#1471 |
Lokacija: Vinkovci
Postovi: 478
http://prntscr.com/aruomk Večeras mi nešto šteka net, može li koji komentar? Ove greške dolje nisam dugo vidio ili možda nisam obraća pozornost. Imao sam prije problema pa su dečki popravili instalacije. Na vipu sam, Vinkovci. |
#1472 | |
Datum registracije: Dec 2012
Postovi: 187
#1474 |
Postovi: 187
Jel imaš informaciju, ima tko u tvojem kvartu Iskonov VDSL? Ovo mi je full čudno. kao da si na najlošijem DSLAM-u koji postoji kod iskona. To bi trebalo ići nešto više, ne puno ali bi trebalo biti više pogotovo jer si na ADSL2+ |
#1475 |
Postovi: 1,128
#1476 |
Datum registracije: Apr 2016
Lokacija: Bihać
Postovi: 5
Može li neki komentar za ovaj slučaj? Šta bi se ovdje moglo maksimalno izvući? Mode: VDSL2 Traffic Type: PTM Status: Up Link Power State: L0 Downstream Upstream Line Coding(Trellis): On On SNR Margin (0.1 dB): 104 119 Attenuation (0.1 dB): 0 0 Output Power (0.1 dBm): 129 71 Attainable Rate (Kbps): 28448 3725 Path 0 Path 1 Downstream Upstream Downstream Upstream Rate (Kbps): 18727 1060 0 0 B (# of bytes in Mux Data Frame): 31 17 0 0 M (# of Mux Data Frames in an RS codeword): 1 1 0 0 T (# of Mux Data Frames in an OH sub-frame): 64 1 0 0 R (# of redundancy bytes in the RS codeword): 10 16 0 0 S (# of data symbols over which the RS code word spans): 0.0543 0.5112 0.0000 0.0000 L (# of bits transmitted in each data symbol): 6193 579 0 0 D (interleaver depth): 601 10 0 0 I (interleaver block size in bytes): 42 37 0 0 N (RS codeword size): 42 37 0 0 Delay (msec): 8 1 0 0 INP (DMT symbol): 3.50 1.00 0.00 0.00 OH Frames: 61859236 18760099 0 0 OH Frame Errors: 771 0 0 0 RS Words: 2279037527 934199 0 0 RS Correctable Errors: 1293001 0 0 0 RS Uncorrectable Errors: 93378 0 0 0 HEC Errors: 9574 0 0 0 OCD Errors: 663 0 0 0 LCD Errors: 663 0 0 0 Total Cells: 3040229021 0 0 0 Data Cells: 661594806 0 0 0 Bit Errors: 0 0 0 0 Total ES: 202 0 Total SES: 1 0 Total UAS: 20 20 Zadnje izmijenjeno od: nastavnikhe. 21.04.2016. u 09:25. |
#1478 |
Lokacija: Vinkovci
Postovi: 478
#1479 |
Postovi: 187
#1480 | |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,108
#1481 |
Lokacija: Bihać
Postovi: 5
Jel to znači da bih mogao imati nekih 25/1 Mbps stabilno!? Sad imam ADSL 10 paket,a podnio sam zahtjev za 25/1. |
#1482 |
Postovi: 187
Ček malo pa to ima MaxTV gore ili? vidio sam 18 da ti je down pa sam pomislio da ti je paket od 20 mbita. Ako imaš MaxTV gasi to sranje s linije. Uključi kad dobiješ optiku. |
#1483 | |
Lokacija: Bihać
Postovi: 5
Od prvog maja imaju novu ponudu u sklopu koje bih mogao imati paket sa TV uz net od 25/1Mbps. Pa sam mislio, kako je maksimalna propusnost koju očitava modem 28Mbps/1, da bih mogao uzeti taj paket sa većom brzinom. |
#1484 | |
Postovi: 187
#1485 | |
Lokacija: Bihać
Postovi: 5
Zato sam mislio preći na taj paket, jer bih kako sam ja računao imao veću brzinu. Sad imam 10 i Moja TV i 20 Mbps i TV kao što si i napisao bi bilo odlično. |
#1486 |
Expert from the shadow
Lokacija: Sibinj
Postovi: 696
znam da kvaliteta parice nije najbolja, ali do prije 3-4 mjeseca max propusnost linije je bila 17800, sad jedva 9000. tcom sluzba za korisnike kaze da ne mogu nista napraviti, a po kalkulatorima na netu vidim da je ovo propusnost za adsl, ne za adsl2 ili vdsl. Neki prijedlog? |
#1487 |
RESPECT MY AUTHORITAH
Postovi: 7,493
Stavi slike prije i poslije. Ovo je katastrofa, udaljen 3km od centrale po ovome. Moguće da su ti na izvodu u ulici/zgradi spajali novog korisnika i tvoj spoj je sada loš, spojen samo s jednom žicom itd. Prijavi T-Comu i stavii m sliku prije i poslije.
#1489 |
Postovi: 488
Iskon, zyxel modem. Speedtest pokazuje ok brzinu (48-49/9), ali veza često puca. To se najviše primjeti kod gledanja youtube na tabletu. Mislio sam da je problem u wi-fi vezi i lošem zyxelu, ali se počelo događati i na pc-u koji je spojen žično. Jednostavno se ništa ne želi loadati, a lampice na routeru svijetle ok. Problem riješi reboot routera, ali mi je tlaka svaki put rebootat router. ![]() |
#1491 |
Postovi: 488
Baš pukne, a problem riješi reboot routera. Poslao sam e-mail tehničarima i oni kažu da im dostupni podaci ne prikazuju problem. Koliko sam uspio skužit parica je skroz ok, da je ovaj snr margin 20 umjesto 9 bilo bi još bolje, ali to ne bi trebao biti uzrok problema. Kad uhvatim vremena prebacit ću zyxel u bridge i staviti tp link da daje dhcp. Ako ni to ne pomogne, vraćam se natrag b.netu na kabel jer s njim tj. s thompson routerom nisam imao takvih problema. |
#1493 | |
Postovi: 187
#1494 | |
Lokacija: Bistra
Postovi: 5,108
Danas je napokon parica malo normalnija. Citiraj:
I to čim je inspektor iz HAKOM-a došao s bolovanja Neka, treba ih pritisnuti i vidljivo je da se može. I mora.Sad treba samo vidjeti koliko dugo.
#1495 |
Datum registracije: Feb 2016
Postovi: 94
Pozdrav. Iskonov san korisnik (duo, tel+net, 10mbps download) već duži niz godina. Nedavno me kontaktirao Vip i za otprilike iste novce nudi duo paket uz brzinu neta 5 do 50 mbps. Pošto mi se ne sviđa taj raspon jer želim da bar imam onda minimalnu brzinu 35, zanima me da li bi mi neko mogao reći koju uopće max brzinu mogu dobiti za ove parametre:Line mode:ADSL2+ Maximum line rate:15172 kbps (downstream) / 1273 kbps (upstream) Noise margin:6.3 dB (downstream) / 11.4 dB (upstream) Line attenuation:18.2 dB (downstream) / 9.9 dB (upstream Output power:17.3 dBm (downstream) / 12.6 dBm (upstream) Da li se parica može popravljati/zamijeniti kako bi dobili veće brzine? Koga treba zvati za to? Mislim da sam 1000 i nesto metara od centrale, prijatelj koji je na 700 i nesto metara ima 40 mbps downloada preko tcoma. Živim u predgrađu Splita. |
#1496 |
Postovi: 7,493
Imaš očajnu paricu kojoj je max ovo što sada imaš. (jako niska margina) Ako nemaš bnet infrastrukturu u zgradi onda ti vip nudi sve isto s postojećom paricom odnosno istu max brzinu kao i sada.
#1497 | |
Postovi: 94
A nema zgrada, ovde gdje živim su obiteljske kuće (predgrađe). Šta mogu napraviti da bi imao internet od 30-40-50 mbps, osim molit se Bogu ? |
#1499 |
Postovi: 7,493
Prijavi trenutnom operateru kvar, reci da ti susjed ima puno bolje parametre i brzinu od tebe. No vrlo vjerojatno ti je lakše preseliti se nego dobiti 40mbps ovdje
#1500 |
Postovi: 94
E pa to me zanima. Je li se inače kod ovakvih stvari (jako niska margina) zove operater i da li su oni dužni popraviti tu marginu (i da li je uopće mogu popraviti)? Je li netko imao sličnih iskustava i da li su vam tscumovci ili koji već odgovorili? |
