Staro 13.02.2014., 12:28   #1081
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Feb 13 PC Game Update Notes
-General stability improvements
-Fix for an issue where spawning into, or switching to, a gunner seat in an IFV/MBT sometimes could cause the game to crash
-Fix for missing sound in Team/Squad Deathmatch
-Fix for an issue in the Defuse game mode, where a bomb carrier would be permanently spotted
-Decreased the rate at which the kill card would incorrectly display 0 health, while the enemy was clearly alive
-Fixed an invisible wall that was incorrectly positioned in one of the fallen concrete pipes on Zavod 311
-Fix for an issue where bullet impact sounds weren’t properly matching the actual number of impacts
-Fix for an issue where the “Draw” message would not display on-screen once a Conquest round ended with both teams having the same amount of tickets
-Fix for a game crash that could occur when spectating a player in a vehicle
-Fix for an issue where long IDs wouldn’t scroll on dog tags
-Fix for missing grass physics in terrain
Mantle
-Fix for a crash that would occur when activating full screen in portrait mode
-Fix for stuttering that could appear during video sequences on multi-GPU PCs
-Fix for a memory system leak that could cause stalls, which would result in frames taking longer to process
-Reduced the amount of stalls that occurred when running with high graphics setting that require more GPU memory than is currently available
-Fixed screenshots on multi-GPU PCs
-Players now have to explicitly enable Mantle, as it is no longer enabled by default
Danas natrag na mantle api, da vidimo jel fix prodavanje magle il šljaka bez stuttera
Staro 13.02.2014., 18:24   #1082
Has
Has's Avatar
Datum registracije: Jan 2014
Lokacija: Austria
Postovi: 112
Hebemti, ovu zakrpu čekam već dva tjedna valjda.
Has je offline   Reply With Quote
Staro 13.02.2014., 18:49   #1083
Tihomir111
ZeNgE_Tiho_Cro
Tihomir111's Avatar
Lokacija: Virovitica
Postovi: 466
opet soundloop crash... svaka partija danas
Tihomir111 je offline   Reply With Quote
Staro 13.02.2014., 20:16   #1084
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
S uključenim mantleom više nema frame dropova. Sad padne i više se ne diže.
Zakucalo mi je fps na 1. Čak i chat šteka.
sinisa1989 je online   Reply With Quote
Staro 13.02.2014., 22:45   #1085
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Autor Tihomir111 Pregled postova
Skinem jucer bf4 i radi odlicno, danas izadje od 400 mb patch i SJEBE SVE , znaci svaka mapa freeze i sound loop. Podsjetio sam se zasto sam prestao igrati ovo smece prije 2 mj...
Staro 14.02.2014., 13:33   #1086
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
Nakon zadnjeg isprobavanja igre došlo mi je da im j. bo.a oca i sve anđele i svete
Gadovi prokleti, su sakrili refund button kad sam ga tražio, nije se moglo do helpa nikako, email nisu ostavili ,broj telefona vješto skriven, nudili mi jedino forum ili čitat faq ..... Na forumu sam mogo postavit kao pitanje communityu ali u biti nemogu nito jer izbaci invalid http sa svakim browserom dakle nisu mi dozvolili legalnu akciju refunda.
Ono što me zanima je neki link da im rečem dvije ?
Znam da mi neće pomoć i da refund sada neću dobiti ali želim poslat
mail gadnog sadržaja nekome u ea.
Michel je offline   Reply With Quote
Staro 14.02.2014., 14:54   #1087
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor sinisa1989 Pregled postova
Odigrao sam nekakvih 7-8 rundi sa ukljucenim Mantle-om.Od toga sam imao jedan 'Battlefield 4 has stopped working' (rusi se samo na Lockeru, ili kada treba ucitati drugu rundu Lockera.Na ostalim mapama nisam imao niti jedan crash), na svim ostalim mapama sve kao bubreg u loju, jedino sam na B zastavi na Golmud Railway-u CQ Large imao drop o kojem Sinke prica.
Znaci, FPS pao na 1 i mo's ga j*bat.I tako nekih 5-10 sekundi sam imao opaki slideshow i FPS 1-2, onda se igra vratila u normalu i poslije nisam imao problema.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 14.02.2014., 15:39   #1088
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Autor Alph4Dawg Pregled postova
Meni se to dogodilo na Lancang damu kod A flaga. Ali meni je trajalo nekih 30-45 sekundi. Nakon toga se 'smirilo', ali kasnije je opet bilo p**darija. Tak da sam ga ugasio. Još dva-tri patch i dva tri drivera, pa će vjerojatno biti upotrebljivo. Zasad, nažalost, u većini slučajeva, još uvijek nije.
Staro 14.02.2014., 17:42   #1089
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,755
Staro 14.02.2014., 17:56   #1090
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
zašto? šta bi oni trebali,zarađuju i to je jedino bitno,neznam šta taj sad glumata,sad mu je krivo šta više ne radi u ea pa ih blati ili šta
esc je offline   Reply With Quote
Staro 14.02.2014., 17:58   #1091
Ati freak
aka Striko
Ati freak's Avatar
Postovi: 1,755
Autor esc Pregled postova
To nije "taj" lik, on samo glumi tog CEOa...
Staro 14.02.2014., 18:03   #1092
esc
Lynnfield
Postovi: 1,023
pa piše ispod da je on bivši ea ceo
Staro 14.02.2014., 18:07   #1093
Ati freak
aka Striko
Ati freak's Avatar
Postovi: 1,755
Zadnje izmijenjeno od: Ati freak. 14.02.2014. u 18:21.
Staro 14.02.2014., 18:14   #1094
esc
Lynnfield
Postovi: 1,023
nema tu slike
ne ipak nije
Staro 15.02.2014., 21:18   #1095
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Jebem i njih i taj kurcevi patch, da 400 mb moze sjebat igru od 30 gb to mi nikako nije jasno. Niti jedan server niti jedna mapa, nemogu igrat duze od 3 min odmah soundloop.
Staro 16.02.2014., 00:33   #1096
sa20
sa20's Avatar
Postovi: 199
Autor xulos Pregled postova
Al sto je gore, može li se itko sjetiti ijednog patcha koji nije zeznuo barem duplo stvari nego je popravio .
sa20 je offline   Reply With Quote
Staro 16.02.2014., 00:40   #1097
esc
Lynnfield
Postovi: 1,023
Autor sa20 Pregled postova
oko 2h neprekidnog igranja,dakle bez ikakvog rušenja...nešto vam drugo ne štima
Staro 16.02.2014., 03:36   #1098
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Meni se danas srusila jednom, 15tak min nakon pocetka runde. Iz drugog pokusaja je radila normalno skoro sat vremena. Vise od toga ni nemrem igrat tu igru. Grije procesor ko da je neki test za stabilnost.
Jer se upisuje XP ak se igra srusi? Nisam uspio to skuzit. Prijasnji su upisivali..
Staro 16.02.2014., 11:15   #1099
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Aj molim te ne trkeljaj gluposti : http://battlelog.battlefield.com/bf4...4774131036047/
Staro 16.02.2014., 12:00   #1100
dejan_08
dejan_08's Avatar
Datum registracije: Jun 2013
Lokacija: Sračinec
Postovi: 24
Meni isto radi bez i jednog problema i sa svakim patchom mi je još bolje i brže tako da ne priča gluposti
dejan_08 je offline   Reply With Quote
Staro 16.02.2014., 12:17   #1101
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Je , i onda je svizac dosao i zamotao cokoladu u omot... Daj molim te.
Staro 16.02.2014., 13:05   #1102
sa20
sa20's Avatar
Postovi: 199
Autor dejan_08 Pregled postova
A gle niste u pravu momci. 10 posto ljudi govori da nema problema a 90 posto ljudi svako malo javlja nove probleme.
Ne moguće da baš mi svi ostali imamo zmrdani hardware
Staro 16.02.2014., 13:21   #1103
Guls
Guls's Avatar
Lokacija: Sveta Nedelja
Postovi: 2,938
Netko tolerira bugove, a netko ne.
Intel i7 9700F
32GB Hyper-X DDR4-2666
2TB 970Pro PCIe NVMe M.2
Windows 11 Professional
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 16.02.2014., 14:01   #1104
Full Throttle
Full Throttle's Avatar
Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 873
ak radi polovici ljudi, a polovici ne, to i dalje ne znači da igra radi kak spada.
kolko ja znam, još uvijek bi se developeri trebali prilagoditi aktualnom hardveru i platformama, a ne obrnuto.
Full Throttle je offline   Reply With Quote
Staro 16.02.2014., 14:27   #1105
Ati freak
aka Striko
Ati freak's Avatar
Postovi: 1,755
Autor Guls Pregled postova
To nije tolerancija. To je vec razina idiotizma ili je netko toliko glup da ne vidi šta je bug i kako bi nešto trebalo raditi.
Staro 16.02.2014., 15:17   #1106
Neo-ST
Neo-ST's Avatar
Postovi: 8,555
jopis i ja nemamo taj sound loop i sve nam radi...
Staro 16.02.2014., 15:44   #1107
Ati freak
aka Striko
Ati freak's Avatar
Postovi: 1,755
Nije soundloop jedini problem ove igre......... dapace
Staro 16.02.2014., 15:49   #1108
Guls
Guls's Avatar
Postovi: 2,938
A činjenica je da je igra u banani i da trebaš provesti sate i sate testiranja i isprobavanja kombinacija da bi u konačnici mogao reći da igra radi. Ja sam kod sebe uspio složiti da igra radi bez problema (do ovog zadnjeg patcha koji je usrao stvar opet), ali ako je već stvar plaćena, onda bi se ona trebala prilagoditi korisniku, a ne korisnik njoj. Mislim, to bi bilo logično, ne? Nije čovjek rob igre...
Intel i7 9700F
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 16.02.2014., 16:02   #1109
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Tako je, slažem se u potpunosti.
Očito je jedino da je čista stvar sreće hoće li igra radit ili neće, i to ne samo bf, nego još masa igara izdanih unazad par godina, a kupiti nešto i razmišljati o tome da li će igra raditi na kompu ili ne, je suludo i bezobzirno od publishera igre.
Da, kako je neo rekao, nemamo soundloop i igra radi 90+% vremena kako treba, ali to je kao što je već rečeno očito samo stvar čiste sreće.
Na ts-u nas ima sa sličnim i istim hardverom dosta i nekima sve radi, a nekima nikako, dakle, nema baš previše veze sa hardverom. Softver neću dovodit u pitanje i kako netko iskonfigurira vlastito računalo, windowse, av, fw, itd., ali realno, priča se o faking igri, koja bi trebala radit kad se instalira original na računalo sa originalnim windowsima, a ne tweakat pol kompa i postavki da bi proradila.
Btw, mantle radi daleko bolje sada, nema više stuttera, bar kod mene, ali sa uključenim mantleom se zna scrashat igra katkad pri promjeni mape. Na dx-u ne.
@vido - razumijem tvoj rant, i ja bi pi...o i više da imam takvih problema sa igrom, ali realno, 48 stranica na battlelogu o soundloopu vs 600.000 registriranih aktivnih igrača je priličan broj vs tih par stotina postova igrača sa soundloopom. Tako da se ipak ne radi ni približno o većini ako ćemo bit pošteni. Meni se scrashala dvaput od nove godine pa sam šizio po battlelogu, a kamoli da imam ko neki problema na svakoj mapi i u svakoj rundi
Staro 16.02.2014., 16:04   #1110
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,812
Meni se igra upravo crashala (sound loop) 2 puta za redom kada sam revivao. Prije toga sam imao samo jedan crash nakon patcha.
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
