Zaključane teme
Staro 06.03.2014., 19:03   #3001
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
Pa o tome se pričalo prije više od godinu dana kad se saznalo za SDS na S3 / N2. Rado bih vidio te informacije na kojima je navodno zasnovana ta teorija.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline
Staro 06.03.2014., 19:09   #3002
zwer
crnjo
zwer's Avatar
Postovi: 1,907
na S4 sluzbeno stigo KitKat... i maj.u mu j...m upgradea se i obrise mi 4-5 aplikacija ukljucujuci onu za ebanking...
9900K-32GB-5TB-3060TI
zwer je online
Staro 06.03.2014., 21:43   #3003
trpi
molim savjet kojih par koraka treba uraditi da se note 2 vrati na skroz official. sad je gore sve custom, rom, kernel, recovery... binary counter povecan. planiram prodati mobitel pa neznam jesam li duzan vratiti ga na official, ili pokusati objasniti ekipi sta mu je uradjeno... ili ga jednostavno prodati ovakvog nista ne spominjuci... jesu li ikad nekome odbili garanciju zbog binary countera? knox odnosno warranty void je na 0, to je ok.
note 2 je originalno iz teleta, pa da skinem sa sammobile TWO zadnji rom za croatiu flashnem i to je to? prije toga staviti stock recovery i resetirati sa trianglom away? to nista nece povecati knox?
Staro 06.03.2014., 22:05   #3004
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 940
Autor trpi Pregled postova
Upravo taj redosljed, iako mislim da cak ne treba stavljati stock recovery nego ga ODIN stavlja nakon flashanja offical ROMa.
Knox se nebi trebao povecati.
dinos3 je offline
Staro 06.03.2014., 22:09   #3005
trpi
koliko se sjecam iz flasherskih dana ako se resetira sa trianglom away a gore je custom recovery - binary ide na 1 cim se mobitel upali sljedeci put... ne znam jel se sta mijenjalo sa 4.3 romovima, bootloaderima i knoxom...
Staro 07.03.2014., 10:18   #3006
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Pitaj Boga što napravi KNOX kad na njega lupiš Triangle Away. Mobitel se vjerojatno samouništi manjom nuklearnom eksplozijom.
Šalu na stranu. Nisam probao jer ostajem na 4.1.2 zbog Note 10.1 2012 i Win8 kompatibilnosti, ali pogledam tu i tamo, pa sam na XDA pročitao da se sad može rootati 4.3 bez aktivacije KNOXa, a ima i neka metoda za vraćanje bootloader countera na 0, samo nije više sa triangle away nego s nekim drugim alatom. Ne sjećam se više točno. Pogledati na XDA! No kao što rekoh, to sam pročitao. Nisam probao. Ne garantiram.
Što se tiče prodaje, naravno da trebaš reći da je bio rootan i da mu je aktiviran counter, ako to nisi 100% riješio. Bi li ti htio da tebi netko tak nešto prešuti? Naročito ako nemaš iskustva ili volje prčkati?
Nego, zna li se koju verziju SNote-a će imati Note2 na 4.4, jednom kad izađe? 2.0, 3.0, 4.0? Ako izađe. Najavili jesu. I hoće li konačno imati ostale Note3 feature?
Što se tiče Note2, TRA (Hrvatska globalno) je još uvijek na 4.1.2. Kao i Note 10.1 2012 edition. Sramota!
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 07.03.2014. u 10:23.
Staro 07.03.2014., 14:28   #3007
Postovi: 33,921
Očigledno će se i S5 prodavati k'o vruće kifle
http://www.androidcentral.com/galaxy...any-turn-sales
coconut je offline
Staro 11.03.2014., 19:55   #3008
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
da ja vas pitam, jel S4 stvarno dobar mob, od sviju njega sam tako rec nikad koristio, nekako mi je uvijek bio odbojan, no sad me privlaci, jer sam se razocarao u nexus i LG g2, zbog problema sa mikrofonom.
mislim na njega odmah puknuti google play edition rom kitkat, tvornicki
Gabre je offline
Staro 11.03.2014., 20:31   #3009
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Autor Gabre Pregled postova
Meni je S4 jedan od najdrazih mobitela. Vrhunska kamera, microSD podrska, kitkat upgrade, 2GB RAM-a, gorilla glass 3, izmjenjiva baterija, bezicno punjenje itd. Imas puno izbora za zastitne maske ( waterproof ). Jedino pazi sa custom romovima da ne aktiviras KNOX, u tom slucaju gubis garanciju.
QuidZz je offline
Staro 11.03.2014., 20:44   #3010
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
ja bi eventualno stavio samo onaj rom koji dolazi uz google play edition verziju mobitela,
danas cu vratiti G2 i uzeti S4, sad ne znam jel bi crni ili bijeli lol
Gabre je offline
Staro 11.03.2014., 20:46   #3011
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Nemam iskustva u stavljanju ROM-ova na mobitele ali znam da je lako aktivirat KNOX i da vrlo lako mozes izgubit garanciju.
Crveni.
QuidZz je offline
Staro 11.03.2014., 21:22   #3012
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
titanium sivi vjerojatno
Gabre je offline
Staro 12.03.2014., 13:44   #3013
Postovi: 33,921
Pojavio se S5 16Gb na preorderu kod Engleza - 456 GBP sa poštarinom
http://www.mobicity.co.uk/samsung-ga...l#.UyBWgs5N3Yl
coconut je offline
Staro 12.03.2014., 15:27   #3014
poltergeist
poltergeist's Avatar
Datum registracije: Aug 2010
Postovi: 429
Autor coconut Pregled postova
Well yeah it's not hard to get 300000 registrations if you are offering a free S5 everyday
Koje su to jeftine korejske fore. Trash totalni
poltergeist je offline
Staro 12.03.2014., 17:59   #3015
Vendetta
Vendetta's Avatar
Postovi: 919
Sigurno ste iskusniji pa vas molim za savjet.
Kronologija servisa i NO SIM problema mog starog S3:
  • Počne mi se pojavljivati tu i tamo poruka da mi je iznenada izvađena SIM kartica i da moram resetirat uređaj. Nakon reseta sve radi.
  • Problem postane stalan nedavno kada nakon xy reseta i povrataka na tvorničke postavke mobitel više ne prepoznaje SIM nikako. Moj sim radi u drugim aparatima, drugi simovi ne rade u mom.
  • Konačno mi dosadi imat tablet i odnesem mob u europatrade
  • Uzmu ga pod garaniju (važeća do 7. mjesca) na servis
  • Vrate mi ga nakon par dana navodno promjenili SIM slot (brat ga predigne). Dođem doma stavim karticu, mobitel ima isti problem. I dalje ne prepoznaje SIM.
  • Isti dan odem do europatrade-a i kažem im da su mi vratili mobitel sa istim problemom. Kažu "onda ovo ide za ZG" i opet ga preuzmu.
  • Nakon 5-6 dana dolazi poruka "vaš uređaj je gotov...", odem po njega. Kažu zamjenili su cijelu matičnu (vrijednost 1500kn). Probam stavit karticu, sve radi, odem doma, nastavim sa životom. Navečer primjetim gore da mi uređaj nema signala (prekriženi kružić). U postavkama jednostavno neće da locira više mrežu i katkada baca poruku prilikom pokušaja odabira mreže ručno da nije umetnuta SIM kartica.
  • Dosadi mi tortura sa tim mobitelom, kupim drugi i ovaj dam bratu da se sa njim zajebava. On ga odnese po treći put na servis i opet ga pošalju u Zagreb.
  • Danas ga zove netko iz Zagreba, frustiran nemogućnošću otklona kvara i pita ga ima li račun.
Treba li im stvarno račun jer ga nemam, i zašto im sada odjednom treba račun ako su već toliko energije, vremena i novih djelova uložili u taj skoro 2 godine star mobitel?
Mobitel mi je pao zadnji put na parkingu prije godinu i nešto dana ali radio je uredno do prije mijesec dana i osim kozmetičkog oštećenja na aluminijskom okviru ništa drugo mu nije bilo.
Vendetta je offline
Staro 13.03.2014., 16:36   #3016
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Android 4.4 KitKat might be available for the Galaxy S3, Note 2 and Grand 2 Duos after all
Izvor.
QuidZz je offline
Staro 13.03.2014., 16:53   #3017
Postovi: 33,921
Bilo bi lijepo da se to ostvari iako me baš više i nije toliko briga jer moram uzeti novi mob u 12 mjesecu pa će S3 na oglasnik.
coconut je offline
Staro 13.03.2014., 17:23   #3018
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Uh ima jos dosta vremena do tada.
Bas sam citao u tele2, pise da mozes 3 mj prije isteka tekuce pretplate produzit pretplatu i naravno uzeti novi mobitel.
QuidZz je offline
Staro 13.03.2014., 17:29   #3019
Postovi: 33,921
Ja sam na VIP-u. Čekam da se kod nas pojave S5, XZ2 i iP6 sa cijenama pa ću odlučiti kojeg uzeti, a kojeg prodati.
coconut je offline
Staro 13.03.2014., 17:35   #3020
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Auu slatke muke imas.
QuidZz je offline
Staro 13.03.2014., 21:21   #3021
Mitsuoka
Samsung Mob!ler
Mitsuoka's Avatar
Datum registracije: Mar 2012
Postovi: 162
Ne bi ih nazvao slatke jer moraš izabrati manje zlo. Da uzimam stvarno ne znam što bi uzeo.
Mitsuoka je offline
Staro 13.03.2014., 21:41   #3022
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Novi iPhone nije jos izasao, neznamo sta nas ceka od Apple-a. A izmedu S5 i Z2 osobno bih odabrao Z2.
QuidZz je offline
Staro 13.03.2014., 22:13   #3023
Autor Mitsuoka Pregled postova
Ja recimo znam što nebi uzeo. Nebi uzeo Applea i Samsunga
Brko je offline
Staro 14.03.2014., 02:47   #3024
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
danas sam se bas malo duze zanimao sa S4, pa to je zapravo jako interesantan mobitel, nije mi ni touchwizz cak uopce los, dapace, lijepo je slozen.
vrlo elegantan, tanak, lagan mobitel, malih dimenzija a stvarno veliki keran, s tim da ima punih 5" jer im akapacitivne tipke, definitivno cu razmisliti o S5 kad izidje, ako HTC ne bude bas ono, vau. a po vidjenom, sumnjam.
bolji mi je izgledom i dimenzijama nego nexus 5 i g2
Gabre je offline
Staro 14.03.2014., 07:42   #3025
Postovi: 33,921
Autor QuidZz Pregled postova
A pazi sad - mogu uzeti full povoljno 3 moba i još na račun firme!
coconut je offline
Staro 14.03.2014., 07:58   #3026
Wow...
Brko je offline
Staro 14.03.2014., 09:17   #3027
Mitsuoka
Samsung Mob!ler
Mitsuoka's Avatar
Postovi: 162
A ja bi prvoga iz jednadžbe izbacio sony. I onda iPhone jer me mogu igrat Ingress na njemu
Mitsuoka je offline
Staro 14.03.2014., 09:25   #3028
Hebiga, tebi samsung plaća da ih reklamiraš. Jasno da ne smiješ uzeti bolji android mobitel ili mobitel koji je tvoje ogulio za milijardu dolara mi smrtnici imamo slobodu odabira
Brko je offline
Staro 14.03.2014., 09:32   #3029
Mitsuoka
Samsung Mob!ler
Mitsuoka's Avatar
Postovi: 162
To me ne sprečava da imam druge mobitele. Štoviše, uzimam samo HTC zadnjih godina dok se One nije pojavia i od tada ne znam što bi uzeo. Note3 mi je trenutno jedini uređaj za koji bi dao koju kunu, ali ona fejk koža mi je too much. Uopće ne znam što bi uzeo, a sad mi ističe pretplata brzo.
Mitsuoka je offline
Staro 14.03.2014., 11:54   #3030
Postovi: 33,921
coconut je offline
Zaključane teme
