		#871 | |
			Datum registracije: Apr 2015
					Postovi: 1,703
 link -->Linksys PAP2-NA € 16,11 Free Shipping Zadnje izmijenjeno od: skalar. 13.04.2016. u 16:41.  |
		#872 | |
			Datum registracije: Oct 2010
				Lokacija: Kaštel Lukšić
					Postovi: 1,573
 BTW koliko te došao VoIP adapter jer ja gledam na jedan od Ciscoa. Sent from my Nexus 6P using Tapatalk Zadnje izmijenjeno od: Karlo666. 13.04.2016. u 16:09.  |
		#874 |
					Postovi: 23,552
		 @Karlo666 E kolega treba pozornije pratiti pa nebi pitao, čoek stavio link, trenutno "akcija" po cca $18 > oko 125 Kn. @extasy Stavi RB konfig ovdje (samo zamaskiraj user / pass) pa možda nađemo gdje je problem.  |
		#875 |
				Lokacija: st
					Postovi: 371
		 add name=bridge1 /interface pppoe-client add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \ password=service-name=optika use-peer-dns=yes user=\ @htnet-dsl /interface wireless set [ find default-name=wlan1 ] country=croatia disabled=no mode=ap-bridge \ ssid=SpeedPort wireless-protocol=802.11 /interface wireless security-profiles set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\ dynamic-keys wpa-pre-shared-key=wpa2-pre-shared-key= /ip pool add name=dhcp ranges=182.168.88.3-182.168.88.254 /ip dhcp-server add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1 /interface bridge port add bridge=bridge1 interface=ether2 add bridge=bridge1 interface=ether3 add bridge=bridge1 interface=ether4 add bridge=bridge1 interface=ether5 add bridge=bridge1 interface=ether6 add bridge=bridge1 interface=ether7 add bridge=bridge1 interface=ether8 add bridge=bridge1 interface=ether9 add bridge=bridge1 interface=ether10 add bridge=bridge1 interface=sfp1 add bridge=bridge1 interface=wlan1 /ip address add address=182.168.88.1/24 interface=ether2 network=182.168.88.0 /ip dhcp-client add dhcp-options=hostname,clientid interface=ether1 /ip dhcp-server network add address=182.168.88.0/24 gateway=182.168.88.1 netmask=24 /ip firewall nat add action=masquerade chain=srcnat out-interface=pppoe-out1 /ip upnp set enabled=yes /ip upnp interfaces add interface=bridge1 type=internal add interface=pppoe-out1 type=external Zadnje izmijenjeno od: extasy. 13.04.2016. u 17:39.  |
		#876 |
			Datum registracije: Jan 2012
				Lokacija: righthere
					Postovi: 441
		 vlan-id provjeri  |
		#877 |
					Postovi: 23,552
		 Probaj pppoe-client nakačiti na vlan2 a ne na ether1  |
		#878 |
			 do you speak it?
				Lokacija: ::1
					Postovi: 1,629
				 ja sam uspješno asusa spojio direkno na ont internet (nekih 20% brže nego na speadportu ili zte-u) i maxtv rade bez greške VoIP adapter čekam iz kine.
		link -->Linksys PAP2-NA € 16,11 Free Shipping  |
		#879 |
				Lokacija: st
					Postovi: 371
		#880 |
					Postovi: 23,552
		 A "vrati se korak nazad", probaj upaliti ako nije FastTrack > http://forum.mikrotik.com/viewtopic.php?t=96302 općenito pregledaj nat / firewall rules jer dosta ovisi o njima.  |
		#882 |
					Postovi: 23,552
		 Polako, MT je malo zeznut jer nije baš next - next - gotofo. Čak i da je problem "samo" u upload - u, opet sve ostalo mora biti bolje nego Spped spori. Ostavi MT konfig koji radi, odmori malo, vrati mu se kad te uhvati volja. Kako se ostalo ponaša ?  |
		#883 | |
			 Laughing Man
					Postovi: 3,041
		 @extasy: Probaj na bridge 1 podignut MTU na 1500, mene je to znalo zezat na potezu 2011<->vdsl modem. To ovako nabrzaka, još uspoređujem moju i tvoju konfu... EDIT: koja verzija ROS-a je gore? EDIT2: MTU na pppoe int na 1472.
 Zadnje izmijenjeno od: Pomo. 13.04.2016. u 20:12.  |
		#885 | |
			 Laughing Man
					Postovi: 3,041
		 Znam da sam se dosta igrao s tim postavkama, završio na 1472. I to, koliko se sjećam ne prema Internetu, nego sam testirao vezu VDSL modem (ZTE931 u to vrijeme) i Tik, RB2011-UiAS-2HnD. http://www.tp-link.us/FAQ-190.html Kod mene je složena difoltna ruta, vdsl modem mi je pingabilan iz lan mreže. VDSL modem je na 192.168.1.x, router na 192.168.2.x.
		#886 | |
					Postovi: 1,573
 Sent from my Nexus 6P using Tapatalk  |
		#887 |
					Postovi: 23,552
		 Standardno je MTU=1500 u Lan / Wlan, toliko mu je vjerojatno i po defaultu. Na WAN odnosno PPPoE konekciji std. ide 1492, međutim ima slučajeva (razlikama u pameti uređaja) kada ga treba korigirati. EDIT: Treba malo potražiti objašnjenja > https://www.google.com/search?q=MTU+for+pppoe+vith+vlan https://samuel.kadolph.com/2015/02/m...using-pppoe-2/ Kvaka22 je jeli "uračunata" razlika kada se koristi Vlan ili ne u web konfigu pojedinog uređaja. Zadnje izmijenjeno od: Nikky. 13.04.2016. u 20:33.  |
		#888 | |
			 Laughing Man
					Postovi: 3,041
		 Tako sam i došao do 1472. Iskreno tek sad sam se sjetio cijele priče. Uglavnom nakon restarta uređaja nije mi se pouzdano podizala PPPoE konekcija. Istraživanje je dovelo do MTU podešavanja. Meni nije pomoglo, bilo je do T-coma, ali nek proba, nemere naškodit.
 Zadnje izmijenjeno od: Nikky. 13.04.2016. u 21:36.  |
		#889 |
				Lokacija: st
					Postovi: 371
		 Igrao sam se cijelo popodne pa sam sve iskljucio jer je vec bilo kasno pošto to mi nije doma jer sam povezan sa jos 3 mikrotika do svog pc-a par kilometara dalje.  Download je isto bio slabiji nesto cca 60mbita ali MAX TV, VOIP rade preko speedporta bez problema. Iskreno nisam se nikad susreo sa ovoliko mozganja na mikrotiku a ni optici. Mozda sam u kablazi falio nesto? ONT - Speedport lan1 - lan 2 - MT eth1? VLAN config pri kreiranju nista nisam radio osim oznacio da je "pod eth1" i ID 100 ? @ promo 1500 je def. po MT mislim a ROS je zadnji ovaj 6.34.4  |
		#890 |
					Postovi: 1,573
		#891 | |
			 Laughing Man
					Postovi: 3,041
		 Da, al 1472+28=1500, što je difolt za bridge int na kojem je ostatak lan mreže kod mene. EDIT: evo sad gledam, nije isto pingat 8.8.8.8 i vdsl modem. Vratio sam kod sebe sve na default. I radi uredno.
 Zadnje izmijenjeno od: Nikky. 14.04.2016. u 00:22.  |
		#892 | |
					Postovi: 1,703
		#893 |
					Postovi: 23,552
		 Bitno ti je što vjerniji originalu (ako se slučajno radi o kopiji), izvadit VoIp postavke ili ih možda imaš od prije (od adresa, kodeka, user / pass). Sa time bi trebao VoIp podesiti iz prve.  |
		#895 | |
					Postovi: 1,703
 postavke imam sa zte-a jedino me pass muči -gdje njega mogu nać?  |
		#896 |
					Postovi: 23,552
		 A moraš ga nekako iščupati, kolege će me ispraviti al nisam siguro da ima postupak sa ZTE, iz ovih drugih routera imamo proceduru.  |
		#898 |
					Postovi: 23,552
		 Nisam siguro, morat ćeš prekopati po ovoj temi ili ako netko od kolega zna pa se javi.  |
