Staro 01.02.2016., 11:14   #6121
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,298
DOKUČE
sori morao sam
Staro 01.02.2016., 15:40   #6122
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,410
<table border="0" cellpadding="0" cellspacing="0"><tbody><tr><td class="label">Connection status:</td> <td class="rightSide"> Connected (0:05:46:18)</td></tr><tr><td class="label">Connection mode:</td><td class="rightSide">Always on</td></tr><tr><td class="label">IP address:</td><td class="rightSide">93.136.109.105</td></tr> <tr> <td class="label">MAC address:</td> <td class="rightSide"> 98:8B:5D:F6:B8:C7</td></tr><tr><td class="label">Default gateway:</td><td class="rightSide">172.29.252.63</td></tr><tr><td class="label">Preferred DNS server:</td><td class="rightSide">195.29.166.117</td></tr><tr><td class="label">Alternate DNS server:</td><td class="rightSide">195.29.149.197</td></tr><tr><td class="label">Downstream rate:</td><td class="rightSide">4901 kbps</td></tr><tr><td class="label">Upstream rate:</td><td class="rightSide">636 kbps</td></tr> <tr> <td class="label">PPPoE pass-through:</td> <td class="rightSide"> Disabled</td></tr><tr><td class="label">ADSL Line
</td><td>
</td></tr><tr><td class="label">Status:</td><td class="rightSide">Cable connected</td></tr><tr><td class="label">Line mode:</td><td class="rightSide">ADSL2+</td></tr><tr><td class="label">Maximum line rate:</td><td class="rightSide">25356 kbps (downstream) / 1432 kbps (upstream)</td></tr><tr><td class="label">Noise margin:</td><td class="rightSide">27.6 dB (downstream) / 17.8 dB (upstream)</td></tr><tr><td class="label">Line attenuation:</td><td class="rightSide">12 dB (downstream) / 9 dB (upstream)</td></tr><tr><td class="label">Output power:</td><td class="rightSide">4.5 dBm (downstream) / 6540.4 dBm (upstream)</td></tr></tbody></table>
Može meni procjena što bi mogao imati?
Itko? Otprilike samo?
Staro 01.02.2016., 16:21   #6123
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,480
Moguće i 50Mbps, sigurno 30mbps Mirko.
Staro 01.02.2016., 22:47   #6124
zicozg
zicozg's Avatar
Lokacija: cro
Postovi: 110
Imam jednu ideju pa me zanima dali je izvediva ili dali je mozda netko probao.
Zivim u zgradi i na katu su 2 stana. Moj i jos jedan. vrata preko puta vrata.
U tom jednom je optika (ja uzimam od tamo net preko wierelessa) i ima MAX tv, jedan uređaj.
Kad bih narucio jos jedan dodatan uređaj, dali bih ga mogao spojiti u drugi stan i dali bi radilo?
zicozg je offline   Reply With Quote
Staro 02.02.2016., 09:53   #6125
Pepermint
Pepermint's Avatar
Postovi: 587
ako dovedeš mrežni kabel do 2. max TV-a, radit će
P: Guild Wars 2 account, ponude na PM
Pepermint je offline   Reply With Quote
Staro 02.02.2016., 15:55   #6126
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,410
Autor Ag008 Pregled postova
Pustili dns 30 (31) mbps
Da vas pitam, ako imam 30Mbps a moguce je 50 i sad uzmem max tv, hoce li mi promet za max tv ici na ovih 30 sto imam ili na ovih 20 razlike sto jos mogu imat?
Staro 02.02.2016., 16:01   #6127
Ag008
Ag008's Avatar
Postovi: 7,480
stavi parametre parice na vdslu sada
Staro 02.02.2016., 16:32   #6128
Prezime
Datum registracije: Aug 2013
Postovi: 4,329
Promet interneta i maxtv-a je odvojen, a ako si mislio na dostupnu brzinu, onda MaxTv SD uvjek zauzme cca 5Mbps trenutno raspolozive/zakupljene brzine, a dva prijemnika ili jedan sa HD paketom zauzima cca 10Mbps...
Staro 03.02.2016., 20:16   #6129
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,410
Imam ovaj nekakav speedport novi i jednostavno ne mogu naći parametre na njemu.
Autor Prezime Pregled postova
Hvala
I mene zanima nešto slično kao što je kolega zicozg pitao, dakle modem i priključak za telefon su mi u prizemlju a maxtv bi mi trebao na katu. U jednom kafiću sam vidio da su kod modema u utičnicu uključili neki adapter koji je i sam zapravo utičnica ali na njemu isto tako ima za uštekati i LAN kabel, onda su na drugom mjestu u kafiću isto to uključili kod tv-a i 2 LAN kabela uključili u oba ta adaptera i posve normalno im radi tv, za itko o čemu je riječ?
Staro 03.02.2016., 21:19   #6130
h3lld
Disturbed
h3lld's Avatar
Lokacija: Bogu Iza Nogu
Postovi: 1,420
To ti je set powerline adaptera, preko t-coma košta par 199kn, ne znam točno cijene u slobodno prodaji. Bazira da se da signal ide preko strujnih vodova.
-potpis-
h3lld je offline   Reply With Quote
Staro 04.02.2016., 08:26   #6131
lutherus
lutherus's Avatar
Datum registracije: Sep 2011
Lokacija: Dubai UAE
Postovi: 714
powerline adapter je u slobodnoj prodaji od 50 do 200kn.
Note to the AMD haters: nobody cares
lutherus je offline   Reply With Quote
Staro 04.02.2016., 11:54   #6132
frkiZG
Datum registracije: Mar 2015
Postovi: 16
Jedno pitanje, trenutno imam Speedport router koji sam dobio od HT-a, ako nabavim ZTE (isto od HT-a) hoće li na ZTE-u raditi telefon?
frkiZG je offline   Reply With Quote
Staro 04.02.2016., 12:24   #6133
denied
denied's Avatar
Postovi: 1,193
Autor frkiZG Pregled postova
Da.
denied je offline   Reply With Quote
Staro 04.02.2016., 13:29   #6134
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Samo da pitam, je ovo OK račun ili me muljaju?
To mi je prvi put da dobivam račun od njih, pa zato
http://i.imgur.com/k5tkd4s.jpg
Staro 04.02.2016., 17:24   #6135
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Autor X-Plosiv Pregled postova
prvi put pa zatezne kamate?
meni je, bez maxtv i turbo opcije, racun ~200-210kn
Jesi pod ugovorom?
http://i.imgur.com/bI6dwxK.png
kolicina 0.935, u w0t m8??
Staro 04.02.2016., 17:50   #6136
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Zatezne kamate jer su idioti. Prvi računs u mi ispostavili za cca 1500 kn više, i onda kada su uvidjeli grešku ga smanjili. Sada vjerojatno računaju to da nisam platio ODMAH, nego tek kasnije nakon što su sanirali grešku.
Pod ugovorom sam 24 mjeseca...
Staro 04.02.2016., 19:24   #6137
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,410
Autor h3lld Pregled postova
Ima netko da koristi ovo, jeli dobro funkcionira, zice od uticnica trebaju biti nesto posebno napravljene, mislim instalacija i to?
Staro 04.02.2016., 19:40   #6138
partwish
Creeper
Datum registracije: May 2013
Postovi: 2,211
Autor pci_e3x Pregled postova
Kada prijaviš kvar i nešto ti ne funkcionira ne plaćaš račun za onaj period za koji nisi imao uslugu. Ako je sve radilo cijeli mjesec kako treba količina je 1, ako nije onda je ispod 1 i račun se umanjuje.
Staro 04.02.2016., 22:49   #6139
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
thx na info
jos kada bih mogao kao kvar prijaviti da nisu u staju isporucit vise od 4mbit
Staro 05.02.2016., 23:12   #6140
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Se desilo nekome da se smanji upload brzina?
Prije mi je bila 650-700 kb/s, a sada mi je 570 kb/sec. Download je ostao isti, 3.7 mb/sec.
Bio mi se resetirao ruter, dodani neki novi programi na TV-u, a brzina ova. Sada gledam da ih zovem i napravim show
Ruter je Speedport W724V, a ovo su parametri
http://i.imgur.com/KPxyILh.jpg
Staro 06.02.2016., 01:23   #6141
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,410
Gdje nađe parametre na tom speedportu?
Staro 06.02.2016., 06:57   #6142
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Logiraj se na ruter, onda otvori novi tab i otvori ovaj link: http://192.168.1.1/html/engineer/ro_dsl.htm
Staro 06.02.2016., 07:09   #6143
lutherus
lutherus's Avatar
Lokacija: Dubai UAE
Postovi: 714
It tcoma mi odbili prigovor uz obrazloženje jer postoji parica postoji i mogučnost za max3 paketom a kako je brzina do 4 mbit/s mojih 0,004-0,74 mbit/s ulazi upravu u segment DO. E pa mater im lopovsku sad ide još 5 prigovora i žalba na odogovor.
Staro 06.02.2016., 07:39   #6144
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Još ti nisu riješili ovu ultra brzinu? Stvarno su jadni. Jesi probao prijaviti stvar hakomu?
SaleFFS je online   Reply With Quote
Staro 06.02.2016., 08:42   #6145
lutherus
lutherus's Avatar
Lokacija: Dubai UAE
Postovi: 714
Nisu, a sasvim sam siguran da ni neće. Hakom za rješavanje spora traži da prvo tcomu šaljem prigovor i onda kopiju prigovora i njihov odgovor priložim žalbi za hakom što ću ovih dana. Inaće ova bahatost tcoma me sve više nervira. Tražili i optiku jer kablovi idu pokraj kuće i kroz dvorište, zgrade u kvartu spojene od prošle godine kao i kuće nekih političara, no tcom tvrdi da optička mreža tu ne postoji.
Staro 06.02.2016., 09:20   #6146
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,410
Ti prigovori imaju 3 stupnja, prvo obican koji si slao onda neka komisija ako se ne varam drugi stupanj i ako te i tu odbiju trece je hakom.
Staro 06.02.2016., 11:10   #6147
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,410
Evo nakon puštenih 30mbps:
https://i.gyazo.com/d98df71b54dad57b...8f4b40156d.png
Edit: sry na double
Staro 07.02.2016., 10:34   #6148
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Danas htio pogledati parametre i stoje mi nule za up/dl. U čemu bi mogao biti problem?
http://imgur.com/3L5Aehf
Staro 07.02.2016., 12:13   #6149
back2quick
Datum registracije: Jan 2012
Lokacija: righthere
Postovi: 441
ADSL2 gubi podršku kako se DSLamovi zamjenjuju rekao bih
back2quick je offline   Reply With Quote
Staro 07.02.2016., 14:39   #6150
Ag008
Ag008's Avatar
Postovi: 7,480
@sale, ne znam kak0o si imao prije ali parica ti je loša. Max oko 10mbps sada.
@back2quick, adsl2 na brojnim mjestima i centralama ostaje jer postoje brojne petlje od +1km a neki ni ne žele brzine veće od 5mbps (umirovljenici i oni koji otvaraju samo novine...)
