Staro 28.01.2013., 15:40   #1
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,438
Nvidia GeForce v313.95 Beta Driver
This is the recommended GeForce driver for the Crysis 3 Multiplayer Open Beta. It delivers a smoother gaming experience, and boosts SLI performance by up to 65%.
EA’s recommended GeForce GPU for Crysis 3 is a GeForce GTX 560 or higher. For the Hi-Performance PC Specification, EA recommends GeForce GTX 680. See the full Crysis 3 system requirements on GeForce.com.
GeForce R313 drivers also provide significant performance increases in other top games like Assassin’s Creed III, Call of Duty: Black Ops II, and Far Cry 3.
New in GeForce R313 Drivers
Performance Boost – Increases performance for GeForce 400/500/600 series GPUs in several PC games vs. GeForce 310.90 WHQL-certified drivers. Results will vary depending on your GPU and system configuration:
GeForce GTX 670:
Up to 28% in Assassin’s Creed III
Up to 11% in Civilization V
Up to 8% in Far Cry 3
Up to 6% in Just Cause 2
Up to 5% in Deus Ex: Human Revolution
Up to 5% in Dirt 3
Up to 5% in Batman: Arkham City
Up to 5% in Far Cry 2
Up to 4% in Call of Duty: Black Ops II
Up to 3% in Shogun: Total War
Up to 3% in Stalker: Call of Pripyat
NVIDIA SLI Technology – Adds or updates the following SLI profiles:
Crysis 3 – updated SLI profile
Warframe– updated SLI profile
DmC: Devil May Cry– added SLI profile
NVIDIA CUDA
Includes support for applications built using CUDA 5 or earlier version of the CUDA Toolkit. More information at http://developer.nvidia.com/cuda-toolkit
Additional Details
Installs PhysX System Software 9.12.1031.
Installs HD Audio v1.3.23.1
Supports OpenGL 4.3 for GeForce 400-series and later GPUs.
Supports DisplayPort 1.2 for GeForce GTX 600 series GPUs.
Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
http://www.geforce.co.uk/drivers
Staro 28.01.2013., 19:09   #2
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,568
Nema BF-a , nema updejta
Staro 30.01.2013., 12:04   #3
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,438
Staro 30.01.2013., 14:00   #4
Blek Ops2 je podebljan za nekih 600% do sada kaj se tiče performansi, dok izgleda da su Betlfild 3 ispolirali svašta
ajmo, ko ih je metnuo na GTX 660 Ti, jel se vidi ?
Staro 30.01.2013., 15:04   #5
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,438
ne osjećam razliku..crysis 3 sam probo 2-3 minute nažalost kolko je smeće..ostatak igara ko prije više manje
Staro 30.01.2013., 15:10   #6
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Rade dobro driveri.
Razlike u perf nisam uspoređivao...
Core2Duo22 je offline   Reply With Quote
Staro 30.01.2013., 15:18   #7
A jebiga, budući Crysis 3 ne mislim igrati dok ne izađe kompletna igra (a možda i tada ne), to mi isto ne predstavlja neki benčmark. Zanima me jel Metro što bolji ili STALKER-i ili F1 2012
Autor Core2Duo22 Pregled postova
Rade dobro driveri.
meni potpuno nebitna informacija onda ostajem na zadnjim prošlogodišnjim 310.70. i oni rade dobro, i radi HDMI na TV i to je bitno
Staro 04.02.2013., 14:45   #8
zagy1984
zagy1984's Avatar
Datum registracije: Jan 2012
Postovi: 105
kod mene baš i nema razlike koji fps-više , ali je problem u tome što mi jedna kartica radi konstantno na 40 % opterečenja bez obzira na idle ili load.. stavio frišku instalaciju drivera i problem ponovno prisutan
zagy1984 je offline   Reply With Quote
Staro 05.02.2013., 09:33   #9
Autor zagy1984 Pregled postova
Jesi googlao o tom problemu? Jel to inače uobičajeno ili ti se pojavljuje sa zadnje 2 revizije drivera?
Staro 05.02.2013., 12:18   #10
zagy1984
zagy1984's Avatar
Postovi: 105
nisam, al tako mi je bilo sa serijom 310.54 i 310.61..ostali su uredno radili bez ikakvih problema u SLI-u..naravno do ovih zadnjih u kojima mi jedna kartica uvijek radi na 40%..
Staro 06.02.2013., 08:26   #11
Stavio drivere na 3 mašine, GT630, GTX650 i GTX 660 Ti.
Ono što primjećujem da NVDIDA Control Panel brže reagira na podražaje prilikom upraljanja izlaznog signala (2 monitora i/ili TV).
Što se igara i temperature nisam primjetio razliku na GTX 660 Ti, ali GT630 glađe vrti COD:MW3, a Palit GTX650 malo manje turira vent.
Staro 07.02.2013., 14:06   #12
slavonac90
slavonac90's Avatar
Postovi: 1,522
jel stavio netko to sa 4xx serijom i ima li neke razlike?
slavonac90 je online   Reply With Quote
Staro 10.02.2013., 09:13   #13
James Hunt
James Hunt's Avatar
Datum registracije: Dec 2011
Lokacija: zagorje/zg
Postovi: 47
od kad sam ove stavio pojavio mi se nekakav flickering u far cry 3,postavke nisam dirao u samoj igri?!
James Hunt je offline   Reply With Quote
Staro 11.02.2013., 11:54   #14
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
već je vani .96
gnomisa je offline   Reply With Quote
Staro 11.02.2013., 12:20   #15
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,438
Autor gnomisa Pregled postova
već je vani .96
3. post
Staro 11.02.2013., 12:39   #16
gnomisa
gnomisa's Avatar
Postovi: 1,556
3. post
Je*iga, godine rade svoje. Tek sad sam vidio link.
Nego, što bi značila ova nova opcija Vertical SYNC smooth? Jel to locka max fps na frejm manje od monitorovog (recimo na 59) ili je to nekaj drugo?
Staro 11.02.2013., 14:49   #17
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,438
ne vidim to, vsync stavi adaptive, odlična stvar, baš se vidi kako su fluidnije igre
Staro 11.02.2013., 16:40   #18
gnomisa
gnomisa's Avatar
Postovi: 1,556
Postoji ta opcija ali je izlgeda samo za SLI.
