Postovi: 1,345
wireless 11 AD kuca na vrata
Datum registracije: Feb 2010
Lokacija: Ploče
Postovi: 1,184
..evo pročitah, napreduje tehnologija ![]() ![]() |
Postovi: 1,345
kopajući noćas malo dublje po temi, nađoh još sljedeće (google prevod sa njemačkog pa je gramatički i kontekstno samo približan): "In the company's blog simply states that the use of the corresponding chip is planned in various devices that are to come, among other things from the fields of telecommunications and Smart Home. Contrary to the currently fastest standard 802.11ac, which reaches a maximum of 1,300 Mbits per second in practice, will allow about 6,900 Mbits per second, the successor from a standing start. This is possible thanks to the operation in the 60 GHz band, but the one huge drawback involves. Because if there are obstacles between the transmitter to receiver, such as walls, the transmission rate drops relatively faster than networks in the 2.4 or 5 GHz range. Similarly, the maximum range is significantly lower with about 10 m. Both problems will be encountered with Beamforming, then the information on the possible range and data rates, but it does not reveal. Under optimal conditions, so Samsung could we but reach net rates of up to 575 MB per second with wireless ad. As practicable, the new standard will be at the start of the appropriately equipped devices, is still difficult to estimate. For one thing, the binding conditions have not yet been determined, on the other ad-capable routers have not yet been announced." vjerojatno je zamišljeno da cijela stvar radi preko uređaja sa većim brojem antena (4, 6 pa i više) kao i sa učestalijom upotrebom neke vrste ripitera/ekstendera. ali, ako se samo približe najavljivanoj propusnosti od 575 MB/s, zbogom žicama u kući, i to ne samo prilikom distribucije pristupa internetu, nego si i vrlo lako mogu zamisliti NAS bežično. ostaje nam samo čekati u nadi da će se uređaji brzo pojaviti na tržištu te da nećemo morati prodavati organe da bi si ih mogli priuštiti. |
Postovi: 1,345
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,463
Da ti je netko pred 5-10 godina rekao da ces moci imati 10 MB/s, isto su svi govorili zice vise nece trebati ![]() ![]() 60 GHz je band dosta ogranicen svime, a za ovaj beam forming cu morat malo vidjeti po internetu kako oni to planiraju. Laicki, prebacili bi se sa omni antena na usmjereni prijenos. Tu se onda povlaci pitanje pracenja objekta, i koliko se zapravo efektivno dobije... |
#7 | |
Postovi: 1,345
no, moguće je da će biti onako kako Ti kažeš, ta sada se još nezna točno, dostupne informacije su još prilično šture (ili ja neznam do njih doći). naravno, to za sobom povlači pitanje ukupne propusnosti samih rutera: nekako sumnjam da će današnji gigabitni (SOHO) ruteri biti dovoljno snažni da proguraju silne megabajte bežično. u svakom slučaju, u susret nam se valja uzbudljivo "bežično" vrijeme. ![]() |
Lokacija: Hrvatistan
Postovi: 4,164
tko pljuje? samo velim da su sve previše napuhali btw. Današnji SOHO switchevi ti imaju propusnost po 2gbps (ili 200mbps) po portu današnji SOHO routeri ti nisu ništa više osim routera na kojeg ti je nakeljen switch a i kao što rekoh - žica je zakon ![]() Zadnje izmijenjeno od: domis. 14.10.2014. u 15:45. |
Postovi: 23,517
I opet sve miriše na podvalu i interes kompanija a ne malog čoeka ![]() šta će mi "ludilo" brzina koja se može bacit do prve prepreke, logična posljedica dizanja frekvencije, za primjer, zašto nisu "izmislili" standard u FI bandu koji se sada oslobodio prelaskom na DVB-T, a ne, to su ostavili za xy operatere ... |
Postovi: 1,345
"rvacka" posla po cijelom svijetu, sunce im... |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,772
Postovi: 23,517
Šuti tamo, neću politiku u moju butigu ![]() Formula bi bila: cca beskonačno = žica ![]() |
Avocado
Postovi: 7,853
Ako su postigli brzinu od 0.5GB/s bežično, recimo da imaš crno na bijelo prilikom prebacivanja datoteka tu brzinu, kako dosad tehnologija nije toliko napredovala pa da kroz CAT5e kabel guraju gotovo 5 puta manju brzinu od ~120MB/s, a za veće brzine rade SciFi kablove (CAT6,7,8)? ![]() ![]() Bez ulaženja u dubinu (možemo i to ako se ukaže potreba), moramo uzeti u obzir da, počevši od 11Mbps standarda nadalje, nikad nisi mogao imati maksimalnu propusnost makar bio u laboratorijskim uvjetima. Unutar tih 11Mbps (ili stavi brojku po izboru) se nalaze korisnički podaci koje prebacujemo + ogromna količina redundancije i ECC metoda. Ovaj ne-korisnički dio raste kako raste frekvencija kojom sustav komunicira, ali isto tako raste i s brzinom. Naravno, napredak tih metoda je neminovan, no nitko mi ne može prodati foru da ću prebaciti podatak s pol GB u sekundi kad znam da je i u idealnim uvjetima (laboratorijskim) ta brojka znatno manja, usudio bih se reći ispod 70% nazivne brzine. Ubacimo u priču realnu situaciju, ne daj bože da dišeš kraj aparata i eto te na 50% brzine. Kamoli kad susjedi počnu kupovat nove ultrabrze routere ![]() Nema kruha od wlana osim kad se mora, pa ne bi velike megalomanske firme vukle CAT5e po novim novcatim zgradama kad imaju 500MB/s wlan i cijena instalacija je 0. ![]() Naravno, sad se dotičemo i onoga što je Renesis rekao, 4K streaming sadržaja. I dalje je najveći problem osigurati vezu do samog korisnika te brzine da bi mogli dalje pričati o LAN distribuciji takvog sadržaja ![]() Bit će zanimljivo vidjeti kako će riješiti problem zidova ![]()
Spoiler alert! |
#17 |
Postovi: 4,164
malo štemanja, bušenja, farbanja, 2-3 gigabitna switcha na lako dostupnim mjestima za zamijeniti ako krepaju i dam se kladiti da bi trosak bio i manji nego za...pa onaj linksys od 2 soma kunića ![]() kabel imam, volje za bušenje i štemanje još nemam, al bude jednog dana ![]() |
#18 |
Ex-Gastarbajter
Postovi: 5,463
OK nakon malo edukacije oko postojecih metoda beamforminga. postoje dva kampa: 1. fizicki beamforming kroz usmjerivanje antena 2. DSP beamforming gdje se kroz prilagodbu faze i amplitude signala dolazi do boljeg signala na mjestu receivera. oba su zanimljiva, ali sa trenutacnim rjesenjima, nisu pretjerano djelotvorna. Problem propagacije: 60 GHz nije bezveze "free" band, tu je taman negdje rezonancija molekule O2 (kisik, jel), i prilicno se gusi u atmosferi. U kucnoj upotrebi to nije veliki faktor, ali za wifi linkove na iole nekoj udaljenosti (100+ metera) je veoma velika prepreka. Istina, i 2.4 GHz je taman rezonancija H2O, al ima daleko manje gusenje u atmosferi. U kucnoj upotrebi 60 GHz ne penetrira prakticki nikakve prepreke ili to radi sa velikim penalima... |
#19 | |
Postovi: 1,345
gledam malo NETGEAR R8000 koji je doduše "samo" AC standard, kada su mu antene uvučene u kućište, čini mi se da je konstruiran i/ili za stropnu montažu. šteta da baš nema previše testova pa da se vidi koliko dobro slični uređaji bežično funkcioniraju. |
#20 | ||
Avocado
Postovi: 7,853
Zato je pitanje: što u ovom slučaju djelotvorno znači? Je li to mogućnost primanja podataka na udaljenosti od XY metara uz 70% max BW ili na YZ metara uz 20% BW ![]() Citiraj:
Fun fact: Intelov WiDi radi u 2.4GHz ili 5GHz pojasu, 1080p slika i 5.1 zvuk. Čini mi se da će se za postizanje dovoljnog bandwitha za 4K ipak morati odvojeni standard koristiti u kojem se može lijepo definirati vrsta sadržaja, a ne općeniti wifi pa da kroz njega proturimo i 4K stream ![]()
Spoiler alert! |
#22 |
Avocado
Postovi: 7,853
TL;DR: evo kalkulatora sadržaja za do HD rezolucije, nemojte zaboraviti h.264 odabrati, znatno manje bandwitha cucla ![]() http://www.stardot.com/bandwidth-and-storage-calculator Spoiler: jako dosadan tekst.
Spoiler alert! |
#24 |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
Pa obzirom da vec sada LTE ide do vrlo pristojne brzine od parsto megabita (s nekakvom nadogradnjom i do GBps downstream), ne bi me cudilo i da ovakvo nesto realiziraju kroz koju godinu...
#25 |
Avocado
Postovi: 7,853
Te se tehnologije LTE-a isto ostvaruju pomocu beam forminga i/ili upotrebom velikog broja mikroćelija te dinamičnom raspodjelom kanala među korisnicima što može rezultirati prilično visokim brzinama uz obveznu statičnost receivera. Načelno, razlika je "samo" u frekvencijskom pojasu rada.
Spoiler alert! |
#26 |
Postovi: 432
Može zrak (LTE) samo zavisi kako je netko pokriven. Paralelno moraju i dalje raditi na pokrivenosti, kapacitetima a ne samo brzinama. |
#27 |
Avocado
Postovi: 7,853
Problem pokrivenosti/kapaciteta neminovno povlači broj repetitora/baznih stanica, povećanje broja ćelija i smanjenje opsega ćelija. To košta u infrastrukturi ali se trebaju paziti i zakonske granice zračenja koje su prilično niske s obzirom na nizak rizik ovog oblika zračenja (sunčevo zračenje je štetnije). Pošto se povećanjem frekvencije penetracija signala u materijal smanjuje, da bi zadržali istu razinu signala morali bi povećati snagu zračenja. To je vrlo nepraktično za korištenje u kućnim okolinama jer bi trošili previše energije za pokretanje takvih uređaja. Iz istog razloga je upstream link kod svih oblika komunikacije (xDSL, optika, kabel) na nižoj frekvenciji nego što je to downstream od operatera (centrale).
Spoiler alert! Zadnje izmijenjeno od: De5tr0yer. 18.10.2014. u 21:36. |
#29 |
Ex-Gastarbajter
Postovi: 5,463
veci bandwidth prometa zahtjeva veci frekvencijski raspon po kanalu. 100 MHz od 2,4 Ghz ili 100 MHz od 60 GHz i nije isto ![]() |
#30 | |
Lokacija: Ploče
Postovi: 1,184
![]() ....i zaboravite koaksijalne kablove do antena...ni valovod neće na tim frekvencijama biti primjenjiv za privatne kupce , a to znači da će uređaj morati imati antene unutrašnje. Zadnje izmijenjeno od: D/G. 18.10.2014. u 20:00. |
