13.02.2014., 11:28 | #1081 |
gadget freak
Lokacija: Jasenovac
Postovi: 2,200
Feb 13 PC Game Update Notes -General stability improvements -Fix for an issue where spawning into, or switching to, a gunner seat in an IFV/MBT sometimes could cause the game to crash -Fix for missing sound in Team/Squad Deathmatch -Fix for an issue in the Defuse game mode, where a bomb carrier would be permanently spotted -Decreased the rate at which the kill card would incorrectly display 0 health, while the enemy was clearly alive -Fixed an invisible wall that was incorrectly positioned in one of the fallen concrete pipes on Zavod 311 -Fix for an issue where bullet impact sounds weren’t properly matching the actual number of impacts -Fix for an issue where the “Draw” message would not display on-screen once a Conquest round ended with both teams having the same amount of tickets -Fix for a game crash that could occur when spectating a player in a vehicle -Fix for an issue where long IDs wouldn’t scroll on dog tags -Fix for missing grass physics in terrain Mantle -Fix for a crash that would occur when activating full screen in portrait mode -Fix for stuttering that could appear during video sequences on multi-GPU PCs -Fix for a memory system leak that could cause stalls, which would result in frames taking longer to process -Reduced the amount of stalls that occurred when running with high graphics setting that require more GPU memory than is currently available -Fixed screenshots on multi-GPU PCs -Players now have to explicitly enable Mantle, as it is no longer enabled by default Danas natrag na mantle api, da vidimo jel fix prodavanje magle il šljaka bez stuttera
13.02.2014., 19:16 | #1084 |
Bazinga
Lokacija: Križevci
Postovi: 3,883
S uključenim mantleom više nema frame dropova. Sad padne i više se ne diže. Zakucalo mi je fps na 1. Čak i chat šteka.
13.02.2014., 21:45 | #1085 |
Lokacija: Keebwork
Postovi: 7,476
14.02.2014., 12:33 | #1086 |
Lokacija: Dubrovnik
Postovi: 1,279
Nakon zadnjeg isprobavanja igre došlo mi je da im j. bo.a oca i sve anđele i svete Gadovi prokleti, su sakrili refund button kad sam ga tražio, nije se moglo do helpa nikako, email nisu ostavili ,broj telefona vješto skriven, nudili mi jedino forum ili čitat faq ..... Na forumu sam mogo postavit kao pitanje communityu ali u biti nemogu nito jer izbaci invalid http sa svakim browserom dakle nisu mi dozvolili legalnu akciju refunda. Ono što me zanima je neki link da im rečem dvije ? Znam da mi neće pomoć i da refund sada neću dobiti ali želim poslat mail gadnog sadržaja nekome u ea. |
14.02.2014., 13:54 | #1087 | |
Addicted to music.
Postovi: 1,782
Znaci, FPS pao na 1 i mo's ga j*bat.I tako nekih 5-10 sekundi sam imao opaki slideshow i FPS 1-2, onda se igra vratila u normalu i poslije nisam imao problema.
All you have is your fire and the place you need to reach. Don't you ever tame your demons, always keep them on a leash. |
14.02.2014., 14:39 | #1088 | |
Bazinga
Lokacija: Križevci
Postovi: 3,883
14.02.2014., 16:56 | #1090 | |
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
14.02.2014., 16:58 | #1091 |
aka Striko
Lokacija: Krapina
Postovi: 1,676
14.02.2014., 17:07 | #1093 |
aka Striko
Lokacija: Krapina
Postovi: 1,676
Pošten trgovac : 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 , 10, 11 , 12 , 13 , 14, 15, 16 . Zadnje izmijenjeno od: Ati freak. 14.02.2014. u 17:21. |
14.02.2014., 17:14 | #1094 | |
Lynnfield
Postovi: 1,023
ne ipak nije |
15.02.2014., 20:18 | #1095 |
Lokacija: Keebwork
Postovi: 7,476
Jebem i njih i taj kurcevi patch, da 400 mb moze sjebat igru od 30 gb to mi nikako nije jasno. Niti jedan server niti jedna mapa, nemogu igrat duze od 3 min odmah soundloop.
15.02.2014., 23:33 | #1096 |
Postovi: 199
Al sto je gore, može li se itko sjetiti ijednog patcha koji nije zeznuo barem duplo stvari nego je popravio . |
15.02.2014., 23:40 | #1097 |
Lynnfield
Postovi: 1,023
16.02.2014., 02:36 | #1098 |
Postovi: 5,891
Meni se danas srusila jednom, 15tak min nakon pocetka runde. Iz drugog pokusaja je radila normalno skoro sat vremena. Vise od toga ni nemrem igrat tu igru. Grije procesor ko da je neki test za stabilnost. Jer se upisuje XP ak se igra srusi? Nisam uspio to skuzit. Prijasnji su upisivali.. |
16.02.2014., 10:15 | #1099 |
Lokacija: Keebwork
Postovi: 7,476
Aj molim te ne trkeljaj gluposti : http://battlelog.battlefield.com/bf4...4774131036047/
16.02.2014., 11:00 | #1100 | |
Datum registracije: Jun 2013
Lokacija: Sračinec
Postovi: 24
Meni isto radi bez i jednog problema i sa svakim patchom mi je još bolje i brže tako da ne priča gluposti |
16.02.2014., 12:05 | #1102 |
Postovi: 199
16.02.2014., 13:01 | #1104 | |
Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 852
kolko ja znam, još uvijek bi se developeri trebali prilagoditi aktualnom hardveru i platformama, a ne obrnuto. |
16.02.2014., 13:27 | #1105 |
aka Striko
Lokacija: Krapina
Postovi: 1,676
16.02.2014., 14:49 | #1108 |
Lokacija: Sveta Nedelja
Postovi: 2,937
A činjenica je da je igra u banani i da trebaš provesti sate i sate testiranja i isprobavanja kombinacija da bi u konačnici mogao reći da igra radi. Ja sam kod sebe uspio složiti da igra radi bez problema (do ovog zadnjeg patcha koji je usrao stvar opet), ali ako je već stvar plaćena, onda bi se ona trebala prilagoditi korisniku, a ne korisnik njoj. Mislim, to bi bilo logično, ne? Nije čovjek rob igre...
16.02.2014., 15:02 | #1109 | |
gadget freak
Lokacija: Jasenovac
Postovi: 2,200
Očito je jedino da je čista stvar sreće hoće li igra radit ili neće, i to ne samo bf, nego još masa igara izdanih unazad par godina, a kupiti nešto i razmišljati o tome da li će igra raditi na kompu ili ne, je suludo i bezobzirno od publishera igre. Da, kako je neo rekao, nemamo soundloop i igra radi 90+% vremena kako treba, ali to je kao što je već rečeno očito samo stvar čiste sreće. Na ts-u nas ima sa sličnim i istim hardverom dosta i nekima sve radi, a nekima nikako, dakle, nema baš previše veze sa hardverom. Softver neću dovodit u pitanje i kako netko iskonfigurira vlastito računalo, windowse, av, fw, itd., ali realno, priča se o faking igri, koja bi trebala radit kad se instalira original na računalo sa originalnim windowsima, a ne tweakat pol kompa i postavki da bi proradila. Btw, mantle radi daleko bolje sada, nema više stuttera, bar kod mene, ali sa uključenim mantleom se zna scrashat igra katkad pri promjeni mape. Na dx-u ne. @vido - razumijem tvoj rant, i ja bi pi...o i više da imam takvih problema sa igrom, ali realno, 48 stranica na battlelogu o soundloopu vs 600.000 registriranih aktivnih igrača je priličan broj vs tih par stotina postova igrača sa soundloopom. Tako da se ipak ne radi ni približno o većini ako ćemo bit pošteni. Meni se scrashala dvaput od nove godine pa sam šizio po battlelogu, a kamoli da imam ko neki problema na svakoj mapi i u svakoj rundi
