Staro 11.02.2016., 21:41   #3061
Charmander
Ultrapiretik
Charmander's Avatar
Postovi: 903
skini od M$ media creation tool i skini sliku. tom slikom upgradeaj na zadnji build dostupan u obliku .iso fajla i onda provjeri jel rade updatei.
Moja trgovanja: 1, 2, 3, 4, 5, 6, 7, 8
Picoin invite: bass999 // minepi.com/bass999
Charmander je offline   Reply With Quote
Staro 12.02.2016., 09:00   #3062
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,112
Microsoft Upgrades Windows 10 Powers Of Control
It looks as though Microsoft has done a U turn on Windows 10 background telemetry. The company says it is releasing updates later this year that will give you full control over all background telemetry and data tracking. Thanks to Executioner for the link.
Contacting me again a Microsoft spokesperson explained the company now wanted to speak about the issue. In short: Microsoft is taking action. It has decided to release updates "later this year" which will enable users to fully control all background telemetry and data tracking and, if desired, disable it completely. Microsoft also asked me to stress that disabling these background operations is something it would "strongly recommend against".
http://www.forbes.com/sites/gordonke...0b9578c8539743
Staro 12.02.2016., 09:28   #3063
Moshus
Moshus's Avatar
Datum registracije: Nov 2010
Postovi: 176
u daljnjem tekstu piše da se to odnosi isključivo za enterprise verziju, dok će na ostalim verzijama ostati po starom.
Osobno koristim Spybot Anti Beacon već neko vrijeme po pitanju blokiranja telemetrije. daleko od toga da je 100% zaštita, ali barem donekle spriječi praćenje. Pokazao mi se kao ok stvarčica zasad. jel ima ko iskustva sa drugim sličnim programima?
Moshus je offline   Reply With Quote
Staro 12.02.2016., 10:07   #3064
Wizzard
Wizzard's Avatar
Postovi: 493
Ja koristim O&O ShutUp10 za sada se isto pokazo ok..free je i radi svoj posao ok..ako nekoga zanima da isproba evo link..https://www.oo-software.com/en/shutup10
CPU: Amd Ryzen 5 9600x cooled by Ac Freezer 36 Co
MBO: Gigabyte x870 Gaming X Wifi 7
RAM: 2x16gb ddr5 Kingston Fury Beast Rgb Expo 6000mt
VGA: ASRock Intel Arc B580 Challenger OC 12Gb
HDD: Nvme Kingston KC 3000 1TB+Cruical SSD BX500 1TB+1000Gb WD10EZEX-22MFCA0
PSU: SeaSonic G-Series (Gold) Modular 550 W
Case: Endorfy ARX 700 ARGB
Mause: Logitech G403 Hero
Monitor: Asus Tuf Gaming VG249 24"
OS: Win 10 X64 Pro
Wizzard je offline   Reply With Quote
Staro 12.02.2016., 11:16   #3065
Moshus
Moshus's Avatar
Postovi: 176
ok mi izgleda programčić, ima dosta opcija.
u međuvremenu sam naletio na dobar guide po pitanju zaštite od telemtrije pa koga zanima eto linka: https://www.youtube.com/watch?v=u1kGMCfb2xw
konkretno u guideu se koristi Spybot Anti Beacon, ali može se koristiti bilo šta toga tipa. koliko vidim ovaj O&O ShutUp10 je u suštini identična stvar.
Staro 12.02.2016., 20:23   #3066
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,112
Microsoft has no plans to change Windows 10 consumer privacy settings
Another report from Forbes turns out to be incorrect. Sources with direct knowledge of Windows product plans confirm that there are no plans to change privacy options for Windows 10.
http://www.zdnet.com/article/microso...vacy-settings/
Ko tu koga...
Staro 12.02.2016., 20:43   #3067
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,086
Kaj se tiče Gordon Kelly-ja i njegovih isprdaka koje naziva člancima na Forbesu...
http://www.zdnet.com/article/when-it...teur-analysts/
U rangu Softpedije po razini pizdarija koje može stisnuti u jedan članak.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
Staro 12.02.2016., 23:29   #3068
Guls
Guls's Avatar
Lokacija: Sveta Nedelja
Postovi: 2,938
Znači poludit hoću.
Remotely se želim spojiti na računalo ,w10 na w10.
Pokrenem rdp, upišem adresu, poveži, ništa.
Opet, ništa.
Treći put, opa, evo upiši kredencije. Upišem. Poveži. Krive kredencije.
Reko ok, kiksal sam, opet upišem, krive kredencije.
Nisam kiksal.
Idem opet upisat, upišem, evo ga, voila. Radi.
ok, reko glup sam. dođem doma, palim vpn, spajam se, otvara kredencije, upisujem, pogrešno. I tako već jedno pol vure ja upisujem kredencije, ma kakvi. A na neki win7 stroj se spajam bez problema.
Za poludit.
Intel i7 9700F
32GB Hyper-X DDR4-2666
2TB 970Pro PCIe NVMe M.2
Windows 11 Professional
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 12.02.2016., 23:36   #3069
catroot
catroot's Avatar
Datum registracije: Apr 2009
Lokacija: I live in 43 05'04.11"N 17 57'36.71"E
Postovi: 881
Najviše problema sa desetkom sam imao sa driverima na laptopu.. Kad se instaliraju driveri od intel ili amd grafike, bude ono windows resource protection found corrupt files...
I da dok nisam onemogućio intel management engine interface u device manageru nisam mogao ugasiti laptop kako spada.. Odnosno kod isključivanja mu je trebalo jedno 20sek. da se ugasi.
Zadnje izmijenjeno od: catroot. 12.02.2016. u 23:49.
catroot je offline   Reply With Quote
Staro 13.02.2016., 18:01   #3070
Postovi: 34,027
Primjetio sam zanimljiv "problem". Za gledanje slika koristim FastStone Image Viewer, za muziku WinAmp, a za videe KMPLayer. Često mi W10 izbaci poruku da mora resetirati te aplikacije i prebaciti na svoje defaultne Fotografije, Groove i Filmovi i TV što me prilično živcira.
Može li se to nekako spriječiti ili kompletno deinstalirati te njegove defaulte?
Staro 13.02.2016., 19:14   #3071
Wizzard
Wizzard's Avatar
Postovi: 493
Ja sam napravio ovako i nemam nikakvih problema..sve otvaram sa mojim postvakama..
recimo ovako ....ili recimo desni klik na film ili na mp3 ili flac pa open with i zadaš mu default..
OS: Win 10 X64 Pro
Staro 14.02.2016., 15:05   #3072
Postovi: 34,027
Sve sam ja to napravio, ali opet ih resetira na 'svoje' defaultne appse.
Staro 14.02.2016., 15:09   #3073
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,654
Da to napravi nakon svakog veceg builda. Prave se glupi kao slucajno je, samo da bi sto vise ljudi koristilo Edge i ostale poluproizvode.
Eto nismo jedini
http://www.theinquirer.net/inquirer/...icrosoft-stock
Zadnje izmijenjeno od: Bono. 16.02.2016. u 12:02.
Staro 17.02.2016., 20:34   #3074
Matoje
Matoje's Avatar
Datum registracije: Apr 2011
Lokacija: Velika Gorica
Postovi: 181
imam mogućnost preuzimanja windosa preko dreamsparka pa me zanima da li da uzmem education ili muliple editions verziju? porčito sam negdje da prestankom akademskog statusa licenca ostaje, jel to istina?
Matoje je offline   Reply With Quote
Staro 18.02.2016., 07:47   #3075
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,464
Tako je bilo sa starim (Win 7, Win 8.1) verzijama, sad ne znam ako su nesto promijenili sa Win 10
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 18.02.2016., 09:52   #3076
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,573
Ostaje ti licenca.
Staro 20.02.2016., 11:57   #3077
baban
baban's Avatar
Datum registracije: Aug 2008
Lokacija: DE
Postovi: 591
da li kod clean installa mora biti ista verzija sto se jezika tice ili mogu recimo instalirati EN verziju ako trenutno imam DE verziju?
da pojasnim malo..upgrejdo sam win 7 pro DE na win 10 pro DE pa bi napravio clean install al sa EN verzijom jer language pack ne prevede bas sve a ja sam slab sa njemackim
zahvaljujem
baban je offline   Reply With Quote
Staro 20.02.2016., 12:09   #3078
zdravko_c
Lokacija: Vinkovci
Postovi: 531
jezik nije bitan, slobodno instaliraj EN verziju
zdravko_c je offline   Reply With Quote
Staro 20.02.2016., 21:52   #3079
Goranbm
Goranbm's Avatar
Postovi: 1,238
Može neki link za download Windows 10 ISO. Bio na microsoft stranici ali mi daje error kad idem na preuzimanja.
Goranbm je offline   Reply With Quote
Staro 20.02.2016., 22:18   #3080
baban
baban's Avatar
Lokacija: DE
Postovi: 591
skini media creation tool od microsofta i preko njega sve odradis
Staro 23.02.2016., 21:59   #3081
Karlo666
Karlo666's Avatar
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,573
Autor baban Pregled postova
Moram da ovo spomenem. Svaki put kada bi napravio instalaciju preko media creation toola veličina je uvik varirala 100 MB manje/više.Kako, zašto nebih znao ali problema nisam imao.
Pošten trgovac:
1,2,3,
Staro 25.02.2016., 08:27   #3082
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,112
If you’re like me, you might have opened up your Windows 10 laptop today only to see a giant ad for Square Enix’s Rise of the Tomb Raider plastered across your login screen. This is the work of the “Windows Spotlight” feature in your Personalization settings, and thankfully, you can turn it off for good.
http://www.howtogeek.com/243263/how-...0-lock-screen/
Staro 26.02.2016., 01:33   #3083
Edge330
Datum registracije: Sep 2012
Postovi: 59
Stvarno sam potresen nekim odlukama na Windows 10. Stavio sam Windows prije kojih par tjedana na lap.
1) Defaultna opcija je bila da se iz aplikacija stvari ne spremaju u MyDocuments na HDD-u nego na OneDrive-u. Dakle nije nista syncano s diska nego direktno spremljeno na OneDrive bez i da se sprema na HDD.
2) Spor internet, gledam koji je razlog, OneDrive uploada neku datoteku od par GB u oblak, oke, nisam uspio saznati koja je to datoteka, nisam uspio naci cancel/pouse tipku, jedino rjesenje je bilo iskljuciti onedrive skroz, ako ga ukljucim i dalje upload-a nepoznatu datoteku.
3) Power opcije se nakon svakog restarta vrate na default, wtf?
4) Svako malo nesto vrti u background-u, nema mira.
Sad je jasno da je Win 10 nije bezveze bio besplatan doslovno svima, realno se bez placanja mogao legalno aktivirati. Win 10 je tajni projekt MS-a u zelji da bude Google.
Veliko razocarenje, nekad je to bila ozbiljna kompanija s ozbiljnim softverom.
Edge330 je offline   Reply With Quote
Staro 26.02.2016., 10:10   #3084
Razor
Postovi: 96
Autor Edge330 Pregled postova
....Win 10 je tajni projekt MS-a u zelji da bude Google.
Tajni? Sto je tu tajno? Pa sve su objavili javno, sve se zna i prilikom instalacije ti sve fino pise (cak i ako ne citas eulu, dovoljno je porazmisliti o opcijama za koje te pita da postavis). Nema tu tajnosti, MS mjenja nacin poslovanja i to je to.
Razor je offline   Reply With Quote
Staro 26.02.2016., 10:18   #3085
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,654
Samo neka rade na tome kao i office koji ne mozes aktivirati bez msn accounta ili ako s jednim accountom aktiviras 10 kompjutera moras si voditi u excelu tablicu aktivacija jer im je njihov licence manager toliko retardiran.
Staro 26.02.2016., 10:58   #3086
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,086
To nije defaultna opcija.
U OneDriveu ti uz file pokazuje znakić koji simbolizira je li file uploadan ili nije. Istina, glupo je kaj nema limit ili barem pause mogućnost (koju je Win8.1 imao).
Prvi glas o tome. Provjeri jel su ti driveri svi kako spada instalirani.
Najnormalnija stvar da će Winsi na početku vrtiti Superfetch, Indexing Service, background task-ove i generalno podešavati se i prilagođavati tvojem usage-u. S vremenom će, ako ne budeš "supertviker" i gasio servise navodeći se po tutorialima haxora sa Internetova, Windowsi raditi brže.
Jest, tajni je, pogotovo od kad su uveli Windows Insider program. Ali ššš, nikom ni riječi.
A tu se djelomično slažem. Osobno mislim da nisu trebali po defaultu ostaviti upaljen Spotlight i CDO na Enterprise SKU-u. Dobro da je tamo ali eto, mogli su shendlati bolje.
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 01.03.2016., 14:26   #3087
Matoje
Matoje's Avatar
Postovi: 181
imam problem s windowsima, kada nakon ne korištenja odu u sleep il nešto nemoguće ih je probuditi, prošo cijelu tpkovnicu, mišem kliko ali na ekranu i dalje piše da nema signala i zna mi se dogodit da kada upalim komp samo mi se odjednom ugasi i upali monitor i piše da nema signala i kada monitor ugasim i upalim normalno radi. zna neko di je problem?
Staro 01.03.2016., 23:47   #3088
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
KB3140743 (OS Build 10586.122)
  • Improved reliability in numerous areas, including OS and Windows Update installation, startup, installing and configuring Windows for the first time, authentication, resuming from hibernation, shutdown, kernel, Start menu, storage, Windows Hello, display modes, Miracast, AppLocker, Internet Explorer 11, Microsoft Edge browser, network connectivity and discovery, and File Explorer.
  • Improved performance in video thumbnail generation, NetLogon, Windows Store, and standby power consumption.
  • Improved support for devices including some wearables, displays, and printer scenarios.
  • Reset app default when a registry setting is deleted or corrupted and streamlined notification about the corruption.
  • Fixed an issue causing favorites to be lost after updates are installed.
  • Fixed several issues that individually could cause certain apps to fail to launch, update, or allow in-app purchases.
  • Improved quality of Cortana voices and translations of multiple languages of an Internet Explorer dialog box.
  • Improved support for apps, fonts, graphics and display, airplane mode, Group Policy, PowerShell MDM, Windows Journal, Microsoft Edge, printing, touch display, roaming credentials, Push-Button Reset, Windows UX, local and streaming video, audio quality, error reporting, USMT, and VHD creation.
http://windows.microsoft.com/en-us/w...ory-windows-10
Staro 02.03.2016., 12:13   #3089
Hombre
Datum registracije: Jan 2011
Lokacija: Ploče
Postovi: 283
I ja sam, posve nenamjerno, prešao na 10. Došla neka polovna kanta koja je imala legalni Win7 i ja napravio upgrade. Sa stanovišta korisnika koji ne kopa po svemu i svačemu više nego dobro. Da napomenem onom tko je napisao da je MS bio ozbiljna firma... u većini slučajeva su izbacivali poluproizvode.
Ono što mene muči i zbog čega se javljam je boja fonta ispod ikona na desktopu koja je bijela (zakleo bih se da je nedavno bila crna) što mi je malo nezgodno dok tutoriali po netu ne donose korist pa bih cijenio konstruktivan savjet kako da budu crne boje.
Hombre je offline   Reply With Quote
Staro 02.03.2016., 12:23   #3090
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,469
hmm ovako iz glave, možda je crna kad je bijeli wallpaper i obrnuto
