws 4 (Red / Blue / Black)
XL / XM / XH = RipjawsX
ZL / ZM / ZH = RipjawsZ
RL / RM / RH = Ripjaws
TZ = Trident Z
TX = TridentX
TD = Trident
AB / AO / AR = ARES
ECO = ECO
SR = Sniper
IS / ISL = Aegis
NQ / PK / HK = Performance
NT / NS = Value RAM
SQ / SK = SO-DIMM for laptop
Additional Trident Z Color:
TZ = Classic Trident Z, Dual Black&Silver body w/ Red top-bar
TZSW = Silver body w/ White top-bar
TZSK = Silver body w/ Black top-bar
TZKW = Black body w/ White top-bar
TZKO = Black body w/ Orange top-bar
TZKY = Black body w/ Yellow top-bar
*If there is a “D” after the series name, then memory cooling fan is included, such as “8GTXD”
*You can find the capacity of each module by dividing the Total Capacity by Modules per kit. For example, F3-12800CL9Q-16GBXL = 16GB/4(Q) = 4GB per module, while F3-12800CL9D-16GBXL = 16GB/2(D) = 8GB per module.
*If there is a "B" as the third letter of the series, such as "TZB" or "RKB", then it typically designates a different CL timing value when compared to the original model without the "B" in the third letter.
Ak se ne varam, kolega warlock25 ti ima tu memu u svojoj konfi, taman smo u slično vrijeme kupili kolko se sjećam pred 2 mjeseca. Možda njega cimnut na PM, vidim u threadu za vlasnike da mu radi na 3200 MHz. Zaboravil sam napomenuti, taj GVKB je single rank ak ti treba taj info.
EDIT:
Joj da, zaboravil. Najčešće kod GSkilla:
3200 MHz CL16 - Hynix (zna biti i nešt Samsunga, al ak se ne varam Samsung ima 16-16-16 latencije dok je Hynix isključivo 16-18-18)
3200 MHz CL14 - Samsung b-die
Puno.
Ak ti se da čitati:
Q:
A:
Memory type:
F1 = DDR
F2 = DDR2
F3 = DDR3
F4 = DDR4
FA = For Mac
Frequency:
8500 = 1066MHz
12800 = 1600MHz
14900 = 1866MHz
17000 = 2133MHz
19200 = 2400MHz
CL Timing:
Modules per kit:
Total capacity:
Series:
TZ = Trident Z
TX = TridentX
TD = Trident
AB / AO / AR = ARES
ECO = ECO
SR = Sniper
IS / ISL = Aegis
NT / NS = Value RAM
EDIT:
Zadnje izmijenjeno od: Nidjo89. 13.04.2017. u 20:33. Razlog: nadopuna
Staro 13.04.2017., 20:40   #2225
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Autor bloodlike Pregled postova
zato sto je pobrao dobre reviewe i mogao sam si priustiti, a cooler ce dati
Ali u tim recenzijama pod a) uglavnom imali samo 1600X i 1500X pa se nisu imali obvezu osvrtati na ostala 2 modela, b) u svim recenzijama koje sam ja dosad pogledao su ili potpuno otvoreno ili "između redaka" rekli da je 1600 bolja kupovina od 1600X, c) common sense ako si pratio situaciju sa ryzen 7 (R7 1700 vs ostali) gdje si mogao vidjeti da su svi isti procesori.
Također od ovih što sam ja pogledao su svi osim jokera istaknuli da 1600X dolazi bez coolera, jedino joker to nije shvatio
Staro 13.04.2017., 20:54   #2226
shar
Overclocker
shar's Avatar
Datum registracije: Nov 2016
Postovi: 523
Čak i ako se dogodi da dobiješ samsung čip na 3200c16 kitu, puno veća je vjerovatnost da je korišten E-die nego B-die.
E die je sličan hynixu uz nešto bolje skaliranje sa naponom.
Long story short: ako vam se ne nateže sa memorijom, platiš b die i miran si jer znaš da će radit, možeš klokat a ne moraš. Doduše to vrijedi do izdavanja updatea od strane AMDa, nakon toga ćemo morat vidjeti kako se situacija razvila.
shar je offline   Reply With Quote
Staro 13.04.2017., 21:36   #2227
BladeRy
BladeRy's Avatar
Postovi: 2,000
@Nidjo
Tnx na pojasnjenju. PMao kolegu pa da vidimo kako ide. Al ako njemu radi, ne vidim zasto nebi i meni. Doduse, uvijek ima shanse za Murphyev zakon...
Staro 13.04.2017., 21:38   #2228
Colossus
Colossus's Avatar
Postovi: 379
Po onome što sam ja do sad viđao po netu i recenzijama, upravo tako 1600x dolazi BEZ coolera, što ga i kod nas i vani praktički onome ko je malo bar pratio cijelu tematiku znači da je 1600 puno bolja kupnja, praktički identičan proc za manje para+dobiješ stock cooler+uložiš razliku u cijeni u dobar cooler ako ti treba za OC ili ako su uši osjetljive na buku stocka na max.
Kod nas ako ćeš kupovati 1600x onda moraš jos uzeti neki cooler solidan što je onda na kraju dosta skuplja računica ako se gleda svaka kuna, nego da se odmah kupi 1600, pa čak i da mu se poslje doda non stock cooler.
Staro 13.04.2017., 22:54   #2229
S3arch1ng
Lokacija: Međimurje
Postovi: 175
Ako nekom zatreba - G.Skill lista sa Samsung B-Die...
S3arch1ng je offline   Reply With Quote
Staro 14.04.2017., 00:11   #2230
Manuel Calavera
Postovi: 14,589
Od 14 do 30 min https://www.youtube.com/watch?v=OE7swnns50o
Podcast o "prekrasnim" iskustvima sa msi pločama navedenog dvojca, o ryzenu 5 itd.
Par kul rečenica
https://youtu.be/eH6R-QdRFOI?t=17m20s
Zadnje izmijenjeno od: Manuel Calavera. 14.04.2017. u 00:16.
Staro 14.04.2017., 00:14   #2231
jed2i
jed2i's Avatar
Datum registracije: Jul 2004
Postovi: 1,771
Evo za sve koji imaju Thermaltake coolere, napisao sam kilometarski mail u kojem ih tražim objašnjenje zašto bi ja kao kupac nastavio koristit njihove proizvode s obzirom da mi Corsair i Nzxt nude besplatnu dostavu am4 bracketa ako imam njihove coolere, skrenuo im pažnju na apsolutno suludu cijenu dostave i ponudili su se da mi besplatno pošalju AM4 bracket.
Dakle ako nekome treba bracket za am4 i ima Thermaltake Cooler, samo oštro na njih i poslat će vam bracket
Staro 14.04.2017., 00:54   #2232
karuro
karuro's Avatar
Postovi: 110
Autor Bono Pregled postova
Ja isto ne kuzim taj hejt na gigabyte koji se vecinom temelji na proslim iskustvima. Ja sam vise nego zadovoljan sa gigabytom i to mi je no. 1 odabir. To je kao da ja pricam kako je asrock smece jer prije 10 godina nisu imali softverski multiplier nego preko jumpera koje nisu isporucili. Tako da sam starih diskova skidao desetak jumpera da bi procesor uopce radio.
Asus mi se cini debelo precijenen, a MSI-u ne vjerujem nista jer crkavaju ploce daleko vise od ostalih.
Gigabyte UEFI je davnih dana bio bugovit ali eto kako je tada bilo tako se i danas prica za njega.
Sent from my SM-G850F using Tapatalk
Ha vidis kak je to subjektivno... meni je msi recimo prvi izbor, a imao isto boga i vraga. Sad imam "sigurni"asus i onako naaah.
karuro je offline   Reply With Quote
Staro 14.04.2017., 00:57   #2233
Manuel Calavera
Postovi: 14,589
Veoma je važno o kojemu se socketu radi, tako da nema neke vajde od generaliziranja
Staro 14.04.2017., 10:19   #2234
lutherus
lutherus's Avatar
Datum registracije: Sep 2011
Lokacija: Dubai UAE
Postovi: 714
Ono kaj mene zanima je podrška za iommu kod procesora i od strane trenutno dobavljivih matičnih.
Note to the AMD haters: nobody cares
lutherus je offline   Reply With Quote
Staro 14.04.2017., 11:02   #2235
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 727
U kom kontekstu ? Za virtualke ? ... meni vmWare na R7 radi ok.
Staro 14.04.2017., 11:10   #2236
Kad je parastos za ove i3 i i5 procesore? Da se lepo obučem...
Sent from my SM-G930F using Tapatalk
Staro 14.04.2017., 11:34   #2237
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
i3 ne jos.
Za i5 je vec odrzana misa zadusnica.
Amd_Shill je offline   Reply With Quote
Staro 14.04.2017., 11:50   #2238
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Baš me nasmija
Rip i5 & i3
Staro 14.04.2017., 12:23   #2239
Manuel Calavera
Postovi: 14,589
Nego kako taj čudni čiko to sve lijepo i jasno objasni. Evo još i iz onog prvog linka ukratko osvrt u odnosu na i5
https://youtu.be/OE7swnns50o?t=28m11s
Slažem se i sa onim da se ne isplati previše ulagati oko overclockiranja istih (high end mbo, bruatalan cooler) jer nema pretjerane koristi. Kaže da je najisplativije stavit 3.7ghz + ostavit wraith spire + auto napon i prst u uho. Mada s druge strane kupovinu aftermarket coolera ne smatram troškom platforme, isplati se jer može ostati godinama.
Inače gledao sam cijeli ovaj podcast sa njim i wendelom. Predobra emisija, prejaki su.
Zadnje izmijenjeno od: Manuel Calavera. 14.04.2017. u 12:36.
Staro 14.04.2017., 12:47   #2240
BladeRy
BladeRy's Avatar
Postovi: 2,000
Slazem se sa ulaganjem u ok cooler, kupio sam prije 7-8 godina Zalmana 9500, taj nema sta nije ohladio. Evo i sad radi na 900rpma preko potenciometra i xeon je na 30c. Full load 50-55c usred ljeta.
Tako da posten cooler, vise tisine i bolji temp i znas da ce trajat 5+ godina.
I jel tko primjetio problem sa 350 chipsetom, kao VRMovi se griju ohoho. Uz clock do 3.8 oni odu na 85-90c+. A temp ce jos ic gore kako dolazi ljeto.
Staro 14.04.2017., 13:08   #2241
Colossus
Colossus's Avatar
Postovi: 379
Nešto tipa LC-CC-120, Arctic Freezer i32 , Hyper 212 Evo ništa dalje od toga ne treba trošit pare.
https://youtu.be/RNu-QiVr95M?t=251
I/ili uz ovo ghetto hlađenje uzet neki Top down vent tipa Raijintek Palas--be quiet! Shadow Rock LP pa nek pirka na VRM drito, ne vjerujem da će se zapalit na ljeto ryzen ploče dilje planete, da je problem već bi bilo masovnih prijava, barem tako logika nalaže.
A mozda onima što nemaju klime u sobama, i dobra prozračna kućišta bude potrebno dati jedan complementary Pastor aparatić sa mount bracketom za kućište sa strane
Staro 14.04.2017., 13:12   #2242
Colossus
Colossus's Avatar
Postovi: 379
Autor ShebY Pregled postova
Baš me nasmija
Rip i5 & i3
I to forumaš Syss mora uzet mjeru i sašit na ruke
Staro 14.04.2017., 13:15   #2243
Manuel Calavera
Postovi: 14,589
Može link?
Šema je što bolje B350 i entry X370 imaju isti ili sličan VRM, pa sumnjam u veliku razliku. Recimo onu x370 as rockicu je onaj tech city testirao u australiji, a tamo je bilo ljeto, te često kaže u videima da mu je ambijentalna temperatura 28C. Mislim vidiš i po njemu jer je sav crven i u potkošulji . Ostali reviewi su potvrdili njegove temperature.
Inače i da dolaze do 85-90C (al kažem, volio bi prvo vidjeti gdje i koje mbo) to nije ohoho za vrm tj. "unutra je"
Autor Colossus Pregled postova
Lc-cc-120 je vjerojatno i dalje best buy bez konkurencije, dok ovi 212 evo i sl. nisu neki value već neko vrijeme. Em koštaju skoro 300kn, te tipa 80% više od sličnog lc-cc-120, za jako slične novce idu bolji cooleri tipa ninja 4 (često bude oko 300kn), također i THERMALRIGHT Macho Direct, pa i onaj Fortis 3 HE1425. Dakle oko 300-njak kn max je što se IMO isplati dati za cooler, jer su slični odnosno identični po performansama starom NH-D14, a on je ionako sličan/preblizu 240mm vodenim...
Zadnje izmijenjeno od: Manuel Calavera. 14.04.2017. u 13:26.
Staro 14.04.2017., 13:18   #2244
jed2i
jed2i's Avatar
Postovi: 1,771
Gledaj koliko napona daju procesoru.
Ako se ne varam, to reportaju oni koji ga hrane s 1.35+ V
Staro 14.04.2017., 13:19   #2245
Colossus
Colossus's Avatar
Postovi: 379
Evo ja sam čitao malo ovdje o toj temi :
http://www.overclock.net/t/1626601/p...m-temperatures
I neki tamo lumen je stavio ovaj link lista VRM po pločama, na švabski.
https://www.hardwareluxx.de/communit...e-1155146.html
Pa je dole hans obrazložio na njemačkom, skuzi se poanta neka ako se prevede sa google translate.
https://www.hardwareluxx.de/communit...e-1158162.html lol
Zadnje izmijenjeno od: Colossus. 14.04.2017. u 13:26.
Staro 14.04.2017., 13:45   #2246
BladeRy
BladeRy's Avatar
Postovi: 2,000
Da, bas na to sam i ja naletio. Racunam ako je sve ok u danima kad mi je 15-20 u sobi, kako ce bit na 35c+ i gaming.
Neki kazu da je to do aftermarket hladjenja, tj da spire nekako zrak nabije i po VRmu, a noctue, cryrigi, itd i vodena ne rade nikakvo strujanje zraka preko VRMa.
Sad se oceka OC_Freaka da kaze kako je njemu na AB350 koja je clockana.
Staro 14.04.2017., 13:47   #2247
Matoje
Matoje's Avatar
Datum registracije: Apr 2011
Lokacija: Velika Gorica
Postovi: 183
Može pomoć oko odabira rama, planiram uzeti r5 1600 i b350 gaming 3 ploču, ali ne znam koji ram. Vidim da se spominje od g.skilla ripjaws v kao dobar ali nigjde nisam našao kod nas 8gb(2x4gb) na 3200mhz, ali sam našao od 3000mhz. Hoće li biti velike razlike između ta dva? Da li mi je bolje uzeti corsair vengence lpx ili neki drugi?
Matoje je offline   Reply With Quote
Staro 14.04.2017., 13:54   #2248
Manuel Calavera
Postovi: 14,589
Prema listama izgleda da je glede VRM-a još najkupovina asus x370 prime pro za oko 1300kn (adm i uzishop), te asus B350 prime plus (ispod 800kn u uzishopu s popustom).
Matoje
Što se tiče samog rama vjerujem da se svaki može dići minimum za jednu razinu gore. Pitanje je samo dali može zbog biosa u ovome trenutku
Staro 14.04.2017., 14:58   #2249
bloodlike
bloodlike's Avatar
Lokacija: OS
Postovi: 216
mali update.. znaci 1600x sto je oglasavan kao box u linku ne dolazi sa cooler, to su trebali iznati i ne oglasavati tako, ali kao ispriku dobit cu cooler uz proc sto je posteno, na kraju se isplatilo
Zadnje izmijenjeno od: bloodlike. 14.04.2017. u 15:53.
bloodlike je offline   Reply With Quote
Staro 14.04.2017., 15:00   #2250
BladeRy
BladeRy's Avatar
Postovi: 2,000
Znaci, kao i obicno, do njih je. A jucer ti lik provjeri i 1600x stize sa cooelrom Dobra provjera.
