Staro 16.01.2003., 12:44   #1
evilstoy
evilstoy's Avatar
Datum registracije: Oct 2001
Lokacija: Enterprise bridge
Postovi: 285
Wink Trebam jednu insajdersku informaciju
Da li itko zna u firmama HGSpot, Ve-Mil ili neka druga na kojoj jezgri su XP 1700+ ?
Dakle, trazim Thoroughbred!
Hvala.
When you will look for an Athlon XP 1700+ with intention to overclock it later on, you should keep in mind that there are still some older processors based on the 0.18micron Palomino core. That is why you have to make sure beforehand that the CPU you are getting is based on the new Thoroughbred. In fact, the exteriors of Palomino and Thoroughbred do differ quite a lot from each other: Palomino die is much bigger and is shaped as a square, while the Thoroughbred core is rectangular.
Ne vjerujem da ce mi bas dati da si u skladistu sam odaberem proc.
Ubuntu 8.10
cpu Intel Q6600 @3GHz (333x9) w/Scythe MINE Rev.B - 29C idle
mbo Gigabyte P35-DS3 ram 8GB Kingston DDR2 667MHz
gpu Asus EN9600GT hdd 2xWD3200AAKS - RAID1
case Chieftec BX-03B-B-B psu Fortron BS 400W
evilstoy je offline   Reply With Quote
Staro 16.01.2003., 13:09   #2
msvrtan
Postovi: 2,735
Re: Trebam jednu insajdersku informaciju
Hvala.
mislim da su sad vec svi na novoj jezgri..najbolje ti je ipak pri kupnji pitati..ne boj se ne grizu...
msvrtan je offline   Reply With Quote
Staro 16.01.2003., 13:14   #3
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Jučer ja uzeo u HG XP 1700+, na novoj je jezgri. Ali pitaj rađe nekako su me čudno gledali kad sam tražio da ga vidim tako da pretpostavljam da možda imaju i starih (koje možda uvaljaju u gotove confe).
Staro 16.01.2003., 23:38   #4
Marjan
Marjan's Avatar
Postovi: 44
Ja isto planiram uzeti procesor AMD 1700 XP i kojiu onda da uzmem ili pazim da neuzmem Palomino ili Thoroughbred. Koji je bolji za overlocking??
Marjan je offline   Reply With Quote
Staro 17.01.2003., 00:44   #5
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
Jel ima kakva velika razlika izmedu Palomino i Thoroughbreda?
Veky je offline   Reply With Quote
Staro 17.01.2003., 04:53   #6
marac
marac's Avatar
Postovi: 2,030
Razlika je ogromna izmedju Palomina i Tbreda
Kao 1.-u temperaturi (Tbred se puno manje grije - i do 8c razlike)
Kao 2.-u overclocku jer je mnozitelj vec otkljucan a i samim time sto manja temp. znaci vise "mhz"
Sve u svemu pravi izbor za male nofce!!!!
Staro 17.01.2003., 12:43   #7
Marjan
Marjan's Avatar
Postovi: 44
Marac di si ti kupia svoga Tbreda na 1700 mhz?
Tor ti kažeš da si uzeo Tbreda na 1700 mhz u HG spotu a ja u cjeniku na njihovim stranicama gledam AMD athlon xp 1700+ i u njegovom opisu piše Palomino. Tako da mi sad više ništa nije jasno.
Staro 17.01.2003., 13:15   #8
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Uzeso si mi rijeć iz tipkovnice - gdi
Kamo got da pogledam - core Palomino, pa ćak i za 2700+@333 FSB ( genijalni Autronic - LOL )
Staro 17.01.2003., 14:34   #9
acer
Whatever :)
acer's Avatar
Lokacija: Rijeka,Bulevard
Postovi: 1,754
Ja sam uzeo XP 1700+ u Ventexu u Rijeci sa novom jezgrom i mogu reći da sam prezadovoljan.Temperature se kreću od 36-37 u idle i 42-44(nakon 3d mark-a ili igranja neke igre).
Mac Mini M4
Staro 17.01.2003., 15:19   #10
msvrtan
Postovi: 2,735
ma u hg spotu nisu promjenili ono kaj pise na cjeniku...samo su spori i ne razmisljaju...
Staro 17.01.2003., 15:43   #11
marac
marac's Avatar
Postovi: 2,030
Uzeo sam ga od lika kaj zivi(posluje) pokraj fera
ima i svoj sajt ide nekako ovako simson.8m.net
javim ti jos tocno cijena je 500kn
Staro 17.01.2003., 15:49   #12
sc00pe
Postovi: 14
Nisam nasao na nijednom cjeniku Thoroughbred procesor. Kod svih pise Palomino. Valjda govorimo o istom : Xp 1700+ , 1800+ 1900+, 2000+ ,2100+ . Kolko znam samo su 2200+ , 2400+ itd. na Tbred jezgri.
sc00pe je offline   Reply With Quote
Staro 17.01.2003., 15:50   #13
RAK
Feldwebel
RAK's Avatar
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
Razlika je ukratko u 0.13 i 0.18 mikona.
S tim dolazi i overclock i niza temperatura. Čitate li vi novosti na PcEkspertu ili, kao ja, samo bulaznite po forumu.
Tih kao mačka
Brz kao gepard
Jak kao lav
Elegantan kao leopard
Nisam to ja, to je moj komp.
Staro 17.01.2003., 16:01   #14
marac
marac's Avatar
Postovi: 2,030
evo ga nasao sam
http://simpson.8m.net
i svi pokupovajte TBred i nafrljite ih u neslucene brzine
P.S.-Palomino mi puno ljepse izgleda
Staro 18.01.2003., 00:19   #15
darius
darius's Avatar
Datum registracije: Jul 2002
Postovi: 297
evo ga nasao sam
ja znam za tog tipa od prije,nisam nikad nis od njega kupovao
pa me zanima, ono kaj on daje garanciju ... kaj ja bi njemu na rijec trebo vjerovat da ak mi nekaj krepa on ce zamijenit ??
darius je offline   Reply With Quote
Staro 18.01.2003., 01:05   #16
marac
marac's Avatar
Postovi: 2,030
Gle sto se tice garancije nisam siguran jer sam do sada samo proc kupio od njega i nadam ser da ce na tom i ostati(ostatak kompa je poprilicno svjez pa di trebao kupit nesto samo ak krepa)
Lik mi je rekao da imam garanciju na proc mjesec dana i da nesmije pocrnit i bla,bla.......
Za ostale stvari najbolje ga je pitat(nazovi ga ne kosta puno)
i s njim se dogovorit ali po njuvsima vidim cesto da ga hvale pa je ocito da sve rijesava na vrijeme i ne jebe radi garancije
Staro 22.01.2003., 01:36   #17
mara
Postovi: 64
po čemu mogu znati koji xp1.8 imam?
1700@(10*210)2100 MHz
Epox 8RDA3
2x512 kingmax 4000
ATI Sapphire 9800PRO 430/760MHz
mara je offline   Reply With Quote
Staro 22.01.2003., 18:51   #18
marac
marac's Avatar
Postovi: 2,030
Tbred je ak je zeleni i iam crnu naljepnicu na sebi:confused:
Staro 23.01.2003., 00:54   #19
miato
(°_°)
miato's Avatar
Postovi: 3,249
OK, proc se mozda isplati kupovat od tih svercera, jel ionako ak ga skuris klokanjem, nigdje ti nece dati novi.
No recimo hardovi i sl. na sto je garancija 3. godine ipak se trebas priupitati oce li taj covjek jos uvijek biti u hrvatskoj nakon 3 godine kad tebi rikne hard :confused:
mislim da se ipak isplati za vrednije stvari dati 5-10% vise i kupit kod legalnih lopova.
No opet, to je samo moje misljenje
Staro 23.01.2003., 01:12   #20
msvrtan
Postovi: 2,735
a na koji to disk ima 3 godine garancije? imas na scsi a nekako to sverceri ne prodaju....nazalost svih nas imas stare vijesti...
Staro 23.01.2003., 17:23   #21
miato
(°_°)
miato's Avatar
Postovi: 3,249
Pa dobro, govorio sam napamet (sto se tice harda). No cinjenica je da kod takvih svercera zajebancije sigurno ima (govorim iz iskustva, ne svojeg ali od frenda). Jel oni dok kupe robu, dobe garanciju. No kad prodaju robu, garancija vec tece, pa da bi izbjegli probleme da im prodje garancija na mjestu gdje su kupili, smanje tebi garanciju za duplo (ono, sa 12mj. na 6 mj. i sl)
